- To:
- Subject: [cgal-discuss] how to convert from General_Polygon to
- Date: Sun, 3 May 2009 23:33:24 +0200 (CEST)
Hi
I have a list of General_Polygons I want to convert to
Polygon_with_holes ,, I have tried a lot of things without luck
,,,,how to ?
I just want to Join them using
Polygon_set pgnset;
pgnset.join(ph.begin(),ph.end());
typedef below.
Best regards
kim
typedef Traits::Curve_2 Curve;
typedef Traits::X_monotone_curve_2 XCurve;
typedef Traits::Point_2 Circular_point_2;
typedef Traits::Polygon_2 Polygon_2;
typedef CGAL::General_polygon_2<Traits> General_Polygon;
typedef CGAL::General_polygon_2<Traits> P2;
typedef CGAL::General_polygon_with_holes_2<Polygon_2> Polygon_with_holes;
typedef CGAL::General_polygon_set_2<Traits> Polygon_set;
- [cgal-discuss] how to convert from General_Polygon to, cgal, 05/03/2009
- Re: [cgal-discuss] how to convert from General_Polygon to, guyzucke, 05/04/2009
- Message not available
- Re: [cgal-discuss] how to convert from General_Polygon to, Kim, 05/07/2009
