cgal-discuss - Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation
  • To:
  • Subject: Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation
  • Date: Mon, 15 Jun 2009 10:46:18 +0200
  • Organization: Buf Compagnie
Hi Peter,
I'm sorry that I was confused about the nef3 and off format.
The model is simply generated as the intersection of 5 identical torus of same dimensions.
This is how I do the intersection :
For each model (torus), I first convert it from my geometry to Polyhedron_3 structure, then create a Nef_3 from this polyhedron (checking that it is valid and closed and that the result is valid and simple).
Then I compute the intersection of this newly created Nef with the Nef i got at the previous step, and check that the resulting nef is valid and simple.
But here is something is just noticed by testing : if I take my 5 toruses, and compute the intersections "by hand", two-by-two, i am getting the same crash even sooner, when I intersect the last torus with the previous results...
And, if i compute directly the intersection of the 5 toruses with the sphere (i.e. the problem for which I contacted you in the first place) it works just fine !
I am getting really confused with this... because this mean that the problem only occurs when I convert my result Nefs back to Polyhedron then to my geometry, and then do the opposite process to get back to nef structure.
Indeed I have another question... If the real problem is self-intersections in the original models, is there a way provided by CGAL to detect them in a Nef_3 or in a Polyhedron_3 ?
Please tell me if you need more information. Thank you so much for your help !
Laure
Peter Hachenberger wrote:
Hi Laure,
the model seems to have lots of self-intersections, or consists of several
separate volumes. When I convert it to an off files (the one you gave me is
a nef3 file) and then construct it facet by facet with our troubleshoot constructor,
I get 16 volumes. I admit that this can also stem from the floating-point errors introduced in the conversion into an off file, but I don't think so. For me, it is most
important to find out, how you generated the file. Did you generate it with the CGAL Nef3
code? What where the base models/files?
Peter
-----Laure Guicherd
wrote: -----
To:
Date: 06/12/2009 06:03PM
Subject: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation
Hi everyone,
First i would like to thank you for all the great work.
I'm having a problem with boolean operations on Nef_polyhedron_3.
I'm using a Simple_cartesian<Gmpq> kernel and so far everything
was ok,
it really works fine with a lot of models :)
But I'm in trouble with a model that seems to be problematic, that
passes every test with success (the Polyhedron converted from my
geometry is both "valid" and "closed", and the Nef polyhedron
converted
from this polyhedron is "valid" and "simple".)
So I can get a valid nef, but when i try to compute boolean
operations
with a simple sphere (attached as sphere.off), the program crashes
on :
terminate called after throwing an instance of
'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: itl != it->second.end()
File:
/net/rnd/src/CGAL-3.4/linux-x86_64-gcc-4.1.1/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1088
Abort
I must admit I am really stuck here, as the model seems closed, valid
and with no self-intersections.
The strangest thing is that it works fine with a cube, or most of the
time if the sphere intersects the model differently.
I'm really sorry that the model is really big, unfortunately I was
unable to reproduce the problem with a simpler one, so here is the
path
to the .off file (that is too big to be attached for the mailing
list) :
http://dl.free.fr/rXNVUQVqg
Am i missing something ? Or do you think there is a problem with the
model topology ? And if there is, how can i detect it in the
future to
prevent crashes ?
Any help would be really appreciated, thank you !
Best regards,
Laure Guicherd
-- You are currently subscribed to cgal-discuss.
Selective Nef Complex
standard
vertices 58
halfedges 336
facets 224
volumes 2
shalfedges 672
shalfloops 0
sfaces 116
0 { 0 7, 0 15, 0 1, -2 | 0 5 0 1 } 1
1 { 8 15, 16 31, 2 3, -2 | 0 -5 0 1 } 1
2 { 16 20, 32 41, 4 5, -2 | 8025465 19375168 0 4194304 } 1
3 { 21 25, 42 51, 6 7, -2 | 11349703 38750336 -11349703 8388608 } 1
4 { 26 30, 52 61, 8 9, -2 | 0 19375168 -8025465 4194304 } 1
5 { 31 35, 62 71, 10 11, -2 | -11349703 38750336 -11349703 8388608 } 1
6 { 36 40, 72 81, 12 13, -2 | -8025465 19375168 0 4194304 } 1
7 { 41 45, 82 91, 14 15, -2 | -11349703 38750336 11349703 8388608 } 1
8 { 46 50, 92 101, 16 17, -2 | 0 19375168 8025465 4194304 } 1
9 { 51 55, 102 111, 18 19, -2 | 11349703 38750336 11349703 8388608 } 1
10 { 56 61, 112 123, 20 21, -2 | 463409 463409 0 131072 } 1
11 { 62 67, 124 135, 22 23, -2 | 327680 463409 -327680 131072 } 1
12 { 68 73, 136 147, 24 25, -2 | 0 463409 -463409 131072 } 1
13 { 74 79, 148 159, 26 27, -2 | -327680 463409 -327680 131072 } 1
14 { 80 85, 160 171, 28 29, -2 | -463409 463409 0 131072 } 1
15 { 86 91, 172 183, 30 31, -2 | -327680 463409 327680 131072 } 1
16 { 92 97, 184 195, 32 33, -2 | 0 463409 463409 131072 } 1
17 { 98 103, 196 207, 34 35, -2 | 327680 463409 327680 131072 } 1
18 { 104 109, 208 219, 36 37, -2 | 19375168 8025465 0 4194304 } 1
19 { 110 115, 220 231, 38 39, -2 | 13700317 8025465 -13700317
4194304 } 1
20 { 116 121, 232 243, 40 41, -2 | 0 8025465 -19375168 4194304 } 1
21 { 122 127, 244 255, 42 43, -2 | -13700317 8025465 -13700317
4194304 } 1
22 { 128 133, 256 267, 44 45, -2 | -19375168 8025465 0 4194304 } 1
23 { 134 139, 268 279, 46 47, -2 | -13700317 8025465 13700317
4194304 } 1
24 { 140 145, 280 291, 48 49, -2 | 0 8025465 19375168 4194304 } 1
25 { 146 151, 292 303, 50 51, -2 | 13700317 8025465 13700317
4194304 } 1
26 { 152 157, 304 315, 52 53, -2 | 5 0 0 1 } 1
27 { 158 163, 316 327, 54 55, -2 | 463409 0 -463409 131072 } 1
28 { 164 169, 328 339, 56 57, -2 | 0 0 -5 1 } 1
29 { 170 175, 340 351, 58 59, -2 | -463409 0 -463409 131072 } 1
30 { 176 181, 352 363, 60 61, -2 | -5 0 0 1 } 1
31 { 182 187, 364 375, 62 63, -2 | -463409 0 463409 131072 } 1
32 { 188 193, 376 387, 64 65, -2 | 0 0 5 1 } 1
33 { 194 199, 388 399, 66 67, -2 | 463409 0 463409 131072 } 1
34 { 200 205, 400 411, 68 69, -2 | 19375168 -8025465 0 4194304 } 1
35 { 206 211, 412 423, 70 71, -2 | 13700317 -8025465 -13700317
4194304 } 1
36 { 212 217, 424 435, 72 73, -2 | 0 -8025465 -19375168 4194304 } 1
37 { 218 223, 436 447, 74 75, -2 | -13700317 -8025465 -13700317
4194304 } 1
38 { 224 229, 448 459, 76 77, -2 | -19375168 -8025465 0 4194304 } 1
39 { 230 235, 460 471, 78 79, -2 | -13700317 -8025465 13700317
4194304 } 1
40 { 236 241, 472 483, 80 81, -2 | 0 -8025465 19375168 4194304 } 1
41 { 242 247, 484 495, 82 83, -2 | 13700317 -8025465 13700317
4194304 } 1
42 { 248 253, 496 507, 84 85, -2 | 463409 -463409 0 131072 } 1
43 { 254 259, 508 519, 86 87, -2 | 327680 -463409 -327680 131072 } 1
44 { 260 265, 520 531, 88 89, -2 | 0 -463409 -463409 131072 } 1
45 { 266 271, 532 543, 90 91, -2 | -327680 -463409 -327680 131072 } 1
46 { 272 277, 544 555, 92 93, -2 | -463409 -463409 0 131072 } 1
47 { 278 283, 556 567, 94 95, -2 | -327680 -463409 327680 131072 } 1
48 { 284 289, 568 579, 96 97, -2 | 0 -463409 463409 131072 } 1
49 { 290 295, 580 591, 98 99, -2 | 327680 -463409 327680 131072 } 1
50 { 296 300, 592 601, 100 101, -2 | 8025465 -19375168 0 4194304 } 1
51 { 301 305, 602 611, 102 103, -2 | 11349703 -38750336 -11349703
8388608 } 1
52 { 306 310, 612 621, 104 105, -2 | 0 -19375168 -8025465 4194304 } 1
53 { 311 315, 622 631, 106 107, -2 | -11349703 -38750336 -11349703
8388608 } 1
54 { 316 320, 632 641, 108 109, -2 | -8025465 -19375168 0 4194304 } 1
55 { 321 325, 642 651, 110 111, -2 | -11349703 -38750336 11349703
8388608 } 1
56 { 326 330, 652 661, 112 113, -2 | 0 -19375168 8025465 4194304 } 1
57 { 331 335, 662 671, 114 115, -2 | 11349703 -38750336 11349703
8388608 } 1
0 { 17, 0, 0 0 | 8025465 -1596352 0 1 } 1
1 { 51, 0, 0 1 | 11349703 -3192704 11349703 1 } 1
2 { 46, 0, 0 3 | 0 -1596352 8025465 1 } 1
3 { 41, 0, 0 5 | -11349703 -3192704 11349703 1 } 1
4 { 36, 0, 0 7 | -8025465 -1596352 0 1 } 1
5 { 31, 0, 0 9 | -11349703 -3192704 -11349703 1 } 1
6 { 26, 0, 0 11 | 0 -1596352 -8025465 1 } 1
7 { 21, 0, 0 13 | 11349703 -3192704 -11349703 1 } 1
8 { 332, 1, 0 16 | 11349703 3192704 11349703 1 } 1
9 { 296, 1, 0 17 | 8025465 1596352 0 1 } 1
10 { 302, 1, 0 19 | 11349703 3192704 -11349703 1 } 1
11 { 307, 1, 0 21 | 0 1596352 -8025465 1 } 1
12 { 312, 1, 0 23 | -11349703 3192704 -11349703 1 } 1
13 { 317, 1, 0 25 | -8025465 1596352 0 1 } 1
14 { 322, 1, 0 27 | -11349703 3192704 11349703 1 } 1
15 { 327, 1, 0 29 | 0 1596352 8025465 1 } 1
16 { 52, 2, 0 32 | -4701227 0 11349703 1 } 1
17 { 0, 2, 0 33 | -8025465 1596352 0 1 } 1
18 { 25, 2, 0 35 | -4701227 0 -11349703 1 } 1
19 { 58, 2, 0 37 | 6803623 -4546080 0 1 } 1
20 { 103, 2, 0 39 | 492059 -909216 2097152 1 } 1
21 { 7, 3, 0 42 | -11349703 3192704 11349703 1 } 1
22 { 30, 3, 0 43 | -11349703 0 -4701227 1 } 1
23 { 66, 3, 0 45 | 9621817 -9092160 -9621817 1 } 1
24 { 59, 3, 0 47 | 18308473 -9092160 11349703 1 } 1
25 { 18, 3, 0 49 | 4701227 0 11349703 1 } 1
26 { 6, 4, 0 52 | 0 1596352 8025465 1 } 1
27 { 35, 4, 0 53 | -11349703 0 4701227 1 } 1
28 { 72, 4, 0 55 | 0 -4546080 -6803623 1 } 1
29 { 67, 4, 0 57 | 2097152 -909216 -492059 1 } 1
30 { 22, 4, 0 59 | 11349703 0 4701227 1 } 1
31 { 5, 5, 0 62 | 11349703 3192704 11349703 1 } 1
32 { 40, 5, 0 63 | -4701227 0 11349703 1 } 1
33 { 78, 5, 0 65 | -9621817 -9092160 -9621817 1 } 1
34 { 73, 5, 0 67 | 11349703 -9092160 -18308473 1 } 1
35 { 27, 5, 0 69 | 11349703 0 -4701227 1 } 1
36 { 4, 6, 0 72 | 8025465 1596352 0 1 } 1
37 { 45, 6, 0 73 | 4701227 0 11349703 1 } 1
38 { 84, 6, 0 75 | -6803623 -4546080 0 1 } 1
39 { 79, 6, 0 77 | -492059 -909216 -2097152 1 } 1
40 { 32, 6, 0 79 | 4701227 0 -11349703 1 } 1
41 { 3, 7, 0 82 | 11349703 3192704 -11349703 1 } 1
42 { 50, 7, 0 83 | 11349703 0 4701227 1 } 1
43 { 90, 7, 0 85 | -9621817 -9092160 9621817 1 } 1
44 { 85, 7, 0 87 | -18308473 -9092160 -11349703 1 } 1
45 { 37, 7, 0 89 | -4701227 0 -11349703 1 } 1
46 { 2, 8, 0 92 | 0 1596352 -8025465 1 } 1
47 { 55, 8, 0 93 | 11349703 0 -4701227 1 } 1
48 { 96, 8, 0 95 | 0 -4546080 6803623 1 } 1
49 { 91, 8, 0 97 | -2097152 -909216 492059 1 } 1
50 { 42, 8, 0 99 | -11349703 0 -4701227 1 } 1
51 { 1, 9, 0 102 | -11349703 3192704 -11349703 1 } 1
52 { 16, 9, 0 103 | 4701227 0 -11349703 1 } 1
53 { 102, 9, 0 105 | 9621817 -9092160 9621817 1 } 1
54 { 97, 9, 0 107 | -11349703 -9092160 18308473 1 } 1
55 { 47, 9, 0 109 | -11349703 0 4701227 1 } 1
56 { 151, 10, 0 112 | -1128771 -6803623 13700317 1 } 1
57 { 98, 10, 0 113 | -135729 0 327680 1 } 1
58 { 19, 10, 0 115 | -6803623 4546080 0 1 } 1
59 { 24, 10, 0 117 | -18308473 9092160 -11349703 1 } 1
60 { 65, 10, 0 119 | -135729 0 -327680 1 } 1
