- To:
- Subject: Re: [cgal-discuss] Polyhedron demo problem
- Date: Thu, 14 May 2009 16:59:30 +0200
Hello
I'm under Ubuntu 9.04 with cmake 2.6patch2 and I have exactly the same problem:
undefined reference to `dgelss'.
I have tried the original CMakeLists.txt and this one but it's the same result.
I have compiled taucs from taucs_full.tgz (3.4) and it's ok.
I have exactly the same error if I use :
- lapack from /usr/local/lib (result of the taucs compilation)
- lapack from /usr/lib
- lapack from /usr/lib/atlas
Do you have an idea for this problem ???
Thank you.
Laurent Rineau (GeometryFactory) a écrit :
On Sunday 25 January 2009 22:09:45 Rob wrote:
Laurent Rineau (GeometryFactory) wrote:
On Saturday 24 January 2009 17:44:12 Rob wrote:
Hello,Can you show us the output of cmake, and attach your CMakeCache.txt file?
I seem to have a problem linking the Polyhedron demo in the 3.4
release of CGAL. When I try to make the demo in /demo/Polyhedron, it
compiles successfully, but then gives the following error during
linking:
CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o: In function
`CGAL::Monge_via_jet_fitting<CGAL::Filtered_kernel<CGAL::Simple_cartesia
n<d ouble>
, CGAL::Cartesian<double>,CGAL::Lapack_svd>::solve_linear_system(CGAL::Lapack_matrix&,
CGAL::Lapack_vector&)':
Polyhedron_3.cpp:(.text._ZN4CGAL21Monge_via_jet_fittingINS_15Filtered_ke
rne
lINS_16Simple_cartesianIdEEEENS_9CartesianIdEENS_10Lapack_svdEE19solve_l
inea
r_systemERNS_13Lapack_matrixERNS_13Lapack_vectorE[CGAL::Monge_via_jet_fi
ttin g<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Lapack_vector&)]+0x94): undefined reference to `dgelss'
collect2: ld returned 1 exit status
make[2]: *** [demo/Polyhedron/Polyhedron_3] Error 1
make[2]: Leaving directory `/home/rob/SoftwareStaging/CGAL-3.4/build'
make[1]: *** [demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/all] Error 2
make[1]: Leaving directory `/home/rob/SoftwareStaging/CGAL-3.4/build'
make: *** [all] Error 2
I've checked multiple times, and I configure cmake with lapack, so I
can't figure out why it's complaining at me. Any help would be greatly
appreciated.
It seems LAPACK is not configured correctly.
Rob,
I think the bug is my fault. The file demo/Polyhedron/CMakeList.txt does not deal correctly with case when LAPACK is present but not TAUCS.
Please try to copy the attached CMakeLists.txt to demo/Polyhedron/CMakeList.txt and recompile the Polyhedron demo, and tell us if that fixes your linkage problem.
begin:vcard fn:Martial TOLA n:TOLA;Martial org;quoted-printable:CNRS/INSA de Lyon/Universit=C3=A9 Claude Bernard Lyon 1/Universit=C3=A9Lu= mi=C3=A8re Lyon 2/Ecole Centrale de Lyon;Laboratoire LIRIS - UMR 5205 email;internet: title;quoted-printable:Ing=C3=A9nieur d'=C3=A9tudes CNRS url:http://liris.cnrs.fr/martial.tola version:2.1 end:vcard
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/14/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/14/2009
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/15/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent . Saboret, 05/15/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Saboret, 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/18/2009
