- To:
- Subject: [cgal-discuss] Intersections with delta in CGAL
- Date: Mon, 04 May 2009 08:56:50 +0200
Hi!
I am using CGAL::Simple_cartesian<double> as Kernel. for Polyhedron_3.
In my algorithm I need to compute the intersections of the planes induced by the faces of the polyhedra. That seems to work fine.
But when I try to compute the intersections of the resulting intersection lines there seems to be a problem.
CGAL says there is no intersection, but when I display the lines there is an intersection.
I guess what I need is an intersection test which accepts a delta value to be more stable.
I tried to find a function which computes the minimum distance between the lines and the point where this minimum distance occurs, but without success.
Do I need to implement my own tests or can I do this with CGAL? A hint would be nice :)
Best Regards,
Matthias
- [cgal-discuss] how to use triangulation::incident_facets, nksallem, 05/03/2009
- [cgal-discuss] Intersections with delta in CGAL, Matthias Teich, 05/04/2009
- RE: [cgal-discuss] Intersections with delta in CGAL, Max, 05/04/2009
- Re: [cgal-discuss] Intersections with delta in CGAL, Andreas Fabri, 05/04/2009
- Re: [cgal-discuss] Intersections with delta in CGAL, Matthias Teich, 05/06/2009
- Re: [cgal-discuss] how to use triangulation::incident_facets, Olivier Devillers, 05/04/2009
- Re: [cgal-discuss] how to use triangulation::incident_facets, Nizar Khalifa Sallem, 05/04/2009
- Re: [cgal-discuss] how to use triangulation::incident_facets, Andreas Fabri, 05/04/2009
- Re: [cgal-discuss] how to use triangulation::incident_facets, Daniel Duque, 05/04/2009