61 { 106, 10, 0 121 | 4546080 -6803623 0 1 } 1
62 { 71, 11, 0 124 | -327680 0 -135729 1 } 1
63 { 114, 11, 0 125 | 3214557 -6803623 -3214557 1 } 1
64 { 107, 11, 0 127 | 8889408 -6803623 10485760 1 } 1
65 { 60, 11, 0 129 | 135729 0 327680 1 } 1
66 { 23, 11, 0 131 | -9621817 9092160 9621817 1 } 1
67 { 29, 11, 0 133 | -2097152 909216 492059 1 } 1
68 { 77, 12, 0 136 | -327680 0 135729 1 } 1
69 { 120, 12, 0 137 | 0 -6803623 -4546080 1 } 1
70 { 115, 12, 0 139 | 13700317 -6803623 1128771 1 } 1
71 { 62, 12, 0 141 | 327680 0 135729 1 } 1
72 { 28, 12, 0 143 | 0 4546080 6803623 1 } 1
73 { 34, 12, 0 145 | -11349703 9092160 18308473 1 } 1
74 { 83, 13, 0 148 | -135729 0 327680 1 } 1
75 { 126, 13, 0 149 | -3214557 -6803623 -3214557 1 } 1
76 { 121, 13, 0 151 | 10485760 -6803623 -8889408 1 } 1
77 { 68, 13, 0 153 | 327680 0 -135729 1 } 1
78 { 33, 13, 0 155 | 9621817 9092160 9621817 1 } 1
79 { 39, 13, 0 157 | 492059 909216 2097152 1 } 1
80 { 89, 14, 0 160 | 135729 0 327680 1 } 1
81 { 132, 14, 0 161 | -4546080 -6803623 0 1 } 1
82 { 127, 14, 0 163 | 1128771 -6803623 -13700317 1 } 1
83 { 74, 14, 0 165 | 135729 0 -327680 1 } 1
84 { 38, 14, 0 167 | 6803623 4546080 0 1 } 1
85 { 44, 14, 0 169 | 18308473 9092160 11349703 1 } 1
86 { 95, 15, 0 172 | 327680 0 135729 1 } 1
87 { 138, 15, 0 173 | -3214557 -6803623 3214557 1 } 1
88 { 133, 15, 0 175 | -8889408 -6803623 -10485760 1 } 1
89 { 80, 15, 0 177 | -135729 0 -327680 1 } 1
90 { 43, 15, 0 179 | 9621817 9092160 -9621817 1 } 1
91 { 49, 15, 0 181 | 2097152 909216 -492059 1 } 1
92 { 101, 16, 0 184 | 327680 0 -135729 1 } 1
93 { 144, 16, 0 185 | 0 -6803623 4546080 1 } 1
94 { 139, 16, 0 187 | -13700317 -6803623 -1128771 1 } 1
95 { 86, 16, 0 189 | -327680 0 -135729 1 } 1
96 { 48, 16, 0 191 | 0 4546080 -6803623 1 } 1
97 { 54, 16, 0 193 | 11349703 9092160 -18308473 1 } 1
98 { 57, 17, 0 196 | 135729 0 -327680 1 } 1
99 { 150, 17, 0 197 | 3214557 -6803623 3214557 1 } 1
100 { 145, 17, 0 199 | -10485760 -6803623 8889408 1 } 1
101 { 92, 17, 0 201 | -327680 0 135729 1 } 1
102 { 53, 17, 0 203 | -9621817 9092160 -9621817 1 } 1
103 { 20, 17, 0 205 | -492059 909216 -2097152 1 } 1
104 { 199, 18, 0 208 | -4546080 -8025465 14829088 1 } 1
105 { 146, 18, 0 209 | -5674851 0 13700317 1 } 1
106 { 61, 18, 0 211 | -4546080 6803623 0 1 } 1
107 { 64, 18, 0 213 | -8889408 6803623 -10485760 1 } 1
108 { 113, 18, 0 215 | -5674851 0 -13700317 1 } 1
109 { 154, 18, 0 217 | 1596352 -8025465 0 1 } 1
110 { 119, 19, 0 220 | -13700317 0 -5674851 1 } 1
111 { 162, 19, 0 221 | 53751 -382165 -53751 1 } 1
112 { 155, 19, 0 223 | 7271203 -8025465 13700317 1 } 1
113 { 108, 19, 0 225 | 5674851 0 13700317 1 } 1
114 { 63, 19, 0 227 | -3214557 6803623 3214557 1 } 1
115 { 70, 19, 0 229 | -13700317 6803623 -1128771 1 } 1
116 { 125, 20, 0 232 | -13700317 0 5674851 1 } 1
117 { 168, 20, 0 233 | 0 -8025465 -1596352 1 } 1
118 { 163, 20, 0 235 | 14829088 -8025465 4546080 1 } 1
119 { 110, 20, 0 237 | 13700317 0 5674851 1 } 1
120 { 69, 20, 0 239 | 0 6803623 4546080 1 } 1
121 { 76, 20, 0 241 | -10485760 6803623 8889408 1 } 1
122 { 131, 21, 0 244 | -5674851 0 13700317 1 } 1
123 { 174, 21, 0 245 | -53751 -382165 -53751 1 } 1
124 { 169, 21, 0 247 | 13700317 -8025465 -7271203 1 } 1
125 { 116, 21, 0 249 | 13700317 0 -5674851 1 } 1
126 { 75, 21, 0 251 | 3214557 6803623 3214557 1 } 1
127 { 82, 21, 0 253 | -1128771 6803623 13700317 1 } 1
128 { 137, 22, 0 256 | 5674851 0 13700317 1 } 1
129 { 180, 22, 0 257 | -1596352 -8025465 0 1 } 1
130 { 175, 22, 0 259 | 4546080 -8025465 -14829088 1 } 1
131 { 122, 22, 0 261 | 5674851 0 -13700317 1 } 1
132 { 81, 22, 0 263 | 4546080 6803623 0 1 } 1
133 { 88, 22, 0 265 | 8889408 6803623 10485760 1 } 1
134 { 143, 23, 0 268 | 13700317 0 5674851 1 } 1
135 { 186, 23, 0 269 | -53751 -382165 53751 1 } 1
136 { 181, 23, 0 271 | -7271203 -8025465 -13700317 1 } 1
137 { 128, 23, 0 273 | -5674851 0 -13700317 1 } 1
138 { 87, 23, 0 275 | 3214557 6803623 -3214557 1 } 1
139 { 94, 23, 0 277 | 13700317 6803623 1128771 1 } 1
140 { 149, 24, 0 280 | 13700317 0 -5674851 1 } 1
141 { 192, 24, 0 281 | 0 -8025465 1596352 1 } 1
142 { 187, 24, 0 283 | -14829088 -8025465 -4546080 1 } 1
143 { 134, 24, 0 285 | -13700317 0 -5674851 1 } 1
144 { 93, 24, 0 287 | 0 6803623 -4546080 1 } 1
145 { 100, 24, 0 289 | 10485760 6803623 -8889408 1 } 1
146 { 105, 25, 0 292 | 5674851 0 -13700317 1 } 1
147 { 198, 25, 0 293 | 53751 -382165 53751 1 } 1
148 { 193, 25, 0 295 | -13700317 -8025465 7271203 1 } 1
149 { 140, 25, 0 297 | -13700317 0 5674851 1 } 1
150 { 99, 25, 0 299 | -3214557 6803623 -3214557 1 } 1
151 { 56, 25, 0 301 | 1128771 6803623 -13700317 1 } 1
152 { 247, 26, 0 304 | -7271203 -8025465 13700317 1 } 1
153 { 194, 26, 0 305 | -191951 0 463409 1 } 1
154 { 109, 26, 0 307 | -1596352 8025465 0 1 } 1
155 { 112, 26, 0 309 | -7271203 8025465 -13700317 1 } 1
156 { 161, 26, 0 311 | -191951 0 -463409 1 } 1
157 { 202, 26, 0 313 | -1596352 -8025465 0 1 } 1
158 { 167, 27, 0 316 | -463409 0 -191951 1 } 1
159 { 210, 27, 0 317 | -53751 -382165 53751 1 } 1
160 { 203, 27, 0 319 | 4546080 -8025465 14829088 1 } 1
161 { 156, 27, 0 321 | 191951 0 463409 1 } 1
162 { 111, 27, 0 323 | -53751 382165 53751 1 } 1
163 { 118, 27, 0 325 | -14829088 8025465 -4546080 1 } 1
164 { 173, 28, 0 328 | -463409 0 191951 1 } 1
165 { 216, 28, 0 329 | 0 -8025465 1596352 1 } 1
166 { 211, 28, 0 331 | 13700317 -8025465 7271203 1 } 1
167 { 158, 28, 0 333 | 463409 0 191951 1 } 1
168 { 117, 28, 0 335 | 0 8025465 1596352 1 } 1
169 { 124, 28, 0 337 | -13700317 8025465 7271203 1 } 1
170 { 179, 29, 0 340 | -191951 0 463409 1 } 1
171 { 222, 29, 0 341 | 53751 -382165 53751 1 } 1
172 { 217, 29, 0 343 | 14829088 -8025465 -4546080 1 } 1
173 { 164, 29, 0 345 | 463409 0 -191951 1 } 1
174 { 123, 29, 0 347 | 53751 382165 53751 1 } 1
175 { 130, 29, 0 349 | -4546080 8025465 14829088 1 } 1
176 { 185, 30, 0 352 | 191951 0 463409 1 } 1
177 { 228, 30, 0 353 | 1596352 -8025465 0 1 } 1
178 { 223, 30, 0 355 | 7271203 -8025465 -13700317 1 } 1
179 { 170, 30, 0 357 | 191951 0 -463409 1 } 1
180 { 129, 30, 0 359 | 1596352 8025465 0 1 } 1
181 { 136, 30, 0 361 | 7271203 8025465 13700317 1 } 1
182 { 191, 31, 0 364 | 463409 0 191951 1 } 1
183 { 234, 31, 0 365 | 53751 -382165 -53751 1 } 1
184 { 229, 31, 0 367 | -4546080 -8025465 -14829088 1 } 1
185 { 176, 31, 0 369 | -191951 0 -463409 1 } 1
186 { 135, 31, 0 371 | 53751 382165 -53751 1 } 1
187 { 142, 31, 0 373 | 14829088 8025465 4546080 1 } 1
188 { 197, 32, 0 376 | 463409 0 -191951 1 } 1
189 { 240, 32, 0 377 | 0 -8025465 -1596352 1 } 1
190 { 235, 32, 0 379 | -13700317 -8025465 -7271203 1 } 1
191 { 182, 32, 0 381 | -463409 0 -191951 1 } 1
192 { 141, 32, 0 383 | 0 8025465 -1596352 1 } 1
193 { 148, 32, 0 385 | 13700317 8025465 -7271203 1 } 1
194 { 153, 33, 0 388 | 191951 0 -463409 1 } 1
195 { 246, 33, 0 389 | -53751 -382165 -53751 1 } 1
196 { 241, 33, 0 391 | -14829088 -8025465 4546080 1 } 1
197 { 188, 33, 0 393 | -463409 0 191951 1 } 1
198 { 147, 33, 0 395 | -53751 382165 -53751 1 } 1
199 { 104, 33, 0 397 | 4546080 8025465 -14829088 1 } 1
200 { 295, 34, 0 400 | -8889408 -6803623 10485760 1 } 1
201 { 242, 34, 0 401 | -5674851 0 13700317 1 } 1
202 { 157, 34, 0 403 | 1596352 8025465 0 1 } 1
203 { 160, 34, 0 405 | -4546080 8025465 -14829088 1 } 1
204 { 209, 34, 0 407 | -5674851 0 -13700317 1 } 1
205 { 250, 34, 0 409 | -4546080 -6803623 0 1 } 1
206 { 215, 35, 0 412 | -13700317 0 -5674851 1 } 1
207 { 258, 35, 0 413 | -3214557 -6803623 3214557 1 } 1
208 { 251, 35, 0 415 | 1128771 -6803623 13700317 1 } 1
209 { 204, 35, 0 417 | 5674851 0 13700317 1 } 1
210 { 159, 35, 0 419 | 53751 382165 -53751 1 } 1
211 { 166, 35, 0 421 | -13700317 8025465 -7271203 1 } 1
212 { 221, 36, 0 424 | -13700317 0 5674851 1 } 1
213 { 264, 36, 0 425 | 0 -6803623 4546080 1 } 1
214 { 259, 36, 0 427 | 10485760 -6803623 8889408 1 } 1
215 { 206, 36, 0 429 | 13700317 0 5674851 1 } 1
216 { 165, 36, 0 431 | 0 8025465 -1596352 1 } 1
217 { 172, 36, 0 433 | -14829088 8025465 4546080 1 } 1
218 { 227, 37, 0 436 | -5674851 0 13700317 1 } 1
219 { 270, 37, 0 437 | 3214557 -6803623 3214557 1 } 1
220 { 265, 37, 0 439 | 13700317 -6803623 -1128771 1 } 1
221 { 212, 37, 0 441 | 13700317 0 -5674851 1 } 1
222 { 171, 37, 0 443 | -53751 382165 -53751 1 } 1
223 { 178, 37, 0 445 | -7271203 8025465 13700317 1 } 1
224 { 233, 38, 0 448 | 5674851 0 13700317 1 } 1
225 { 276, 38, 0 449 | 4546080 -6803623 0 1 } 1
226 { 271, 38, 0 451 | 8889408 -6803623 -10485760 1 } 1
227 { 218, 38, 0 453 | 5674851 0 -13700317 1 } 1
228 { 177, 38, 0 455 | -1596352 8025465 0 1 } 1
229 { 184, 38, 0 457 | 4546080 8025465 14829088 1 } 1
230 { 239, 39, 0 460 | 13700317 0 5674851 1 } 1
231 { 282, 39, 0 461 | 3214557 -6803623 -3214557 1 } 1
232 { 277, 39, 0 463 | -1128771 -6803623 -13700317 1 } 1
233 { 224, 39, 0 465 | -5674851 0 -13700317 1 } 1
234 { 183, 39, 0 467 | -53751 382165 53751 1 } 1
235 { 190, 39, 0 469 | 13700317 8025465 7271203 1 } 1
236 { 245, 40, 0 472 | 13700317 0 -5674851 1 } 1
237 { 288, 40, 0 473 | 0 -6803623 -4546080 1 } 1
238 { 283, 40, 0 475 | -10485760 -6803623 -8889408 1 } 1
239 { 230, 40, 0 477 | -13700317 0 -5674851 1 } 1
240 { 189, 40, 0 479 | 0 8025465 1596352 1 } 1
241 { 196, 40, 0 481 | 14829088 8025465 -4546080 1 } 1
242 { 201, 41, 0 484 | 5674851 0 -13700317 1 } 1
243 { 294, 41, 0 485 | -3214557 -6803623 -3214557 1 } 1
244 { 289, 41, 0 487 | -13700317 -6803623 1128771 1 } 1
245 { 236, 41, 0 489 | -13700317 0 5674851 1 } 1
246 { 195, 41, 0 491 | 53751 382165 53751 1 } 1
247 { 152, 41, 0 493 | 7271203 8025465 -13700317 1 } 1
248 { 335, 42, 0 496 | -18308473 -9092160 11349703 1 } 1
249 { 290, 42, 0 497 | -135729 0 327680 1 } 1
250 { 205, 42, 0 499 | 4546080 6803623 0 1 } 1
251 { 208, 42, 0 501 | -1128771 6803623 -13700317 1 } 1
252 { 257, 42, 0 503 | -135729 0 -327680 1 } 1
253 { 298, 42, 0 505 | -6803623 -4546080 0 1 } 1
254 { 263, 43, 0 508 | -327680 0 -135729 1 } 1
255 { 304, 43, 0 509 | -9621817 -9092160 9621817 1 } 1
256 { 299, 43, 0 511 | -492059 -909216 2097152 1 } 1
257 { 252, 43, 0 513 | 135729 0 327680 1 } 1
258 { 207, 43, 0 515 | 3214557 6803623 -3214557 1 } 1
259 { 214, 43, 0 517 | -10485760 6803623 -8889408 1 } 1
260 { 269, 44, 0 520 | -327680 0 135729 1 } 1
261 { 309, 44, 0 521 | 0 -4546080 6803623 1 } 1
262 { 305, 44, 0 523 | 11349703 -9092160 18308473 1 } 1
263 { 254, 44, 0 525 | 327680 0 135729 1 } 1
264 { 213, 44, 0 527 | 0 6803623 -4546080 1 } 1
265 { 220, 44, 0 529 | -13700317 6803623 1128771 1 } 1
266 { 275, 45, 0 532 | -135729 0 327680 1 } 1
267 { 314, 45, 0 533 | 9621817 -9092160 9621817 1 } 1
268 { 310, 45, 0 535 | 2097152 -909216 492059 1 } 1
269 { 260, 45, 0 537 | 327680 0 -135729 1 } 1
270 { 219, 45, 0 539 | -3214557 6803623 -3214557 1 } 1
271 { 226, 45, 0 541 | -8889408 6803623 10485760 1 } 1
272 { 281, 46, 0 544 | 135729 0 327680 1 } 1
273 { 319, 46, 0 545 | 6803623 -4546080 0 1 } 1
274 { 315, 46, 0 547 | 18308473 -9092160 -11349703 1 } 1
