- To:
- Subject: Re: [cgal-discuss] how to use triangulation::incident_facets
- Date: Mon, 4 May 2009 13:50:01 +0200
- Organization: UPM
Hello,
On Monday 04 May 2009 13:38:35 Andreas Fabri wrote:
> Well, you compared to a kind of null pointer, and you can circulate
> around as long as you want fc will never be equal to a null pointer.
A. Fabri's point is, "done" is copy-created from "fc" before "fc" points to
anything. Just exchanging two lines of the original work should work (even
though AF's code is more elegant):
Facet_circulator fc;
fc = D.incident_facets(m_edge);
Facet_circulator done(fc);
do{
if (!D.is_infinite(*fc)){
//do something
}while (++fc != done);
Best,
Daniel
Nueva dirección de e-mail!
- [cgal-discuss] how to use triangulation::incident_facets, nksallem, 05/03/2009
- [cgal-discuss] Intersections with delta in CGAL, Matthias Teich, 05/04/2009
- RE: [cgal-discuss] Intersections with delta in CGAL, Max, 05/04/2009
- Re: [cgal-discuss] Intersections with delta in CGAL, Andreas Fabri, 05/04/2009
- Re: [cgal-discuss] Intersections with delta in CGAL, Matthias Teich, 05/06/2009
- Re: [cgal-discuss] how to use triangulation::incident_facets, Olivier Devillers, 05/04/2009
- Re: [cgal-discuss] how to use triangulation::incident_facets, Nizar Khalifa Sallem, 05/04/2009
- Re: [cgal-discuss] how to use triangulation::incident_facets, Andreas Fabri, 05/04/2009
- Re: [cgal-discuss] how to use triangulation::incident_facets, Daniel Duque, 05/04/2009
