cgal-discuss - Re: [cgal-discuss] Intersections with delta in CGAL
  • To:
  • Subject: Re: [cgal-discuss] Intersections with delta in CGAL
  • Date: Mon, 04 May 2009 13:08:07 +0200
Hello,
Besided exactness issues, note that you are in charge to initialize the
planes associated to the faces. The data structure only provides the
storage.
andreas
Max wrote:
I am using CGAL::Simple_cartesian<double> as Kernel. for Polyhedron_3.
In my algorithm I need to compute the intersections of the planes
induced by the faces of the polyhedra. That seems to work fine.
But when I try to compute the intersections of the resulting
intersection lines there seems to be a problem.
CGAL says there is no intersection, but when I display the lines there
is an intersection.
I guess what I need is an intersection test which accepts a delta value
to be more stable.
I tried to find a function which computes the minimum distance between
the lines and the point where this minimum distance occurs, but without
success.
Do I need to implement my own tests or can I do this with CGAL? A hint
would be nice :)
Best Regards,
Matthias
CGAL will give the exact result, more exact than what you can see with your
eyes, as long as you are using an exact kernel.
Generally, you should use exact kernel types playing with (nef_)polyhedra.
The predefined Exact_predicates_exact_constructions_kernel is a good choice.
HTH.
B/Rgds
Max
