cgal-discuss - [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation
  • To:
  • Subject: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation
  • Date: Fri, 12 Jun 2009 18:03:37 +0200
  • Organization: Buf Compagnie
Hi everyone,
First i would like to thank you for all the great work.
I'm having a problem with boolean operations on Nef_polyhedron_3.
I'm using a Simple_cartesian<Gmpq> kernel and so far everything was ok, it really works fine with a lot of models :)
But I'm in trouble with a model that seems to be problematic, that passes every test with success (the Polyhedron converted from my geometry is both "valid" and "closed", and the Nef polyhedron converted from this polyhedron is "valid" and "simple".)
So I can get a valid nef, but when i try to compute boolean operations with a simple sphere (attached as sphere.off), the program crashes on :
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: itl != it->second.end()
File: /net/rnd/src/CGAL-3.4/linux-x86_64-gcc-4.1.1/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1088
Abort
I must admit I am really stuck here, as the model seems closed, valid and with no self-intersections.
The strangest thing is that it works fine with a cube, or most of the time if the sphere intersects the model differently.
I'm really sorry that the model is really big, unfortunately I was unable to reproduce the problem with a simpler one, so here is the path to the .off file (that is too big to be attached for the mailing list) : http://dl.free.fr/rXNVUQVqg
Am i missing something ? Or do you think there is a problem with the model topology ? And if there is, how can i detect it in the future to prevent crashes ?
Any help would be really appreciated, thank you !
Best regards,
Laure Guicherd
Selective Nef Complex
standard
vertices 58
halfedges 336
facets 224
volumes 2
shalfedges 672
shalfloops 0
sfaces 116
0 { 0 7, 0 15, 0 1, -2 | 0 5 0 1 } 1
1 { 8 15, 16 31, 2 3, -2 | 0 -5 0 1 } 1
2 { 16 20, 32 41, 4 5, -2 | 8025465 19375168 0 4194304 } 1
3 { 21 25, 42 51, 6 7, -2 | 11349703 38750336 -11349703 8388608 } 1
4 { 26 30, 52 61, 8 9, -2 | 0 19375168 -8025465 4194304 } 1
5 { 31 35, 62 71, 10 11, -2 | -11349703 38750336 -11349703 8388608 } 1
6 { 36 40, 72 81, 12 13, -2 | -8025465 19375168 0 4194304 } 1
7 { 41 45, 82 91, 14 15, -2 | -11349703 38750336 11349703 8388608 } 1
8 { 46 50, 92 101, 16 17, -2 | 0 19375168 8025465 4194304 } 1
9 { 51 55, 102 111, 18 19, -2 | 11349703 38750336 11349703 8388608 } 1
10 { 56 61, 112 123, 20 21, -2 | 463409 463409 0 131072 } 1
11 { 62 67, 124 135, 22 23, -2 | 327680 463409 -327680 131072 } 1
12 { 68 73, 136 147, 24 25, -2 | 0 463409 -463409 131072 } 1
13 { 74 79, 148 159, 26 27, -2 | -327680 463409 -327680 131072 } 1
14 { 80 85, 160 171, 28 29, -2 | -463409 463409 0 131072 } 1
15 { 86 91, 172 183, 30 31, -2 | -327680 463409 327680 131072 } 1
16 { 92 97, 184 195, 32 33, -2 | 0 463409 463409 131072 } 1
17 { 98 103, 196 207, 34 35, -2 | 327680 463409 327680 131072 } 1
18 { 104 109, 208 219, 36 37, -2 | 19375168 8025465 0 4194304 } 1
19 { 110 115, 220 231, 38 39, -2 | 13700317 8025465 -13700317 4194304 } 1
20 { 116 121, 232 243, 40 41, -2 | 0 8025465 -19375168 4194304 } 1
21 { 122 127, 244 255, 42 43, -2 | -13700317 8025465 -13700317 4194304 } 1
22 { 128 133, 256 267, 44 45, -2 | -19375168 8025465 0 4194304 } 1
23 { 134 139, 268 279, 46 47, -2 | -13700317 8025465 13700317 4194304 } 1
24 { 140 145, 280 291, 48 49, -2 | 0 8025465 19375168 4194304 } 1
25 { 146 151, 292 303, 50 51, -2 | 13700317 8025465 13700317 4194304 } 1
26 { 152 157, 304 315, 52 53, -2 | 5 0 0 1 } 1
27 { 158 163, 316 327, 54 55, -2 | 463409 0 -463409 131072 } 1
28 { 164 169, 328 339, 56 57, -2 | 0 0 -5 1 } 1
29 { 170 175, 340 351, 58 59, -2 | -463409 0 -463409 131072 } 1
30 { 176 181, 352 363, 60 61, -2 | -5 0 0 1 } 1
31 { 182 187, 364 375, 62 63, -2 | -463409 0 463409 131072 } 1
32 { 188 193, 376 387, 64 65, -2 | 0 0 5 1 } 1
33 { 194 199, 388 399, 66 67, -2 | 463409 0 463409 131072 } 1
34 { 200 205, 400 411, 68 69, -2 | 19375168 -8025465 0 4194304 } 1
35 { 206 211, 412 423, 70 71, -2 | 13700317 -8025465 -13700317 4194304 } 1
36 { 212 217, 424 435, 72 73, -2 | 0 -8025465 -19375168 4194304 } 1
37 { 218 223, 436 447, 74 75, -2 | -13700317 -8025465 -13700317 4194304 } 1
38 { 224 229, 448 459, 76 77, -2 | -19375168 -8025465 0 4194304 } 1
39 { 230 235, 460 471, 78 79, -2 | -13700317 -8025465 13700317 4194304 } 1
40 { 236 241, 472 483, 80 81, -2 | 0 -8025465 19375168 4194304 } 1
41 { 242 247, 484 495, 82 83, -2 | 13700317 -8025465 13700317 4194304 } 1
42 { 248 253, 496 507, 84 85, -2 | 463409 -463409 0 131072 } 1
43 { 254 259, 508 519, 86 87, -2 | 327680 -463409 -327680 131072 } 1
44 { 260 265, 520 531, 88 89, -2 | 0 -463409 -463409 131072 } 1
45 { 266 271, 532 543, 90 91, -2 | -327680 -463409 -327680 131072 } 1
46 { 272 277, 544 555, 92 93, -2 | -463409 -463409 0 131072 } 1
47 { 278 283, 556 567, 94 95, -2 | -327680 -463409 327680 131072 } 1
48 { 284 289, 568 579, 96 97, -2 | 0 -463409 463409 131072 } 1
49 { 290 295, 580 591, 98 99, -2 | 327680 -463409 327680 131072 } 1
50 { 296 300, 592 601, 100 101, -2 | 8025465 -19375168 0 4194304 } 1
51 { 301 305, 602 611, 102 103, -2 | 11349703 -38750336 -11349703 8388608 } 1
52 { 306 310, 612 621, 104 105, -2 | 0 -19375168 -8025465 4194304 } 1
53 { 311 315, 622 631, 106 107, -2 | -11349703 -38750336 -11349703 8388608 } 1
54 { 316 320, 632 641, 108 109, -2 | -8025465 -19375168 0 4194304 } 1
55 { 321 325, 642 651, 110 111, -2 | -11349703 -38750336 11349703 8388608 } 1
56 { 326 330, 652 661, 112 113, -2 | 0 -19375168 8025465 4194304 } 1
57 { 331 335, 662 671, 114 115, -2 | 11349703 -38750336 11349703 8388608 } 1
0 { 17, 0, 0 0 | 8025465 -1596352 0 1 } 1
1 { 51, 0, 0 1 | 11349703 -3192704 11349703 1 } 1
2 { 46, 0, 0 3 | 0 -1596352 8025465 1 } 1
3 { 41, 0, 0 5 | -11349703 -3192704 11349703 1 } 1
4 { 36, 0, 0 7 | -8025465 -1596352 0 1 } 1
5 { 31, 0, 0 9 | -11349703 -3192704 -11349703 1 } 1
6 { 26, 0, 0 11 | 0 -1596352 -8025465 1 } 1
7 { 21, 0, 0 13 | 11349703 -3192704 -11349703 1 } 1
8 { 332, 1, 0 16 | 11349703 3192704 11349703 1 } 1
9 { 296, 1, 0 17 | 8025465 1596352 0 1 } 1
10 { 302, 1, 0 19 | 11349703 3192704 -11349703 1 } 1
11 { 307, 1, 0 21 | 0 1596352 -8025465 1 } 1
12 { 312, 1, 0 23 | -11349703 3192704 -11349703 1 } 1
13 { 317, 1, 0 25 | -8025465 1596352 0 1 } 1
14 { 322, 1, 0 27 | -11349703 3192704 11349703 1 } 1
15 { 327, 1, 0 29 | 0 1596352 8025465 1 } 1
16 { 52, 2, 0 32 | -4701227 0 11349703 1 } 1
17 { 0, 2, 0 33 | -8025465 1596352 0 1 } 1
18 { 25, 2, 0 35 | -4701227 0 -11349703 1 } 1
19 { 58, 2, 0 37 | 6803623 -4546080 0 1 } 1
20 { 103, 2, 0 39 | 492059 -909216 2097152 1 } 1
21 { 7, 3, 0 42 | -11349703 3192704 11349703 1 } 1
22 { 30, 3, 0 43 | -11349703 0 -4701227 1 } 1
23 { 66, 3, 0 45 | 9621817 -9092160 -9621817 1 } 1
24 { 59, 3, 0 47 | 18308473 -9092160 11349703 1 } 1
25 { 18, 3, 0 49 | 4701227 0 11349703 1 } 1
26 { 6, 4, 0 52 | 0 1596352 8025465 1 } 1
27 { 35, 4, 0 53 | -11349703 0 4701227 1 } 1
28 { 72, 4, 0 55 | 0 -4546080 -6803623 1 } 1
29 { 67, 4, 0 57 | 2097152 -909216 -492059 1 } 1
30 { 22, 4, 0 59 | 11349703 0 4701227 1 } 1
31 { 5, 5, 0 62 | 11349703 3192704 11349703 1 } 1
32 { 40, 5, 0 63 | -4701227 0 11349703 1 } 1
33 { 78, 5, 0 65 | -9621817 -9092160 -9621817 1 } 1
34 { 73, 5, 0 67 | 11349703 -9092160 -18308473 1 } 1
35 { 27, 5, 0 69 | 11349703 0 -4701227 1 } 1
36 { 4, 6, 0 72 | 8025465 1596352 0 1 } 1
37 { 45, 6, 0 73 | 4701227 0 11349703 1 } 1
38 { 84, 6, 0 75 | -6803623 -4546080 0 1 } 1
39 { 79, 6, 0 77 | -492059 -909216 -2097152 1 } 1
40 { 32, 6, 0 79 | 4701227 0 -11349703 1 } 1
41 { 3, 7, 0 82 | 11349703 3192704 -11349703 1 } 1
42 { 50, 7, 0 83 | 11349703 0 4701227 1 } 1
43 { 90, 7, 0 85 | -9621817 -9092160 9621817 1 } 1
44 { 85, 7, 0 87 | -18308473 -9092160 -11349703 1 } 1
45 { 37, 7, 0 89 | -4701227 0 -11349703 1 } 1
46 { 2, 8, 0 92 | 0 1596352 -8025465 1 } 1
47 { 55, 8, 0 93 | 11349703 0 -4701227 1 } 1
48 { 96, 8, 0 95 | 0 -4546080 6803623 1 } 1
49 { 91, 8, 0 97 | -2097152 -909216 492059 1 } 1
50 { 42, 8, 0 99 | -11349703 0 -4701227 1 } 1
51 { 1, 9, 0 102 | -11349703 3192704 -11349703 1 } 1
52 { 16, 9, 0 103 | 4701227 0 -11349703 1 } 1
53 { 102, 9, 0 105 | 9621817 -9092160 9621817 1 } 1
54 { 97, 9, 0 107 | -11349703 -9092160 18308473 1 } 1
55 { 47, 9, 0 109 | -11349703 0 4701227 1 } 1
56 { 151, 10, 0 112 | -1128771 -6803623 13700317 1 } 1
57 { 98, 10, 0 113 | -135729 0 327680 1 } 1
58 { 19, 10, 0 115 | -6803623 4546080 0 1 } 1
59 { 24, 10, 0 117 | -18308473 9092160 -11349703 1 } 1
60 { 65, 10, 0 119 | -135729 0 -327680 1 } 1
61 { 106, 10, 0 121 | 4546080 -6803623 0 1 } 1
62 { 71, 11, 0 124 | -327680 0 -135729 1 } 1
63 { 114, 11, 0 125 | 3214557 -6803623 -3214557 1 } 1
64 { 107, 11, 0 127 | 8889408 -6803623 10485760 1 } 1
65 { 60, 11, 0 129 | 135729 0 327680 1 } 1
66 { 23, 11, 0 131 | -9621817 9092160 9621817 1 } 1
67 { 29, 11, 0 133 | -2097152 909216 492059 1 } 1
68 { 77, 12, 0 136 | -327680 0 135729 1 } 1
69 { 120, 12, 0 137 | 0 -6803623 -4546080 1 } 1
70 { 115, 12, 0 139 | 13700317 -6803623 1128771 1 } 1
71 { 62, 12, 0 141 | 327680 0 135729 1 } 1
72 { 28, 12, 0 143 | 0 4546080 6803623 1 } 1
73 { 34, 12, 0 145 | -11349703 9092160 18308473 1 } 1
74 { 83, 13, 0 148 | -135729 0 327680 1 } 1
75 { 126, 13, 0 149 | -3214557 -6803623 -3214557 1 } 1
76 { 121, 13, 0 151 | 10485760 -6803623 -8889408 1 } 1
77 { 68, 13, 0 153 | 327680 0 -135729 1 } 1
78 { 33, 13, 0 155 | 9621817 9092160 9621817 1 } 1
79 { 39, 13, 0 157 | 492059 909216 2097152 1 } 1
80 { 89, 14, 0 160 | 135729 0 327680 1 } 1
81 { 132, 14, 0 161 | -4546080 -6803623 0 1 } 1
82 { 127, 14, 0 163 | 1128771 -6803623 -13700317 1 } 1
83 { 74, 14, 0 165 | 135729 0 -327680 1 } 1
84 { 38, 14, 0 167 | 6803623 4546080 0 1 } 1
85 { 44, 14, 0 169 | 18308473 9092160 11349703 1 } 1
86 { 95, 15, 0 172 | 327680 0 135729 1 } 1
87 { 138, 15, 0 173 | -3214557 -6803623 3214557 1 } 1
88 { 133, 15, 0 175 | -8889408 -6803623 -10485760 1 } 1
89 { 80, 15, 0 177 | -135729 0 -327680 1 } 1
90 { 43, 15, 0 179 | 9621817 9092160 -9621817 1 } 1
91 { 49, 15, 0 181 | 2097152 909216 -492059 1 } 1
92 { 101, 16, 0 184 | 327680 0 -135729 1 } 1
93 { 144, 16, 0 185 | 0 -6803623 4546080 1 } 1
94 { 139, 16, 0 187 | -13700317 -6803623 -1128771 1 } 1
95 { 86, 16, 0 189 | -327680 0 -135729 1 } 1
96 { 48, 16, 0 191 | 0 4546080 -6803623 1 } 1
97 { 54, 16, 0 193 | 11349703 9092160 -18308473 1 } 1
98 { 57, 17, 0 196 | 135729 0 -327680 1 } 1
99 { 150, 17, 0 197 | 3214557 -6803623 3214557 1 } 1
100 { 145, 17, 0 199 | -10485760 -6803623 8889408 1 } 1
101 { 92, 17, 0 201 | -327680 0 135729 1 } 1
102 { 53, 17, 0 203 | -9621817 9092160 -9621817 1 } 1
103 { 20, 17, 0 205 | -492059 909216 -2097152 1 } 1
104 { 199, 18, 0 208 | -4546080 -8025465 14829088 1 } 1
105 { 146, 18, 0 209 | -5674851 0 13700317 1 } 1
106 { 61, 18, 0 211 | -4546080 6803623 0 1 } 1
107 { 64, 18, 0 213 | -8889408 6803623 -10485760 1 } 1
108 { 113, 18, 0 215 | -5674851 0 -13700317 1 } 1
109 { 154, 18, 0 217 | 1596352 -8025465 0 1 } 1
110 { 119, 19, 0 220 | -13700317 0 -5674851 1 } 1
111 { 162, 19, 0 221 | 53751 -382165 -53751 1 } 1
112 { 155, 19, 0 223 | 7271203 -8025465 13700317 1 } 1
113 { 108, 19, 0 225 | 5674851 0 13700317 1 } 1
114 { 63, 19, 0 227 | -3214557 6803623 3214557 1 } 1
115 { 70, 19, 0 229 | -13700317 6803623 -1128771 1 } 1
116 { 125, 20, 0 232 | -13700317 0 5674851 1 } 1
117 { 168, 20, 0 233 | 0 -8025465 -1596352 1 } 1
118 { 163, 20, 0 235 | 14829088 -8025465 4546080 1 } 1
119 { 110, 20, 0 237 | 13700317 0 5674851 1 } 1
120 { 69, 20, 0 239 | 0 6803623 4546080 1 } 1
121 { 76, 20, 0 241 | -10485760 6803623 8889408 1 } 1
122 { 131, 21, 0 244 | -5674851 0 13700317 1 } 1
123 { 174, 21, 0 245 | -53751 -382165 -53751 1 } 1
124 { 169, 21, 0 247 | 13700317 -8025465 -7271203 1 } 1
125 { 116, 21, 0 249 | 13700317 0 -5674851 1 } 1
126 { 75, 21, 0 251 | 3214557 6803623 3214557 1 } 1
127 { 82, 21, 0 253 | -1128771 6803623 13700317 1 } 1
128 { 137, 22, 0 256 | 5674851 0 13700317 1 } 1
129 { 180, 22, 0 257 | -1596352 -8025465 0 1 } 1
130 { 175, 22, 0 259 | 4546080 -8025465 -14829088 1 } 1
131 { 122, 22, 0 261 | 5674851 0 -13700317 1 } 1
132 { 81, 22, 0 263 | 4546080 6803623 0 1 } 1
133 { 88, 22, 0 265 | 8889408 6803623 10485760 1 } 1
134 { 143, 23, 0 268 | 13700317 0 5674851 1 } 1
135 { 186, 23, 0 269 | -53751 -382165 53751 1 } 1
136 { 181, 23, 0 271 | -7271203 -8025465 -13700317 1 } 1