275 { 266, 46, 0 549 | 135729 0 -327680 1 } 1
276 { 225, 46, 0 551 | -4546080 6803623 0 1 } 1
277 { 232, 46, 0 553 | 1128771 6803623 13700317 1 } 1
278 { 287, 47, 0 556 | 327680 0 135729 1 } 1
279 { 324, 47, 0 557 | 9621817 -9092160 -9621817 1 } 1
280 { 320, 47, 0 559 | 492059 -909216 -2097152 1 } 1
281 { 272, 47, 0 561 | -135729 0 -327680 1 } 1
282 { 231, 47, 0 563 | -3214557 6803623 3214557 1 } 1
283 { 238, 47, 0 565 | 10485760 6803623 8889408 1 } 1
284 { 293, 48, 0 568 | 327680 0 -135729 1 } 1
285 { 329, 48, 0 569 | 0 -4546080 -6803623 1 } 1
286 { 325, 48, 0 571 | -11349703 -9092160 -18308473 1 } 1
287 { 278, 48, 0 573 | -327680 0 -135729 1 } 1
288 { 237, 48, 0 575 | 0 6803623 4546080 1 } 1
289 { 244, 48, 0 577 | 13700317 6803623 -1128771 1 } 1
290 { 249, 49, 0 580 | 135729 0 -327680 1 } 1
291 { 334, 49, 0 581 | -9621817 -9092160 -9621817 1 } 1
292 { 330, 49, 0 583 | -2097152 -909216 -492059 1 } 1
293 { 284, 49, 0 585 | -327680 0 135729 1 } 1
294 { 243, 49, 0 587 | 3214557 6803623 3214557 1 } 1
295 { 200, 49, 0 589 | 8889408 6803623 -10485760 1 } 1
296 { 9, 50, 0 592 | -8025465 -1596352 0 1 } 1
297 { 331, 50, 0 593 | -4701227 0 11349703 1 } 1
298 { 253, 50, 0 595 | 6803623 4546080 0 1 } 1
299 { 256, 50, 0 597 | 492059 909216 -2097152 1 } 1
300 { 303, 50, 0 599 | -4701227 0 -11349703 1 } 1
301 { 308, 51, 0 602 | -11349703 0 -4701227 1 } 1
302 { 10, 51, 0 603 | -11349703 -3192704 11349703 1 } 1
303 { 300, 51, 0 605 | 4701227 0 11349703 1 } 1
304 { 255, 51, 0 607 | 9621817 9092160 -9621817 1 } 1
305 { 262, 51, 0 609 | -11349703 9092160 -18308473 1 } 1
306 { 313, 52, 0 612 | -11349703 0 4701227 1 } 1
307 { 11, 52, 0 613 | 0 -1596352 8025465 1 } 1
308 { 301, 52, 0 615 | 11349703 0 4701227 1 } 1
309 { 261, 52, 0 617 | 0 4546080 -6803623 1 } 1
310 { 268, 52, 0 619 | -2097152 909216 -492059 1 } 1
311 { 318, 53, 0 622 | -4701227 0 11349703 1 } 1
312 { 12, 53, 0 623 | 11349703 -3192704 11349703 1 } 1
313 { 306, 53, 0 625 | 11349703 0 -4701227 1 } 1
314 { 267, 53, 0 627 | -9621817 9092160 -9621817 1 } 1
315 { 274, 53, 0 629 | -18308473 9092160 11349703 1 } 1
316 { 323, 54, 0 632 | 4701227 0 11349703 1 } 1
317 { 13, 54, 0 633 | 8025465 -1596352 0 1 } 1
318 { 311, 54, 0 635 | 4701227 0 -11349703 1 } 1
319 { 273, 54, 0 637 | -6803623 4546080 0 1 } 1
320 { 280, 54, 0 639 | -492059 909216 2097152 1 } 1
321 { 328, 55, 0 642 | 11349703 0 4701227 1 } 1
322 { 14, 55, 0 643 | 11349703 -3192704 -11349703 1 } 1
323 { 316, 55, 0 645 | -4701227 0 -11349703 1 } 1
324 { 279, 55, 0 647 | -9621817 9092160 9621817 1 } 1
325 { 286, 55, 0 649 | 11349703 9092160 18308473 1 } 1
326 { 333, 56, 0 652 | 11349703 0 -4701227 1 } 1
327 { 15, 56, 0 653 | 0 -1596352 -8025465 1 } 1
328 { 321, 56, 0 655 | -11349703 0 -4701227 1 } 1
329 { 285, 56, 0 657 | 0 4546080 6803623 1 } 1
330 { 292, 56, 0 659 | 2097152 909216 492059 1 } 1
331 { 297, 57, 0 662 | 4701227 0 -11349703 1 } 1
332 { 8, 57, 0 663 | -11349703 -3192704 -11349703 1 } 1
333 { 326, 57, 0 665 | -11349703 0 4701227 1 } 1
334 { 291, 57, 0 667 | 9621817 9092160 9621817 1 } 1
335 { 248, 57, 0 669 | 18308473 9092160 -11349703 1 } 1
0 { 1, 46 , , 0 | 390505298499993600 584428630068822016
-161751994812334080 -3446908240540666777 } 1
1 { 0, 47 , , 1 | -390505298499993600 -584428630068822016
161751994812334080 3446908240540666777 } 1
2 { 3, 48 , , 0 | 6762877133028065280 10121261924216864768
-2801290974351851520 -59694381686239744481 } 1
3 { 2, 49 , , 1 | -6762877133028065280 -10121261924216864768
2801290974351851520 59694381686239744481 } 1
4 { 5, 142 , , 0 | 246813956928 891764473856 -595863797760
-5259554517527 } 1
5 { 4, 143 , , 1 | -246813956928 -891764473856 595863797760
5259554517527 } 1
6 { 7, 58 , , 0 | 26678961660493824 96393538930081792
-64408353647886336 -568520545671846649 } 1
7 { 6, 59 , , 1 | -26678961660493824 -96393538930081792
64408353647886336 568520545671846649 } 1
8 { 9, 154 , , 0 | -161751994812334080 584428630068822016
-390505298499993600 -3446908240540666777 } 1
9 { 8, 155 , , 1 | 161751994812334080 -584428630068822016
390505298499993600 3446908240540666777 } 1
10 { 11, 68 , , 0 | -2801290974351851520 10121261924216864768
-6762877133028065280 -59694381686239744481 } 1
11 { 10, 69 , , 1 | 2801290974351851520 -10121261924216864768
6762877133028065280 59694381686239744481 } 1
12 { 13, 166 , , 0 | -595863797760 891764473856 -246813956928
-5259554517527 } 1
13 { 12, 167 , , 1 | 595863797760 -891764473856 246813956928
5259554517527 } 1
14 { 15, 156 , , 0 | -64408353647886336 96393538930081792
-26678961660493824 -568520545671846649 } 1
15 { 14, 157 , , 1 | 64408353647886336 -96393538930081792
26678961660493824 568520545671846649 } 1
16 { 17, 170 , , 0 | -390505298499993600 584428630068822016
17 { 16, 171 , , 1 | 390505298499993600 -584428630068822016
-161751994812334080 3446908240540666777 } 1
18 { 19, 168 , , 0 | -6762877133028065280 10121261924216864768
19 { 18, 169 , , 1 | 6762877133028065280 -10121261924216864768
-2801290974351851520 59694381686239744481 } 1
20 { 21, 182 , , 0 | -246813956928 891764473856 595863797760
-5259554517527 } 1
21 { 20, 183 , , 1 | 246813956928 -891764473856 -595863797760
5259554517527 } 1
22 { 23, 180 , , 0 | -26678961660493824 96393538930081792
23 { 22, 181 , , 1 | 26678961660493824 -96393538930081792
-64408353647886336 568520545671846649 } 1
24 { 25, 194 , , 0 | 161751994812334080 584428630068822016
25 { 24, 195 , , 1 | -161751994812334080 -584428630068822016
-390505298499993600 3446908240540666777 } 1
26 { 27, 192 , , 0 | 2801290974351851520 10121261924216864768
27 { 26, 193 , , 1 | -2801290974351851520 -10121261924216864768
-6762877133028065280 59694381686239744481 } 1
28 { 29, 38 , , 0 | 595863797760 891764473856 246813956928
-5259554517527 } 1
29 { 28, 39 , , 1 | -595863797760 -891764473856 -246813956928
5259554517527 } 1
30 { 31, 104 , , 0 | 64408353647886336 96393538930081792
31 { 30, 105 , , 1 | -64408353647886336 -96393538930081792
-26678961660493824 568520545671846649 } 1
32 { 33, 126 , , 0 | 190897749705709568 127554727773339648
-79072351816034304 -1125898832011112861 } 1
33 { 32, 127 , , 1 | -190897749705709568 -127554727773339648
79072351816034304 1125898832011112861 } 1
34 { 35, 128 , , 0 | 4458822369280 2979318988800 -1846897892334
-26297772587635 } 1
35 { 34, 129 , , 1 | -4458822369280 -2979318988800 1846897892334
26297772587635 } 1
36 { 37, 238 , , 0 | 5060630516226195456 8163522918135889920
-12217455981165412352 -72057564168901956059 } 1
37 { 36, 239 , , 1 | -5060630516226195456 -8163522918135889920
12217455981165412352 72057564168901956059 } 1
38 { 39, 140 , , 0 | 121038300272001024 195252013604929536
-292213382793134080 -1723448576960985277 } 1
39 { 38, 141 , , 1 | -121038300272001024 -195252013604929536
292213382793134080 1723448576960985277 } 1
40 { 41, 250 , , 0 | -79072351816034304 127554727773339648
-190897749705709568 -1125898832011112861 } 1
41 { 40, 251 , , 1 | 79072351816034304 -127554727773339648
190897749705709568 1125898832011112861 } 1
42 { 43, 152 , , 0 | -1846897892334 2979318988800 -4458822369280
-26297772587635 } 1
43 { 42, 153 , , 1 | 1846897892334 -2979318988800 4458822369280
26297772587635 } 1
44 { 45, 262 , , 0 | -12217455981165412352 8163522918135889920
-5060630516226195456 -72057564168901956059 } 1
45 { 44, 263 , , 1 | 12217455981165412352 -8163522918135889920
5060630516226195456 72057564168901956059 } 1
46 { 47, 164 , , 0 | -292213382793134080 195252013604929536
-121038300272001024 -1723448576960985277 } 1
47 { 46, 165 , , 1 | 292213382793134080 -195252013604929536
121038300272001024 1723448576960985277 } 1
48 { 49, 266 , , 0 | -190897749705709568 127554727773339648
49 { 48, 267 , , 1 | 190897749705709568 -127554727773339648
-79072351816034304 1125898832011112861 } 1
50 { 51, 264 , , 0 | -4458822369280 2979318988800 1846897892334
-26297772587635 } 1
51 { 50, 265 , , 1 | 4458822369280 -2979318988800 -1846897892334
26297772587635 } 1
52 { 53, 278 , , 0 | -5060630516226195456 8163522918135889920
53 { 52, 279 , , 1 | 5060630516226195456 -8163522918135889920
-12217455981165412352 72057564168901956059 } 1
54 { 55, 276 , , 0 | -121038300272001024 195252013604929536
55 { 54, 277 , , 1 | 121038300272001024 -195252013604929536
-292213382793134080 1723448576960985277 } 1
56 { 57, 290 , , 0 | 79072351816034304 127554727773339648
57 { 56, 291 , , 1 | -79072351816034304 -127554727773339648
-190897749705709568 1125898832011112861 } 1
58 { 59, 288 , , 0 | 1846897892334 2979318988800 4458822369280
-26297772587635 } 1
59 { 58, 289 , , 1 | -1846897892334 -2979318988800 -4458822369280
26297772587635 } 1
60 { 61, 302 , , 0 | 12217455981165412352 8163522918135889920
61 { 60, 303 , , 1 | -12217455981165412352 -8163522918135889920
-5060630516226195456 72057564168901956059 } 1
62 { 63, 196 , , 0 | 292213382793134080 195252013604929536
63 { 62, 197 , , 1 | -292213382793134080 -195252013604929536
-121038300272001024 1723448576960985277 } 1
64 { 65, 222 , , 0 | 35419740097 7045251072 -14671390783
-177098700485 } 1
65 { 64, 223 , , 1 | -35419740097 -7045251072 14671390783
177098700485 } 1
66 { 67, 224 , , 0 | 109951414572405 21870528443584
-45543318080715 -549757072862025 } 1
67 { 66, 225 , , 1 | -109951414572405 -21870528443584
45543318080715 549757072862025 } 1
68 { 69, 334 , , 0 | 1540496032215 739763883968 -3719072710185
-18595363550925 } 1
69 { 68, 335 , , 1 | -1540496032215 -739763883968 3719072710185
18595363550925 } 1
70 { 71, 236 , , 0 | 4441557877585920 2132858173784064
-10722880811632640 -53614329288727445 } 1
71 { 70, 237 , , 1 | -4441557877585920 -2132858173784064
10722880811632640 53614329288727445 } 1
72 { 73, 346 , , 0 | -14671390783 7045251072 -35419740097
-177098700485 } 1
73 { 72, 347 , , 1 | 14671390783 -7045251072 35419740097
177098700485 } 1
74 { 75, 248 , , 0 | -45543318080715 21870528443584
-109951414572405 -549757072862025 } 1
75 { 74, 249 , , 1 | 45543318080715 -21870528443584
109951414572405 549757072862025 } 1
76 { 77, 358 , , 0 | -3719072710185 739763883968 -1540496032215
-18595363550925 } 1
77 { 76, 359 , , 1 | 3719072710185 -739763883968 1540496032215
18595363550925 } 1
78 { 79, 260 , , 0 | -10722880811632640 2132858173784064
-4441557877585920 -53614329288727445 } 1
79 { 78, 261 , , 1 | 10722880811632640 -2132858173784064
4441557877585920 53614329288727445 } 1
80 { 81, 362 , , 0 | -35419740097 7045251072 14671390783
-177098700485 } 1
81 { 80, 363 , , 1 | 35419740097 -7045251072 -14671390783
177098700485 } 1
82 { 83, 360 , , 0 | -109951414572405 21870528443584
83 { 82, 361 , , 1 | 109951414572405 -21870528443584
-45543318080715 549757072862025 } 1
84 { 85, 374 , , 0 | -1540496032215 739763883968 3719072710185
-18595363550925 } 1
85 { 84, 375 , , 1 | 1540496032215 -739763883968 -3719072710185
18595363550925 } 1
86 { 87, 372 , , 0 | -4441557877585920 2132858173784064
