- To:
- Subject: Re: [cgal-discuss] Polyhedron demo problem
- Date: Fri, 15 May 2009 13:01:10 +0200
result of cmake-gui:
The C compiler identification is GNU
The CXX compiler identification is GNU
CGAL_MAJOR_VERSION=3
CGAL_MINOR_VERSION=4
CGAL_BUILD_VERSION=
CGAL_SONAME_VERSION=3
CGAL_SOVERSION =3.0.0
CGAL_REFERENCE_CACHE_DIR=
Building shared libraries
Targetting Unix Makefiles
Using /usr/bin/c++ compiler.
USING CMake version: 2.6.2
System: Linux
USING GCC_VERSION = '4.3.3'
Using gcc version 4 or later. Adding -frounding-math
Build type: Release
USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
USING LDFLAGS = ' '
GMPXX include: /usr/include
GMPXX libraries: /usr/lib/libgmpxx.so
GMP include: /usr/include
GMP libraries: /usr/lib/libgmp.so
GMP definitions:
USING GMP_VERSION = '4.2.4'
MPFR include: /usr/include
MPFR libraries: /usr/lib/libmpfr.so
MPFR definitions: USING MPFR_VERSION = '2.4.0'
Boost include: /usr/include
Boost libraries: /usr/lib/libboost_thread-gcc43-mt-1_35.so
Boost definitions:
USING BOOST_VERSION = '1.35.0'
CMAKE_INSTALL_PREFIX=/usr/local
OpenGL include: /usr/include
OpenGL libraries: /usr/lib/libGLU.so;/usr/lib/libGL.so;/usr/lib/libSM.so;/usr/lib/libICE.so;/usr/lib/libX11.so;/usr/lib/libXext.so
USING ZLIB_VERSION = '1.2.3.3'
ZLib include: /usr/include
ZLib libraries: /usr/lib/libz.so
USING QT4_VERSION = '4.5.1'
OpenGL definitions:
Qt4 include: /home/user/qtsdk-2009.02/qt/include
Qt4 libraries: optimized;/home/user/qtsdk-2009.02/qt/lib/libQtOpenGL.so;debug;/home/user/qtsdk-2009.02/qt/lib/libQtOpenGL.so;-lGLU -lGL;optimized;/home/user/qtsdk-2009.02/qt/lib/libQtGui.so;debug;/home/user/qtsdk-2009.02/qt/lib/libQtGui.so;/usr/lib/libSM.so;/usr/lib/libICE.so;/usr/lib/libXrender.so;/usr/lib/libfreetype.so;/usr/lib/libfontconfig.so;/usr/lib/libXext.so;/usr/lib/libX11.so;/usr/lib/libm.so;optimized;/home/user/qtsdk-2009.02/qt/lib/libQtCore.so;debug;/home/user/qtsdk-2009.02/qt/lib/libQtCore.so;/usr/lib/librt.so;-lpthread;-ldl
Qt4 definitions: -DQT_DLL
moc executable: /home/user/qtsdk-2009.02/qt/bin/moc
uic executable: /home/user/qtsdk-2009.02/qt/bin/uic
Configuring /home/user/Bureau/CGAL-3.4/examples/Algebraic_foundations example
Configuring /home/user/Bureau/CGAL-3.4/examples/Alpha_shapes_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Alpha_shapes_3 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Apollonius_graph_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Approximate_min_ellipsoid_d example
Configuring /home/user/Bureau/CGAL-3.4/examples/Arrangement_on_surface_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/BGL_arrangement_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/BGL_polyhedron_3 example
Configuring /home/user/Bureau/CGAL-3.4/examples/BGL_triangulation_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Boolean_set_operations_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Box_intersection_d example
Configuring /home/user/Bureau/CGAL-3.4/examples/CGALimageIO example
Configuring /home/user/Bureau/CGAL-3.4/examples/Circular_kernel_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Circular_kernel_3 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Circulator example
Configuring /home/user/Bureau/CGAL-3.4/examples/Convex_hull_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Convex_hull_3 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Core example
Configuring /home/user/Bureau/CGAL-3.4/examples/Envelope_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Envelope_3 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Filtered_kernel example
Configuring /home/user/Bureau/CGAL-3.4/examples/Generator example
Configuring /home/user/Bureau/CGAL-3.4/examples/HalfedgeDS example
Configuring /home/user/Bureau/CGAL-3.4/examples/Interpolation example
Configuring /home/user/Bureau/CGAL-3.4/examples/Interval_skip_list example
Configuring /home/user/Bureau/CGAL-3.4/examples/Jet_fitting_3 example
LAPACK include: LAPACK definitions:
LAPACK libraries: /usr/local/lib/liblapack.a
LAPACK link flags: BLAS include: BLAS definitions:
BLAS libraries: /usr/local/lib/libf77blas.a;/usr/local/lib/libcblas.a
BLAS link flags: Boost.ProgramOptions library: /usr/lib/libboost_program_options-gcc43-mt-1_35.so