137 { 128, 23, 0 273 | -5674851 0 -13700317 1 } 1
138 { 87, 23, 0 275 | 3214557 6803623 -3214557 1 } 1
139 { 94, 23, 0 277 | 13700317 6803623 1128771 1 } 1
140 { 149, 24, 0 280 | 13700317 0 -5674851 1 } 1
141 { 192, 24, 0 281 | 0 -8025465 1596352 1 } 1
142 { 187, 24, 0 283 | -14829088 -8025465 -4546080 1 } 1
143 { 134, 24, 0 285 | -13700317 0 -5674851 1 } 1
144 { 93, 24, 0 287 | 0 6803623 -4546080 1 } 1
145 { 100, 24, 0 289 | 10485760 6803623 -8889408 1 } 1
146 { 105, 25, 0 292 | 5674851 0 -13700317 1 } 1
147 { 198, 25, 0 293 | 53751 -382165 53751 1 } 1
148 { 193, 25, 0 295 | -13700317 -8025465 7271203 1 } 1
149 { 140, 25, 0 297 | -13700317 0 5674851 1 } 1
150 { 99, 25, 0 299 | -3214557 6803623 -3214557 1 } 1
151 { 56, 25, 0 301 | 1128771 6803623 -13700317 1 } 1
152 { 247, 26, 0 304 | -7271203 -8025465 13700317 1 } 1
153 { 194, 26, 0 305 | -191951 0 463409 1 } 1
154 { 109, 26, 0 307 | -1596352 8025465 0 1 } 1
155 { 112, 26, 0 309 | -7271203 8025465 -13700317 1 } 1
156 { 161, 26, 0 311 | -191951 0 -463409 1 } 1
157 { 202, 26, 0 313 | -1596352 -8025465 0 1 } 1
158 { 167, 27, 0 316 | -463409 0 -191951 1 } 1
159 { 210, 27, 0 317 | -53751 -382165 53751 1 } 1
160 { 203, 27, 0 319 | 4546080 -8025465 14829088 1 } 1
161 { 156, 27, 0 321 | 191951 0 463409 1 } 1
162 { 111, 27, 0 323 | -53751 382165 53751 1 } 1
163 { 118, 27, 0 325 | -14829088 8025465 -4546080 1 } 1
164 { 173, 28, 0 328 | -463409 0 191951 1 } 1
165 { 216, 28, 0 329 | 0 -8025465 1596352 1 } 1
166 { 211, 28, 0 331 | 13700317 -8025465 7271203 1 } 1
167 { 158, 28, 0 333 | 463409 0 191951 1 } 1
168 { 117, 28, 0 335 | 0 8025465 1596352 1 } 1
169 { 124, 28, 0 337 | -13700317 8025465 7271203 1 } 1
170 { 179, 29, 0 340 | -191951 0 463409 1 } 1
171 { 222, 29, 0 341 | 53751 -382165 53751 1 } 1
172 { 217, 29, 0 343 | 14829088 -8025465 -4546080 1 } 1
173 { 164, 29, 0 345 | 463409 0 -191951 1 } 1
174 { 123, 29, 0 347 | 53751 382165 53751 1 } 1
175 { 130, 29, 0 349 | -4546080 8025465 14829088 1 } 1
176 { 185, 30, 0 352 | 191951 0 463409 1 } 1
177 { 228, 30, 0 353 | 1596352 -8025465 0 1 } 1
178 { 223, 30, 0 355 | 7271203 -8025465 -13700317 1 } 1
179 { 170, 30, 0 357 | 191951 0 -463409 1 } 1
180 { 129, 30, 0 359 | 1596352 8025465 0 1 } 1
181 { 136, 30, 0 361 | 7271203 8025465 13700317 1 } 1
182 { 191, 31, 0 364 | 463409 0 191951 1 } 1
183 { 234, 31, 0 365 | 53751 -382165 -53751 1 } 1
184 { 229, 31, 0 367 | -4546080 -8025465 -14829088 1 } 1
185 { 176, 31, 0 369 | -191951 0 -463409 1 } 1
186 { 135, 31, 0 371 | 53751 382165 -53751 1 } 1
187 { 142, 31, 0 373 | 14829088 8025465 4546080 1 } 1
188 { 197, 32, 0 376 | 463409 0 -191951 1 } 1
189 { 240, 32, 0 377 | 0 -8025465 -1596352 1 } 1
190 { 235, 32, 0 379 | -13700317 -8025465 -7271203 1 } 1
191 { 182, 32, 0 381 | -463409 0 -191951 1 } 1
192 { 141, 32, 0 383 | 0 8025465 -1596352 1 } 1
193 { 148, 32, 0 385 | 13700317 8025465 -7271203 1 } 1
194 { 153, 33, 0 388 | 191951 0 -463409 1 } 1
195 { 246, 33, 0 389 | -53751 -382165 -53751 1 } 1
196 { 241, 33, 0 391 | -14829088 -8025465 4546080 1 } 1
197 { 188, 33, 0 393 | -463409 0 191951 1 } 1
198 { 147, 33, 0 395 | -53751 382165 -53751 1 } 1
199 { 104, 33, 0 397 | 4546080 8025465 -14829088 1 } 1
200 { 295, 34, 0 400 | -8889408 -6803623 10485760 1 } 1
201 { 242, 34, 0 401 | -5674851 0 13700317 1 } 1
202 { 157, 34, 0 403 | 1596352 8025465 0 1 } 1
203 { 160, 34, 0 405 | -4546080 8025465 -14829088 1 } 1
204 { 209, 34, 0 407 | -5674851 0 -13700317 1 } 1
205 { 250, 34, 0 409 | -4546080 -6803623 0 1 } 1
206 { 215, 35, 0 412 | -13700317 0 -5674851 1 } 1
207 { 258, 35, 0 413 | -3214557 -6803623 3214557 1 } 1
208 { 251, 35, 0 415 | 1128771 -6803623 13700317 1 } 1
209 { 204, 35, 0 417 | 5674851 0 13700317 1 } 1
210 { 159, 35, 0 419 | 53751 382165 -53751 1 } 1
211 { 166, 35, 0 421 | -13700317 8025465 -7271203 1 } 1
212 { 221, 36, 0 424 | -13700317 0 5674851 1 } 1
213 { 264, 36, 0 425 | 0 -6803623 4546080 1 } 1
214 { 259, 36, 0 427 | 10485760 -6803623 8889408 1 } 1
215 { 206, 36, 0 429 | 13700317 0 5674851 1 } 1
216 { 165, 36, 0 431 | 0 8025465 -1596352 1 } 1
217 { 172, 36, 0 433 | -14829088 8025465 4546080 1 } 1
218 { 227, 37, 0 436 | -5674851 0 13700317 1 } 1
219 { 270, 37, 0 437 | 3214557 -6803623 3214557 1 } 1
220 { 265, 37, 0 439 | 13700317 -6803623 -1128771 1 } 1
221 { 212, 37, 0 441 | 13700317 0 -5674851 1 } 1
222 { 171, 37, 0 443 | -53751 382165 -53751 1 } 1
223 { 178, 37, 0 445 | -7271203 8025465 13700317 1 } 1
224 { 233, 38, 0 448 | 5674851 0 13700317 1 } 1
225 { 276, 38, 0 449 | 4546080 -6803623 0 1 } 1
226 { 271, 38, 0 451 | 8889408 -6803623 -10485760 1 } 1
227 { 218, 38, 0 453 | 5674851 0 -13700317 1 } 1
228 { 177, 38, 0 455 | -1596352 8025465 0 1 } 1
229 { 184, 38, 0 457 | 4546080 8025465 14829088 1 } 1
230 { 239, 39, 0 460 | 13700317 0 5674851 1 } 1
231 { 282, 39, 0 461 | 3214557 -6803623 -3214557 1 } 1
232 { 277, 39, 0 463 | -1128771 -6803623 -13700317 1 } 1
233 { 224, 39, 0 465 | -5674851 0 -13700317 1 } 1
234 { 183, 39, 0 467 | -53751 382165 53751 1 } 1
235 { 190, 39, 0 469 | 13700317 8025465 7271203 1 } 1
236 { 245, 40, 0 472 | 13700317 0 -5674851 1 } 1
237 { 288, 40, 0 473 | 0 -6803623 -4546080 1 } 1
238 { 283, 40, 0 475 | -10485760 -6803623 -8889408 1 } 1
239 { 230, 40, 0 477 | -13700317 0 -5674851 1 } 1
240 { 189, 40, 0 479 | 0 8025465 1596352 1 } 1
241 { 196, 40, 0 481 | 14829088 8025465 -4546080 1 } 1
242 { 201, 41, 0 484 | 5674851 0 -13700317 1 } 1
243 { 294, 41, 0 485 | -3214557 -6803623 -3214557 1 } 1
244 { 289, 41, 0 487 | -13700317 -6803623 1128771 1 } 1
245 { 236, 41, 0 489 | -13700317 0 5674851 1 } 1
246 { 195, 41, 0 491 | 53751 382165 53751 1 } 1
247 { 152, 41, 0 493 | 7271203 8025465 -13700317 1 } 1
248 { 335, 42, 0 496 | -18308473 -9092160 11349703 1 } 1
249 { 290, 42, 0 497 | -135729 0 327680 1 } 1
250 { 205, 42, 0 499 | 4546080 6803623 0 1 } 1
251 { 208, 42, 0 501 | -1128771 6803623 -13700317 1 } 1
252 { 257, 42, 0 503 | -135729 0 -327680 1 } 1
253 { 298, 42, 0 505 | -6803623 -4546080 0 1 } 1
254 { 263, 43, 0 508 | -327680 0 -135729 1 } 1
255 { 304, 43, 0 509 | -9621817 -9092160 9621817 1 } 1
256 { 299, 43, 0 511 | -492059 -909216 2097152 1 } 1
257 { 252, 43, 0 513 | 135729 0 327680 1 } 1
258 { 207, 43, 0 515 | 3214557 6803623 -3214557 1 } 1
259 { 214, 43, 0 517 | -10485760 6803623 -8889408 1 } 1
260 { 269, 44, 0 520 | -327680 0 135729 1 } 1
261 { 309, 44, 0 521 | 0 -4546080 6803623 1 } 1
262 { 305, 44, 0 523 | 11349703 -9092160 18308473 1 } 1
263 { 254, 44, 0 525 | 327680 0 135729 1 } 1
264 { 213, 44, 0 527 | 0 6803623 -4546080 1 } 1
265 { 220, 44, 0 529 | -13700317 6803623 1128771 1 } 1
266 { 275, 45, 0 532 | -135729 0 327680 1 } 1
267 { 314, 45, 0 533 | 9621817 -9092160 9621817 1 } 1
268 { 310, 45, 0 535 | 2097152 -909216 492059 1 } 1
269 { 260, 45, 0 537 | 327680 0 -135729 1 } 1
270 { 219, 45, 0 539 | -3214557 6803623 -3214557 1 } 1
271 { 226, 45, 0 541 | -8889408 6803623 10485760 1 } 1
272 { 281, 46, 0 544 | 135729 0 327680 1 } 1
273 { 319, 46, 0 545 | 6803623 -4546080 0 1 } 1
274 { 315, 46, 0 547 | 18308473 -9092160 -11349703 1 } 1
275 { 266, 46, 0 549 | 135729 0 -327680 1 } 1
276 { 225, 46, 0 551 | -4546080 6803623 0 1 } 1
277 { 232, 46, 0 553 | 1128771 6803623 13700317 1 } 1
278 { 287, 47, 0 556 | 327680 0 135729 1 } 1
279 { 324, 47, 0 557 | 9621817 -9092160 -9621817 1 } 1
280 { 320, 47, 0 559 | 492059 -909216 -2097152 1 } 1
281 { 272, 47, 0 561 | -135729 0 -327680 1 } 1
282 { 231, 47, 0 563 | -3214557 6803623 3214557 1 } 1
283 { 238, 47, 0 565 | 10485760 6803623 8889408 1 } 1
284 { 293, 48, 0 568 | 327680 0 -135729 1 } 1
285 { 329, 48, 0 569 | 0 -4546080 -6803623 1 } 1
286 { 325, 48, 0 571 | -11349703 -9092160 -18308473 1 } 1
287 { 278, 48, 0 573 | -327680 0 -135729 1 } 1
288 { 237, 48, 0 575 | 0 6803623 4546080 1 } 1
289 { 244, 48, 0 577 | 13700317 6803623 -1128771 1 } 1
290 { 249, 49, 0 580 | 135729 0 -327680 1 } 1
291 { 334, 49, 0 581 | -9621817 -9092160 -9621817 1 } 1
292 { 330, 49, 0 583 | -2097152 -909216 -492059 1 } 1
293 { 284, 49, 0 585 | -327680 0 135729 1 } 1
294 { 243, 49, 0 587 | 3214557 6803623 3214557 1 } 1
295 { 200, 49, 0 589 | 8889408 6803623 -10485760 1 } 1
296 { 9, 50, 0 592 | -8025465 -1596352 0 1 } 1
297 { 331, 50, 0 593 | -4701227 0 11349703 1 } 1
298 { 253, 50, 0 595 | 6803623 4546080 0 1 } 1
299 { 256, 50, 0 597 | 492059 909216 -2097152 1 } 1
300 { 303, 50, 0 599 | -4701227 0 -11349703 1 } 1
301 { 308, 51, 0 602 | -11349703 0 -4701227 1 } 1
302 { 10, 51, 0 603 | -11349703 -3192704 11349703 1 } 1
303 { 300, 51, 0 605 | 4701227 0 11349703 1 } 1
304 { 255, 51, 0 607 | 9621817 9092160 -9621817 1 } 1
305 { 262, 51, 0 609 | -11349703 9092160 -18308473 1 } 1
306 { 313, 52, 0 612 | -11349703 0 4701227 1 } 1
307 { 11, 52, 0 613 | 0 -1596352 8025465 1 } 1
308 { 301, 52, 0 615 | 11349703 0 4701227 1 } 1
309 { 261, 52, 0 617 | 0 4546080 -6803623 1 } 1
310 { 268, 52, 0 619 | -2097152 909216 -492059 1 } 1
311 { 318, 53, 0 622 | -4701227 0 11349703 1 } 1
312 { 12, 53, 0 623 | 11349703 -3192704 11349703 1 } 1
313 { 306, 53, 0 625 | 11349703 0 -4701227 1 } 1
314 { 267, 53, 0 627 | -9621817 9092160 -9621817 1 } 1
315 { 274, 53, 0 629 | -18308473 9092160 11349703 1 } 1
316 { 323, 54, 0 632 | 4701227 0 11349703 1 } 1
317 { 13, 54, 0 633 | 8025465 -1596352 0 1 } 1
318 { 311, 54, 0 635 | 4701227 0 -11349703 1 } 1
319 { 273, 54, 0 637 | -6803623 4546080 0 1 } 1
320 { 280, 54, 0 639 | -492059 909216 2097152 1 } 1
321 { 328, 55, 0 642 | 11349703 0 4701227 1 } 1
322 { 14, 55, 0 643 | 11349703 -3192704 -11349703 1 } 1
323 { 316, 55, 0 645 | -4701227 0 -11349703 1 } 1
324 { 279, 55, 0 647 | -9621817 9092160 9621817 1 } 1
325 { 286, 55, 0 649 | 11349703 9092160 18308473 1 } 1
326 { 333, 56, 0 652 | 11349703 0 -4701227 1 } 1
327 { 15, 56, 0 653 | 0 -1596352 -8025465 1 } 1
328 { 321, 56, 0 655 | -11349703 0 -4701227 1 } 1
329 { 285, 56, 0 657 | 0 4546080 6803623 1 } 1
330 { 292, 56, 0 659 | 2097152 909216 492059 1 } 1
331 { 297, 57, 0 662 | 4701227 0 -11349703 1 } 1
332 { 8, 57, 0 663 | -11349703 -3192704 -11349703 1 } 1
333 { 326, 57, 0 665 | -11349703 0 4701227 1 } 1
334 { 291, 57, 0 667 | 9621817 9092160 9621817 1 } 1
335 { 248, 57, 0 669 | 18308473 9092160 -11349703 1 } 1
0 { 1, 46 , , 0 | 390505298499993600 584428630068822016 -161751994812334080
-3446908240540666777 } 1
1 { 0, 47 , , 1 | -390505298499993600 -584428630068822016 161751994812334080
2 { 3, 48 , , 0 | 6762877133028065280 10121261924216864768
-2801290974351851520 -59694381686239744481 } 1
3 { 2, 49 , , 1 | -6762877133028065280 -10121261924216864768
2801290974351851520 59694381686239744481 } 1
4 { 5, 142 , , 0 | 246813956928 891764473856 -595863797760 -5259554517527 } 1
5 { 4, 143 , , 1 | -246813956928 -891764473856 595863797760 5259554517527 } 1
6 { 7, 58 , , 0 | 26678961660493824 96393538930081792 -64408353647886336
-568520545671846649 } 1
7 { 6, 59 , , 1 | -26678961660493824 -96393538930081792 64408353647886336
8 { 9, 154 , , 0 | -161751994812334080 584428630068822016 -390505298499993600
9 { 8, 155 , , 1 | 161751994812334080 -584428630068822016 390505298499993600
10 { 11, 68 , , 0 | -2801290974351851520 10121261924216864768
-6762877133028065280 -59694381686239744481 } 1
11 { 10, 69 , , 1 | 2801290974351851520 -10121261924216864768
6762877133028065280 59694381686239744481 } 1
12 { 13, 166 , , 0 | -595863797760 891764473856 -246813956928 -5259554517527
} 1
13 { 12, 167 , , 1 | 595863797760 -891764473856 246813956928 5259554517527 } 1
14 { 15, 156 , , 0 | -64408353647886336 96393538930081792 -26678961660493824
15 { 14, 157 , , 1 | 64408353647886336 -96393538930081792 26678961660493824
16 { 17, 170 , , 0 | -390505298499993600 584428630068822016
161751994812334080 -3446908240540666777 } 1
17 { 16, 171 , , 1 | 390505298499993600 -584428630068822016
-161751994812334080 3446908240540666777 } 1
18 { 19, 168 , , 0 | -6762877133028065280 10121261924216864768
19 { 18, 169 , , 1 | 6762877133028065280 -10121261924216864768
-2801290974351851520 59694381686239744481 } 1
20 { 21, 182 , , 0 | -246813956928 891764473856 595863797760 -5259554517527 }
1
21 { 20, 183 , , 1 | 246813956928 -891764473856 -595863797760 5259554517527 }
1
22 { 23, 180 , , 0 | -26678961660493824 96393538930081792 64408353647886336
23 { 22, 181 , , 1 | 26678961660493824 -96393538930081792 -64408353647886336
24 { 25, 194 , , 0 | 161751994812334080 584428630068822016 390505298499993600
25 { 24, 195 , , 1 | -161751994812334080 -584428630068822016