87 { 86, 373 , , 1 | 4441557877585920 -2132858173784064
-10722880811632640 53614329288727445 } 1
88 { 89, 386 , , 0 | 14671390783 7045251072 35419740097
-177098700485 } 1
89 { 88, 387 , , 1 | -14671390783 -7045251072 -35419740097
177098700485 } 1
90 { 91, 384 , , 0 | 45543318080715 21870528443584 109951414572405
91 { 90, 385 , , 1 | -45543318080715 -21870528443584
-109951414572405 549757072862025 } 1
92 { 93, 398 , , 0 | 3719072710185 739763883968 1540496032215
-18595363550925 } 1
93 { 92, 399 , , 1 | -3719072710185 -739763883968 -1540496032215
18595363550925 } 1
94 { 95, 292 , , 0 | 10722880811632640 2132858173784064
95 { 94, 293 , , 1 | -10722880811632640 -2132858173784064
-4441557877585920 53614329288727445 } 1
96 { 97, 418 , , 0 | 10722880811632640 -2132858173784064
97 { 96, 419 , , 1 | -10722880811632640 2132858173784064
98 { 99, 320 , , 0 | 3719072710185 -739763883968 -1540496032215
-18595363550925 } 1
99 { 98, 321 , , 1 | -3719072710185 739763883968 1540496032215
18595363550925 } 1
100 { 101, 430 , , 0 | 45543318080715 -21870528443584
101 { 100, 431 , , 1 | -45543318080715 21870528443584
102 { 103, 332 , , 0 | 14671390783 -7045251072 -35419740097
-177098700485 } 1
103 { 102, 333 , , 1 | -14671390783 7045251072 35419740097
177098700485 } 1
104 { 105, 342 , , 0 | -4441557877585920 -2132858173784064
105 { 104, 343 , , 1 | 4441557877585920 2132858173784064
106 { 107, 344 , , 0 | -1540496032215 -739763883968 -3719072710185
-18595363550925 } 1
107 { 106, 345 , , 1 | 1540496032215 739763883968 3719072710185
18595363550925 } 1
108 { 109, 354 , , 0 | -109951414572405 -21870528443584
109 { 108, 355 , , 1 | 109951414572405 21870528443584
110 { 111, 356 , , 0 | -35419740097 -7045251072 -14671390783
-177098700485 } 1
111 { 110, 357 , , 1 | 35419740097 7045251072 14671390783
177098700485 } 1
112 { 113, 458 , , 0 | -10722880811632640 -2132858173784064
113 { 112, 459 , , 1 | 10722880811632640 2132858173784064
114 { 115, 352 , , 0 | -3719072710185 -739763883968 1540496032215
-18595363550925 } 1
115 { 114, 353 , , 1 | 3719072710185 739763883968 -1540496032215
18595363550925 } 1
116 { 117, 470 , , 0 | -45543318080715 -21870528443584
117 { 116, 471 , , 1 | 45543318080715 21870528443584
118 { 119, 364 , , 0 | -14671390783 -7045251072 35419740097
-177098700485 } 1
119 { 118, 365 , , 1 | 14671390783 7045251072 -35419740097
177098700485 } 1
120 { 121, 482 , , 0 | 4441557877585920 -2132858173784064
121 { 120, 483 , , 1 | -4441557877585920 2132858173784064
122 { 123, 480 , , 0 | 1540496032215 -739763883968 3719072710185
-18595363550925 } 1
123 { 122, 481 , , 1 | -1540496032215 739763883968 -3719072710185
18595363550925 } 1
124 { 125, 494 , , 0 | 109951414572405 -21870528443584
125 { 124, 495 , , 1 | -109951414572405 21870528443584
126 { 127, 492 , , 0 | 35419740097 -7045251072 14671390783
-177098700485 } 1
127 { 126, 493 , , 1 | -35419740097 7045251072 -14671390783
177098700485 } 1
128 { 129, 514 , , 0 | 292213382793134080 -195252013604929536
129 { 128, 515 , , 1 | -292213382793134080 195252013604929536
130 { 131, 416 , , 0 | 12217455981165412352 -8163522918135889920
131 { 130, 417 , , 1 | -12217455981165412352 8163522918135889920
132 { 133, 526 , , 0 | 1846897892334 -2979318988800 -4458822369280
-26297772587635 } 1
133 { 132, 527 , , 1 | -1846897892334 2979318988800 4458822369280
26297772587635 } 1
134 { 135, 428 , , 0 | 79072351816034304 -127554727773339648
135 { 134, 429 , , 1 | -79072351816034304 127554727773339648
136 { 137, 438 , , 0 | -121038300272001024 -195252013604929536
137 { 136, 439 , , 1 | 121038300272001024 195252013604929536
138 { 139, 440 , , 0 | -5060630516226195456 -8163522918135889920
139 { 138, 441 , , 1 | 5060630516226195456 8163522918135889920
140 { 141, 450 , , 0 | -4458822369280 -2979318988800
-1846897892334 -26297772587635 } 1
141 { 140, 451 , , 1 | 4458822369280 2979318988800 1846897892334
26297772587635 } 1
142 { 143, 452 , , 0 | -190897749705709568 -127554727773339648
143 { 142, 453 , , 1 | 190897749705709568 127554727773339648
144 { 145, 554 , , 0 | -292213382793134080 -195252013604929536
145 { 144, 555 , , 1 | 292213382793134080 195252013604929536
146 { 147, 448 , , 0 | -12217455981165412352 -8163522918135889920
147 { 146, 449 , , 1 | 12217455981165412352 8163522918135889920
148 { 149, 566 , , 0 | -1846897892334 -2979318988800 4458822369280
-26297772587635 } 1
149 { 148, 567 , , 1 | 1846897892334 2979318988800 -4458822369280
26297772587635 } 1
150 { 151, 460 , , 0 | -79072351816034304 -127554727773339648
151 { 150, 461 , , 1 | 79072351816034304 127554727773339648
152 { 153, 578 , , 0 | 121038300272001024 -195252013604929536
153 { 152, 579 , , 1 | -121038300272001024 195252013604929536
154 { 155, 576 , , 0 | 5060630516226195456 -8163522918135889920
155 { 154, 577 , , 1 | -5060630516226195456 8163522918135889920
156 { 157, 590 , , 0 | 4458822369280 -2979318988800 1846897892334
-26297772587635 } 1
157 { 156, 591 , , 1 | -4458822369280 2979318988800 -1846897892334
26297772587635 } 1
158 { 159, 588 , , 0 | 190897749705709568 -127554727773339648
159 { 158, 589 , , 1 | -190897749705709568 127554727773339648
160 { 161, 606 , , 0 | 64408353647886336 -96393538930081792
161 { 160, 607 , , 1 | -64408353647886336 96393538930081792
162 { 163, 596 , , 0 | 595863797760 -891764473856 -246813956928
-5259554517527 } 1
163 { 162, 597 , , 1 | -595863797760 891764473856 246813956928
5259554517527 } 1
164 { 165, 616 , , 0 | 2801290974351851520 -10121261924216864768
165 { 164, 617 , , 1 | -2801290974351851520 10121261924216864768
166 { 167, 524 , , 0 | 161751994812334080 -584428630068822016
167 { 166, 525 , , 1 | -161751994812334080 584428630068822016
168 { 169, 534 , , 0 | -26678961660493824 -96393538930081792
169 { 168, 535 , , 1 | 26678961660493824 96393538930081792
170 { 171, 536 , , 0 | -246813956928 -891764473856 -595863797760
-5259554517527 } 1
171 { 170, 537 , , 1 | 246813956928 891764473856 595863797760
5259554517527 } 1
172 { 173, 546 , , 0 | -6762877133028065280 -10121261924216864768
173 { 172, 547 , , 1 | 6762877133028065280 10121261924216864768
174 { 175, 548 , , 0 | -390505298499993600 -584428630068822016
175 { 174, 549 , , 1 | 390505298499993600 584428630068822016
176 { 177, 558 , , 0 | -64408353647886336 -96393538930081792
177 { 176, 559 , , 1 | 64408353647886336 96393538930081792
178 { 179, 544 , , 0 | -595863797760 -891764473856 246813956928
-5259554517527 } 1
179 { 178, 545 , , 1 | 595863797760 891764473856 -246813956928
5259554517527 } 1
180 { 181, 650 , , 0 | -2801290974351851520 -10121261924216864768
181 { 180, 651 , , 1 | 2801290974351851520 10121261924216864768
182 { 183, 556 , , 0 | -161751994812334080 -584428630068822016
183 { 182, 557 , , 1 | 161751994812334080 584428630068822016
184 { 185, 660 , , 0 | 26678961660493824 -96393538930081792
185 { 184, 661 , , 1 | -26678961660493824 96393538930081792
186 { 187, 658 , , 0 | 246813956928 -891764473856 595863797760
-5259554517527 } 1
187 { 186, 659 , , 1 | -246813956928 891764473856 -595863797760
5259554517527 } 1
188 { 189, 670 , , 0 | 6762877133028065280 -10121261924216864768
189 { 188, 671 , , 1 | -6762877133028065280 10121261924216864768
190 { 191, 668 , , 0 | 390505298499993600 -584428630068822016
191 { 190, 669 , , 1 | -390505298499993600 584428630068822016
192 { 193, 14 , , 0 | 18118121083456 91086644186895 -7504813123904
-455433220934475 } 1
193 { 192, 15 , , 1 | -18118121083456 -91086644186895
7504813123904 455433220934475 } 1
194 { 195, 60 , , 0 | 7504813123904 91086644186895 -18118121083456
195 { 194, 61 , , 1 | -7504813123904 -91086644186895
18118121083456 455433220934475 } 1
196 { 197, 70 , , 0 | -7504813123904 91086644186895
-18118121083456 -455433220934475 } 1
197 { 196, 71 , , 1 | 7504813123904 -91086644186895 18118121083456
455433220934475 } 1
198 { 199, 80 , , 0 | -18118121083456 91086644186895
-7504813123904 -455433220934475 } 1
199 { 198, 81 , , 1 | 18118121083456 -91086644186895 7504813123904
455433220934475 } 1
200 { 201, 72 , , 0 | -18118121083456 91086644186895 7504813123904
201 { 200, 73 , , 1 | 18118121083456 -91086644186895
-7504813123904 455433220934475 } 1
202 { 203, 82 , , 0 | -7504813123904 91086644186895 18118121083456
203 { 202, 83 , , 1 | 7504813123904 -91086644186895
-18118121083456 455433220934475 } 1
204 { 205, 92 , , 0 | 7504813123904 91086644186895 18118121083456
205 { 204, 93 , , 1 | -7504813123904 -91086644186895
206 { 207, 0 , , 0 | 18118121083456 91086644186895 7504813123904
207 { 206, 1 , , 1 | -18118121083456 -91086644186895
208 { 209, 18 , , 0 | 18118121083456 -91086644186895
209 { 208, 19 , , 1 | -18118121083456 91086644186895 7504813123904
455433220934475 } 1
210 { 211, 20 , , 0 | 7504813123904 -91086644186895
211 { 210, 21 , , 1 | -7504813123904 91086644186895 18118121083456
455433220934475 } 1
212 { 213, 624 , , 0 | -7504813123904 -91086644186895
213 { 212, 625 , , 1 | 7504813123904 91086644186895 18118121083456
455433220934475 } 1
214 { 215, 634 , , 0 | -18118121083456 -91086644186895
215 { 214, 635 , , 1 | 18118121083456 91086644186895 7504813123904
455433220934475 } 1
216 { 217, 632 , , 0 | -18118121083456 -91086644186895
217 { 216, 633 , , 1 | 18118121083456 91086644186895
218 { 219, 642 , , 0 | -7504813123904 -91086644186895
219 { 218, 643 , , 1 | 7504813123904 91086644186895
220 { 221, 30 , , 0 | 7504813123904 -91086644186895 18118121083456
221 { 220, 31 , , 1 | -7504813123904 91086644186895
222 { 223, 16 , , 0 | 18118121083456 -91086644186895 7504813123904
223 { 222, 17 , , 1 | -18118121083456 91086644186895
0 { 0 } 0
1 { 1 } 1
0 { 1, 14, 2, 0, 1, 32, 102, 206 | -18118121083456 -91086644186895
-7504813123904 0 } 1
1 { 0, 3, 15, 1, 0, 103, 33, 207 | 18118121083456 91086644186895
7504813123904 0 } 1
2 { 3, 0, 4, 1, 1, 110, 92, 204 | -7504813123904 -91086644186895
-18118121083456 0 } 1
3 { 2, 5, 1, 2, 0, 93, 111, 205 | 7504813123904 91086644186895
4 { 5, 2, 6, 2, 1, 100, 82, 202 | 7504813123904 -91086644186895
5 { 4, 7, 3, 3, 0, 83, 101, 203 | -7504813123904 91086644186895
6 { 7, 4, 8, 3, 1, 90, 72, 200 | 18118121083456 -91086644186895
7 { 6, 9, 5, 4, 0, 73, 91, 201 | -18118121083456 91086644186895
7504813123904 0 } 1
8 { 9, 6, 10, 4, 1, 80, 62, 198 | 18118121083456 -91086644186895
7504813123904 0 } 1
9 { 8, 11, 7, 5, 0, 63, 81, 199 | -18118121083456 91086644186895
10 { 11, 8, 12, 5, 1, 70, 52, 196 | 7504813123904 -91086644186895
11 { 10, 13, 9, 6, 0, 53, 71, 197 | -7504813123904 91086644186895
12 { 13, 10, 14, 6, 1, 60, 42, 194 | -7504813123904
-91086644186895 18118121083456 0 } 1
13 { 12, 15, 11, 7, 0, 43, 61, 195 | 7504813123904 91086644186895
14 { 15, 12, 0, 7, 1, 50, 34, 192 | -18118121083456
-91086644186895 7504813123904 0 } 1
15 { 14, 1, 13, 0, 0, 35, 51, 193 | 18118121083456 91086644186895
16 { 17, 30, 18, 8, 3, 662, 592, 222 | -18118121083456
91086644186895 -7504813123904 0 } 1
17 { 16, 19, 31, 9, 2, 593, 663, 223 | 18118121083456
