- To:
- Subject: Re: [cgal-discuss] how to convert from General_Polygon to
- Date: Mon, 04 May 2009 14:13:44 +0300
Hi,
You have 2 options.
If you want to join the polygon's into a polygon set you can use the Gps Traits functor for constructing pwh:
GeneralPolygonSetTraits_2::Construct_general_polygon_with_holes_2
which constructs a general polygon with holes from a general polygon and, optionally, a range of holes. It uses the operator
General_polygon_with_holes_2 operator() (const General_polygon_2& pgn_boundary)
or
General_polygon_with_holes_2 operator() (const General_polygon_2& pgn_boundary, HolesInputIterator h_begin, HolesInputIterator h_end)
parameterized by the HolesInputIterator type.
for instance:
typedef Traits::Construct_general_polygon_with_holes_2
Construct_general_polygon_with_holes_2;
Polygon_Set Gps;
Traits tr;
Construct_general_polygon_with_holes_2 functor =
tr.construct_polygon_with_holes_2_object ();
Polygon_with_Holes_2 pwh = functor(your_pgn);
Otherwise, simply use the PWH constructor directly:
General_polygon_with_holes_2(const General_polygon_2& pgn_boundary);
Best,
Guy
Quoting
Hi
I have a list of General_Polygons I want to convert to
Polygon_with_holes ,, I have tried a lot of things without luck
,,,,how to ?
I just want to Join them using
Polygon_set pgnset;
pgnset.join(ph.begin(),ph.end());
typedef below.
Best regards
kim
typedef Traits::Curve_2 Curve;
typedef Traits::X_monotone_curve_2 XCurve;
typedef Traits::Point_2 Circular_point_2;
typedef Traits::Polygon_2 Polygon_2;
typedef CGAL::General_polygon_2<Traits> General_Polygon;
typedef CGAL::General_polygon_2<Traits> P2;
typedef CGAL::General_polygon_with_holes_2<Polygon_2> Polygon_with_holes;
typedef CGAL::General_polygon_set_2<Traits> Polygon_set;
- [cgal-discuss] how to convert from General_Polygon to, cgal, 05/03/2009
- Re: [cgal-discuss] how to convert from General_Polygon to, guyzucke, 05/04/2009
- Message not available
- Re: [cgal-discuss] how to convert from General_Polygon to, Kim, 05/07/2009