-390505298499993600 3446908240540666777 } 1
26 { 27, 192 , , 0 | 2801290974351851520 10121261924216864768
27 { 26, 193 , , 1 | -2801290974351851520 -10121261924216864768
-6762877133028065280 59694381686239744481 } 1
28 { 29, 38 , , 0 | 595863797760 891764473856 246813956928 -5259554517527 } 1
29 { 28, 39 , , 1 | -595863797760 -891764473856 -246813956928 5259554517527 }
1
30 { 31, 104 , , 0 | 64408353647886336 96393538930081792 26678961660493824
31 { 30, 105 , , 1 | -64408353647886336 -96393538930081792 -26678961660493824
32 { 33, 126 , , 0 | 190897749705709568 127554727773339648 -79072351816034304
-1125898832011112861 } 1
33 { 32, 127 , , 1 | -190897749705709568 -127554727773339648
79072351816034304 1125898832011112861 } 1
34 { 35, 128 , , 0 | 4458822369280 2979318988800 -1846897892334
-26297772587635 } 1
35 { 34, 129 , , 1 | -4458822369280 -2979318988800 1846897892334
26297772587635 } 1
36 { 37, 238 , , 0 | 5060630516226195456 8163522918135889920
-12217455981165412352 -72057564168901956059 } 1
37 { 36, 239 , , 1 | -5060630516226195456 -8163522918135889920
12217455981165412352 72057564168901956059 } 1
38 { 39, 140 , , 0 | 121038300272001024 195252013604929536
-292213382793134080 -1723448576960985277 } 1
39 { 38, 141 , , 1 | -121038300272001024 -195252013604929536
292213382793134080 1723448576960985277 } 1
40 { 41, 250 , , 0 | -79072351816034304 127554727773339648
-190897749705709568 -1125898832011112861 } 1
41 { 40, 251 , , 1 | 79072351816034304 -127554727773339648 190897749705709568
42 { 43, 152 , , 0 | -1846897892334 2979318988800 -4458822369280
-26297772587635 } 1
43 { 42, 153 , , 1 | 1846897892334 -2979318988800 4458822369280
26297772587635 } 1
44 { 45, 262 , , 0 | -12217455981165412352 8163522918135889920
-5060630516226195456 -72057564168901956059 } 1
45 { 44, 263 , , 1 | 12217455981165412352 -8163522918135889920
5060630516226195456 72057564168901956059 } 1
46 { 47, 164 , , 0 | -292213382793134080 195252013604929536
-121038300272001024 -1723448576960985277 } 1
47 { 46, 165 , , 1 | 292213382793134080 -195252013604929536
121038300272001024 1723448576960985277 } 1
48 { 49, 266 , , 0 | -190897749705709568 127554727773339648 79072351816034304
49 { 48, 267 , , 1 | 190897749705709568 -127554727773339648
-79072351816034304 1125898832011112861 } 1
50 { 51, 264 , , 0 | -4458822369280 2979318988800 1846897892334
-26297772587635 } 1
51 { 50, 265 , , 1 | 4458822369280 -2979318988800 -1846897892334
26297772587635 } 1
52 { 53, 278 , , 0 | -5060630516226195456 8163522918135889920
53 { 52, 279 , , 1 | 5060630516226195456 -8163522918135889920
-12217455981165412352 72057564168901956059 } 1
54 { 55, 276 , , 0 | -121038300272001024 195252013604929536
55 { 54, 277 , , 1 | 121038300272001024 -195252013604929536
-292213382793134080 1723448576960985277 } 1
56 { 57, 290 , , 0 | 79072351816034304 127554727773339648 190897749705709568
57 { 56, 291 , , 1 | -79072351816034304 -127554727773339648
-190897749705709568 1125898832011112861 } 1
58 { 59, 288 , , 0 | 1846897892334 2979318988800 4458822369280
-26297772587635 } 1
59 { 58, 289 , , 1 | -1846897892334 -2979318988800 -4458822369280
26297772587635 } 1
60 { 61, 302 , , 0 | 12217455981165412352 8163522918135889920
61 { 60, 303 , , 1 | -12217455981165412352 -8163522918135889920
-5060630516226195456 72057564168901956059 } 1
62 { 63, 196 , , 0 | 292213382793134080 195252013604929536 121038300272001024
63 { 62, 197 , , 1 | -292213382793134080 -195252013604929536
-121038300272001024 1723448576960985277 } 1
64 { 65, 222 , , 0 | 35419740097 7045251072 -14671390783 -177098700485 } 1
65 { 64, 223 , , 1 | -35419740097 -7045251072 14671390783 177098700485 } 1
66 { 67, 224 , , 0 | 109951414572405 21870528443584 -45543318080715
-549757072862025 } 1
67 { 66, 225 , , 1 | -109951414572405 -21870528443584 45543318080715
549757072862025 } 1
68 { 69, 334 , , 0 | 1540496032215 739763883968 -3719072710185
-18595363550925 } 1
69 { 68, 335 , , 1 | -1540496032215 -739763883968 3719072710185
18595363550925 } 1
70 { 71, 236 , , 0 | 4441557877585920 2132858173784064 -10722880811632640
-53614329288727445 } 1
71 { 70, 237 , , 1 | -4441557877585920 -2132858173784064 10722880811632640
72 { 73, 346 , , 0 | -14671390783 7045251072 -35419740097 -177098700485 } 1
73 { 72, 347 , , 1 | 14671390783 -7045251072 35419740097 177098700485 } 1
74 { 75, 248 , , 0 | -45543318080715 21870528443584 -109951414572405
75 { 74, 249 , , 1 | 45543318080715 -21870528443584 109951414572405
549757072862025 } 1
76 { 77, 358 , , 0 | -3719072710185 739763883968 -1540496032215
-18595363550925 } 1
77 { 76, 359 , , 1 | 3719072710185 -739763883968 1540496032215 18595363550925
} 1
78 { 79, 260 , , 0 | -10722880811632640 2132858173784064 -4441557877585920
79 { 78, 261 , , 1 | 10722880811632640 -2132858173784064 4441557877585920
80 { 81, 362 , , 0 | -35419740097 7045251072 14671390783 -177098700485 } 1
81 { 80, 363 , , 1 | 35419740097 -7045251072 -14671390783 177098700485 } 1
82 { 83, 360 , , 0 | -109951414572405 21870528443584 45543318080715
83 { 82, 361 , , 1 | 109951414572405 -21870528443584 -45543318080715
549757072862025 } 1
84 { 85, 374 , , 0 | -1540496032215 739763883968 3719072710185
-18595363550925 } 1
85 { 84, 375 , , 1 | 1540496032215 -739763883968 -3719072710185
18595363550925 } 1
86 { 87, 372 , , 0 | -4441557877585920 2132858173784064 10722880811632640
87 { 86, 373 , , 1 | 4441557877585920 -2132858173784064 -10722880811632640
88 { 89, 386 , , 0 | 14671390783 7045251072 35419740097 -177098700485 } 1
89 { 88, 387 , , 1 | -14671390783 -7045251072 -35419740097 177098700485 } 1
90 { 91, 384 , , 0 | 45543318080715 21870528443584 109951414572405
91 { 90, 385 , , 1 | -45543318080715 -21870528443584 -109951414572405
549757072862025 } 1
92 { 93, 398 , , 0 | 3719072710185 739763883968 1540496032215 -18595363550925
} 1
93 { 92, 399 , , 1 | -3719072710185 -739763883968 -1540496032215
18595363550925 } 1
94 { 95, 292 , , 0 | 10722880811632640 2132858173784064 4441557877585920
95 { 94, 293 , , 1 | -10722880811632640 -2132858173784064 -4441557877585920
96 { 97, 418 , , 0 | 10722880811632640 -2132858173784064 -4441557877585920
97 { 96, 419 , , 1 | -10722880811632640 2132858173784064 4441557877585920
98 { 99, 320 , , 0 | 3719072710185 -739763883968 -1540496032215
-18595363550925 } 1
99 { 98, 321 , , 1 | -3719072710185 739763883968 1540496032215 18595363550925
} 1
100 { 101, 430 , , 0 | 45543318080715 -21870528443584 -109951414572405
101 { 100, 431 , , 1 | -45543318080715 21870528443584 109951414572405
549757072862025 } 1
102 { 103, 332 , , 0 | 14671390783 -7045251072 -35419740097 -177098700485 } 1
103 { 102, 333 , , 1 | -14671390783 7045251072 35419740097 177098700485 } 1
104 { 105, 342 , , 0 | -4441557877585920 -2132858173784064 -10722880811632640
105 { 104, 343 , , 1 | 4441557877585920 2132858173784064 10722880811632640
106 { 107, 344 , , 0 | -1540496032215 -739763883968 -3719072710185
-18595363550925 } 1
107 { 106, 345 , , 1 | 1540496032215 739763883968 3719072710185
18595363550925 } 1
108 { 109, 354 , , 0 | -109951414572405 -21870528443584 -45543318080715
109 { 108, 355 , , 1 | 109951414572405 21870528443584 45543318080715
549757072862025 } 1
110 { 111, 356 , , 0 | -35419740097 -7045251072 -14671390783 -177098700485 } 1
111 { 110, 357 , , 1 | 35419740097 7045251072 14671390783 177098700485 } 1
112 { 113, 458 , , 0 | -10722880811632640 -2132858173784064 4441557877585920
113 { 112, 459 , , 1 | 10722880811632640 2132858173784064 -4441557877585920
114 { 115, 352 , , 0 | -3719072710185 -739763883968 1540496032215
-18595363550925 } 1
115 { 114, 353 , , 1 | 3719072710185 739763883968 -1540496032215
18595363550925 } 1
116 { 117, 470 , , 0 | -45543318080715 -21870528443584 109951414572405
117 { 116, 471 , , 1 | 45543318080715 21870528443584 -109951414572405
549757072862025 } 1
118 { 119, 364 , , 0 | -14671390783 -7045251072 35419740097 -177098700485 } 1
119 { 118, 365 , , 1 | 14671390783 7045251072 -35419740097 177098700485 } 1
120 { 121, 482 , , 0 | 4441557877585920 -2132858173784064 10722880811632640
121 { 120, 483 , , 1 | -4441557877585920 2132858173784064 -10722880811632640
122 { 123, 480 , , 0 | 1540496032215 -739763883968 3719072710185
-18595363550925 } 1
123 { 122, 481 , , 1 | -1540496032215 739763883968 -3719072710185
18595363550925 } 1
124 { 125, 494 , , 0 | 109951414572405 -21870528443584 45543318080715
125 { 124, 495 , , 1 | -109951414572405 21870528443584 -45543318080715
549757072862025 } 1
126 { 127, 492 , , 0 | 35419740097 -7045251072 14671390783 -177098700485 } 1
127 { 126, 493 , , 1 | -35419740097 7045251072 -14671390783 177098700485 } 1
128 { 129, 514 , , 0 | 292213382793134080 -195252013604929536
129 { 128, 515 , , 1 | -292213382793134080 195252013604929536
130 { 131, 416 , , 0 | 12217455981165412352 -8163522918135889920
131 { 130, 417 , , 1 | -12217455981165412352 8163522918135889920
132 { 133, 526 , , 0 | 1846897892334 -2979318988800 -4458822369280
-26297772587635 } 1
133 { 132, 527 , , 1 | -1846897892334 2979318988800 4458822369280
26297772587635 } 1
134 { 135, 428 , , 0 | 79072351816034304 -127554727773339648
135 { 134, 429 , , 1 | -79072351816034304 127554727773339648
136 { 137, 438 , , 0 | -121038300272001024 -195252013604929536
137 { 136, 439 , , 1 | 121038300272001024 195252013604929536
138 { 139, 440 , , 0 | -5060630516226195456 -8163522918135889920
139 { 138, 441 , , 1 | 5060630516226195456 8163522918135889920
140 { 141, 450 , , 0 | -4458822369280 -2979318988800 -1846897892334
-26297772587635 } 1
141 { 140, 451 , , 1 | 4458822369280 2979318988800 1846897892334
26297772587635 } 1
142 { 143, 452 , , 0 | -190897749705709568 -127554727773339648
-79072351816034304 -1125898832011112861 } 1
143 { 142, 453 , , 1 | 190897749705709568 127554727773339648
144 { 145, 554 , , 0 | -292213382793134080 -195252013604929536
145 { 144, 555 , , 1 | 292213382793134080 195252013604929536
146 { 147, 448 , , 0 | -12217455981165412352 -8163522918135889920
147 { 146, 449 , , 1 | 12217455981165412352 8163522918135889920
148 { 149, 566 , , 0 | -1846897892334 -2979318988800 4458822369280
-26297772587635 } 1
149 { 148, 567 , , 1 | 1846897892334 2979318988800 -4458822369280
26297772587635 } 1
150 { 151, 460 , , 0 | -79072351816034304 -127554727773339648
151 { 150, 461 , , 1 | 79072351816034304 127554727773339648
152 { 153, 578 , , 0 | 121038300272001024 -195252013604929536
153 { 152, 579 , , 1 | -121038300272001024 195252013604929536
154 { 155, 576 , , 0 | 5060630516226195456 -8163522918135889920
155 { 154, 577 , , 1 | -5060630516226195456 8163522918135889920
156 { 157, 590 , , 0 | 4458822369280 -2979318988800 1846897892334
-26297772587635 } 1
157 { 156, 591 , , 1 | -4458822369280 2979318988800 -1846897892334
26297772587635 } 1
158 { 159, 588 , , 0 | 190897749705709568 -127554727773339648
159 { 158, 589 , , 1 | -190897749705709568 127554727773339648
160 { 161, 606 , , 0 | 64408353647886336 -96393538930081792
-26678961660493824 -568520545671846649 } 1
161 { 160, 607 , , 1 | -64408353647886336 96393538930081792 26678961660493824
162 { 163, 596 , , 0 | 595863797760 -891764473856 -246813956928
-5259554517527 } 1
163 { 162, 597 , , 1 | -595863797760 891764473856 246813956928 5259554517527
} 1
164 { 165, 616 , , 0 | 2801290974351851520 -10121261924216864768
165 { 164, 617 , , 1 | -2801290974351851520 10121261924216864768
166 { 167, 524 , , 0 | 161751994812334080 -584428630068822016
-390505298499993600 -3446908240540666777 } 1
167 { 166, 525 , , 1 | -161751994812334080 584428630068822016
168 { 169, 534 , , 0 | -26678961660493824 -96393538930081792
-64408353647886336 -568520545671846649 } 1
169 { 168, 535 , , 1 | 26678961660493824 96393538930081792 64408353647886336
170 { 171, 536 , , 0 | -246813956928 -891764473856 -595863797760
-5259554517527 } 1
171 { 170, 537 , , 1 | 246813956928 891764473856 595863797760 5259554517527 }
1
172 { 173, 546 , , 0 | -6762877133028065280 -10121261924216864768
173 { 172, 547 , , 1 | 6762877133028065280 10121261924216864768
174 { 175, 548 , , 0 | -390505298499993600 -584428630068822016
-161751994812334080 -3446908240540666777 } 1
175 { 174, 549 , , 1 | 390505298499993600 584428630068822016
176 { 177, 558 , , 0 | -64408353647886336 -96393538930081792
177 { 176, 559 , , 1 | 64408353647886336 96393538930081792 -26678961660493824
178 { 179, 544 , , 0 | -595863797760 -891764473856 246813956928
-5259554517527 } 1
179 { 178, 545 , , 1 | 595863797760 891764473856 -246813956928 5259554517527