18 { 19, 16, 20, 9, 3, 600, 604, 208 | -18118121083456
19 { 18, 21, 17, 10, 2, 605, 601, 209 | 18118121083456
-91086644186895 -7504813123904 0 } 1
20 { 21, 18, 22, 10, 3, 602, 614, 210 | -7504813123904
21 { 20, 23, 19, 11, 2, 615, 603, 211 | 7504813123904
-91086644186895 -18118121083456 0 } 1
22 { 23, 20, 24, 11, 3, 612, 624, 212 | 7504813123904
23 { 22, 25, 21, 12, 2, 625, 613, 213 | -7504813123904
24 { 25, 22, 26, 12, 3, 622, 634, 214 | 18118121083456
25 { 24, 27, 23, 13, 2, 635, 623, 215 | -18118121083456
26 { 27, 24, 28, 13, 3, 632, 644, 216 | 18118121083456
27 { 26, 29, 25, 14, 2, 645, 633, 217 | -18118121083456
28 { 29, 26, 30, 14, 3, 642, 654, 218 | 7504813123904
29 { 28, 31, 27, 15, 2, 655, 643, 219 | -7504813123904
30 { 31, 28, 16, 15, 3, 652, 664, 220 | -7504813123904
31 { 30, 17, 29, 8, 2, 665, 653, 221 | 7504813123904
32 { 33, 40, 34, 16, 5, 102, 0, 206 | -18118121083456
33 { 32, 35, 41, 17, 4, 1, 103, 207 | 18118121083456
34 { 35, 32, 36, 17, 5, 14, 50, 192 | -18118121083456
35 { 34, 37, 33, 18, 4, 51, 15, 193 | 18118121083456
36 { 37, 34, 38, 18, 5, 48, 116, 2 | -51596657814240
-77219100373969 21372154040160 0 } 1
37 { 36, 39, 35, 19, 4, 117, 49, 3 | 51596657814240 77219100373969
-21372154040160 0 } 1
38 { 39, 36, 40, 19, 5, 114, 206, 28 | -9310371840 -13933819904
-3856468077 0 } 1
39 { 38, 41, 37, 20, 4, 207, 115, 29 | 9310371840 13933819904
3856468077 0 } 1
40 { 41, 38, 32, 20, 5, 204, 104, 30 | -491396741088 -735424338761
-203544324192 0 } 1
41 { 40, 33, 39, 16, 4, 105, 205, 31 | 491396741088 735424338761
203544324192 0 } 1
42 { 43, 50, 44, 21, 7, 12, 60, 194 | -7504813123904
43 { 42, 45, 51, 22, 6, 61, 13, 195 | 7504813123904 91086644186895
44 { 45, 42, 46, 22, 7, 58, 132, 6 | -203544324192 -735424338761
491396741088 0 } 1
45 { 44, 47, 43, 23, 6, 133, 59, 7 | 203544324192 735424338761
-491396741088 0 } 1
46 { 47, 44, 48, 23, 7, 130, 118, 0 | -2979318988800
-4458836594153 1234069784640 0 } 1
47 { 46, 49, 45, 24, 6, 119, 131, 1 | 2979318988800 4458836594153
-1234069784640 0 } 1
48 { 49, 46, 50, 24, 7, 116, 36, 2 | -51596657814240
49 { 48, 51, 47, 25, 6, 37, 117, 3 | 51596657814240 77219100373969
50 { 51, 48, 42, 25, 7, 34, 14, 192 | -18118121083456
51 { 50, 43, 49, 21, 6, 15, 35, 193 | 18118121083456
52 { 53, 60, 54, 26, 9, 10, 70, 196 | 7504813123904
53 { 52, 55, 61, 27, 8, 71, 11, 197 | -7504813123904
54 { 55, 52, 56, 27, 9, 68, 144, 10 | 21372154040160
-77219100373969 51596657814240 0 } 1
55 { 54, 57, 53, 28, 8, 145, 69, 11 | -21372154040160
77219100373969 -51596657814240 0 } 1
56 { 57, 54, 58, 28, 9, 142, 134, 4 | -3856468077 -13933819904
9310371840 0 } 1
57 { 56, 59, 55, 29, 8, 135, 143, 5 | 3856468077 13933819904
-9310371840 0 } 1
58 { 59, 56, 60, 29, 9, 132, 44, 6 | -203544324192 -735424338761
491396741088 0 } 1
59 { 58, 61, 57, 30, 8, 45, 133, 7 | 203544324192 735424338761
-491396741088 0 } 1
60 { 61, 58, 52, 30, 9, 42, 12, 194 | -7504813123904
61 { 60, 53, 59, 26, 8, 13, 43, 195 | 7504813123904 91086644186895
62 { 63, 70, 64, 31, 11, 8, 80, 198 | 18118121083456
63 { 62, 65, 71, 32, 10, 81, 9, 199 | -18118121083456
64 { 65, 62, 66, 32, 11, 78, 156, 14 | 491396741088 -735424338761
203544324192 0 } 1
65 { 64, 67, 63, 33, 10, 157, 79, 15 | -491396741088 735424338761
-203544324192 0 } 1
66 { 67, 64, 68, 33, 11, 154, 146, 8 | 1234069784640
-4458836594153 2979318988800 0 } 1
67 { 66, 69, 65, 34, 10, 147, 155, 9 | -1234069784640
4458836594153 -2979318988800 0 } 1
68 { 69, 66, 70, 34, 11, 144, 54, 10 | 21372154040160
69 { 68, 71, 67, 35, 10, 55, 145, 11 | -21372154040160
70 { 71, 68, 62, 35, 11, 52, 10, 196 | 7504813123904
71 { 70, 63, 69, 31, 10, 11, 53, 197 | -7504813123904
72 { 73, 80, 74, 36, 13, 6, 90, 200 | 18118121083456
73 { 72, 75, 81, 37, 12, 91, 7, 201 | -18118121083456
74 { 75, 72, 76, 37, 13, 88, 168, 18 | 51596657814240
-77219100373969 -21372154040160 0 } 1
75 { 74, 77, 73, 38, 12, 169, 89, 19 | -51596657814240
76 { 77, 74, 78, 38, 13, 166, 158, 12 | 9310371840 -13933819904
3856468077 0 } 1
77 { 76, 79, 75, 39, 12, 159, 167, 13 | -9310371840 13933819904
-3856468077 0 } 1
78 { 79, 76, 80, 39, 13, 156, 64, 14 | 491396741088 -735424338761
203544324192 0 } 1
79 { 78, 81, 77, 40, 12, 65, 157, 15 | -491396741088 735424338761
-203544324192 0 } 1
80 { 81, 78, 72, 40, 13, 62, 8, 198 | 18118121083456
81 { 80, 73, 79, 36, 12, 9, 63, 199 | -18118121083456
82 { 83, 90, 84, 41, 15, 4, 100, 202 | 7504813123904
83 { 82, 85, 91, 42, 14, 101, 5, 203 | -7504813123904
84 { 85, 82, 86, 42, 15, 98, 180, 22 | 203544324192 -735424338761
-491396741088 0 } 1
85 { 84, 87, 83, 43, 14, 181, 99, 23 | -203544324192 735424338761
491396741088 0 } 1
86 { 87, 84, 88, 43, 15, 178, 170, 16 | 2979318988800
-4458836594153 -1234069784640 0 } 1
87 { 86, 89, 85, 44, 14, 171, 179, 17 | -2979318988800
88 { 89, 86, 90, 44, 15, 168, 74, 18 | 51596657814240
89 { 88, 91, 87, 45, 14, 75, 169, 19 | -51596657814240
90 { 91, 88, 82, 45, 15, 72, 6, 200 | 18118121083456
91 { 90, 83, 89, 41, 14, 7, 73, 201 | -18118121083456
92 { 93, 100, 94, 46, 17, 2, 110, 204 | -7504813123904
93 { 92, 95, 101, 47, 16, 111, 3, 205 | 7504813123904
94 { 95, 92, 96, 47, 17, 108, 192, 26 | -21372154040160
-77219100373969 -51596657814240 0 } 1
95 { 94, 97, 93, 48, 16, 193, 109, 27 | 21372154040160
96 { 97, 94, 98, 48, 17, 190, 182, 20 | 3856468077 -13933819904
-9310371840 0 } 1
97 { 96, 99, 95, 49, 16, 183, 191, 21 | -3856468077 13933819904
9310371840 0 } 1
98 { 99, 96, 100, 49, 17, 180, 84, 22 | 203544324192 -735424338761
-491396741088 0 } 1
99 { 98, 101, 97, 50, 16, 85, 181, 23 | -203544324192 735424338761
491396741088 0 } 1
100 { 101, 98, 92, 50, 17, 82, 4, 202 | 7504813123904
101 { 100, 93, 99, 46, 16, 5, 83, 203 | -7504813123904
102 { 103, 110, 104, 51, 19, 0, 32, 206 | -18118121083456
103 { 102, 105, 111, 52, 18, 33, 1, 207 | 18118121083456
104 { 105, 102, 106, 52, 19, 40, 204, 30 | -491396741088
-735424338761 -203544324192 0 } 1
105 { 104, 107, 103, 53, 18, 205, 41, 31 | 491396741088
735424338761 203544324192 0 } 1
106 { 107, 104, 108, 53, 19, 202, 194, 24 | -1234069784640
-4458836594153 -2979318988800 0 } 1
107 { 106, 109, 105, 54, 18, 195, 203, 25 | 1234069784640
108 { 109, 106, 110, 54, 19, 192, 94, 26 | -21372154040160
109 { 108, 111, 107, 55, 18, 95, 193, 27 | 21372154040160
110 { 111, 108, 102, 55, 19, 92, 2, 204 | -7504813123904
111 { 110, 103, 109, 51, 18, 3, 93, 205 | 7504813123904
112 { 113, 122, 114, 56, 21, 300, 196, 62 | -2229411184640
-1489654644813 -923448946167 0 } 1
113 { 112, 115, 123, 57, 20, 197, 301, 63 | 2229411184640
1489654644813 923448946167 0 } 1
114 { 115, 112, 116, 57, 21, 206, 38, 28 | -9310371840
-13933819904 -3856468077 0 } 1
115 { 114, 117, 113, 58, 20, 39, 207, 29 | 9310371840 13933819904
3856468077 0 } 1
116 { 117, 114, 118, 58, 21, 36, 48, 2 | -51596657814240
117 { 116, 119, 115, 59, 20, 49, 37, 3 | 51596657814240
118 { 119, 116, 120, 59, 21, 46, 130, 0 | -2979318988800
119 { 118, 121, 117, 60, 20, 131, 47, 1 | 2979318988800
120 { 121, 118, 122, 60, 21, 128, 212, 34 | -2229411184640
-1489659494400 923448946167 0 } 1
121 { 120, 123, 119, 61, 20, 213, 129, 35 | 2229411184640
1489659494400 -923448946167 0 } 1
122 { 123, 120, 112, 61, 21, 210, 302, 60 | -93211791848491
-62282737107360 -38609546785173 0 } 1
123 { 122, 113, 121, 56, 20, 303, 211, 61 | 93211791848491
62282737107360 38609546785173 0 } 1
124 { 125, 134, 126, 62, 23, 140, 228, 38 | -923448946167
-1489654644813 2229411184640 0 } 1
125 { 124, 127, 135, 63, 22, 229, 141, 39 | 923448946167
1489654644813 -2229411184640 0 } 1
126 { 127, 124, 128, 63, 23, 226, 214, 32 | -93211791848491
-62282581920576 38609546785173 0 } 1
127 { 126, 129, 125, 64, 22, 215, 227, 33 | 93211791848491
62282581920576 -38609546785173 0 } 1
128 { 129, 126, 130, 64, 23, 212, 120, 34 | -2229411184640
129 { 128, 131, 127, 65, 22, 121, 213, 35 | 2229411184640
130 { 131, 128, 132, 65, 23, 118, 46, 0 | -2979318988800
131 { 130, 133, 129, 66, 22, 47, 119, 1 | 2979318988800
132 { 133, 130, 134, 66, 23, 44, 58, 6 | -203544324192
-735424338761 491396741088 0 } 1
133 { 132, 135, 131, 67, 22, 59, 45, 7 | 203544324192 735424338761
-491396741088 0 } 1
134 { 135, 132, 124, 67, 23, 56, 142, 4 | -3856468077 -13933819904
9310371840 0 } 1
135 { 134, 125, 133, 62, 22, 143, 57, 5 | 3856468077 13933819904
-9310371840 0 } 1
136 { 137, 146, 138, 68, 25, 152, 240, 42 | 923448946167
-1489659494400 2229411184640 0 } 1
137 { 136, 139, 147, 69, 24, 241, 153, 43 | -923448946167
1489659494400 -2229411184640 0 } 1
138 { 139, 136, 140, 69, 25, 238, 230, 36 | -38609546785173
-62282737107360 93211791848491 0 } 1
139 { 138, 141, 137, 70, 24, 231, 239, 37 | 38609546785173
62282737107360 -93211791848491 0 } 1
140 { 141, 138, 142, 70, 25, 228, 124, 38 | -923448946167
141 { 140, 143, 139, 71, 24, 125, 229, 39 | 923448946167
142 { 143, 140, 144, 71, 25, 134, 56, 4 | -3856468077 -13933819904
9310371840 0 } 1
143 { 142, 145, 141, 72, 24, 57, 135, 5 | 3856468077 13933819904
-9310371840 0 } 1
144 { 145, 142, 146, 72, 25, 54, 68, 10 | 21372154040160
145 { 144, 147, 143, 73, 24, 69, 55, 11 | -21372154040160
146 { 147, 144, 136, 73, 25, 66, 154, 8 | 1234069784640
147 { 146, 137, 145, 68, 24, 155, 67, 9 | -1234069784640
148 { 149, 158, 150, 74, 27, 164, 252, 46 | 2229411184640
-1489654644813 923448946167 0 } 1
149 { 148, 151, 159, 75, 26, 253, 165, 47 | -2229411184640
150 { 151, 148, 152, 75, 27, 250, 242, 40 | 38609546785173
-62282581920576 93211791848491 0 } 1
151 { 150, 153, 149, 76, 26, 243, 251, 41 | -38609546785173
62282581920576 -93211791848491 0 } 1
152 { 153, 150, 154, 76, 27, 240, 136, 42 | 923448946167
153 { 152, 155, 151, 77, 26, 137, 241, 43 | -923448946167
154 { 155, 152, 156, 77, 27, 146, 66, 8 | 1234069784640
155 { 154, 157, 153, 78, 26, 67, 147, 9 | -1234069784640
156 { 157, 154, 158, 78, 27, 64, 78, 14 | 491396741088
-735424338761 203544324192 0 } 1
157 { 156, 159, 155, 79, 26, 79, 65, 15 | -491396741088
158 { 159, 156, 148, 79, 27, 76, 166, 12 | 9310371840 -13933819904
3856468077 0 } 1
159 { 158, 149, 157, 74, 26, 167, 77, 13 | -9310371840 13933819904
-3856468077 0 } 1
160 { 161, 170, 162, 80, 29, 176, 264, 50 | 2229411184640
-1489659494400 -923448946167 0 } 1
161 { 160, 163, 171, 81, 28, 265, 177, 51 | -2229411184640
162 { 163, 160, 164, 81, 29, 262, 254, 44 | 93211791848491
-62282737107360 38609546785173 0 } 1
163 { 162, 165, 161, 82, 28, 255, 263, 45 | -93211791848491
164 { 165, 162, 166, 82, 29, 252, 148, 46 | 2229411184640
165 { 164, 167, 163, 83, 28, 149, 253, 47 | -2229411184640
166 { 167, 164, 168, 83, 29, 158, 76, 12 | 9310371840 -13933819904
3856468077 0 } 1
167 { 166, 169, 165, 84, 28, 77, 159, 13 | -9310371840 13933819904
-3856468077 0 } 1
168 { 169, 166, 170, 84, 29, 74, 88, 18 | 51596657814240
169 { 168, 171, 167, 85, 28, 89, 75, 19 | -51596657814240