Configuring /home/user/Bureau/CGAL-3.4/examples/Kernel_23 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Kinetic_data_structures example
Configuring /home/user/Bureau/CGAL-3.4/examples/Kinetic_framework example
Configuring /home/user/Bureau/CGAL-3.4/examples/Largest_empty_rect_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Matrix_search example
Configuring /home/user/Bureau/CGAL-3.4/examples/Mesh_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Min_annulus_d example
Configuring /home/user/Bureau/CGAL-3.4/examples/Min_circle_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Min_ellipse_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Min_quadrilateral_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Min_sphere_d example
Configuring /home/user/Bureau/CGAL-3.4/examples/Min_sphere_of_spheres_d example
Configuring /home/user/Bureau/CGAL-3.4/examples/Minkowski_sum_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Modular_arithmetic example
Configuring /home/user/Bureau/CGAL-3.4/examples/Nef_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Nef_3 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Nef_S2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/PDB example
Configuring /home/user/Bureau/CGAL-3.4/examples/Partition_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Point_set_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Polygon example
Configuring /home/user/Bureau/CGAL-3.4/examples/Polyhedron example
Configuring /home/user/Bureau/CGAL-3.4/examples/Polyhedron_IO example
Configuring /home/user/Bureau/CGAL-3.4/examples/Polynomial example
Configuring /home/user/Bureau/CGAL-3.4/examples/Polynomial_kernel example
Configuring /home/user/Bureau/CGAL-3.4/examples/Polytope_distance_d example
Configuring /home/user/Bureau/CGAL-3.4/examples/Principal_component_analysis example
Configuring /home/user/Bureau/CGAL-3.4/examples/Profiling_tools example
Configuring /home/user/Bureau/CGAL-3.4/examples/QP_solver example
Configuring /home/user/Bureau/CGAL-3.4/examples/RangeSegmentTrees example
Configuring /home/user/Bureau/CGAL-3.4/examples/Ridges_3 example
Configuring /home/user/Bureau/CGAL-3.4/examples/STL_Extension example
Configuring /home/user/Bureau/CGAL-3.4/examples/Segment_Delaunay_graph_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Skin_surface_3 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Snap_rounding_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Spatial_searching example
Configuring /home/user/Bureau/CGAL-3.4/examples/Spatial_sorting example
Configuring /home/user/Bureau/CGAL-3.4/examples/Straight_skeleton_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Stream_lines_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Subdivision_method_3 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Surface_mesh_parameterization example
USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG -fno-strict-aliasing'
USING EXEFLAGS = ' '
TAUCS include: /usr/local/include
TAUCS definitions:
TAUCS libraries: /usr/local/lib/libtaucs.a;/usr/local/lib/libmetis.a
BLAS link flags: Configuring /home/user/Bureau/CGAL-3.4/examples/Surface_mesh_simplification example
Configuring /home/user/Bureau/CGAL-3.4/examples/Surface_mesher example
Configuring /home/user/Bureau/CGAL-3.4/examples/Triangulation_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Triangulation_3 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Voronoi_diagram_2 example
Configuring /home/user/Bureau/CGAL-3.4/examples/Width_3 example
Configuring /home/user/Bureau/CGAL-3.4/demo/Alpha_shapes_2 demo
NOTICE: The CGAL_Qt3 library was not configured. Please configure CGAL using WITH_CGAL_Qt3=ON.
NOTICE: This demo requires CGAL and Qt3, and will not be compiled.
Configuring /home/user/Bureau/CGAL-3.4/demo/Alpha_shapes_3 demo
Found QGLViewer: /usr/lib/libQGLViewer.so
Configuring /home/user/Bureau/CGAL-3.4/demo/Apollonius_graph_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Arrangement_on_surface_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Boolean_set_operations_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Circular_kernel_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Circular_kernel_3 demo
NOTICE: This demo requires Qt3 and the CGAL Qt3 library, and will not be compiled.