} 1
180 { 181, 650 , , 0 | -2801290974351851520 -10121261924216864768
181 { 180, 651 , , 1 | 2801290974351851520 10121261924216864768
182 { 183, 556 , , 0 | -161751994812334080 -584428630068822016
183 { 182, 557 , , 1 | 161751994812334080 584428630068822016
184 { 185, 660 , , 0 | 26678961660493824 -96393538930081792 64408353647886336
185 { 184, 661 , , 1 | -26678961660493824 96393538930081792
-64408353647886336 568520545671846649 } 1
186 { 187, 658 , , 0 | 246813956928 -891764473856 595863797760 -5259554517527
} 1
187 { 186, 659 , , 1 | -246813956928 891764473856 -595863797760 5259554517527
} 1
188 { 189, 670 , , 0 | 6762877133028065280 -10121261924216864768
189 { 188, 671 , , 1 | -6762877133028065280 10121261924216864768
190 { 191, 668 , , 0 | 390505298499993600 -584428630068822016
191 { 190, 669 , , 1 | -390505298499993600 584428630068822016
192 { 193, 14 , , 0 | 18118121083456 91086644186895 -7504813123904
-455433220934475 } 1
193 { 192, 15 , , 1 | -18118121083456 -91086644186895 7504813123904
455433220934475 } 1
194 { 195, 60 , , 0 | 7504813123904 91086644186895 -18118121083456
195 { 194, 61 , , 1 | -7504813123904 -91086644186895 18118121083456
455433220934475 } 1
196 { 197, 70 , , 0 | -7504813123904 91086644186895 -18118121083456
197 { 196, 71 , , 1 | 7504813123904 -91086644186895 18118121083456
455433220934475 } 1
198 { 199, 80 , , 0 | -18118121083456 91086644186895 -7504813123904
199 { 198, 81 , , 1 | 18118121083456 -91086644186895 7504813123904
455433220934475 } 1
200 { 201, 72 , , 0 | -18118121083456 91086644186895 7504813123904
201 { 200, 73 , , 1 | 18118121083456 -91086644186895 -7504813123904
455433220934475 } 1
202 { 203, 82 , , 0 | -7504813123904 91086644186895 18118121083456
203 { 202, 83 , , 1 | 7504813123904 -91086644186895 -18118121083456
455433220934475 } 1
204 { 205, 92 , , 0 | 7504813123904 91086644186895 18118121083456
205 { 204, 93 , , 1 | -7504813123904 -91086644186895 -18118121083456
455433220934475 } 1
206 { 207, 0 , , 0 | 18118121083456 91086644186895 7504813123904
207 { 206, 1 , , 1 | -18118121083456 -91086644186895 -7504813123904
455433220934475 } 1
208 { 209, 18 , , 0 | 18118121083456 -91086644186895 -7504813123904
209 { 208, 19 , , 1 | -18118121083456 91086644186895 7504813123904
455433220934475 } 1
210 { 211, 20 , , 0 | 7504813123904 -91086644186895 -18118121083456
211 { 210, 21 , , 1 | -7504813123904 91086644186895 18118121083456
455433220934475 } 1
212 { 213, 624 , , 0 | -7504813123904 -91086644186895 -18118121083456
213 { 212, 625 , , 1 | 7504813123904 91086644186895 18118121083456
455433220934475 } 1
214 { 215, 634 , , 0 | -18118121083456 -91086644186895 -7504813123904
215 { 214, 635 , , 1 | 18118121083456 91086644186895 7504813123904
455433220934475 } 1
216 { 217, 632 , , 0 | -18118121083456 -91086644186895 7504813123904
217 { 216, 633 , , 1 | 18118121083456 91086644186895 -7504813123904
455433220934475 } 1
218 { 219, 642 , , 0 | -7504813123904 -91086644186895 18118121083456
219 { 218, 643 , , 1 | 7504813123904 91086644186895 -18118121083456
455433220934475 } 1
220 { 221, 30 , , 0 | 7504813123904 -91086644186895 18118121083456
221 { 220, 31 , , 1 | -7504813123904 91086644186895 -18118121083456
455433220934475 } 1
222 { 223, 16 , , 0 | 18118121083456 -91086644186895 7504813123904
223 { 222, 17 , , 1 | -18118121083456 91086644186895 -7504813123904
455433220934475 } 1
0 { 0 } 0
1 { 1 } 1
0 { 1, 14, 2, 0, 1, 32, 102, 206 | -18118121083456 -91086644186895
-7504813123904 0 } 1
1 { 0, 3, 15, 1, 0, 103, 33, 207 | 18118121083456 91086644186895
7504813123904 0 } 1
2 { 3, 0, 4, 1, 1, 110, 92, 204 | -7504813123904 -91086644186895
-18118121083456 0 } 1
3 { 2, 5, 1, 2, 0, 93, 111, 205 | 7504813123904 91086644186895 18118121083456
0 } 1
4 { 5, 2, 6, 2, 1, 100, 82, 202 | 7504813123904 -91086644186895
5 { 4, 7, 3, 3, 0, 83, 101, 203 | -7504813123904 91086644186895
6 { 7, 4, 8, 3, 1, 90, 72, 200 | 18118121083456 -91086644186895
7 { 6, 9, 5, 4, 0, 73, 91, 201 | -18118121083456 91086644186895 7504813123904
0 } 1
8 { 9, 6, 10, 4, 1, 80, 62, 198 | 18118121083456 -91086644186895
7504813123904 0 } 1
9 { 8, 11, 7, 5, 0, 63, 81, 199 | -18118121083456 91086644186895
10 { 11, 8, 12, 5, 1, 70, 52, 196 | 7504813123904 -91086644186895
11 { 10, 13, 9, 6, 0, 53, 71, 197 | -7504813123904 91086644186895
12 { 13, 10, 14, 6, 1, 60, 42, 194 | -7504813123904 -91086644186895
13 { 12, 15, 11, 7, 0, 43, 61, 195 | 7504813123904 91086644186895
14 { 15, 12, 0, 7, 1, 50, 34, 192 | -18118121083456 -91086644186895
7504813123904 0 } 1
15 { 14, 1, 13, 0, 0, 35, 51, 193 | 18118121083456 91086644186895
16 { 17, 30, 18, 8, 3, 662, 592, 222 | -18118121083456 91086644186895
17 { 16, 19, 31, 9, 2, 593, 663, 223 | 18118121083456 -91086644186895
7504813123904 0 } 1
18 { 19, 16, 20, 9, 3, 600, 604, 208 | -18118121083456 91086644186895
7504813123904 0 } 1
19 { 18, 21, 17, 10, 2, 605, 601, 209 | 18118121083456 -91086644186895
20 { 21, 18, 22, 10, 3, 602, 614, 210 | -7504813123904 91086644186895
21 { 20, 23, 19, 11, 2, 615, 603, 211 | 7504813123904 -91086644186895
22 { 23, 20, 24, 11, 3, 612, 624, 212 | 7504813123904 91086644186895
23 { 22, 25, 21, 12, 2, 625, 613, 213 | -7504813123904 -91086644186895
24 { 25, 22, 26, 12, 3, 622, 634, 214 | 18118121083456 91086644186895
7504813123904 0 } 1
25 { 24, 27, 23, 13, 2, 635, 623, 215 | -18118121083456 -91086644186895
26 { 27, 24, 28, 13, 3, 632, 644, 216 | 18118121083456 91086644186895
27 { 26, 29, 25, 14, 2, 645, 633, 217 | -18118121083456 -91086644186895
7504813123904 0 } 1
28 { 29, 26, 30, 14, 3, 642, 654, 218 | 7504813123904 91086644186895
29 { 28, 31, 27, 15, 2, 655, 643, 219 | -7504813123904 -91086644186895
30 { 31, 28, 16, 15, 3, 652, 664, 220 | -7504813123904 91086644186895
31 { 30, 17, 29, 8, 2, 665, 653, 221 | 7504813123904 -91086644186895
32 { 33, 40, 34, 16, 5, 102, 0, 206 | -18118121083456 -91086644186895
33 { 32, 35, 41, 17, 4, 1, 103, 207 | 18118121083456 91086644186895
7504813123904 0 } 1
34 { 35, 32, 36, 17, 5, 14, 50, 192 | -18118121083456 -91086644186895
7504813123904 0 } 1
35 { 34, 37, 33, 18, 4, 51, 15, 193 | 18118121083456 91086644186895
36 { 37, 34, 38, 18, 5, 48, 116, 2 | -51596657814240 -77219100373969
21372154040160 0 } 1
37 { 36, 39, 35, 19, 4, 117, 49, 3 | 51596657814240 77219100373969
-21372154040160 0 } 1
38 { 39, 36, 40, 19, 5, 114, 206, 28 | -9310371840 -13933819904 -3856468077 0
} 1
39 { 38, 41, 37, 20, 4, 207, 115, 29 | 9310371840 13933819904 3856468077 0 } 1
40 { 41, 38, 32, 20, 5, 204, 104, 30 | -491396741088 -735424338761
-203544324192 0 } 1
41 { 40, 33, 39, 16, 4, 105, 205, 31 | 491396741088 735424338761 203544324192
0 } 1
42 { 43, 50, 44, 21, 7, 12, 60, 194 | -7504813123904 -91086644186895
43 { 42, 45, 51, 22, 6, 61, 13, 195 | 7504813123904 91086644186895
44 { 45, 42, 46, 22, 7, 58, 132, 6 | -203544324192 -735424338761 491396741088
0 } 1
45 { 44, 47, 43, 23, 6, 133, 59, 7 | 203544324192 735424338761 -491396741088
0 } 1
46 { 47, 44, 48, 23, 7, 130, 118, 0 | -2979318988800 -4458836594153
1234069784640 0 } 1
47 { 46, 49, 45, 24, 6, 119, 131, 1 | 2979318988800 4458836594153
-1234069784640 0 } 1
48 { 49, 46, 50, 24, 7, 116, 36, 2 | -51596657814240 -77219100373969
49 { 48, 51, 47, 25, 6, 37, 117, 3 | 51596657814240 77219100373969
50 { 51, 48, 42, 25, 7, 34, 14, 192 | -18118121083456 -91086644186895
7504813123904 0 } 1
51 { 50, 43, 49, 21, 6, 15, 35, 193 | 18118121083456 91086644186895
52 { 53, 60, 54, 26, 9, 10, 70, 196 | 7504813123904 -91086644186895
53 { 52, 55, 61, 27, 8, 71, 11, 197 | -7504813123904 91086644186895
54 { 55, 52, 56, 27, 9, 68, 144, 10 | 21372154040160 -77219100373969
51596657814240 0 } 1
55 { 54, 57, 53, 28, 8, 145, 69, 11 | -21372154040160 77219100373969
-51596657814240 0 } 1
56 { 57, 54, 58, 28, 9, 142, 134, 4 | -3856468077 -13933819904 9310371840 0 }
1
57 { 56, 59, 55, 29, 8, 135, 143, 5 | 3856468077 13933819904 -9310371840 0 } 1
58 { 59, 56, 60, 29, 9, 132, 44, 6 | -203544324192 -735424338761 491396741088
0 } 1
59 { 58, 61, 57, 30, 8, 45, 133, 7 | 203544324192 735424338761 -491396741088
0 } 1
60 { 61, 58, 52, 30, 9, 42, 12, 194 | -7504813123904 -91086644186895
61 { 60, 53, 59, 26, 8, 13, 43, 195 | 7504813123904 91086644186895
62 { 63, 70, 64, 31, 11, 8, 80, 198 | 18118121083456 -91086644186895
7504813123904 0 } 1
63 { 62, 65, 71, 32, 10, 81, 9, 199 | -18118121083456 91086644186895
64 { 65, 62, 66, 32, 11, 78, 156, 14 | 491396741088 -735424338761
203544324192 0 } 1
65 { 64, 67, 63, 33, 10, 157, 79, 15 | -491396741088 735424338761
-203544324192 0 } 1
66 { 67, 64, 68, 33, 11, 154, 146, 8 | 1234069784640 -4458836594153
2979318988800 0 } 1
67 { 66, 69, 65, 34, 10, 147, 155, 9 | -1234069784640 4458836594153
-2979318988800 0 } 1
68 { 69, 66, 70, 34, 11, 144, 54, 10 | 21372154040160 -77219100373969
69 { 68, 71, 67, 35, 10, 55, 145, 11 | -21372154040160 77219100373969
70 { 71, 68, 62, 35, 11, 52, 10, 196 | 7504813123904 -91086644186895
71 { 70, 63, 69, 31, 10, 11, 53, 197 | -7504813123904 91086644186895
72 { 73, 80, 74, 36, 13, 6, 90, 200 | 18118121083456 -91086644186895
73 { 72, 75, 81, 37, 12, 91, 7, 201 | -18118121083456 91086644186895
7504813123904 0 } 1
74 { 75, 72, 76, 37, 13, 88, 168, 18 | 51596657814240 -77219100373969
75 { 74, 77, 73, 38, 12, 169, 89, 19 | -51596657814240 77219100373969
76 { 77, 74, 78, 38, 13, 166, 158, 12 | 9310371840 -13933819904 3856468077 0
} 1
77 { 76, 79, 75, 39, 12, 159, 167, 13 | -9310371840 13933819904 -3856468077 0
} 1
78 { 79, 76, 80, 39, 13, 156, 64, 14 | 491396741088 -735424338761
203544324192 0 } 1
79 { 78, 81, 77, 40, 12, 65, 157, 15 | -491396741088 735424338761
-203544324192 0 } 1
80 { 81, 78, 72, 40, 13, 62, 8, 198 | 18118121083456 -91086644186895
7504813123904 0 } 1
81 { 80, 73, 79, 36, 12, 9, 63, 199 | -18118121083456 91086644186895
82 { 83, 90, 84, 41, 15, 4, 100, 202 | 7504813123904 -91086644186895
83 { 82, 85, 91, 42, 14, 101, 5, 203 | -7504813123904 91086644186895
84 { 85, 82, 86, 42, 15, 98, 180, 22 | 203544324192 -735424338761
-491396741088 0 } 1
85 { 84, 87, 83, 43, 14, 181, 99, 23 | -203544324192 735424338761
491396741088 0 } 1
86 { 87, 84, 88, 43, 15, 178, 170, 16 | 2979318988800 -4458836594153
87 { 86, 89, 85, 44, 14, 171, 179, 17 | -2979318988800 4458836594153
1234069784640 0 } 1
88 { 89, 86, 90, 44, 15, 168, 74, 18 | 51596657814240 -77219100373969
89 { 88, 91, 87, 45, 14, 75, 169, 19 | -51596657814240 77219100373969
90 { 91, 88, 82, 45, 15, 72, 6, 200 | 18118121083456 -91086644186895
91 { 90, 83, 89, 41, 14, 7, 73, 201 | -18118121083456 91086644186895
7504813123904 0 } 1
92 { 93, 100, 94, 46, 17, 2, 110, 204 | -7504813123904 -91086644186895
93 { 92, 95, 101, 47, 16, 111, 3, 205 | 7504813123904 91086644186895
94 { 95, 92, 96, 47, 17, 108, 192, 26 | -21372154040160 -77219100373969
95 { 94, 97, 93, 48, 16, 193, 109, 27 | 21372154040160 77219100373969
96 { 97, 94, 98, 48, 17, 190, 182, 20 | 3856468077 -13933819904 -9310371840 0
} 1
97 { 96, 99, 95, 49, 16, 183, 191, 21 | -3856468077 13933819904 9310371840 0
} 1
98 { 99, 96, 100, 49, 17, 180, 84, 22 | 203544324192 -735424338761
-491396741088 0 } 1
99 { 98, 101, 97, 50, 16, 85, 181, 23 | -203544324192 735424338761
491396741088 0 } 1
100 { 101, 98, 92, 50, 17, 82, 4, 202 | 7504813123904 -91086644186895
101 { 100, 93, 99, 46, 16, 5, 83, 203 | -7504813123904 91086644186895
102 { 103, 110, 104, 51, 19, 0, 32, 206 | -18118121083456 -91086644186895
103 { 102, 105, 111, 52, 18, 33, 1, 207 | 18118121083456 91086644186895
7504813123904 0 } 1
104 { 105, 102, 106, 52, 19, 40, 204, 30 | -491396741088 -735424338761
-203544324192 0 } 1
105 { 104, 107, 103, 53, 18, 205, 41, 31 | 491396741088 735424338761
203544324192 0 } 1
106 { 107, 104, 108, 53, 19, 202, 194, 24 | -1234069784640 -4458836594153
107 { 106, 109, 105, 54, 18, 195, 203, 25 | 1234069784640 4458836594153
2979318988800 0 } 1
108 { 109, 106, 110, 54, 19, 192, 94, 26 | -21372154040160 -77219100373969
109 { 108, 111, 107, 55, 18, 95, 193, 27 | 21372154040160 77219100373969
110 { 111, 108, 102, 55, 19, 92, 2, 204 | -7504813123904 -91086644186895
111 { 110, 103, 109, 51, 18, 3, 93, 205 | 7504813123904 91086644186895
112 { 113, 122, 114, 56, 21, 300, 196, 62 | -2229411184640 -1489654644813
-923448946167 0 } 1
113 { 112, 115, 123, 57, 20, 197, 301, 63 | 2229411184640 1489654644813
923448946167 0 } 1
114 { 115, 112, 116, 57, 21, 206, 38, 28 | -9310371840 -13933819904
-3856468077 0 } 1