170 { 171, 168, 160, 85, 29, 86, 178, 16 | 2979318988800
171 { 170, 161, 169, 80, 28, 179, 87, 17 | -2979318988800
172 { 173, 182, 174, 86, 31, 188, 276, 54 | 923448946167
-1489654644813 -2229411184640 0 } 1
173 { 172, 175, 183, 87, 30, 277, 189, 55 | -923448946167
174 { 175, 172, 176, 87, 31, 274, 266, 48 | 93211791848491
-62282581920576 -38609546785173 0 } 1
175 { 174, 177, 173, 88, 30, 267, 275, 49 | -93211791848491
176 { 177, 174, 178, 88, 31, 264, 160, 50 | 2229411184640
177 { 176, 179, 175, 89, 30, 161, 265, 51 | -2229411184640
178 { 179, 176, 180, 89, 31, 170, 86, 16 | 2979318988800
179 { 178, 181, 177, 90, 30, 87, 171, 17 | -2979318988800
180 { 181, 178, 182, 90, 31, 84, 98, 22 | 203544324192
-735424338761 -491396741088 0 } 1
181 { 180, 183, 179, 91, 30, 99, 85, 23 | -203544324192
182 { 183, 180, 172, 91, 31, 96, 190, 20 | 3856468077 -13933819904
-9310371840 0 } 1
183 { 182, 173, 181, 86, 30, 191, 97, 21 | -3856468077 13933819904
9310371840 0 } 1
184 { 185, 194, 186, 92, 33, 200, 288, 58 | -923448946167
-1489659494400 -2229411184640 0 } 1
185 { 184, 187, 195, 93, 32, 289, 201, 59 | 923448946167
186 { 187, 184, 188, 93, 33, 286, 278, 52 | 38609546785173
-62282737107360 -93211791848491 0 } 1
187 { 186, 189, 185, 94, 32, 279, 287, 53 | -38609546785173
188 { 189, 186, 190, 94, 33, 276, 172, 54 | 923448946167
189 { 188, 191, 187, 95, 32, 173, 277, 55 | -923448946167
190 { 191, 188, 192, 95, 33, 182, 96, 20 | 3856468077 -13933819904
-9310371840 0 } 1
191 { 190, 193, 189, 96, 32, 97, 183, 21 | -3856468077 13933819904
9310371840 0 } 1
192 { 193, 190, 194, 96, 33, 94, 108, 26 | -21372154040160
193 { 192, 195, 191, 97, 32, 109, 95, 27 | 21372154040160
194 { 195, 192, 184, 97, 33, 106, 202, 24 | -1234069784640
195 { 194, 185, 193, 92, 32, 203, 107, 25 | 1234069784640
196 { 197, 206, 198, 98, 35, 112, 300, 62 | -2229411184640
197 { 196, 199, 207, 99, 34, 301, 113, 63 | 2229411184640
198 { 199, 196, 200, 99, 35, 298, 290, 56 | -38609546785173
-62282581920576 -93211791848491 0 } 1
199 { 198, 201, 197, 100, 34, 291, 299, 57 | 38609546785173
200 { 201, 198, 202, 100, 35, 288, 184, 58 | -923448946167
201 { 200, 203, 199, 101, 34, 185, 289, 59 | 923448946167
202 { 203, 200, 204, 101, 35, 194, 106, 24 | -1234069784640
203 { 202, 205, 201, 102, 34, 107, 195, 25 | 1234069784640
204 { 205, 202, 206, 102, 35, 104, 40, 30 | -491396741088
205 { 204, 207, 203, 103, 34, 41, 105, 31 | 491396741088
206 { 207, 204, 196, 103, 35, 38, 114, 28 | -9310371840
207 { 206, 197, 205, 98, 34, 115, 39, 29 | 9310371840 13933819904
3856468077 0 } 1
208 { 209, 218, 210, 104, 37, 396, 292, 94 | -5235781646305
-1041434655168 -2168729432415 0 } 1
209 { 208, 211, 219, 105, 36, 293, 397, 95 | 5235781646305
1041434655168 2168729432415 0 } 1
210 { 211, 208, 212, 105, 37, 302, 122, 60 | -93211791848491
211 { 210, 213, 209, 106, 36, 123, 303, 61 | 93211791848491
212 { 213, 210, 214, 106, 37, 120, 128, 34 | -2229411184640
213 { 212, 215, 211, 107, 36, 129, 121, 35 | 2229411184640
214 { 215, 212, 216, 107, 37, 126, 226, 32 | -93211791848491
215 { 214, 217, 213, 108, 36, 227, 127, 33 | 93211791848491
216 { 217, 214, 218, 108, 37, 224, 308, 66 | -109951414572405
-21870528443584 45543318080715 0 } 1
217 { 216, 219, 215, 109, 36, 309, 225, 67 | 109951414572405
21870528443584 -45543318080715 0 } 1
218 { 219, 216, 208, 109, 37, 306, 398, 92 | -3719072710185
-739763883968 -1540496032215 0 } 1
219 { 218, 209, 217, 104, 36, 399, 307, 93 | 3719072710185
739763883968 1540496032215 0 } 1
220 { 221, 230, 222, 110, 39, 236, 324, 70 | -2168729432415
-1041434655168 5235781646305 0 } 1
221 { 220, 223, 231, 111, 38, 325, 237, 71 | 2168729432415
1041434655168 -5235781646305 0 } 1
222 { 223, 220, 224, 111, 39, 322, 310, 64 | -35419740097
-7045251072 14671390783 0 } 1
223 { 222, 225, 221, 112, 38, 311, 323, 65 | 35419740097
7045251072 -14671390783 0 } 1
224 { 225, 222, 226, 112, 39, 308, 216, 66 | -109951414572405
225 { 224, 227, 223, 113, 38, 217, 309, 67 | 109951414572405
226 { 227, 224, 228, 113, 39, 214, 126, 32 | -93211791848491
227 { 226, 229, 225, 114, 38, 127, 215, 33 | 93211791848491
228 { 229, 226, 230, 114, 39, 124, 140, 38 | -923448946167
229 { 228, 231, 227, 115, 38, 141, 125, 39 | 923448946167
230 { 231, 228, 220, 115, 39, 138, 238, 36 | -38609546785173
231 { 230, 221, 229, 110, 38, 239, 139, 37 | 38609546785173
232 { 233, 242, 234, 116, 41, 248, 336, 74 | 45543318080715
-21870528443584 109951414572405 0 } 1
233 { 232, 235, 243, 117, 40, 337, 249, 75 | -45543318080715
21870528443584 -109951414572405 0 } 1
234 { 235, 232, 236, 117, 41, 334, 326, 68 | -1540496032215
-739763883968 3719072710185 0 } 1
235 { 234, 237, 233, 118, 40, 327, 335, 69 | 1540496032215
739763883968 -3719072710185 0 } 1
236 { 237, 234, 238, 118, 41, 324, 220, 70 | -2168729432415
237 { 236, 239, 235, 119, 40, 221, 325, 71 | 2168729432415
238 { 239, 236, 240, 119, 41, 230, 138, 36 | -38609546785173
239 { 238, 241, 237, 120, 40, 139, 231, 37 | 38609546785173
240 { 241, 238, 242, 120, 41, 136, 152, 42 | 923448946167
241 { 240, 243, 239, 121, 40, 153, 137, 43 | -923448946167
242 { 243, 240, 232, 121, 41, 150, 250, 40 | 38609546785173
243 { 242, 233, 241, 116, 40, 251, 151, 41 | -38609546785173
244 { 245, 254, 246, 122, 43, 260, 348, 78 | 5235781646305
-1041434655168 2168729432415 0 } 1
245 { 244, 247, 255, 123, 42, 349, 261, 79 | -5235781646305
246 { 247, 244, 248, 123, 43, 346, 338, 72 | 14671390783
-7045251072 35419740097 0 } 1
247 { 246, 249, 245, 124, 42, 339, 347, 73 | -14671390783
7045251072 -35419740097 0 } 1
248 { 249, 246, 250, 124, 43, 336, 232, 74 | 45543318080715
249 { 248, 251, 247, 125, 42, 233, 337, 75 | -45543318080715
250 { 251, 248, 252, 125, 43, 242, 150, 40 | 38609546785173
251 { 250, 253, 249, 126, 42, 151, 243, 41 | -38609546785173
252 { 253, 250, 254, 126, 43, 148, 164, 46 | 2229411184640
253 { 252, 255, 251, 127, 42, 165, 149, 47 | -2229411184640
254 { 255, 252, 244, 127, 43, 162, 262, 44 | 93211791848491
255 { 254, 245, 253, 122, 42, 263, 163, 45 | -93211791848491
256 { 257, 266, 258, 128, 45, 272, 360, 82 | 109951414572405
-21870528443584 -45543318080715 0 } 1
257 { 256, 259, 267, 129, 44, 361, 273, 83 | -109951414572405
258 { 259, 256, 260, 129, 45, 358, 350, 76 | 3719072710185
-739763883968 1540496032215 0 } 1
259 { 258, 261, 257, 130, 44, 351, 359, 77 | -3719072710185
260 { 261, 258, 262, 130, 45, 348, 244, 78 | 5235781646305
261 { 260, 263, 259, 131, 44, 245, 349, 79 | -5235781646305
262 { 263, 260, 264, 131, 45, 254, 162, 44 | 93211791848491
263 { 262, 265, 261, 132, 44, 163, 255, 45 | -93211791848491
264 { 265, 262, 266, 132, 45, 160, 176, 50 | 2229411184640
265 { 264, 267, 263, 133, 44, 177, 161, 51 | -2229411184640
266 { 267, 264, 256, 133, 45, 174, 274, 48 | 93211791848491
267 { 266, 257, 265, 128, 44, 275, 175, 49 | -93211791848491
268 { 269, 278, 270, 134, 47, 284, 372, 86 | 2168729432415
-1041434655168 -5235781646305 0 } 1
269 { 268, 271, 279, 135, 46, 373, 285, 87 | -2168729432415
270 { 271, 268, 272, 135, 47, 370, 362, 80 | 35419740097
-7045251072 -14671390783 0 } 1
271 { 270, 273, 269, 136, 46, 363, 371, 81 | -35419740097
272 { 273, 270, 274, 136, 47, 360, 256, 82 | 109951414572405
273 { 272, 275, 271, 137, 46, 257, 361, 83 | -109951414572405
274 { 275, 272, 276, 137, 47, 266, 174, 48 | 93211791848491
275 { 274, 277, 273, 138, 46, 175, 267, 49 | -93211791848491
276 { 277, 274, 278, 138, 47, 172, 188, 54 | 923448946167
277 { 276, 279, 275, 139, 46, 189, 173, 55 | -923448946167
278 { 279, 276, 268, 139, 47, 186, 286, 52 | 38609546785173
279 { 278, 269, 277, 134, 46, 287, 187, 53 | -38609546785173
280 { 281, 290, 282, 140, 49, 296, 384, 90 | -45543318080715
-21870528443584 -109951414572405 0 } 1
281 { 280, 283, 291, 141, 48, 385, 297, 91 | 45543318080715
282 { 283, 280, 284, 141, 49, 382, 374, 84 | 1540496032215
-739763883968 -3719072710185 0 } 1
283 { 282, 285, 281, 142, 48, 375, 383, 85 | -1540496032215
284 { 285, 282, 286, 142, 49, 372, 268, 86 | 2168729432415
285 { 284, 287, 283, 143, 48, 269, 373, 87 | -2168729432415
286 { 287, 284, 288, 143, 49, 278, 186, 52 | 38609546785173
287 { 286, 289, 285, 144, 48, 187, 279, 53 | -38609546785173
288 { 289, 286, 290, 144, 49, 184, 200, 58 | -923448946167
289 { 288, 291, 287, 145, 48, 201, 185, 59 | 923448946167
290 { 291, 288, 280, 145, 49, 198, 298, 56 | -38609546785173
291 { 290, 281, 289, 140, 48, 299, 199, 57 | 38609546785173
292 { 293, 302, 294, 146, 51, 208, 396, 94 | -5235781646305
293 { 292, 295, 303, 147, 50, 397, 209, 95 | 5235781646305
294 { 295, 292, 296, 147, 51, 394, 386, 88 | -14671390783
-7045251072 -35419740097 0 } 1
295 { 294, 297, 293, 148, 50, 387, 395, 89 | 14671390783
296 { 297, 294, 298, 148, 51, 384, 280, 90 | -45543318080715
297 { 296, 299, 295, 149, 50, 281, 385, 91 | 45543318080715
298 { 299, 296, 300, 149, 51, 290, 198, 56 | -38609546785173
299 { 298, 301, 297, 150, 50, 199, 291, 57 | 38609546785173
300 { 301, 298, 302, 150, 51, 196, 112, 62 | -2229411184640
301 { 300, 303, 299, 151, 50, 113, 197, 63 | 2229411184640
302 { 303, 300, 292, 151, 51, 122, 210, 60 | -93211791848491
303 { 302, 293, 301, 146, 50, 211, 123, 61 | 93211791848491
304 { 305, 314, 306, 152, 53, 492, 388, 126 | -35419740097
305 { 304, 307, 315, 153, 52, 389, 493, 127 | 35419740097
306 { 307, 304, 308, 153, 53, 398, 218, 92 | -3719072710185
307 { 306, 309, 305, 154, 52, 219, 399, 93 | 3719072710185
308 { 309, 306, 310, 154, 53, 216, 224, 66 | -109951414572405
309 { 308, 311, 307, 155, 52, 225, 217, 67 | 109951414572405
310 { 311, 308, 312, 155, 53, 222, 322, 64 | -35419740097
311 { 310, 313, 309, 156, 52, 323, 223, 65 | 35419740097
312 { 313, 310, 314, 156, 53, 320, 404, 98 | -3719072710185
313 { 312, 315, 311, 157, 52, 405, 321, 99 | 3719072710185
314 { 315, 312, 304, 157, 53, 402, 494, 124 | -109951414572405
315 { 314, 305, 313, 152, 52, 495, 403, 125 | 109951414572405
316 { 317, 326, 318, 158, 55, 332, 420, 102 | -14671390783
317 { 316, 319, 327, 159, 54, 421, 333, 103 | 14671390783
318 { 319, 316, 320, 159, 55, 418, 406, 96 | -5235781646305
319 { 318, 321, 317, 160, 54, 407, 419, 97 | 5235781646305
320 { 321, 318, 322, 160, 55, 404, 312, 98 | -3719072710185
321 { 320, 323, 319, 161, 54, 313, 405, 99 | 3719072710185
322 { 323, 320, 324, 161, 55, 310, 222, 64 | -35419740097
323 { 322, 325, 321, 162, 54, 223, 311, 65 | 35419740097
324 { 325, 322, 326, 162, 55, 220, 236, 70 | -2168729432415
325 { 324, 327, 323, 163, 54, 237, 221, 71 | 2168729432415
326 { 327, 324, 316, 163, 55, 234, 334, 68 | -1540496032215
327 { 326, 317, 325, 158, 54, 335, 235, 69 | 1540496032215
328 { 329, 338, 330, 164, 57, 344, 432, 106 | 1540496032215
329 { 328, 331, 339, 165, 56, 433, 345, 107 | -1540496032215
330 { 331, 328, 332, 165, 57, 430, 422, 100 | -45543318080715
331 { 330, 333, 329, 166, 56, 423, 431, 101 | 45543318080715
332 { 333, 330, 334, 166, 57, 420, 316, 102 | -14671390783