Configuring /home/user/Bureau/CGAL-3.4/demo/Convex_hull_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Convex_hull_3 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Convex_hull_d demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Envelope_3 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Generator demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Geomview demo
Configuring /home/user/Bureau/CGAL-3.4/demo/GraphicsView demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Interpolation demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Kinetic_data_structures demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Largest_empty_rect_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Matrix_search demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Mesh_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Min_circle_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Min_ellipse_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Min_quadrilateral_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Nef_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Nef_3 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Nef_S2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/PDB demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Partition_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Polygon demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Polyhedron demo
TAUCS definitions:
BLAS link flags: Configuring /home/user/Bureau/CGAL-3.4/demo/Polyhedron_IO demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Robustness demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Segment_Delaunay_graph_2 demo
NOTICE: This demo requires CGAL,, Core, and Qt3, and will not be compiled.
Configuring /home/user/Bureau/CGAL-3.4/demo/Snap_rounding_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Spatial_searching demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Straight_skeleton_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Stream_lines_2 demo
NOTICE: This demo requires CGAL, Qt3, and OpenGL, and will not be compiled.
Configuring /home/user/Bureau/CGAL-3.4/demo/Surface_mesher demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Triangulation_2 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Triangulation_3 demo
Configuring /home/user/Bureau/CGAL-3.4/demo/Voronoi_diagram_2 demo
Configuring done
Generating done
make cgal3.4 : OK
make Polyhedron :
user@ubuntu904desktop:~/Bureau/CGAL-3.4/build/demo/Polyhedron$
make
cd /home/user/Bureau/CGAL-3.4/build && /usr/bin/cmake -H/home/user/Bureau/CGAL-3.4 -B/home/user/Bureau/CGAL-3.4/build --check-build-system CMakeFiles/Makefile.cmake 0
cd /home/user/Bureau/CGAL-3.4/build && /usr/bin/cmake -E cmake_progress_start /home/user/Bureau/CGAL-3.4/build/CMakeFiles /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron/CMakeFiles/progress.make
cd /home/user/Bureau/CGAL-3.4/build && make -f CMakeFiles/Makefile2 demo/Polyhedron/all
make[1]: entrant dans le répertoire « /home/user/Bureau/CGAL-3.4/build »
make -f demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/build.make demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/depend
make[2]: entrant dans le répertoire « /home/user/Bureau/CGAL-3.4/build »
/usr/bin/cmake -E cmake_progress_report /home/user/Bureau/CGAL-3.4/build/CMakeFiles
[ 0%] Generating qrc_Polyhedron_3.cxx
cd /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron && /home/user/qtsdk-2009.02/qt/bin/rcc -name Polyhedron_3 -o /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron/qrc_Polyhedron_3.cxx /home/user/Bureau/CGAL-3.4/demo/Polyhedron/Polyhedron_3.qrc
[ 0%] Generating MainWindow_moc.cpp
cd /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron && /home/user/qtsdk-2009.02/qt/bin/moc -I/home/user/Bureau/CGAL-3.4/demo/Polyhedron/./include -I/home/user/Bureau/CGAL-3.4/build/include -I/home/user/Bureau/CGAL-3.4/include -I/home/user/Bureau/CGAL-3.4/demo/Polyhedron/. -I/home/user/Bureau/CGAL-3.4/build/demo/Polyhedron -I/usr/include -I/home/user/qtsdk-2009.02/qt/include -I/home/user/qtsdk-2009.02/qt/include/QtOpenGL -I/home/user/qtsdk-2009.02/qt/include/QtScript -I/home/user/qtsdk-2009.02/qt/include/QtGui -I/home/user/qtsdk-2009.02/qt/include/QtXml -I/home/user/qtsdk-2009.02/qt/include/QtCore -I/usr/local/include -DQT_DLL -DQT_DLL -DQT_OPENGL_LIB -DQT_SCRIPT_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CORE_LIB -DCGAL_USE_TAUCS -DCGAL_TAUCS_ENABLED -o MainWindow_moc.cpp /home/user/Bureau/CGAL-3.4/demo/Polyhedron/MainWindow.h