115 { 114, 117, 113, 58, 20, 39, 207, 29 | 9310371840 13933819904 3856468077
0 } 1
116 { 117, 114, 118, 58, 21, 36, 48, 2 | -51596657814240 -77219100373969
117 { 116, 119, 115, 59, 20, 49, 37, 3 | 51596657814240 77219100373969
118 { 119, 116, 120, 59, 21, 46, 130, 0 | -2979318988800 -4458836594153
1234069784640 0 } 1
119 { 118, 121, 117, 60, 20, 131, 47, 1 | 2979318988800 4458836594153
120 { 121, 118, 122, 60, 21, 128, 212, 34 | -2229411184640 -1489659494400
923448946167 0 } 1
121 { 120, 123, 119, 61, 20, 213, 129, 35 | 2229411184640 1489659494400
-923448946167 0 } 1
122 { 123, 120, 112, 61, 21, 210, 302, 60 | -93211791848491 -62282737107360
-38609546785173 0 } 1
123 { 122, 113, 121, 56, 20, 303, 211, 61 | 93211791848491 62282737107360
124 { 125, 134, 126, 62, 23, 140, 228, 38 | -923448946167 -1489654644813
2229411184640 0 } 1
125 { 124, 127, 135, 63, 22, 229, 141, 39 | 923448946167 1489654644813
-2229411184640 0 } 1
126 { 127, 124, 128, 63, 23, 226, 214, 32 | -93211791848491 -62282581920576
127 { 126, 129, 125, 64, 22, 215, 227, 33 | 93211791848491 62282581920576
128 { 129, 126, 130, 64, 23, 212, 120, 34 | -2229411184640 -1489659494400
923448946167 0 } 1
129 { 128, 131, 127, 65, 22, 121, 213, 35 | 2229411184640 1489659494400
-923448946167 0 } 1
130 { 131, 128, 132, 65, 23, 118, 46, 0 | -2979318988800 -4458836594153
1234069784640 0 } 1
131 { 130, 133, 129, 66, 22, 47, 119, 1 | 2979318988800 4458836594153
132 { 133, 130, 134, 66, 23, 44, 58, 6 | -203544324192 -735424338761
491396741088 0 } 1
133 { 132, 135, 131, 67, 22, 59, 45, 7 | 203544324192 735424338761
-491396741088 0 } 1
134 { 135, 132, 124, 67, 23, 56, 142, 4 | -3856468077 -13933819904 9310371840
0 } 1
135 { 134, 125, 133, 62, 22, 143, 57, 5 | 3856468077 13933819904 -9310371840
0 } 1
136 { 137, 146, 138, 68, 25, 152, 240, 42 | 923448946167 -1489659494400
2229411184640 0 } 1
137 { 136, 139, 147, 69, 24, 241, 153, 43 | -923448946167 1489659494400
138 { 139, 136, 140, 69, 25, 238, 230, 36 | -38609546785173 -62282737107360
93211791848491 0 } 1
139 { 138, 141, 137, 70, 24, 231, 239, 37 | 38609546785173 62282737107360
-93211791848491 0 } 1
140 { 141, 138, 142, 70, 25, 228, 124, 38 | -923448946167 -1489654644813
2229411184640 0 } 1
141 { 140, 143, 139, 71, 24, 125, 229, 39 | 923448946167 1489654644813
142 { 143, 140, 144, 71, 25, 134, 56, 4 | -3856468077 -13933819904 9310371840
0 } 1
143 { 142, 145, 141, 72, 24, 57, 135, 5 | 3856468077 13933819904 -9310371840
0 } 1
144 { 145, 142, 146, 72, 25, 54, 68, 10 | 21372154040160 -77219100373969
145 { 144, 147, 143, 73, 24, 69, 55, 11 | -21372154040160 77219100373969
146 { 147, 144, 136, 73, 25, 66, 154, 8 | 1234069784640 -4458836594153
2979318988800 0 } 1
147 { 146, 137, 145, 68, 24, 155, 67, 9 | -1234069784640 4458836594153
148 { 149, 158, 150, 74, 27, 164, 252, 46 | 2229411184640 -1489654644813
923448946167 0 } 1
149 { 148, 151, 159, 75, 26, 253, 165, 47 | -2229411184640 1489654644813
-923448946167 0 } 1
150 { 151, 148, 152, 75, 27, 250, 242, 40 | 38609546785173 -62282581920576
151 { 150, 153, 149, 76, 26, 243, 251, 41 | -38609546785173 62282581920576
152 { 153, 150, 154, 76, 27, 240, 136, 42 | 923448946167 -1489659494400
2229411184640 0 } 1
153 { 152, 155, 151, 77, 26, 137, 241, 43 | -923448946167 1489659494400
154 { 155, 152, 156, 77, 27, 146, 66, 8 | 1234069784640 -4458836594153
2979318988800 0 } 1
155 { 154, 157, 153, 78, 26, 67, 147, 9 | -1234069784640 4458836594153
156 { 157, 154, 158, 78, 27, 64, 78, 14 | 491396741088 -735424338761
203544324192 0 } 1
157 { 156, 159, 155, 79, 26, 79, 65, 15 | -491396741088 735424338761
-203544324192 0 } 1
158 { 159, 156, 148, 79, 27, 76, 166, 12 | 9310371840 -13933819904 3856468077
0 } 1
159 { 158, 149, 157, 74, 26, 167, 77, 13 | -9310371840 13933819904
-3856468077 0 } 1
160 { 161, 170, 162, 80, 29, 176, 264, 50 | 2229411184640 -1489659494400
-923448946167 0 } 1
161 { 160, 163, 171, 81, 28, 265, 177, 51 | -2229411184640 1489659494400
923448946167 0 } 1
162 { 163, 160, 164, 81, 29, 262, 254, 44 | 93211791848491 -62282737107360
163 { 162, 165, 161, 82, 28, 255, 263, 45 | -93211791848491 62282737107360
164 { 165, 162, 166, 82, 29, 252, 148, 46 | 2229411184640 -1489654644813
923448946167 0 } 1
165 { 164, 167, 163, 83, 28, 149, 253, 47 | -2229411184640 1489654644813
-923448946167 0 } 1
166 { 167, 164, 168, 83, 29, 158, 76, 12 | 9310371840 -13933819904 3856468077
0 } 1
167 { 166, 169, 165, 84, 28, 77, 159, 13 | -9310371840 13933819904
-3856468077 0 } 1
168 { 169, 166, 170, 84, 29, 74, 88, 18 | 51596657814240 -77219100373969
169 { 168, 171, 167, 85, 28, 89, 75, 19 | -51596657814240 77219100373969
170 { 171, 168, 160, 85, 29, 86, 178, 16 | 2979318988800 -4458836594153
171 { 170, 161, 169, 80, 28, 179, 87, 17 | -2979318988800 4458836594153
1234069784640 0 } 1
172 { 173, 182, 174, 86, 31, 188, 276, 54 | 923448946167 -1489654644813
173 { 172, 175, 183, 87, 30, 277, 189, 55 | -923448946167 1489654644813
2229411184640 0 } 1
174 { 175, 172, 176, 87, 31, 274, 266, 48 | 93211791848491 -62282581920576
175 { 174, 177, 173, 88, 30, 267, 275, 49 | -93211791848491 62282581920576
176 { 177, 174, 178, 88, 31, 264, 160, 50 | 2229411184640 -1489659494400
-923448946167 0 } 1
177 { 176, 179, 175, 89, 30, 161, 265, 51 | -2229411184640 1489659494400
923448946167 0 } 1
178 { 179, 176, 180, 89, 31, 170, 86, 16 | 2979318988800 -4458836594153
179 { 178, 181, 177, 90, 30, 87, 171, 17 | -2979318988800 4458836594153
1234069784640 0 } 1
180 { 181, 178, 182, 90, 31, 84, 98, 22 | 203544324192 -735424338761
-491396741088 0 } 1
181 { 180, 183, 179, 91, 30, 99, 85, 23 | -203544324192 735424338761
491396741088 0 } 1
182 { 183, 180, 172, 91, 31, 96, 190, 20 | 3856468077 -13933819904
-9310371840 0 } 1
183 { 182, 173, 181, 86, 30, 191, 97, 21 | -3856468077 13933819904 9310371840
0 } 1
184 { 185, 194, 186, 92, 33, 200, 288, 58 | -923448946167 -1489659494400
185 { 184, 187, 195, 93, 32, 289, 201, 59 | 923448946167 1489659494400
2229411184640 0 } 1
186 { 187, 184, 188, 93, 33, 286, 278, 52 | 38609546785173 -62282737107360
187 { 186, 189, 185, 94, 32, 279, 287, 53 | -38609546785173 62282737107360
188 { 189, 186, 190, 94, 33, 276, 172, 54 | 923448946167 -1489654644813
189 { 188, 191, 187, 95, 32, 173, 277, 55 | -923448946167 1489654644813
2229411184640 0 } 1
190 { 191, 188, 192, 95, 33, 182, 96, 20 | 3856468077 -13933819904
-9310371840 0 } 1
191 { 190, 193, 189, 96, 32, 97, 183, 21 | -3856468077 13933819904 9310371840
0 } 1
192 { 193, 190, 194, 96, 33, 94, 108, 26 | -21372154040160 -77219100373969
193 { 192, 195, 191, 97, 32, 109, 95, 27 | 21372154040160 77219100373969
194 { 195, 192, 184, 97, 33, 106, 202, 24 | -1234069784640 -4458836594153
195 { 194, 185, 193, 92, 32, 203, 107, 25 | 1234069784640 4458836594153
2979318988800 0 } 1
196 { 197, 206, 198, 98, 35, 112, 300, 62 | -2229411184640 -1489654644813
-923448946167 0 } 1
197 { 196, 199, 207, 99, 34, 301, 113, 63 | 2229411184640 1489654644813
923448946167 0 } 1
198 { 199, 196, 200, 99, 35, 298, 290, 56 | -38609546785173 -62282581920576
199 { 198, 201, 197, 100, 34, 291, 299, 57 | 38609546785173 62282581920576
200 { 201, 198, 202, 100, 35, 288, 184, 58 | -923448946167 -1489659494400
201 { 200, 203, 199, 101, 34, 185, 289, 59 | 923448946167 1489659494400
2229411184640 0 } 1
202 { 203, 200, 204, 101, 35, 194, 106, 24 | -1234069784640 -4458836594153
203 { 202, 205, 201, 102, 34, 107, 195, 25 | 1234069784640 4458836594153
2979318988800 0 } 1
204 { 205, 202, 206, 102, 35, 104, 40, 30 | -491396741088 -735424338761
-203544324192 0 } 1
205 { 204, 207, 203, 103, 34, 41, 105, 31 | 491396741088 735424338761
203544324192 0 } 1
206 { 207, 204, 196, 103, 35, 38, 114, 28 | -9310371840 -13933819904
-3856468077 0 } 1
207 { 206, 197, 205, 98, 34, 115, 39, 29 | 9310371840 13933819904 3856468077
0 } 1
208 { 209, 218, 210, 104, 37, 396, 292, 94 | -5235781646305 -1041434655168
-2168729432415 0 } 1
209 { 208, 211, 219, 105, 36, 293, 397, 95 | 5235781646305 1041434655168
2168729432415 0 } 1
210 { 211, 208, 212, 105, 37, 302, 122, 60 | -93211791848491 -62282737107360
211 { 210, 213, 209, 106, 36, 123, 303, 61 | 93211791848491 62282737107360
212 { 213, 210, 214, 106, 37, 120, 128, 34 | -2229411184640 -1489659494400
923448946167 0 } 1
213 { 212, 215, 211, 107, 36, 129, 121, 35 | 2229411184640 1489659494400
-923448946167 0 } 1
214 { 215, 212, 216, 107, 37, 126, 226, 32 | -93211791848491 -62282581920576
215 { 214, 217, 213, 108, 36, 227, 127, 33 | 93211791848491 62282581920576
216 { 217, 214, 218, 108, 37, 224, 308, 66 | -109951414572405 -21870528443584
45543318080715 0 } 1
217 { 216, 219, 215, 109, 36, 309, 225, 67 | 109951414572405 21870528443584
-45543318080715 0 } 1
218 { 219, 216, 208, 109, 37, 306, 398, 92 | -3719072710185 -739763883968
-1540496032215 0 } 1
219 { 218, 209, 217, 104, 36, 399, 307, 93 | 3719072710185 739763883968
1540496032215 0 } 1
220 { 221, 230, 222, 110, 39, 236, 324, 70 | -2168729432415 -1041434655168
5235781646305 0 } 1
221 { 220, 223, 231, 111, 38, 325, 237, 71 | 2168729432415 1041434655168
-5235781646305 0 } 1
222 { 223, 220, 224, 111, 39, 322, 310, 64 | -35419740097 -7045251072
14671390783 0 } 1
223 { 222, 225, 221, 112, 38, 311, 323, 65 | 35419740097 7045251072
-14671390783 0 } 1
224 { 225, 222, 226, 112, 39, 308, 216, 66 | -109951414572405 -21870528443584
225 { 224, 227, 223, 113, 38, 217, 309, 67 | 109951414572405 21870528443584
226 { 227, 224, 228, 113, 39, 214, 126, 32 | -93211791848491 -62282581920576
227 { 226, 229, 225, 114, 38, 127, 215, 33 | 93211791848491 62282581920576
228 { 229, 226, 230, 114, 39, 124, 140, 38 | -923448946167 -1489654644813
2229411184640 0 } 1
229 { 228, 231, 227, 115, 38, 141, 125, 39 | 923448946167 1489654644813
230 { 231, 228, 220, 115, 39, 138, 238, 36 | -38609546785173 -62282737107360
231 { 230, 221, 229, 110, 38, 239, 139, 37 | 38609546785173 62282737107360
232 { 233, 242, 234, 116, 41, 248, 336, 74 | 45543318080715 -21870528443584
109951414572405 0 } 1
233 { 232, 235, 243, 117, 40, 337, 249, 75 | -45543318080715 21870528443584
-109951414572405 0 } 1
234 { 235, 232, 236, 117, 41, 334, 326, 68 | -1540496032215 -739763883968
3719072710185 0 } 1
235 { 234, 237, 233, 118, 40, 327, 335, 69 | 1540496032215 739763883968
-3719072710185 0 } 1
236 { 237, 234, 238, 118, 41, 324, 220, 70 | -2168729432415 -1041434655168
5235781646305 0 } 1
237 { 236, 239, 235, 119, 40, 221, 325, 71 | 2168729432415 1041434655168
238 { 239, 236, 240, 119, 41, 230, 138, 36 | -38609546785173 -62282737107360
239 { 238, 241, 237, 120, 40, 139, 231, 37 | 38609546785173 62282737107360
240 { 241, 238, 242, 120, 41, 136, 152, 42 | 923448946167 -1489659494400
2229411184640 0 } 1
241 { 240, 243, 239, 121, 40, 153, 137, 43 | -923448946167 1489659494400
242 { 243, 240, 232, 121, 41, 150, 250, 40 | 38609546785173 -62282581920576
243 { 242, 233, 241, 116, 40, 251, 151, 41 | -38609546785173 62282581920576
244 { 245, 254, 246, 122, 43, 260, 348, 78 | 5235781646305 -1041434655168
2168729432415 0 } 1
245 { 244, 247, 255, 123, 42, 349, 261, 79 | -5235781646305 1041434655168
246 { 247, 244, 248, 123, 43, 346, 338, 72 | 14671390783 -7045251072
35419740097 0 } 1
247 { 246, 249, 245, 124, 42, 339, 347, 73 | -14671390783 7045251072
-35419740097 0 } 1
248 { 249, 246, 250, 124, 43, 336, 232, 74 | 45543318080715 -21870528443584
249 { 248, 251, 247, 125, 42, 233, 337, 75 | -45543318080715 21870528443584
250 { 251, 248, 252, 125, 43, 242, 150, 40 | 38609546785173 -62282581920576
251 { 250, 253, 249, 126, 42, 151, 243, 41 | -38609546785173 62282581920576
252 { 253, 250, 254, 126, 43, 148, 164, 46 | 2229411184640 -1489654644813
923448946167 0 } 1
253 { 252, 255, 251, 127, 42, 165, 149, 47 | -2229411184640 1489654644813
-923448946167 0 } 1
254 { 255, 252, 244, 127, 43, 162, 262, 44 | 93211791848491 -62282737107360
255 { 254, 245, 253, 122, 42, 263, 163, 45 | -93211791848491 62282737107360
256 { 257, 266, 258, 128, 45, 272, 360, 82 | 109951414572405 -21870528443584
257 { 256, 259, 267, 129, 44, 361, 273, 83 | -109951414572405 21870528443584
258 { 259, 256, 260, 129, 45, 358, 350, 76 | 3719072710185 -739763883968
1540496032215 0 } 1
259 { 258, 261, 257, 130, 44, 351, 359, 77 | -3719072710185 739763883968
260 { 261, 258, 262, 130, 45, 348, 244, 78 | 5235781646305 -1041434655168
2168729432415 0 } 1
261 { 260, 263, 259, 131, 44, 245, 349, 79 | -5235781646305 1041434655168
262 { 263, 260, 264, 131, 45, 254, 162, 44 | 93211791848491 -62282737107360