333 { 332, 335, 331, 167, 56, 317, 421, 103 | 14671390783
334 { 335, 332, 336, 167, 57, 326, 234, 68 | -1540496032215
335 { 334, 337, 333, 168, 56, 235, 327, 69 | 1540496032215
336 { 337, 334, 338, 168, 57, 232, 248, 74 | 45543318080715
337 { 336, 339, 335, 169, 56, 249, 233, 75 | -45543318080715
338 { 339, 336, 328, 169, 57, 246, 346, 72 | 14671390783
339 { 338, 329, 337, 164, 56, 347, 247, 73 | -14671390783
340 { 341, 350, 342, 170, 59, 356, 444, 110 | 35419740097
341 { 340, 343, 351, 171, 58, 445, 357, 111 | -35419740097
342 { 343, 340, 344, 171, 59, 442, 434, 104 | 2168729432415
343 { 342, 345, 341, 172, 58, 435, 443, 105 | -2168729432415
344 { 345, 342, 346, 172, 59, 432, 328, 106 | 1540496032215
345 { 344, 347, 343, 173, 58, 329, 433, 107 | -1540496032215
346 { 347, 344, 348, 173, 59, 338, 246, 72 | 14671390783
347 { 346, 349, 345, 174, 58, 247, 339, 73 | -14671390783
348 { 349, 346, 350, 174, 59, 244, 260, 78 | 5235781646305
349 { 348, 351, 347, 175, 58, 261, 245, 79 | -5235781646305
350 { 351, 348, 340, 175, 59, 258, 358, 76 | 3719072710185
351 { 350, 341, 349, 170, 58, 359, 259, 77 | -3719072710185
352 { 353, 362, 354, 176, 61, 368, 456, 114 | 3719072710185
353 { 352, 355, 363, 177, 60, 457, 369, 115 | -3719072710185
354 { 355, 352, 356, 177, 61, 454, 446, 108 | 109951414572405
355 { 354, 357, 353, 178, 60, 447, 455, 109 | -109951414572405
356 { 357, 354, 358, 178, 61, 444, 340, 110 | 35419740097
357 { 356, 359, 355, 179, 60, 341, 445, 111 | -35419740097
358 { 359, 356, 360, 179, 61, 350, 258, 76 | 3719072710185
359 { 358, 361, 357, 180, 60, 259, 351, 77 | -3719072710185
360 { 361, 358, 362, 180, 61, 256, 272, 82 | 109951414572405
361 { 360, 363, 359, 181, 60, 273, 257, 83 | -109951414572405
362 { 363, 360, 352, 181, 61, 270, 370, 80 | 35419740097
363 { 362, 353, 361, 176, 60, 371, 271, 81 | -35419740097
364 { 365, 374, 366, 182, 63, 380, 468, 118 | 14671390783
365 { 364, 367, 375, 183, 62, 469, 381, 119 | -14671390783
366 { 367, 364, 368, 183, 63, 466, 458, 112 | 5235781646305
367 { 366, 369, 365, 184, 62, 459, 467, 113 | -5235781646305
368 { 369, 366, 370, 184, 63, 456, 352, 114 | 3719072710185
369 { 368, 371, 367, 185, 62, 353, 457, 115 | -3719072710185
370 { 371, 368, 372, 185, 63, 362, 270, 80 | 35419740097
371 { 370, 373, 369, 186, 62, 271, 363, 81 | -35419740097
372 { 373, 370, 374, 186, 63, 268, 284, 86 | 2168729432415
373 { 372, 375, 371, 187, 62, 285, 269, 87 | -2168729432415
374 { 375, 372, 364, 187, 63, 282, 382, 84 | 1540496032215
375 { 374, 365, 373, 182, 62, 383, 283, 85 | -1540496032215
376 { 377, 386, 378, 188, 65, 392, 480, 122 | -1540496032215
377 { 376, 379, 387, 189, 64, 481, 393, 123 | 1540496032215
378 { 379, 376, 380, 189, 65, 478, 470, 116 | 45543318080715
379 { 378, 381, 377, 190, 64, 471, 479, 117 | -45543318080715
380 { 381, 378, 382, 190, 65, 468, 364, 118 | 14671390783
381 { 380, 383, 379, 191, 64, 365, 469, 119 | -14671390783
382 { 383, 380, 384, 191, 65, 374, 282, 84 | 1540496032215
383 { 382, 385, 381, 192, 64, 283, 375, 85 | -1540496032215
384 { 385, 382, 386, 192, 65, 280, 296, 90 | -45543318080715
385 { 384, 387, 383, 193, 64, 297, 281, 91 | 45543318080715
386 { 387, 384, 376, 193, 65, 294, 394, 88 | -14671390783
387 { 386, 377, 385, 188, 64, 395, 295, 89 | 14671390783
388 { 389, 398, 390, 194, 67, 304, 492, 126 | -35419740097
389 { 388, 391, 399, 195, 66, 493, 305, 127 | 35419740097
390 { 391, 388, 392, 195, 67, 490, 482, 120 | -2168729432415
391 { 390, 393, 389, 196, 66, 483, 491, 121 | 2168729432415
392 { 393, 390, 394, 196, 67, 480, 376, 122 | -1540496032215
393 { 392, 395, 391, 197, 66, 377, 481, 123 | 1540496032215
394 { 395, 392, 396, 197, 67, 386, 294, 88 | -14671390783
395 { 394, 397, 393, 198, 66, 295, 387, 89 | 14671390783
396 { 397, 394, 398, 198, 67, 292, 208, 94 | -5235781646305
397 { 396, 399, 395, 199, 66, 209, 293, 95 | 5235781646305
398 { 399, 396, 388, 199, 67, 218, 306, 92 | -3719072710185
399 { 398, 389, 397, 194, 66, 307, 219, 93 | 3719072710185
400 { 401, 410, 402, 200, 69, 588, 484, 158 | -93211791848491
401 { 400, 403, 411, 201, 68, 485, 589, 159 | 93211791848491
402 { 403, 400, 404, 201, 69, 494, 314, 124 | -109951414572405
403 { 402, 405, 401, 202, 68, 315, 495, 125 | 109951414572405
404 { 405, 402, 406, 202, 69, 312, 320, 98 | -3719072710185
405 { 404, 407, 403, 203, 68, 321, 313, 99 | 3719072710185
406 { 407, 404, 408, 203, 69, 318, 418, 96 | -5235781646305
407 { 406, 409, 405, 204, 68, 419, 319, 97 | 5235781646305
408 { 409, 406, 410, 204, 69, 416, 500, 130 | -93211791848491
409 { 408, 411, 407, 205, 68, 501, 417, 131 | 93211791848491
410 { 411, 408, 400, 205, 69, 498, 590, 156 | -2229411184640
411 { 410, 401, 409, 200, 68, 591, 499, 157 | 2229411184640
412 { 413, 422, 414, 206, 71, 428, 516, 134 | -38609546785173
413 { 412, 415, 423, 207, 70, 517, 429, 135 | 38609546785173
414 { 415, 412, 416, 207, 71, 514, 502, 128 | -2229411184640
415 { 414, 417, 413, 208, 70, 503, 515, 129 | 2229411184640
416 { 417, 414, 418, 208, 71, 500, 408, 130 | -93211791848491
417 { 416, 419, 415, 209, 70, 409, 501, 131 | 93211791848491
418 { 419, 416, 420, 209, 71, 406, 318, 96 | -5235781646305
419 { 418, 421, 417, 210, 70, 319, 407, 97 | 5235781646305
420 { 421, 418, 422, 210, 71, 316, 332, 102 | -14671390783
421 { 420, 423, 419, 211, 70, 333, 317, 103 | 14671390783
422 { 423, 420, 412, 211, 71, 330, 430, 100 | -45543318080715
423 { 422, 413, 421, 206, 70, 431, 331, 101 | 45543318080715
424 { 425, 434, 426, 212, 73, 440, 528, 138 | 38609546785173
425 { 424, 427, 435, 213, 72, 529, 441, 139 | -38609546785173
426 { 427, 424, 428, 213, 73, 526, 518, 132 | -923448946167
427 { 426, 429, 425, 214, 72, 519, 527, 133 | 923448946167
428 { 429, 426, 430, 214, 73, 516, 412, 134 | -38609546785173
429 { 428, 431, 427, 215, 72, 413, 517, 135 | 38609546785173
430 { 431, 428, 432, 215, 73, 422, 330, 100 | -45543318080715
431 { 430, 433, 429, 216, 72, 331, 423, 101 | 45543318080715
432 { 433, 430, 434, 216, 73, 328, 344, 106 | 1540496032215
433 { 432, 435, 431, 217, 72, 345, 329, 107 | -1540496032215
434 { 435, 432, 424, 217, 73, 342, 442, 104 | 2168729432415
435 { 434, 425, 433, 212, 72, 443, 343, 105 | -2168729432415
436 { 437, 446, 438, 218, 75, 452, 540, 142 | 93211791848491
437 { 436, 439, 447, 219, 74, 541, 453, 143 | -93211791848491
438 { 439, 436, 440, 219, 75, 538, 530, 136 | 923448946167
439 { 438, 441, 437, 220, 74, 531, 539, 137 | -923448946167
440 { 441, 438, 442, 220, 75, 528, 424, 138 | 38609546785173
441 { 440, 443, 439, 221, 74, 425, 529, 139 | -38609546785173
442 { 443, 440, 444, 221, 75, 434, 342, 104 | 2168729432415
443 { 442, 445, 441, 222, 74, 343, 435, 105 | -2168729432415
444 { 445, 442, 446, 222, 75, 340, 356, 110 | 35419740097
445 { 444, 447, 443, 223, 74, 357, 341, 111 | -35419740097
446 { 447, 444, 436, 223, 75, 354, 454, 108 | 109951414572405
447 { 446, 437, 445, 218, 74, 455, 355, 109 | -109951414572405
448 { 449, 458, 450, 224, 77, 464, 552, 146 | 93211791848491
449 { 448, 451, 459, 225, 76, 553, 465, 147 | -93211791848491
450 { 451, 448, 452, 225, 77, 550, 542, 140 | 2229411184640
451 { 450, 453, 449, 226, 76, 543, 551, 141 | -2229411184640
452 { 453, 450, 454, 226, 77, 540, 436, 142 | 93211791848491
453 { 452, 455, 451, 227, 76, 437, 541, 143 | -93211791848491
454 { 455, 452, 456, 227, 77, 446, 354, 108 | 109951414572405
455 { 454, 457, 453, 228, 76, 355, 447, 109 | -109951414572405
456 { 457, 454, 458, 228, 77, 352, 368, 114 | 3719072710185
457 { 456, 459, 455, 229, 76, 369, 353, 115 | -3719072710185
458 { 459, 456, 448, 229, 77, 366, 466, 112 | 5235781646305
459 { 458, 449, 457, 224, 76, 467, 367, 113 | -5235781646305
460 { 461, 470, 462, 230, 79, 476, 564, 150 | 38609546785173
461 { 460, 463, 471, 231, 78, 565, 477, 151 | -38609546785173
462 { 463, 460, 464, 231, 79, 562, 554, 144 | 2229411184640
463 { 462, 465, 461, 232, 78, 555, 563, 145 | -2229411184640
464 { 465, 462, 466, 232, 79, 552, 448, 146 | 93211791848491
465 { 464, 467, 463, 233, 78, 449, 553, 147 | -93211791848491
466 { 467, 464, 468, 233, 79, 458, 366, 112 | 5235781646305
467 { 466, 469, 465, 234, 78, 367, 459, 113 | -5235781646305
468 { 469, 466, 470, 234, 79, 364, 380, 118 | 14671390783
469 { 468, 471, 467, 235, 78, 381, 365, 119 | -14671390783
470 { 471, 468, 460, 235, 79, 378, 478, 116 | 45543318080715
471 { 470, 461, 469, 230, 78, 479, 379, 117 | -45543318080715
472 { 473, 482, 474, 236, 81, 488, 576, 154 | -38609546785173
473 { 472, 475, 483, 237, 80, 577, 489, 155 | 38609546785173
474 { 475, 472, 476, 237, 81, 574, 566, 148 | 923448946167
475 { 474, 477, 473, 238, 80, 567, 575, 149 | -923448946167
476 { 477, 474, 478, 238, 81, 564, 460, 150 | 38609546785173
477 { 476, 479, 475, 239, 80, 461, 565, 151 | -38609546785173
478 { 479, 476, 480, 239, 81, 470, 378, 116 | 45543318080715
479 { 478, 481, 477, 240, 80, 379, 471, 117 | -45543318080715
480 { 481, 478, 482, 240, 81, 376, 392, 122 | -1540496032215
481 { 480, 483, 479, 241, 80, 393, 377, 123 | 1540496032215
482 { 483, 480, 472, 241, 81, 390, 490, 120 | -2168729432415
483 { 482, 473, 481, 236, 80, 491, 391, 121 | 2168729432415
484 { 485, 494, 486, 242, 83, 400, 588, 158 | -93211791848491
485 { 484, 487, 495, 243, 82, 589, 401, 159 | 93211791848491
486 { 487, 484, 488, 243, 83, 586, 578, 152 | -923448946167
487 { 486, 489, 485, 244, 82, 579, 587, 153 | 923448946167
488 { 489, 486, 490, 244, 83, 576, 472, 154 | -38609546785173
489 { 488, 491, 487, 245, 82, 473, 577, 155 | 38609546785173
490 { 491, 488, 492, 245, 83, 482, 390, 120 | -2168729432415
491 { 490, 493, 489, 246, 82, 391, 483, 121 | 2168729432415
492 { 493, 490, 494, 246, 83, 388, 304, 126 | -35419740097
493 { 492, 495, 491, 247, 82, 305, 389, 127 | 35419740097
494 { 495, 492, 484, 247, 83, 314, 402, 124 | -109951414572405
495 { 494, 485, 493, 242, 82, 403, 315, 125 | 109951414572405
496 { 497, 506, 498, 248, 85, 668, 580, 190 | -2979318988800
497 { 496, 499, 507, 249, 84, 581, 669, 191 | 2979318988800
498 { 499, 496, 500, 249, 85, 590, 410, 156 | -2229411184640
499 { 498, 501, 497, 250, 84, 411, 591, 157 | 2229411184640
500 { 501, 498, 502, 250, 85, 408, 416, 130 | -93211791848491
501 { 500, 503, 499, 251, 84, 417, 409, 131 | 93211791848491
502 { 503, 500, 504, 251, 85, 414, 514, 128 | -2229411184640
503 { 502, 505, 501, 252, 84, 515, 415, 129 | 2229411184640
504 { 505, 502, 506, 252, 85, 512, 596, 162 | -9310371840
13933819904 3856468077 0 } 1
505 { 504, 507, 503, 253, 84, 597, 513, 163 | 9310371840
506 { 507, 504, 496, 253, 85, 594, 670, 188 | -51596657814240
507 { 506, 497, 505, 248, 84, 671, 595, 189 | 51596657814240
508 { 509, 518, 510, 254, 87, 524, 608, 166 | -1234069784640
509 { 508, 511, 519, 255, 86, 609, 525, 167 | 1234069784640
510 { 511, 508, 512, 255, 87, 606, 598, 160 | -491396741088
511 { 510, 513, 509, 256, 86, 599, 607, 161 | 491396741088