[ 0%] Generating Scene_moc.cpp
cd /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron && /home/user/qtsdk-2009.02/qt/bin/moc -I/home/user/Bureau/CGAL-3.4/demo/Polyhedron/./include -I/home/user/Bureau/CGAL-3.4/build/include -I/home/user/Bureau/CGAL-3.4/include -I/home/user/Bureau/CGAL-3.4/demo/Polyhedron/. -I/home/user/Bureau/CGAL-3.4/build/demo/Polyhedron -I/usr/include -I/home/user/qtsdk-2009.02/qt/include -I/home/user/qtsdk-2009.02/qt/include/QtOpenGL -I/home/user/qtsdk-2009.02/qt/include/QtScript -I/home/user/qtsdk-2009.02/qt/include/QtGui -I/home/user/qtsdk-2009.02/qt/include/QtXml -I/home/user/qtsdk-2009.02/qt/include/QtCore -I/usr/local/include -DQT_DLL -DQT_DLL -DQT_OPENGL_LIB -DQT_SCRIPT_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CORE_LIB -DCGAL_USE_TAUCS -DCGAL_TAUCS_ENABLED -o Scene_moc.cpp /home/user/Bureau/CGAL-3.4/demo/Polyhedron/Scene.h
/usr/bin/cmake -E cmake_progress_report /home/user/Bureau/CGAL-3.4/build/CMakeFiles 90
[100%] Generating Viewer_moc.cpp
cd /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron && /home/user/qtsdk-2009.02/qt/bin/moc -I/home/user/Bureau/CGAL-3.4/demo/Polyhedron/./include -I/home/user/Bureau/CGAL-3.4/build/include -I/home/user/Bureau/CGAL-3.4/include -I/home/user/Bureau/CGAL-3.4/demo/Polyhedron/. -I/home/user/Bureau/CGAL-3.4/build/demo/Polyhedron -I/usr/include -I/home/user/qtsdk-2009.02/qt/include -I/home/user/qtsdk-2009.02/qt/include/QtOpenGL -I/home/user/qtsdk-2009.02/qt/include/QtScript -I/home/user/qtsdk-2009.02/qt/include/QtGui -I/home/user/qtsdk-2009.02/qt/include/QtXml -I/home/user/qtsdk-2009.02/qt/include/QtCore -I/usr/local/include -DQT_DLL -DQT_DLL -DQT_OPENGL_LIB -DQT_SCRIPT_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CORE_LIB -DCGAL_USE_TAUCS -DCGAL_TAUCS_ENABLED -o Viewer_moc.cpp /home/user/Bureau/CGAL-3.4/demo/Polyhedron/Viewer.h
[100%] Generating ui_MainWindow.h
cd /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron && /home/user/qtsdk-2009.02/qt/bin/uic -o /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron/ui_MainWindow.h /home/user/Bureau/CGAL-3.4/demo/Polyhedron/MainWindow.ui
cd /home/user/Bureau/CGAL-3.4/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/user/Bureau/CGAL-3.4 /home/user/Bureau/CGAL-3.4/demo/Polyhedron /home/user/Bureau/CGAL-3.4/build /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/DependInfo.cmake --color=
Scanning dependencies of target Polyhedron_3
make[2]: quittant le répertoire « /home/user/Bureau/CGAL-3.4/build »
make -f demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/build.make demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/build
[100%] Building CXX object demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o
cd /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron && /usr/bin/c++ -DQT_DLL -DQT_DLL -DQT_OPENGL_LIB -DQT_SCRIPT_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CORE_LIB -DCGAL_USE_TAUCS -DCGAL_TAUCS_ENABLED -DQT_NO_DEBUG -frounding-math -O3 -DNDEBUG -I/home/user/Bureau/CGAL-3.4/demo/Polyhedron/./include -I/home/user/Bureau/CGAL-3.4/build/include -I/home/user/Bureau/CGAL-3.4/include -I/home/user/Bureau/CGAL-3.4/demo/Polyhedron/. -I/home/user/Bureau/CGAL-3.4/build/demo/Polyhedron -I/home/user/qtsdk-2009.02/qt/include -I/home/user/qtsdk-2009.02/qt/include/QtOpenGL -I/home/user/qtsdk-2009.02/qt/include/QtScript -I/home/user/qtsdk-2009.02/qt/include/QtGui -I/home/user/qtsdk-2009.02/qt/include/QtXml -I/home/user/qtsdk-2009.02/qt/include/QtCore -I/usr/local/include -o CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o -c /home/user/Bureau/CGAL-3.4/demo/Polyhedron/Polyhedron_3.cpp
Dans le fichier inclus à partir de /usr/include/c++/4.3/ext/hash_set:64,
à partir de /usr/include/boost/graph/adjacency_list.hpp:22,
à partir de /home/user/Bureau/CGAL-3.4/include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse.h:28,
à partir de /home/user/Bureau/CGAL-3.4/include/CGAL/Surface_mesh_simplification/edge_collapse.h:24,
à partir de /home/user/Bureau/CGAL-3.4/demo/Polyhedron/MainWindow_simplify.cpp:10,
à partir de /home/user/Bureau/CGAL-3.4/demo/Polyhedron/Polyhedron_3.cpp:57:
/usr/include/c++/4.3/backward/backward_warning.h:33:2: attention : #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated.