263 { 262, 265, 261, 132, 44, 163, 255, 45 | -93211791848491 62282737107360
264 { 265, 262, 266, 132, 45, 160, 176, 50 | 2229411184640 -1489659494400
-923448946167 0 } 1
265 { 264, 267, 263, 133, 44, 177, 161, 51 | -2229411184640 1489659494400
923448946167 0 } 1
266 { 267, 264, 256, 133, 45, 174, 274, 48 | 93211791848491 -62282581920576
267 { 266, 257, 265, 128, 44, 275, 175, 49 | -93211791848491 62282581920576
268 { 269, 278, 270, 134, 47, 284, 372, 86 | 2168729432415 -1041434655168
269 { 268, 271, 279, 135, 46, 373, 285, 87 | -2168729432415 1041434655168
5235781646305 0 } 1
270 { 271, 268, 272, 135, 47, 370, 362, 80 | 35419740097 -7045251072
-14671390783 0 } 1
271 { 270, 273, 269, 136, 46, 363, 371, 81 | -35419740097 7045251072
14671390783 0 } 1
272 { 273, 270, 274, 136, 47, 360, 256, 82 | 109951414572405 -21870528443584
273 { 272, 275, 271, 137, 46, 257, 361, 83 | -109951414572405 21870528443584
274 { 275, 272, 276, 137, 47, 266, 174, 48 | 93211791848491 -62282581920576
275 { 274, 277, 273, 138, 46, 175, 267, 49 | -93211791848491 62282581920576
276 { 277, 274, 278, 138, 47, 172, 188, 54 | 923448946167 -1489654644813
277 { 276, 279, 275, 139, 46, 189, 173, 55 | -923448946167 1489654644813
2229411184640 0 } 1
278 { 279, 276, 268, 139, 47, 186, 286, 52 | 38609546785173 -62282737107360
279 { 278, 269, 277, 134, 46, 287, 187, 53 | -38609546785173 62282737107360
280 { 281, 290, 282, 140, 49, 296, 384, 90 | -45543318080715 -21870528443584
281 { 280, 283, 291, 141, 48, 385, 297, 91 | 45543318080715 21870528443584
282 { 283, 280, 284, 141, 49, 382, 374, 84 | 1540496032215 -739763883968
283 { 282, 285, 281, 142, 48, 375, 383, 85 | -1540496032215 739763883968
3719072710185 0 } 1
284 { 285, 282, 286, 142, 49, 372, 268, 86 | 2168729432415 -1041434655168
285 { 284, 287, 283, 143, 48, 269, 373, 87 | -2168729432415 1041434655168
5235781646305 0 } 1
286 { 287, 284, 288, 143, 49, 278, 186, 52 | 38609546785173 -62282737107360
287 { 286, 289, 285, 144, 48, 187, 279, 53 | -38609546785173 62282737107360
288 { 289, 286, 290, 144, 49, 184, 200, 58 | -923448946167 -1489659494400
289 { 288, 291, 287, 145, 48, 201, 185, 59 | 923448946167 1489659494400
2229411184640 0 } 1
290 { 291, 288, 280, 145, 49, 198, 298, 56 | -38609546785173 -62282581920576
291 { 290, 281, 289, 140, 48, 299, 199, 57 | 38609546785173 62282581920576
292 { 293, 302, 294, 146, 51, 208, 396, 94 | -5235781646305 -1041434655168
293 { 292, 295, 303, 147, 50, 397, 209, 95 | 5235781646305 1041434655168
2168729432415 0 } 1
294 { 295, 292, 296, 147, 51, 394, 386, 88 | -14671390783 -7045251072
-35419740097 0 } 1
295 { 294, 297, 293, 148, 50, 387, 395, 89 | 14671390783 7045251072
35419740097 0 } 1
296 { 297, 294, 298, 148, 51, 384, 280, 90 | -45543318080715 -21870528443584
297 { 296, 299, 295, 149, 50, 281, 385, 91 | 45543318080715 21870528443584
298 { 299, 296, 300, 149, 51, 290, 198, 56 | -38609546785173 -62282581920576
299 { 298, 301, 297, 150, 50, 199, 291, 57 | 38609546785173 62282581920576
300 { 301, 298, 302, 150, 51, 196, 112, 62 | -2229411184640 -1489654644813
-923448946167 0 } 1
301 { 300, 303, 299, 151, 50, 113, 197, 63 | 2229411184640 1489654644813
923448946167 0 } 1
302 { 303, 300, 292, 151, 51, 122, 210, 60 | -93211791848491 -62282737107360
303 { 302, 293, 301, 146, 50, 211, 123, 61 | 93211791848491 62282737107360
304 { 305, 314, 306, 152, 53, 492, 388, 126 | -35419740097 7045251072
-14671390783 0 } 1
305 { 304, 307, 315, 153, 52, 389, 493, 127 | 35419740097 -7045251072
14671390783 0 } 1
306 { 307, 304, 308, 153, 53, 398, 218, 92 | -3719072710185 -739763883968
307 { 306, 309, 305, 154, 52, 219, 399, 93 | 3719072710185 739763883968
1540496032215 0 } 1
308 { 309, 306, 310, 154, 53, 216, 224, 66 | -109951414572405 -21870528443584
309 { 308, 311, 307, 155, 52, 225, 217, 67 | 109951414572405 21870528443584
310 { 311, 308, 312, 155, 53, 222, 322, 64 | -35419740097 -7045251072
14671390783 0 } 1
311 { 310, 313, 309, 156, 52, 323, 223, 65 | 35419740097 7045251072
-14671390783 0 } 1
312 { 313, 310, 314, 156, 53, 320, 404, 98 | -3719072710185 739763883968
1540496032215 0 } 1
313 { 312, 315, 311, 157, 52, 405, 321, 99 | 3719072710185 -739763883968
314 { 315, 312, 304, 157, 53, 402, 494, 124 | -109951414572405 21870528443584
315 { 314, 305, 313, 152, 52, 495, 403, 125 | 109951414572405 -21870528443584
316 { 317, 326, 318, 158, 55, 332, 420, 102 | -14671390783 7045251072
35419740097 0 } 1
317 { 316, 319, 327, 159, 54, 421, 333, 103 | 14671390783 -7045251072
-35419740097 0 } 1
318 { 319, 316, 320, 159, 55, 418, 406, 96 | -5235781646305 1041434655168
2168729432415 0 } 1
319 { 318, 321, 317, 160, 54, 407, 419, 97 | 5235781646305 -1041434655168
320 { 321, 318, 322, 160, 55, 404, 312, 98 | -3719072710185 739763883968
1540496032215 0 } 1
321 { 320, 323, 319, 161, 54, 313, 405, 99 | 3719072710185 -739763883968
322 { 323, 320, 324, 161, 55, 310, 222, 64 | -35419740097 -7045251072
14671390783 0 } 1
323 { 322, 325, 321, 162, 54, 223, 311, 65 | 35419740097 7045251072
-14671390783 0 } 1
324 { 325, 322, 326, 162, 55, 220, 236, 70 | -2168729432415 -1041434655168
5235781646305 0 } 1
325 { 324, 327, 323, 163, 54, 237, 221, 71 | 2168729432415 1041434655168
326 { 327, 324, 316, 163, 55, 234, 334, 68 | -1540496032215 -739763883968
3719072710185 0 } 1
327 { 326, 317, 325, 158, 54, 335, 235, 69 | 1540496032215 739763883968
328 { 329, 338, 330, 164, 57, 344, 432, 106 | 1540496032215 739763883968
3719072710185 0 } 1
329 { 328, 331, 339, 165, 56, 433, 345, 107 | -1540496032215 -739763883968
330 { 331, 328, 332, 165, 57, 430, 422, 100 | -45543318080715 21870528443584
331 { 330, 333, 329, 166, 56, 423, 431, 101 | 45543318080715 -21870528443584
332 { 333, 330, 334, 166, 57, 420, 316, 102 | -14671390783 7045251072
35419740097 0 } 1
333 { 332, 335, 331, 167, 56, 317, 421, 103 | 14671390783 -7045251072
-35419740097 0 } 1
334 { 335, 332, 336, 167, 57, 326, 234, 68 | -1540496032215 -739763883968
3719072710185 0 } 1
335 { 334, 337, 333, 168, 56, 235, 327, 69 | 1540496032215 739763883968
336 { 337, 334, 338, 168, 57, 232, 248, 74 | 45543318080715 -21870528443584
337 { 336, 339, 335, 169, 56, 249, 233, 75 | -45543318080715 21870528443584
338 { 339, 336, 328, 169, 57, 246, 346, 72 | 14671390783 -7045251072
35419740097 0 } 1
339 { 338, 329, 337, 164, 56, 347, 247, 73 | -14671390783 7045251072
-35419740097 0 } 1
340 { 341, 350, 342, 170, 59, 356, 444, 110 | 35419740097 7045251072
14671390783 0 } 1
341 { 340, 343, 351, 171, 58, 445, 357, 111 | -35419740097 -7045251072
-14671390783 0 } 1
342 { 343, 340, 344, 171, 59, 442, 434, 104 | 2168729432415 1041434655168
5235781646305 0 } 1
343 { 342, 345, 341, 172, 58, 435, 443, 105 | -2168729432415 -1041434655168
344 { 345, 342, 346, 172, 59, 432, 328, 106 | 1540496032215 739763883968
3719072710185 0 } 1
345 { 344, 347, 343, 173, 58, 329, 433, 107 | -1540496032215 -739763883968
346 { 347, 344, 348, 173, 59, 338, 246, 72 | 14671390783 -7045251072
35419740097 0 } 1
347 { 346, 349, 345, 174, 58, 247, 339, 73 | -14671390783 7045251072
-35419740097 0 } 1
348 { 349, 346, 350, 174, 59, 244, 260, 78 | 5235781646305 -1041434655168
2168729432415 0 } 1
349 { 348, 351, 347, 175, 58, 261, 245, 79 | -5235781646305 1041434655168
350 { 351, 348, 340, 175, 59, 258, 358, 76 | 3719072710185 -739763883968
1540496032215 0 } 1
351 { 350, 341, 349, 170, 58, 359, 259, 77 | -3719072710185 739763883968
352 { 353, 362, 354, 176, 61, 368, 456, 114 | 3719072710185 739763883968
353 { 352, 355, 363, 177, 60, 457, 369, 115 | -3719072710185 -739763883968
1540496032215 0 } 1
354 { 355, 352, 356, 177, 61, 454, 446, 108 | 109951414572405 21870528443584
355 { 354, 357, 353, 178, 60, 447, 455, 109 | -109951414572405
-21870528443584 -45543318080715 0 } 1
356 { 357, 354, 358, 178, 61, 444, 340, 110 | 35419740097 7045251072
14671390783 0 } 1
357 { 356, 359, 355, 179, 60, 341, 445, 111 | -35419740097 -7045251072
-14671390783 0 } 1
358 { 359, 356, 360, 179, 61, 350, 258, 76 | 3719072710185 -739763883968
1540496032215 0 } 1
359 { 358, 361, 357, 180, 60, 259, 351, 77 | -3719072710185 739763883968
360 { 361, 358, 362, 180, 61, 256, 272, 82 | 109951414572405 -21870528443584
361 { 360, 363, 359, 181, 60, 273, 257, 83 | -109951414572405 21870528443584
362 { 363, 360, 352, 181, 61, 270, 370, 80 | 35419740097 -7045251072
-14671390783 0 } 1
363 { 362, 353, 361, 176, 60, 371, 271, 81 | -35419740097 7045251072
14671390783 0 } 1
364 { 365, 374, 366, 182, 63, 380, 468, 118 | 14671390783 7045251072
-35419740097 0 } 1
365 { 364, 367, 375, 183, 62, 469, 381, 119 | -14671390783 -7045251072
35419740097 0 } 1
366 { 367, 364, 368, 183, 63, 466, 458, 112 | 5235781646305 1041434655168
367 { 366, 369, 365, 184, 62, 459, 467, 113 | -5235781646305 -1041434655168
2168729432415 0 } 1
368 { 369, 366, 370, 184, 63, 456, 352, 114 | 3719072710185 739763883968
369 { 368, 371, 367, 185, 62, 353, 457, 115 | -3719072710185 -739763883968
1540496032215 0 } 1
370 { 371, 368, 372, 185, 63, 362, 270, 80 | 35419740097 -7045251072
-14671390783 0 } 1
371 { 370, 373, 369, 186, 62, 271, 363, 81 | -35419740097 7045251072
14671390783 0 } 1
372 { 373, 370, 374, 186, 63, 268, 284, 86 | 2168729432415 -1041434655168
373 { 372, 375, 371, 187, 62, 285, 269, 87 | -2168729432415 1041434655168
5235781646305 0 } 1
374 { 375, 372, 364, 187, 63, 282, 382, 84 | 1540496032215 -739763883968
375 { 374, 365, 373, 182, 62, 383, 283, 85 | -1540496032215 739763883968
3719072710185 0 } 1
376 { 377, 386, 378, 188, 65, 392, 480, 122 | -1540496032215 739763883968
377 { 376, 379, 387, 189, 64, 481, 393, 123 | 1540496032215 -739763883968
3719072710185 0 } 1
378 { 379, 376, 380, 189, 65, 478, 470, 116 | 45543318080715 21870528443584
379 { 378, 381, 377, 190, 64, 471, 479, 117 | -45543318080715 -21870528443584
380 { 381, 378, 382, 190, 65, 468, 364, 118 | 14671390783 7045251072
-35419740097 0 } 1
381 { 380, 383, 379, 191, 64, 365, 469, 119 | -14671390783 -7045251072
35419740097 0 } 1
382 { 383, 380, 384, 191, 65, 374, 282, 84 | 1540496032215 -739763883968
383 { 382, 385, 381, 192, 64, 283, 375, 85 | -1540496032215 739763883968
3719072710185 0 } 1
384 { 385, 382, 386, 192, 65, 280, 296, 90 | -45543318080715 -21870528443584
385 { 384, 387, 383, 193, 64, 297, 281, 91 | 45543318080715 21870528443584
386 { 387, 384, 376, 193, 65, 294, 394, 88 | -14671390783 -7045251072
-35419740097 0 } 1
387 { 386, 377, 385, 188, 64, 395, 295, 89 | 14671390783 7045251072
35419740097 0 } 1
388 { 389, 398, 390, 194, 67, 304, 492, 126 | -35419740097 7045251072
-14671390783 0 } 1
389 { 388, 391, 399, 195, 66, 493, 305, 127 | 35419740097 -7045251072
14671390783 0 } 1
390 { 391, 388, 392, 195, 67, 490, 482, 120 | -2168729432415 1041434655168
391 { 390, 393, 389, 196, 66, 483, 491, 121 | 2168729432415 -1041434655168
5235781646305 0 } 1
392 { 393, 390, 394, 196, 67, 480, 376, 122 | -1540496032215 739763883968
393 { 392, 395, 391, 197, 66, 377, 481, 123 | 1540496032215 -739763883968
3719072710185 0 } 1
394 { 395, 392, 396, 197, 67, 386, 294, 88 | -14671390783 -7045251072
-35419740097 0 } 1
395 { 394, 397, 393, 198, 66, 295, 387, 89 | 14671390783 7045251072
35419740097 0 } 1
396 { 397, 394, 398, 198, 67, 292, 208, 94 | -5235781646305 -1041434655168
397 { 396, 399, 395, 199, 66, 209, 293, 95 | 5235781646305 1041434655168
2168729432415 0 } 1
398 { 399, 396, 388, 199, 67, 218, 306, 92 | -3719072710185 -739763883968
399 { 398, 389, 397, 194, 66, 307, 219, 93 | 3719072710185 739763883968
1540496032215 0 } 1
400 { 401, 410, 402, 200, 69, 588, 484, 158 | -93211791848491 62282581920576
401 { 400, 403, 411, 201, 68, 485, 589, 159 | 93211791848491 -62282581920576
402 { 403, 400, 404, 201, 69, 494, 314, 124 | -109951414572405 21870528443584
403 { 402, 405, 401, 202, 68, 315, 495, 125 | 109951414572405 -21870528443584
404 { 405, 402, 406, 202, 69, 312, 320, 98 | -3719072710185 739763883968
1540496032215 0 } 1
405 { 404, 407, 403, 203, 68, 321, 313, 99 | 3719072710185 -739763883968
406 { 407, 404, 408, 203, 69, 318, 418, 96 | -5235781646305 1041434655168
2168729432415 0 } 1
407 { 406, 409, 405, 204, 68, 419, 319, 97 | 5235781646305 -1041434655168
408 { 409, 406, 410, 204, 69, 416, 500, 130 | -93211791848491 62282737107360
409 { 408, 411, 407, 205, 68, 501, 417, 131 | 93211791848491 -62282737107360
410 { 411, 408, 400, 205, 69, 498, 590, 156 | -2229411184640 1489659494400
-923448946167 0 } 1
411 { 410, 401, 409, 200, 68, 591, 499, 157 | 2229411184640 -1489659494400
