- To:
- Subject: Re: [cgal-discuss] Polyhedron demo problem (bis)
- Date: Mon, 18 May 2009 14:04:37 +0200
On Friday 15 May 2009 15:05:34 Martial TOLA (CNRS-Liris) wrote:
> Qt4 include: /usr/include
> Qt4 libraries:
> optimized;/Library/Frameworks/QtOpenGL.framework;debug;/Library/Frameworks/
>QtOpenGL.framework;-framework OpenGL -framework
> AGL;optimized;/Library/Frameworks/QtGui.framework;debug;/Library/Frameworks
>/QtGui.framework;-framework Carbon;-framework
> AppKit;optimized;/Library/Frameworks/QtCore.framework;debug;/Library/Framew
>orks/QtCore.framework;/usr/lib/libz.dylib;-framework ApplicationServices
> Qt4 definitions: -DQT_DLL
> moc executable: /Developer/Tools/Qt/moc
> uic executable: /Developer/Tools/Qt/uic
That shows that Qt is found in the system (/usr/include, and the system
frameworks).
> [100%] Building CXX object
> demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o
> cd /Users/mt/_lib_autres_que_macports/CGAL-3.4/build/demo/Polyhedron &&
> /usr/bin/c++ -DQT_DLL -DQT_OPENGL_LIB -DQT_SCRIPT_LIB -DQT_GUI_LIB
> -DQT_XML_LIB -DQT_CORE_LIB -DCGAL_USE_TAUCS -DLAPACK_USE_F2C
> -DCGAL_USE_F2C -DBLAS_USE_F2C -DCGAL_USE_F2C -DCGAL_TAUCS_ENABLED
> -DQT_NO_DEBUG -frounding-math -O3 -DNDEBUG
> -I/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/./include
> -I/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/include
> -I/Users/mt/_lib_autres_que_macports/CGAL-3.4/include
> -I/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/demo/Polyhedron
> -I/opt/local/include
> -I/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/optimized
> -F/Library/Frameworks
> -I/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/debug
> -I/Library/Frameworks/QtOpenGL.framework/Headers
> -I/Library/Frameworks/QtScript.framework/Headers
> -I/Library/Frameworks/QtGui.framework/Headers
> -I/Library/Frameworks/QtXml.framework/Headers
> -I/Library/Frameworks/QtCore.framework/Headers -F/usr/lib -o
> CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o -c
> /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/Polyhedron_3.cp
>p
My guess is that you have also some Qt headers in /opt/local/include (the
include path is for GMP) and that leads to binary incompatibility at link
time. Verify if Qt is installed in your MacPorts tree.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- Re: [cgal-discuss] Polyhedron demo problem, (continued)
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/15/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Saboret, 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/20/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/20/2009
- [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>, Matthias Teich, 05/20/2009
- Re: [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>, Laurent Rineau (GeometryFactory), 05/20/2009