[100%] Building CXX object demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/qrc_Polyhedron_3.o
cd /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron && /usr/bin/c++ -DQT_DLL -DQT_DLL -DQT_OPENGL_LIB -DQT_SCRIPT_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CORE_LIB -DCGAL_USE_TAUCS -DCGAL_TAUCS_ENABLED -DQT_NO_DEBUG -frounding-math -O3 -DNDEBUG -I/home/user/Bureau/CGAL-3.4/demo/Polyhedron/./include -I/home/user/Bureau/CGAL-3.4/build/include -I/home/user/Bureau/CGAL-3.4/include -I/home/user/Bureau/CGAL-3.4/demo/Polyhedron/. -I/home/user/Bureau/CGAL-3.4/build/demo/Polyhedron -I/home/user/qtsdk-2009.02/qt/include -I/home/user/qtsdk-2009.02/qt/include/QtOpenGL -I/home/user/qtsdk-2009.02/qt/include/QtScript -I/home/user/qtsdk-2009.02/qt/include/QtGui -I/home/user/qtsdk-2009.02/qt/include/QtXml -I/home/user/qtsdk-2009.02/qt/include/QtCore -I/usr/local/include -o CMakeFiles/Polyhedron_3.dir/qrc_Polyhedron_3.o -c /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron/qrc_Polyhedron_3.cxx
Linking CXX executable Polyhedron_3
cd /home/user/Bureau/CGAL-3.4/build/demo/Polyhedron && /usr/bin/cmake -E cmake_link_script CMakeFiles/Polyhedron_3.dir/link.txt --verbose=1
/usr/bin/c++ -frounding-math -O3 -DNDEBUG CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o CMakeFiles/Polyhedron_3.dir/qrc_Polyhedron_3.o -o Polyhedron_3 -rdynamic -L/home/user/Bureau/CGAL-3.4/build/lib -lCGAL_Qt4 -lCGAL -lgmpxx -lmpfr -lgmp -lboost_thread-gcc43-mt-1_35 /home/user/qtsdk-2009.02/qt/lib/libQtOpenGL.so -lGLU -lGL /home/user/qtsdk-2009.02/qt/lib/libQtGui.so -lSM -lICE -lXrender -lfreetype -lfontconfig -lXext -lX11 -lm /home/user/qtsdk-2009.02/qt/lib/libQtCore.so -lrt -lpthread -ldl -lGLU -lGL -lSM -lICE -lX11 -lXext /usr/local/lib/libtaucs.a /usr/local/lib/libmetis.a /usr/local/lib/liblapack.a /usr/local/lib/libf77blas.a /usr/local/lib/libcblas.a /home/user/qtsdk-2009.02/qt/lib/libQtOpenGL.so -lGLU -lGL /home/user/qtsdk-2009.02/qt/lib/libQtScript.so /home/user/qtsdk-2009.02/qt/lib/libQtGui.so -lSM -lICE -lXrender -lfreetype -lfontconfig -lXext -lX11 -lm /home/user/qtsdk-2009.02/qt/lib/libQtXml.so /home/user/qtsdk-2009.02/qt/lib/libQtCore.so -lrt -lpthread -ldl -lCGAL_Qt4 -lCGAL -lgmpxx -lmpfr -lgmp -lboost_thread-gcc43-mt-1_35 /home/user/qtsdk-2009.02/qt/lib/libQtOpenGL.so -lGLU -lGL /home/user/qtsdk-2009.02/qt/lib/libQtGui.so -lSM -lICE -lXrender -lfreetype -lfontconfig -lXext -lX11 -lm /home/user/qtsdk-2009.02/qt/lib/libQtCore.so -lrt -lpthread -ldl -lGLU -lGL -lSM -lICE -lX11 -lXext -lQGLViewer -lGL -lGLU /usr/local/lib/libtaucs.a /usr/local/lib/libmetis.a -lCGAL_Qt4 -lCGAL -lgmpxx -lmpfr -lgmp -lboost_thread-gcc43-mt-1_35 /home/user/qtsdk-2009.02/qt/lib/libQtOpenGL.so -lGLU -lGL /home/user/qtsdk-2009.02/qt/lib/libQtGui.so -lSM -lICE -lXrender -lfreetype -lfontconfig -lXext -lX11 -lm /home/user/qtsdk-2009.02/qt/lib/libQtCore.so -lrt -lpthread -ldl /usr/local/lib/liblapack.a /usr/local/lib/libf77blas.a /usr/local/lib/libcblas.a /home/user/qtsdk-2009.02/qt/lib/libQtScript.so /home/user/qtsdk-2009.02/qt/lib/libQtXml.so -lQGLViewer -Wl,-rpath,/home/user/Bureau/CGAL-3.4/build/lib:/home/user/qtsdk-2009.02/qt/lib
CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o: In function `CGAL::Monge_via_jet_fitting<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >, CGAL::Cartesian<double>, CGAL::Lapack_svd>::solve_linear_system(CGAL::Lapack_matrix&, CGAL::Lapack_vector&)':
Polyhedron_3.cpp:(.text._ZN4CGAL21Monge_via_jet_fittingINS_15Filtered_kernelINS_16Simple_cartesianIdEEEENS_9CartesianIdEENS_10Lapack_svdEE19solve_linear_systemERNS_13Lapack_matrixERNS_13Lapack_vectorE[CGAL::Monge_via_jet_fitting<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >, CGAL::Cartesian<double>, CGAL::Lapack_svd>::solve_linear_system(CGAL::Lapack_matrix&, CGAL::Lapack_vector&)]+0x77): undefined reference to `dgelss'
collect2: ld a retourné 1 code d'état d'exécution
make[2]: *** [demo/Polyhedron/Polyhedron_3] Erreur 1
make[1]: *** [demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/all] Erreur 2
make[1]: quittant le répertoire « /home/user/Bureau/CGAL-3.4/build »
make: *** [all] Erreur 2
a écrit :
Hi Martial,
Could you please delete CMakeCache.txt, run cmake and make in Polyhedron
demo folder, then post the output of cmake and make to this mailing list ?
Regards,
Laurent Saboret
INRIA Sophia Antipolis
I use BLAS (blas, f77blas, cblas), LAPACK, and TAUCS so it's not that.
Laurent Rineau (GeometryFactory) a écrit :
Le jeudi 14 mai 2009 16:59:30, Martial TOLA (CNRS-Liris) a écrit :
HelloI think that error (missing dgelss) is related to BLAS. You need BLAS.
I'm under Ubuntu 9.04 with cmake 2.6patch2 and I have exactly the same
problem:
undefined reference to `dgelss'.
I have tried the original CMakeLists.txt and this one but it's the same
result.
I have compiled taucs from taucs_full.tgz (3.4) and it's ok.
I have exactly the same error if I use :
- lapack from /usr/local/lib (result of the taucs compilation)
- lapack from /usr/lib
- lapack from /usr/lib/atlas
Do you have an idea for this problem ???
begin:vcard fn:Martial TOLA n:TOLA;Martial org;quoted-printable:CNRS/INSA de Lyon/Universit=C3=A9 Claude Bernard Lyon 1/Universit=C3=A9Lu= mi=C3=A8re Lyon 2/Ecole Centrale de Lyon;Laboratoire LIRIS - UMR 5205 email;internet: title;quoted-printable:Ing=C3=A9nieur d'=C3=A9tudes CNRS url:http://liris.cnrs.fr/martial.tola version:2.1 end:vcard
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/14/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/14/2009
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/15/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent . Saboret, 05/15/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Saboret, 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/15/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/18/2009