923448946167 0 } 1
412 { 413, 422, 414, 206, 71, 428, 516, 134 | -38609546785173 62282581920576
413 { 412, 415, 423, 207, 70, 517, 429, 135 | 38609546785173 -62282581920576
414 { 415, 412, 416, 207, 71, 514, 502, 128 | -2229411184640 1489654644813
923448946167 0 } 1
415 { 414, 417, 413, 208, 70, 503, 515, 129 | 2229411184640 -1489654644813
-923448946167 0 } 1
416 { 417, 414, 418, 208, 71, 500, 408, 130 | -93211791848491 62282737107360
417 { 416, 419, 415, 209, 70, 409, 501, 131 | 93211791848491 -62282737107360
418 { 419, 416, 420, 209, 71, 406, 318, 96 | -5235781646305 1041434655168
2168729432415 0 } 1
419 { 418, 421, 417, 210, 70, 319, 407, 97 | 5235781646305 -1041434655168
420 { 421, 418, 422, 210, 71, 316, 332, 102 | -14671390783 7045251072
35419740097 0 } 1
421 { 420, 423, 419, 211, 70, 333, 317, 103 | 14671390783 -7045251072
-35419740097 0 } 1
422 { 423, 420, 412, 211, 71, 330, 430, 100 | -45543318080715 21870528443584
423 { 422, 413, 421, 206, 70, 431, 331, 101 | 45543318080715 -21870528443584
424 { 425, 434, 426, 212, 73, 440, 528, 138 | 38609546785173 62282737107360
425 { 424, 427, 435, 213, 72, 529, 441, 139 | -38609546785173 -62282737107360
426 { 427, 424, 428, 213, 73, 526, 518, 132 | -923448946167 1489659494400
2229411184640 0 } 1
427 { 426, 429, 425, 214, 72, 519, 527, 133 | 923448946167 -1489659494400
428 { 429, 426, 430, 214, 73, 516, 412, 134 | -38609546785173 62282581920576
429 { 428, 431, 427, 215, 72, 413, 517, 135 | 38609546785173 -62282581920576
430 { 431, 428, 432, 215, 73, 422, 330, 100 | -45543318080715 21870528443584
431 { 430, 433, 429, 216, 72, 331, 423, 101 | 45543318080715 -21870528443584
432 { 433, 430, 434, 216, 73, 328, 344, 106 | 1540496032215 739763883968
3719072710185 0 } 1
433 { 432, 435, 431, 217, 72, 345, 329, 107 | -1540496032215 -739763883968
434 { 435, 432, 424, 217, 73, 342, 442, 104 | 2168729432415 1041434655168
5235781646305 0 } 1
435 { 434, 425, 433, 212, 72, 443, 343, 105 | -2168729432415 -1041434655168
436 { 437, 446, 438, 218, 75, 452, 540, 142 | 93211791848491 62282581920576
437 { 436, 439, 447, 219, 74, 541, 453, 143 | -93211791848491 -62282581920576
438 { 439, 436, 440, 219, 75, 538, 530, 136 | 923448946167 1489654644813
2229411184640 0 } 1
439 { 438, 441, 437, 220, 74, 531, 539, 137 | -923448946167 -1489654644813
440 { 441, 438, 442, 220, 75, 528, 424, 138 | 38609546785173 62282737107360
441 { 440, 443, 439, 221, 74, 425, 529, 139 | -38609546785173 -62282737107360
442 { 443, 440, 444, 221, 75, 434, 342, 104 | 2168729432415 1041434655168
5235781646305 0 } 1
443 { 442, 445, 441, 222, 74, 343, 435, 105 | -2168729432415 -1041434655168
444 { 445, 442, 446, 222, 75, 340, 356, 110 | 35419740097 7045251072
14671390783 0 } 1
445 { 444, 447, 443, 223, 74, 357, 341, 111 | -35419740097 -7045251072
-14671390783 0 } 1
446 { 447, 444, 436, 223, 75, 354, 454, 108 | 109951414572405 21870528443584
447 { 446, 437, 445, 218, 74, 455, 355, 109 | -109951414572405
448 { 449, 458, 450, 224, 77, 464, 552, 146 | 93211791848491 62282737107360
449 { 448, 451, 459, 225, 76, 553, 465, 147 | -93211791848491 -62282737107360
450 { 451, 448, 452, 225, 77, 550, 542, 140 | 2229411184640 1489659494400
923448946167 0 } 1
451 { 450, 453, 449, 226, 76, 543, 551, 141 | -2229411184640 -1489659494400
-923448946167 0 } 1
452 { 453, 450, 454, 226, 77, 540, 436, 142 | 93211791848491 62282581920576
453 { 452, 455, 451, 227, 76, 437, 541, 143 | -93211791848491 -62282581920576
454 { 455, 452, 456, 227, 77, 446, 354, 108 | 109951414572405 21870528443584
455 { 454, 457, 453, 228, 76, 355, 447, 109 | -109951414572405
456 { 457, 454, 458, 228, 77, 352, 368, 114 | 3719072710185 739763883968
457 { 456, 459, 455, 229, 76, 369, 353, 115 | -3719072710185 -739763883968
1540496032215 0 } 1
458 { 459, 456, 448, 229, 77, 366, 466, 112 | 5235781646305 1041434655168
459 { 458, 449, 457, 224, 76, 467, 367, 113 | -5235781646305 -1041434655168
2168729432415 0 } 1
460 { 461, 470, 462, 230, 79, 476, 564, 150 | 38609546785173 62282581920576
461 { 460, 463, 471, 231, 78, 565, 477, 151 | -38609546785173 -62282581920576
462 { 463, 460, 464, 231, 79, 562, 554, 144 | 2229411184640 1489654644813
-923448946167 0 } 1
463 { 462, 465, 461, 232, 78, 555, 563, 145 | -2229411184640 -1489654644813
923448946167 0 } 1
464 { 465, 462, 466, 232, 79, 552, 448, 146 | 93211791848491 62282737107360
465 { 464, 467, 463, 233, 78, 449, 553, 147 | -93211791848491 -62282737107360
466 { 467, 464, 468, 233, 79, 458, 366, 112 | 5235781646305 1041434655168
467 { 466, 469, 465, 234, 78, 367, 459, 113 | -5235781646305 -1041434655168
2168729432415 0 } 1
468 { 469, 466, 470, 234, 79, 364, 380, 118 | 14671390783 7045251072
-35419740097 0 } 1
469 { 468, 471, 467, 235, 78, 381, 365, 119 | -14671390783 -7045251072
35419740097 0 } 1
470 { 471, 468, 460, 235, 79, 378, 478, 116 | 45543318080715 21870528443584
471 { 470, 461, 469, 230, 78, 479, 379, 117 | -45543318080715 -21870528443584
472 { 473, 482, 474, 236, 81, 488, 576, 154 | -38609546785173 62282737107360
473 { 472, 475, 483, 237, 80, 577, 489, 155 | 38609546785173 -62282737107360
474 { 475, 472, 476, 237, 81, 574, 566, 148 | 923448946167 1489659494400
475 { 474, 477, 473, 238, 80, 567, 575, 149 | -923448946167 -1489659494400
2229411184640 0 } 1
476 { 477, 474, 478, 238, 81, 564, 460, 150 | 38609546785173 62282581920576
477 { 476, 479, 475, 239, 80, 461, 565, 151 | -38609546785173 -62282581920576
478 { 479, 476, 480, 239, 81, 470, 378, 116 | 45543318080715 21870528443584
479 { 478, 481, 477, 240, 80, 379, 471, 117 | -45543318080715 -21870528443584
480 { 481, 478, 482, 240, 81, 376, 392, 122 | -1540496032215 739763883968
481 { 480, 483, 479, 241, 80, 393, 377, 123 | 1540496032215 -739763883968
3719072710185 0 } 1
482 { 483, 480, 472, 241, 81, 390, 490, 120 | -2168729432415 1041434655168
483 { 482, 473, 481, 236, 80, 491, 391, 121 | 2168729432415 -1041434655168
5235781646305 0 } 1
484 { 485, 494, 486, 242, 83, 400, 588, 158 | -93211791848491 62282581920576
485 { 484, 487, 495, 243, 82, 589, 401, 159 | 93211791848491 -62282581920576
486 { 487, 484, 488, 243, 83, 586, 578, 152 | -923448946167 1489654644813
487 { 486, 489, 485, 244, 82, 579, 587, 153 | 923448946167 -1489654644813
2229411184640 0 } 1
488 { 489, 486, 490, 244, 83, 576, 472, 154 | -38609546785173 62282737107360
489 { 488, 491, 487, 245, 82, 473, 577, 155 | 38609546785173 -62282737107360
490 { 491, 488, 492, 245, 83, 482, 390, 120 | -2168729432415 1041434655168
491 { 490, 493, 489, 246, 82, 391, 483, 121 | 2168729432415 -1041434655168
5235781646305 0 } 1
492 { 493, 490, 494, 246, 83, 388, 304, 126 | -35419740097 7045251072
-14671390783 0 } 1
493 { 492, 495, 491, 247, 82, 305, 389, 127 | 35419740097 -7045251072
14671390783 0 } 1
494 { 495, 492, 484, 247, 83, 314, 402, 124 | -109951414572405 21870528443584
495 { 494, 485, 493, 242, 82, 403, 315, 125 | 109951414572405 -21870528443584
496 { 497, 506, 498, 248, 85, 668, 580, 190 | -2979318988800 4458836594153
497 { 496, 499, 507, 249, 84, 581, 669, 191 | 2979318988800 -4458836594153
1234069784640 0 } 1
498 { 499, 496, 500, 249, 85, 590, 410, 156 | -2229411184640 1489659494400
-923448946167 0 } 1
499 { 498, 501, 497, 250, 84, 411, 591, 157 | 2229411184640 -1489659494400
923448946167 0 } 1
500 { 501, 498, 502, 250, 85, 408, 416, 130 | -93211791848491 62282737107360
501 { 500, 503, 499, 251, 84, 417, 409, 131 | 93211791848491 -62282737107360
502 { 503, 500, 504, 251, 85, 414, 514, 128 | -2229411184640 1489654644813
923448946167 0 } 1
503 { 502, 505, 501, 252, 84, 515, 415, 129 | 2229411184640 -1489654644813
-923448946167 0 } 1
504 { 505, 502, 506, 252, 85, 512, 596, 162 | -9310371840 13933819904
3856468077 0 } 1
505 { 504, 507, 503, 253, 84, 597, 513, 163 | 9310371840 -13933819904
-3856468077 0 } 1
506 { 507, 504, 496, 253, 85, 594, 670, 188 | -51596657814240 77219100373969
507 { 506, 497, 505, 248, 84, 671, 595, 189 | 51596657814240 -77219100373969
508 { 509, 518, 510, 254, 87, 524, 608, 166 | -1234069784640 4458836594153
2979318988800 0 } 1
509 { 508, 511, 519, 255, 86, 609, 525, 167 | 1234069784640 -4458836594153
510 { 511, 508, 512, 255, 87, 606, 598, 160 | -491396741088 735424338761
203544324192 0 } 1
511 { 510, 513, 509, 256, 86, 599, 607, 161 | 491396741088 -735424338761
-203544324192 0 } 1
512 { 513, 510, 514, 256, 87, 596, 504, 162 | -9310371840 13933819904
3856468077 0 } 1
513 { 512, 515, 511, 257, 86, 505, 597, 163 | 9310371840 -13933819904
-3856468077 0 } 1
514 { 515, 512, 516, 257, 87, 502, 414, 128 | -2229411184640 1489654644813
923448946167 0 } 1
515 { 514, 517, 513, 258, 86, 415, 503, 129 | 2229411184640 -1489654644813
-923448946167 0 } 1
516 { 517, 514, 518, 258, 87, 412, 428, 134 | -38609546785173 62282581920576
517 { 516, 519, 515, 259, 86, 429, 413, 135 | 38609546785173 -62282581920576
518 { 519, 516, 508, 259, 87, 426, 526, 132 | -923448946167 1489659494400
2229411184640 0 } 1
519 { 518, 509, 517, 254, 86, 527, 427, 133 | 923448946167 -1489659494400
520 { 521, 530, 522, 260, 89, 536, 618, 170 | 3856468077 13933819904
9310371840 0 } 1
521 { 520, 523, 531, 261, 88, 619, 537, 171 | -3856468077 -13933819904
-9310371840 0 } 1
522 { 523, 520, 524, 261, 89, 616, 610, 164 | -21372154040160 77219100373969
523 { 522, 525, 521, 262, 88, 611, 617, 165 | 21372154040160 -77219100373969
524 { 525, 522, 526, 262, 89, 608, 508, 166 | -1234069784640 4458836594153
2979318988800 0 } 1
525 { 524, 527, 523, 263, 88, 509, 609, 167 | 1234069784640 -4458836594153
526 { 527, 524, 528, 263, 89, 518, 426, 132 | -923448946167 1489659494400
2229411184640 0 } 1
527 { 526, 529, 525, 264, 88, 427, 519, 133 | 923448946167 -1489659494400
528 { 529, 526, 530, 264, 89, 424, 440, 138 | 38609546785173 62282737107360
529 { 528, 531, 527, 265, 88, 441, 425, 139 | -38609546785173 -62282737107360
530 { 531, 528, 520, 265, 89, 438, 538, 136 | 923448946167 1489654644813
2229411184640 0 } 1
531 { 530, 521, 529, 260, 88, 539, 439, 137 | -923448946167 -1489654644813
532 { 533, 542, 534, 266, 91, 548, 628, 174 | 2979318988800 4458836594153
1234069784640 0 } 1
533 { 532, 535, 543, 267, 90, 629, 549, 175 | -2979318988800 -4458836594153
534 { 535, 532, 536, 267, 91, 626, 620, 168 | 203544324192 735424338761
491396741088 0 } 1
535 { 534, 537, 533, 268, 90, 621, 627, 169 | -203544324192 -735424338761
-491396741088 0 } 1
536 { 537, 534, 538, 268, 91, 618, 520, 170 | 3856468077 13933819904
9310371840 0 } 1
537 { 536, 539, 535, 269, 90, 521, 619, 171 | -3856468077 -13933819904
-9310371840 0 } 1
538 { 539, 536, 540, 269, 91, 530, 438, 136 | 923448946167 1489654644813
2229411184640 0 } 1
539 { 538, 541, 537, 270, 90, 439, 531, 137 | -923448946167 -1489654644813
540 { 541, 538, 542, 270, 91, 436, 452, 142 | 93211791848491 62282581920576
541 { 540, 543, 539, 271, 90, 453, 437, 143 | -93211791848491 -62282581920576
542 { 543, 540, 532, 271, 91, 450, 550, 140 | 2229411184640 1489659494400
923448946167 0 } 1
543 { 542, 533, 541, 266, 90, 551, 451, 141 | -2229411184640 -1489659494400
-923448946167 0 } 1
544 { 545, 554, 546, 272, 93, 560, 638, 178 | 9310371840 13933819904
-3856468077 0 } 1
545 { 544, 547, 555, 273, 92, 639, 561, 179 | -9310371840 -13933819904
3856468077 0 } 1
546 { 547, 544, 548, 273, 93, 636, 630, 172 | 51596657814240 77219100373969
547 { 546, 549, 545, 274, 92, 631, 637, 173 | -51596657814240 -77219100373969
548 { 549, 546, 550, 274, 93, 628, 532, 174 | 2979318988800 4458836594153
1234069784640 0 } 1
549 { 548, 551, 547, 275, 92, 533, 629, 175 | -2979318988800 -4458836594153
550 { 551, 548, 552, 275, 93, 542, 450, 140 | 2229411184640 1489659494400
923448946167 0 } 1
551 { 550, 553, 549, 276, 92, 451, 543, 141 | -2229411184640 -1489659494400
-923448946167 0 } 1
552 { 553, 550, 554, 276, 93, 448, 464, 146 | 93211791848491 62282737107360
553 { 552, 555, 551, 277, 92, 465, 449, 147 | -93211791848491 -62282737107360
554 { 555, 552, 544, 277, 93, 462, 562, 144 | 2229411184640 1489654644813
-923448946167 0 } 1
555 { 554, 545, 553, 272, 92, 563, 463, 145 | -2229411184640 -1489654644813
923448946167 0 } 1
556 { 557, 566, 558, 278, 95, 572, 648, 182 | 1234069784640 4458836594153
557 { 556, 559, 567, 279, 94, 649, 573, 183 | -1234069784640 -4458836594153
2979318988800 0 } 1
558 { 559, 556, 560, 279, 95, 646, 640, 176 | 491396741088 735424338761
-203544324192 0 } 1
559 { 558, 561, 557, 280, 94, 641, 647, 177 | -491396741088 -735424338761
203544324192 0 } 1
