cgal-discuss - Re: [cgal-discuss] how to convert from General_Polygon to
  • To:
  • Subject: Re: [cgal-discuss] how to convert from General_Polygon to
  • Date: Thu, 7 May 2009 02:30:18 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type :content-transfer-encoding; b=JXbi9WRmQtFGj3TjzJc4qQ56rou/CFHhAhjLwe0lG04Qk9zfZ1/NRbuUhjOg8xVLl8 I6edvyDjk0isJcDgj1a/laYJYcaP9BkhS99U6nzYAF/aG5oJlsP4LHxDwk5Hi4dvn2D5 VDga3TLkQiM2uQqCElD8Qgnf5UlIlIoWmDhnU=
hi
thx for you help
br
Kim
On Thu, May 7, 2009 at 12:25 AM, Kim Pedersen
wrote:
> hi
> thx for you help
> br
> Kim
> On Mon, May 4, 2009 at 1:13 PM,
> wrote:
>> Hi,
>> You have 2 options.
>> If you want to join the polygon's into a polygon set you can use the Gps
>> Traits functor for constructing pwh:
>> GeneralPolygonSetTraits_2::Construct_general_polygon_with_holes_2
>> which constructs a general polygon with holes from a general polygon and,
>> optionally, a range of holes. It uses the operator
>> General_polygon_with_holes_2  operator() (const General_polygon_2&
>> pgn_boundary)
>> or
>> pgn_boundary, HolesInputIterator h_begin, HolesInputIterator h_end)
>> parameterized by the HolesInputIterator type.
>> for instance:
>> typedef Traits::Construct_general_polygon_with_holes_2
>>                                   Construct_general_polygon_with_holes_2;
>> Polygon_Set Gps;
>> Traits tr;
>> Construct_general_polygon_with_holes_2 functor =
>>                    tr.construct_polygon_with_holes_2_object ();
>> Polygon_with_Holes_2 pwh = functor(your_pgn);
>> Otherwise, simply use the PWH constructor directly:
>> General_polygon_with_holes_2(const General_polygon_2& pgn_boundary);
>> Best,
>> Guy
>> Quoting
>>> Hi
>>> I have a list of   General_Polygons I want to convert to
>>> Polygon_with_holes  ,, I have tried a lot of things without luck
>>> ,,,,how to ?
>>> I just want to Join them  using
>>> Polygon_set pgnset;
>>> pgnset.join(ph.begin(),ph.end());
>>> typedef below.
>>> Best regards
>>> kim
>>> typedef Traits::Curve_2                               Curve;
>>> typedef Traits::X_monotone_curve_2                    XCurve;
>>> typedef Traits::Point_2                               Circular_point_2;
>>> typedef Traits::Polygon_2                             Polygon_2;
>>> typedef CGAL::General_polygon_2<Traits>               General_Polygon;
>>> typedef CGAL::General_polygon_2<Traits>               P2;
>>> typedef CGAL::General_polygon_with_holes_2<Polygon_2> Polygon_with_holes;
>>> typedef CGAL::General_polygon_set_2<Traits>           Polygon_set;
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