560 { 561, 558, 562, 280, 95, 638, 544, 178 | 9310371840 13933819904
-3856468077 0 } 1
561 { 560, 563, 559, 281, 94, 545, 639, 179 | -9310371840 -13933819904
3856468077 0 } 1
562 { 563, 560, 564, 281, 95, 554, 462, 144 | 2229411184640 1489654644813
-923448946167 0 } 1
563 { 562, 565, 561, 282, 94, 463, 555, 145 | -2229411184640 -1489654644813
923448946167 0 } 1
564 { 565, 562, 566, 282, 95, 460, 476, 150 | 38609546785173 62282581920576
565 { 564, 567, 563, 283, 94, 477, 461, 151 | -38609546785173 -62282581920576
566 { 567, 564, 556, 283, 95, 474, 574, 148 | 923448946167 1489659494400
567 { 566, 557, 565, 278, 94, 575, 475, 149 | -923448946167 -1489659494400
2229411184640 0 } 1
568 { 569, 578, 570, 284, 97, 584, 658, 186 | -3856468077 13933819904
-9310371840 0 } 1
569 { 568, 571, 579, 285, 96, 659, 585, 187 | 3856468077 -13933819904
9310371840 0 } 1
570 { 571, 568, 572, 285, 97, 656, 650, 180 | 21372154040160 77219100373969
571 { 570, 573, 569, 286, 96, 651, 657, 181 | -21372154040160 -77219100373969
572 { 573, 570, 574, 286, 97, 648, 556, 182 | 1234069784640 4458836594153
573 { 572, 575, 571, 287, 96, 557, 649, 183 | -1234069784640 -4458836594153
2979318988800 0 } 1
574 { 575, 572, 576, 287, 97, 566, 474, 148 | 923448946167 1489659494400
575 { 574, 577, 573, 288, 96, 475, 567, 149 | -923448946167 -1489659494400
2229411184640 0 } 1
576 { 577, 574, 578, 288, 97, 472, 488, 154 | -38609546785173 62282737107360
577 { 576, 579, 575, 289, 96, 489, 473, 155 | 38609546785173 -62282737107360
578 { 579, 576, 568, 289, 97, 486, 586, 152 | -923448946167 1489654644813
579 { 578, 569, 577, 284, 96, 587, 487, 153 | 923448946167 -1489654644813
2229411184640 0 } 1
580 { 581, 590, 582, 290, 99, 496, 668, 190 | -2979318988800 4458836594153
581 { 580, 583, 591, 291, 98, 669, 497, 191 | 2979318988800 -4458836594153
1234069784640 0 } 1
582 { 583, 580, 584, 291, 99, 666, 660, 184 | -203544324192 735424338761
-491396741088 0 } 1
583 { 582, 585, 581, 292, 98, 661, 667, 185 | 203544324192 -735424338761
491396741088 0 } 1
584 { 585, 582, 586, 292, 99, 658, 568, 186 | -3856468077 13933819904
-9310371840 0 } 1
585 { 584, 587, 583, 293, 98, 569, 659, 187 | 3856468077 -13933819904
9310371840 0 } 1
586 { 587, 584, 588, 293, 99, 578, 486, 152 | -923448946167 1489654644813
587 { 586, 589, 585, 294, 98, 487, 579, 153 | 923448946167 -1489654644813
2229411184640 0 } 1
588 { 589, 586, 590, 294, 99, 484, 400, 158 | -93211791848491 62282581920576
589 { 588, 591, 587, 295, 98, 401, 485, 159 | 93211791848491 -62282581920576
590 { 591, 588, 580, 295, 99, 410, 498, 156 | -2229411184640 1489659494400
-923448946167 0 } 1
591 { 590, 581, 589, 290, 98, 499, 411, 157 | 2229411184640 -1489659494400
923448946167 0 } 1
592 { 593, 600, 594, 296, 101, 16, 662, 222 | -18118121083456 91086644186895
593 { 592, 595, 601, 297, 100, 663, 17, 223 | 18118121083456 -91086644186895
7504813123904 0 } 1
594 { 595, 592, 596, 297, 101, 670, 506, 188 | -51596657814240 77219100373969
595 { 594, 597, 593, 298, 100, 507, 671, 189 | 51596657814240 -77219100373969
596 { 597, 594, 598, 298, 101, 504, 512, 162 | -9310371840 13933819904
3856468077 0 } 1
597 { 596, 599, 595, 299, 100, 513, 505, 163 | 9310371840 -13933819904
-3856468077 0 } 1
598 { 599, 596, 600, 299, 101, 510, 606, 160 | -491396741088 735424338761
203544324192 0 } 1
599 { 598, 601, 597, 300, 100, 607, 511, 161 | 491396741088 -735424338761
-203544324192 0 } 1
600 { 601, 598, 592, 300, 101, 604, 18, 208 | -18118121083456 91086644186895
7504813123904 0 } 1
601 { 600, 593, 599, 296, 100, 19, 605, 209 | 18118121083456 -91086644186895
602 { 603, 610, 604, 301, 103, 614, 20, 210 | -7504813123904 91086644186895
603 { 602, 605, 611, 302, 102, 21, 615, 211 | 7504813123904 -91086644186895
604 { 605, 602, 606, 302, 103, 18, 600, 208 | -18118121083456 91086644186895
7504813123904 0 } 1
605 { 604, 607, 603, 303, 102, 601, 19, 209 | 18118121083456 -91086644186895
606 { 607, 604, 608, 303, 103, 598, 510, 160 | -491396741088 735424338761
203544324192 0 } 1
607 { 606, 609, 605, 304, 102, 511, 599, 161 | 491396741088 -735424338761
-203544324192 0 } 1
608 { 609, 606, 610, 304, 103, 508, 524, 166 | -1234069784640 4458836594153
2979318988800 0 } 1
609 { 608, 611, 607, 305, 102, 525, 509, 167 | 1234069784640 -4458836594153
610 { 611, 608, 602, 305, 103, 522, 616, 164 | -21372154040160 77219100373969
611 { 610, 603, 609, 301, 102, 617, 523, 165 | 21372154040160 -77219100373969
612 { 613, 620, 614, 306, 105, 624, 22, 212 | 7504813123904 91086644186895
613 { 612, 615, 621, 307, 104, 23, 625, 213 | -7504813123904 -91086644186895
614 { 615, 612, 616, 307, 105, 20, 602, 210 | -7504813123904 91086644186895
615 { 614, 617, 613, 308, 104, 603, 21, 211 | 7504813123904 -91086644186895
616 { 617, 614, 618, 308, 105, 610, 522, 164 | -21372154040160 77219100373969
617 { 616, 619, 615, 309, 104, 523, 611, 165 | 21372154040160 -77219100373969
618 { 619, 616, 620, 309, 105, 520, 536, 170 | 3856468077 13933819904
9310371840 0 } 1
619 { 618, 621, 617, 310, 104, 537, 521, 171 | -3856468077 -13933819904
-9310371840 0 } 1
620 { 621, 618, 612, 310, 105, 534, 626, 168 | 203544324192 735424338761
491396741088 0 } 1
621 { 620, 613, 619, 306, 104, 627, 535, 169 | -203544324192 -735424338761
-491396741088 0 } 1
622 { 623, 630, 624, 311, 107, 634, 24, 214 | 18118121083456 91086644186895
7504813123904 0 } 1
623 { 622, 625, 631, 312, 106, 25, 635, 215 | -18118121083456 -91086644186895
624 { 625, 622, 626, 312, 107, 22, 612, 212 | 7504813123904 91086644186895
625 { 624, 627, 623, 313, 106, 613, 23, 213 | -7504813123904 -91086644186895
626 { 627, 624, 628, 313, 107, 620, 534, 168 | 203544324192 735424338761
491396741088 0 } 1
627 { 626, 629, 625, 314, 106, 535, 621, 169 | -203544324192 -735424338761
-491396741088 0 } 1
628 { 629, 626, 630, 314, 107, 532, 548, 174 | 2979318988800 4458836594153
1234069784640 0 } 1
629 { 628, 631, 627, 315, 106, 549, 533, 175 | -2979318988800 -4458836594153
630 { 631, 628, 622, 315, 107, 546, 636, 172 | 51596657814240 77219100373969
631 { 630, 623, 629, 311, 106, 637, 547, 173 | -51596657814240
-77219100373969 -21372154040160 0 } 1
632 { 633, 640, 634, 316, 109, 644, 26, 216 | 18118121083456 91086644186895
633 { 632, 635, 641, 317, 108, 27, 645, 217 | -18118121083456 -91086644186895
7504813123904 0 } 1
634 { 635, 632, 636, 317, 109, 24, 622, 214 | 18118121083456 91086644186895
7504813123904 0 } 1
635 { 634, 637, 633, 318, 108, 623, 25, 215 | -18118121083456 -91086644186895
636 { 637, 634, 638, 318, 109, 630, 546, 172 | 51596657814240 77219100373969
637 { 636, 639, 635, 319, 108, 547, 631, 173 | -51596657814240
638 { 639, 636, 640, 319, 109, 544, 560, 178 | 9310371840 13933819904
-3856468077 0 } 1
639 { 638, 641, 637, 320, 108, 561, 545, 179 | -9310371840 -13933819904
3856468077 0 } 1
640 { 641, 638, 632, 320, 109, 558, 646, 176 | 491396741088 735424338761
-203544324192 0 } 1
641 { 640, 633, 639, 316, 108, 647, 559, 177 | -491396741088 -735424338761
203544324192 0 } 1
642 { 643, 650, 644, 321, 111, 654, 28, 218 | 7504813123904 91086644186895
643 { 642, 645, 651, 322, 110, 29, 655, 219 | -7504813123904 -91086644186895
644 { 645, 642, 646, 322, 111, 26, 632, 216 | 18118121083456 91086644186895
645 { 644, 647, 643, 323, 110, 633, 27, 217 | -18118121083456 -91086644186895
7504813123904 0 } 1
646 { 647, 644, 648, 323, 111, 640, 558, 176 | 491396741088 735424338761
-203544324192 0 } 1
647 { 646, 649, 645, 324, 110, 559, 641, 177 | -491396741088 -735424338761
203544324192 0 } 1
648 { 649, 646, 650, 324, 111, 556, 572, 182 | 1234069784640 4458836594153
649 { 648, 651, 647, 325, 110, 573, 557, 183 | -1234069784640 -4458836594153
2979318988800 0 } 1
650 { 651, 648, 642, 325, 111, 570, 656, 180 | 21372154040160 77219100373969
651 { 650, 643, 649, 321, 110, 657, 571, 181 | -21372154040160
-77219100373969 51596657814240 0 } 1
652 { 653, 660, 654, 326, 113, 664, 30, 220 | -7504813123904 91086644186895
653 { 652, 655, 661, 327, 112, 31, 665, 221 | 7504813123904 -91086644186895
654 { 655, 652, 656, 327, 113, 28, 642, 218 | 7504813123904 91086644186895
655 { 654, 657, 653, 328, 112, 643, 29, 219 | -7504813123904 -91086644186895
656 { 657, 654, 658, 328, 113, 650, 570, 180 | 21372154040160 77219100373969
657 { 656, 659, 655, 329, 112, 571, 651, 181 | -21372154040160
658 { 659, 656, 660, 329, 113, 568, 584, 186 | -3856468077 13933819904
-9310371840 0 } 1
659 { 658, 661, 657, 330, 112, 585, 569, 187 | 3856468077 -13933819904
9310371840 0 } 1
660 { 661, 658, 652, 330, 113, 582, 666, 184 | -203544324192 735424338761
-491396741088 0 } 1
661 { 660, 653, 659, 326, 112, 667, 583, 185 | 203544324192 -735424338761
491396741088 0 } 1
662 { 663, 670, 664, 331, 115, 592, 16, 222 | -18118121083456 91086644186895
663 { 662, 665, 671, 332, 114, 17, 593, 223 | 18118121083456 -91086644186895
7504813123904 0 } 1
664 { 665, 662, 666, 332, 115, 30, 652, 220 | -7504813123904 91086644186895
665 { 664, 667, 663, 333, 114, 653, 31, 221 | 7504813123904 -91086644186895
666 { 667, 664, 668, 333, 115, 660, 582, 184 | -203544324192 735424338761
-491396741088 0 } 1
667 { 666, 669, 665, 334, 114, 583, 661, 185 | 203544324192 -735424338761
491396741088 0 } 1
668 { 669, 666, 670, 334, 115, 580, 496, 190 | -2979318988800 4458836594153
669 { 668, 671, 667, 335, 114, 497, 581, 191 | 2979318988800 -4458836594153
1234069784640 0 } 1
670 { 671, 668, 662, 335, 115, 506, 594, 188 | -51596657814240 77219100373969
671 { 670, 663, 669, 331, 114, 595, 507, 189 | 51596657814240 -77219100373969
0 { 0, 1 , , , 0 } 0
1 { 0, 0 , , , 1 } 1
2 { 1, 17 , , , 0 } 0
3 { 1, 16 , , , 1 } 1
4 { 2, 33 , , , 0 } 0
5 { 2, 32 , , , 1 } 1
6 { 3, 43 , , , 0 } 0
7 { 3, 42 , , , 1 } 1
8 { 4, 53 , , , 0 } 0
9 { 4, 52 , , , 1 } 1
10 { 5, 63 , , , 0 } 0
11 { 5, 62 , , , 1 } 1
12 { 6, 73 , , , 0 } 0
13 { 6, 72 , , , 1 } 1
14 { 7, 83 , , , 0 } 0
15 { 7, 82 , , , 1 } 1
16 { 8, 93 , , , 0 } 0
17 { 8, 92 , , , 1 } 1
18 { 9, 103 , , , 0 } 0
19 { 9, 102 , , , 1 } 1
20 { 10, 113 , , , 0 } 0
21 { 10, 112 , , , 1 } 1
22 { 11, 125 , , , 0 } 0
23 { 11, 124 , , , 1 } 1
24 { 12, 137 , , , 0 } 0
25 { 12, 136 , , , 1 } 1
26 { 13, 149 , , , 0 } 0
27 { 13, 148 , , , 1 } 1
28 { 14, 161 , , , 0 } 0
29 { 14, 160 , , , 1 } 1
30 { 15, 173 , , , 0 } 0
31 { 15, 172 , , , 1 } 1
32 { 16, 185 , , , 0 } 0
33 { 16, 184 , , , 1 } 1
34 { 17, 197 , , , 0 } 0
35 { 17, 196 , , , 1 } 1
36 { 18, 209 , , , 0 } 0
37 { 18, 208 , , , 1 } 1
38 { 19, 221 , , , 0 } 0
39 { 19, 220 , , , 1 } 1
40 { 20, 233 , , , 0 } 0
41 { 20, 232 , , , 1 } 1
42 { 21, 245 , , , 0 } 0
43 { 21, 244 , , , 1 } 1
44 { 22, 257 , , , 0 } 0
45 { 22, 256 , , , 1 } 1
46 { 23, 269 , , , 0 } 0
47 { 23, 268 , , , 1 } 1
48 { 24, 281 , , , 0 } 0
49 { 24, 280 , , , 1 } 1
50 { 25, 293 , , , 0 } 0
51 { 25, 292 , , , 1 } 1
52 { 26, 305 , , , 0 } 0
53 { 26, 304 , , , 1 } 1
54 { 27, 317 , , , 0 } 0
55 { 27, 316 , , , 1 } 1
56 { 28, 329 , , , 0 } 0
57 { 28, 328 , , , 1 } 1
58 { 29, 341 , , , 0 } 0
59 { 29, 340 , , , 1 } 1
60 { 30, 353 , , , 0 } 0
61 { 30, 352 , , , 1 } 1
62 { 31, 365 , , , 0 } 0
63 { 31, 364 , , , 1 } 1
64 { 32, 377 , , , 0 } 0
65 { 32, 376 , , , 1 } 1
66 { 33, 389 , , , 0 } 0
67 { 33, 388 , , , 1 } 1
68 { 34, 401 , , , 0 } 0
69 { 34, 400 , , , 1 } 1
70 { 35, 413 , , , 0 } 0
71 { 35, 412 , , , 1 } 1
72 { 36, 425 , , , 0 } 0
73 { 36, 424 , , , 1 } 1
74 { 37, 437 , , , 0 } 0
75 { 37, 436 , , , 1 } 1
76 { 38, 449 , , , 0 } 0
77 { 38, 448 , , , 1 } 1
78 { 39, 461 , , , 0 } 0
79 { 39, 460 , , , 1 } 1
80 { 40, 473 , , , 0 } 0
81 { 40, 472 , , , 1 } 1
82 { 41, 485 , , , 0 } 0
83 { 41, 484 , , , 1 } 1
84 { 42, 497 , , , 0 } 0
85 { 42, 496 , , , 1 } 1
86 { 43, 509 , , , 0 } 0
87 { 43, 508 , , , 1 } 1
88 { 44, 521 , , , 0 } 0
89 { 44, 520 , , , 1 } 1
90 { 45, 533 , , , 0 } 0
91 { 45, 532 , , , 1 } 1
92 { 46, 545 , , , 0 } 0
93 { 46, 544 , , , 1 } 1
94 { 47, 557 , , , 0 } 0
95 { 47, 556 , , , 1 } 1
96 { 48, 569 , , , 0 } 0
97 { 48, 568 , , , 1 } 1
98 { 49, 581 , , , 0 } 0
99 { 49, 580 , , , 1 } 1
100 { 50, 593 , , , 0 } 0
101 { 50, 592 , , , 1 } 1
102 { 51, 603 , , , 0 } 0
103 { 51, 602 , , , 1 } 1
104 { 52, 613 , , , 0 } 0
105 { 52, 612 , , , 1 } 1
106 { 53, 623 , , , 0 } 0
107 { 53, 622 , , , 1 } 1
108 { 54, 633 , , , 0 } 0
109 { 54, 632 , , , 1 } 1
110 { 55, 643 , , , 0 } 0
111 { 55, 642 , , , 1 } 1
112 { 56, 653 , , , 0 } 0
113 { 56, 652 , , , 1 } 1
114 { 57, 663 , , , 0 } 0
115 { 57, 662 , , , 1 } 1
/* end Selective Nef complex */