512 { 513, 510, 514, 256, 87, 596, 504, 162 | -9310371840
513 { 512, 515, 511, 257, 86, 505, 597, 163 | 9310371840
514 { 515, 512, 516, 257, 87, 502, 414, 128 | -2229411184640
515 { 514, 517, 513, 258, 86, 415, 503, 129 | 2229411184640
516 { 517, 514, 518, 258, 87, 412, 428, 134 | -38609546785173
517 { 516, 519, 515, 259, 86, 429, 413, 135 | 38609546785173
518 { 519, 516, 508, 259, 87, 426, 526, 132 | -923448946167
519 { 518, 509, 517, 254, 86, 527, 427, 133 | 923448946167
520 { 521, 530, 522, 260, 89, 536, 618, 170 | 3856468077
13933819904 9310371840 0 } 1
521 { 520, 523, 531, 261, 88, 619, 537, 171 | -3856468077
-13933819904 -9310371840 0 } 1
522 { 523, 520, 524, 261, 89, 616, 610, 164 | -21372154040160
523 { 522, 525, 521, 262, 88, 611, 617, 165 | 21372154040160
524 { 525, 522, 526, 262, 89, 608, 508, 166 | -1234069784640
525 { 524, 527, 523, 263, 88, 509, 609, 167 | 1234069784640
526 { 527, 524, 528, 263, 89, 518, 426, 132 | -923448946167
527 { 526, 529, 525, 264, 88, 427, 519, 133 | 923448946167
528 { 529, 526, 530, 264, 89, 424, 440, 138 | 38609546785173
529 { 528, 531, 527, 265, 88, 441, 425, 139 | -38609546785173
530 { 531, 528, 520, 265, 89, 438, 538, 136 | 923448946167
531 { 530, 521, 529, 260, 88, 539, 439, 137 | -923448946167
532 { 533, 542, 534, 266, 91, 548, 628, 174 | 2979318988800
533 { 532, 535, 543, 267, 90, 629, 549, 175 | -2979318988800
534 { 535, 532, 536, 267, 91, 626, 620, 168 | 203544324192
535 { 534, 537, 533, 268, 90, 621, 627, 169 | -203544324192
536 { 537, 534, 538, 268, 91, 618, 520, 170 | 3856468077
537 { 536, 539, 535, 269, 90, 521, 619, 171 | -3856468077
538 { 539, 536, 540, 269, 91, 530, 438, 136 | 923448946167
539 { 538, 541, 537, 270, 90, 439, 531, 137 | -923448946167
540 { 541, 538, 542, 270, 91, 436, 452, 142 | 93211791848491
541 { 540, 543, 539, 271, 90, 453, 437, 143 | -93211791848491
542 { 543, 540, 532, 271, 91, 450, 550, 140 | 2229411184640
543 { 542, 533, 541, 266, 90, 551, 451, 141 | -2229411184640
544 { 545, 554, 546, 272, 93, 560, 638, 178 | 9310371840
545 { 544, 547, 555, 273, 92, 639, 561, 179 | -9310371840
-13933819904 3856468077 0 } 1
546 { 547, 544, 548, 273, 93, 636, 630, 172 | 51596657814240
547 { 546, 549, 545, 274, 92, 631, 637, 173 | -51596657814240
548 { 549, 546, 550, 274, 93, 628, 532, 174 | 2979318988800
549 { 548, 551, 547, 275, 92, 533, 629, 175 | -2979318988800
550 { 551, 548, 552, 275, 93, 542, 450, 140 | 2229411184640
551 { 550, 553, 549, 276, 92, 451, 543, 141 | -2229411184640
552 { 553, 550, 554, 276, 93, 448, 464, 146 | 93211791848491
553 { 552, 555, 551, 277, 92, 465, 449, 147 | -93211791848491
554 { 555, 552, 544, 277, 93, 462, 562, 144 | 2229411184640
555 { 554, 545, 553, 272, 92, 563, 463, 145 | -2229411184640
556 { 557, 566, 558, 278, 95, 572, 648, 182 | 1234069784640
557 { 556, 559, 567, 279, 94, 649, 573, 183 | -1234069784640
558 { 559, 556, 560, 279, 95, 646, 640, 176 | 491396741088
559 { 558, 561, 557, 280, 94, 641, 647, 177 | -491396741088
560 { 561, 558, 562, 280, 95, 638, 544, 178 | 9310371840
561 { 560, 563, 559, 281, 94, 545, 639, 179 | -9310371840
562 { 563, 560, 564, 281, 95, 554, 462, 144 | 2229411184640
563 { 562, 565, 561, 282, 94, 463, 555, 145 | -2229411184640
564 { 565, 562, 566, 282, 95, 460, 476, 150 | 38609546785173
565 { 564, 567, 563, 283, 94, 477, 461, 151 | -38609546785173
566 { 567, 564, 556, 283, 95, 474, 574, 148 | 923448946167
567 { 566, 557, 565, 278, 94, 575, 475, 149 | -923448946167
568 { 569, 578, 570, 284, 97, 584, 658, 186 | -3856468077
569 { 568, 571, 579, 285, 96, 659, 585, 187 | 3856468077
-13933819904 9310371840 0 } 1
570 { 571, 568, 572, 285, 97, 656, 650, 180 | 21372154040160
571 { 570, 573, 569, 286, 96, 651, 657, 181 | -21372154040160
572 { 573, 570, 574, 286, 97, 648, 556, 182 | 1234069784640
573 { 572, 575, 571, 287, 96, 557, 649, 183 | -1234069784640
574 { 575, 572, 576, 287, 97, 566, 474, 148 | 923448946167
575 { 574, 577, 573, 288, 96, 475, 567, 149 | -923448946167
576 { 577, 574, 578, 288, 97, 472, 488, 154 | -38609546785173
577 { 576, 579, 575, 289, 96, 489, 473, 155 | 38609546785173
578 { 579, 576, 568, 289, 97, 486, 586, 152 | -923448946167
579 { 578, 569, 577, 284, 96, 587, 487, 153 | 923448946167
580 { 581, 590, 582, 290, 99, 496, 668, 190 | -2979318988800
581 { 580, 583, 591, 291, 98, 669, 497, 191 | 2979318988800
582 { 583, 580, 584, 291, 99, 666, 660, 184 | -203544324192
583 { 582, 585, 581, 292, 98, 661, 667, 185 | 203544324192
584 { 585, 582, 586, 292, 99, 658, 568, 186 | -3856468077
585 { 584, 587, 583, 293, 98, 569, 659, 187 | 3856468077
586 { 587, 584, 588, 293, 99, 578, 486, 152 | -923448946167
587 { 586, 589, 585, 294, 98, 487, 579, 153 | 923448946167
588 { 589, 586, 590, 294, 99, 484, 400, 158 | -93211791848491
589 { 588, 591, 587, 295, 98, 401, 485, 159 | 93211791848491
590 { 591, 588, 580, 295, 99, 410, 498, 156 | -2229411184640
591 { 590, 581, 589, 290, 98, 499, 411, 157 | 2229411184640
592 { 593, 600, 594, 296, 101, 16, 662, 222 | -18118121083456
593 { 592, 595, 601, 297, 100, 663, 17, 223 | 18118121083456
594 { 595, 592, 596, 297, 101, 670, 506, 188 | -51596657814240
595 { 594, 597, 593, 298, 100, 507, 671, 189 | 51596657814240
596 { 597, 594, 598, 298, 101, 504, 512, 162 | -9310371840
597 { 596, 599, 595, 299, 100, 513, 505, 163 | 9310371840
598 { 599, 596, 600, 299, 101, 510, 606, 160 | -491396741088
599 { 598, 601, 597, 300, 100, 607, 511, 161 | 491396741088
600 { 601, 598, 592, 300, 101, 604, 18, 208 | -18118121083456
601 { 600, 593, 599, 296, 100, 19, 605, 209 | 18118121083456
602 { 603, 610, 604, 301, 103, 614, 20, 210 | -7504813123904
603 { 602, 605, 611, 302, 102, 21, 615, 211 | 7504813123904
604 { 605, 602, 606, 302, 103, 18, 600, 208 | -18118121083456
605 { 604, 607, 603, 303, 102, 601, 19, 209 | 18118121083456
606 { 607, 604, 608, 303, 103, 598, 510, 160 | -491396741088
607 { 606, 609, 605, 304, 102, 511, 599, 161 | 491396741088
608 { 609, 606, 610, 304, 103, 508, 524, 166 | -1234069784640
609 { 608, 611, 607, 305, 102, 525, 509, 167 | 1234069784640
610 { 611, 608, 602, 305, 103, 522, 616, 164 | -21372154040160
611 { 610, 603, 609, 301, 102, 617, 523, 165 | 21372154040160
612 { 613, 620, 614, 306, 105, 624, 22, 212 | 7504813123904
613 { 612, 615, 621, 307, 104, 23, 625, 213 | -7504813123904
614 { 615, 612, 616, 307, 105, 20, 602, 210 | -7504813123904
615 { 614, 617, 613, 308, 104, 603, 21, 211 | 7504813123904
616 { 617, 614, 618, 308, 105, 610, 522, 164 | -21372154040160
617 { 616, 619, 615, 309, 104, 523, 611, 165 | 21372154040160
618 { 619, 616, 620, 309, 105, 520, 536, 170 | 3856468077
619 { 618, 621, 617, 310, 104, 537, 521, 171 | -3856468077
620 { 621, 618, 612, 310, 105, 534, 626, 168 | 203544324192
621 { 620, 613, 619, 306, 104, 627, 535, 169 | -203544324192
622 { 623, 630, 624, 311, 107, 634, 24, 214 | 18118121083456
623 { 622, 625, 631, 312, 106, 25, 635, 215 | -18118121083456
624 { 625, 622, 626, 312, 107, 22, 612, 212 | 7504813123904
625 { 624, 627, 623, 313, 106, 613, 23, 213 | -7504813123904
626 { 627, 624, 628, 313, 107, 620, 534, 168 | 203544324192
627 { 626, 629, 625, 314, 106, 535, 621, 169 | -203544324192
628 { 629, 626, 630, 314, 107, 532, 548, 174 | 2979318988800
629 { 628, 631, 627, 315, 106, 549, 533, 175 | -2979318988800
630 { 631, 628, 622, 315, 107, 546, 636, 172 | 51596657814240
631 { 630, 623, 629, 311, 106, 637, 547, 173 | -51596657814240
632 { 633, 640, 634, 316, 109, 644, 26, 216 | 18118121083456
633 { 632, 635, 641, 317, 108, 27, 645, 217 | -18118121083456
634 { 635, 632, 636, 317, 109, 24, 622, 214 | 18118121083456
635 { 634, 637, 633, 318, 108, 623, 25, 215 | -18118121083456
636 { 637, 634, 638, 318, 109, 630, 546, 172 | 51596657814240
637 { 636, 639, 635, 319, 108, 547, 631, 173 | -51596657814240
638 { 639, 636, 640, 319, 109, 544, 560, 178 | 9310371840
639 { 638, 641, 637, 320, 108, 561, 545, 179 | -9310371840
640 { 641, 638, 632, 320, 109, 558, 646, 176 | 491396741088
641 { 640, 633, 639, 316, 108, 647, 559, 177 | -491396741088
642 { 643, 650, 644, 321, 111, 654, 28, 218 | 7504813123904
643 { 642, 645, 651, 322, 110, 29, 655, 219 | -7504813123904
644 { 645, 642, 646, 322, 111, 26, 632, 216 | 18118121083456
645 { 644, 647, 643, 323, 110, 633, 27, 217 | -18118121083456
646 { 647, 644, 648, 323, 111, 640, 558, 176 | 491396741088
647 { 646, 649, 645, 324, 110, 559, 641, 177 | -491396741088
648 { 649, 646, 650, 324, 111, 556, 572, 182 | 1234069784640
649 { 648, 651, 647, 325, 110, 573, 557, 183 | -1234069784640
650 { 651, 648, 642, 325, 111, 570, 656, 180 | 21372154040160
651 { 650, 643, 649, 321, 110, 657, 571, 181 | -21372154040160
652 { 653, 660, 654, 326, 113, 664, 30, 220 | -7504813123904
653 { 652, 655, 661, 327, 112, 31, 665, 221 | 7504813123904
654 { 655, 652, 656, 327, 113, 28, 642, 218 | 7504813123904
655 { 654, 657, 653, 328, 112, 643, 29, 219 | -7504813123904
656 { 657, 654, 658, 328, 113, 650, 570, 180 | 21372154040160
657 { 656, 659, 655, 329, 112, 571, 651, 181 | -21372154040160
658 { 659, 656, 660, 329, 113, 568, 584, 186 | -3856468077
659 { 658, 661, 657, 330, 112, 585, 569, 187 | 3856468077
660 { 661, 658, 652, 330, 113, 582, 666, 184 | -203544324192
661 { 660, 653, 659, 326, 112, 667, 583, 185 | 203544324192
662 { 663, 670, 664, 331, 115, 592, 16, 222 | -18118121083456
663 { 662, 665, 671, 332, 114, 17, 593, 223 | 18118121083456
664 { 665, 662, 666, 332, 115, 30, 652, 220 | -7504813123904
665 { 664, 667, 663, 333, 114, 653, 31, 221 | 7504813123904
666 { 667, 664, 668, 333, 115, 660, 582, 184 | -203544324192
667 { 666, 669, 665, 334, 114, 583, 661, 185 | 203544324192
668 { 669, 666, 670, 334, 115, 580, 496, 190 | -2979318988800
669 { 668, 671, 667, 335, 114, 497, 581, 191 | 2979318988800
670 { 671, 668, 662, 335, 115, 506, 594, 188 | -51596657814240
671 { 670, 663, 669, 331, 114, 595, 507, 189 | 51596657814240
0 { 0, 1 , , , 0 } 0
1 { 0, 0 , , , 1 } 1
2 { 1, 17 , , , 0 } 0
3 { 1, 16 , , , 1 } 1
4 { 2, 33 , , , 0 } 0
5 { 2, 32 , , , 1 } 1
6 { 3, 43 , , , 0 } 0
7 { 3, 42 , , , 1 } 1
8 { 4, 53 , , , 0 } 0
9 { 4, 52 , , , 1 } 1
10 { 5, 63 , , , 0 } 0
11 { 5, 62 , , , 1 } 1
12 { 6, 73 , , , 0 } 0
13 { 6, 72 , , , 1 } 1
14 { 7, 83 , , , 0 } 0
15 { 7, 82 , , , 1 } 1
16 { 8, 93 , , , 0 } 0
17 { 8, 92 , , , 1 } 1
18 { 9, 103 , , , 0 } 0
19 { 9, 102 , , , 1 } 1
20 { 10, 113 , , , 0 } 0
21 { 10, 112 , , , 1 } 1
22 { 11, 125 , , , 0 } 0
23 { 11, 124 , , , 1 } 1
24 { 12, 137 , , , 0 } 0
25 { 12, 136 , , , 1 } 1
26 { 13, 149 , , , 0 } 0
27 { 13, 148 , , , 1 } 1
28 { 14, 161 , , , 0 } 0
29 { 14, 160 , , , 1 } 1
30 { 15, 173 , , , 0 } 0
31 { 15, 172 , , , 1 } 1
32 { 16, 185 , , , 0 } 0
33 { 16, 184 , , , 1 } 1
34 { 17, 197 , , , 0 } 0
35 { 17, 196 , , , 1 } 1
36 { 18, 209 , , , 0 } 0
37 { 18, 208 , , , 1 } 1
38 { 19, 221 , , , 0 } 0
39 { 19, 220 , , , 1 } 1
40 { 20, 233 , , , 0 } 0
41 { 20, 232 , , , 1 } 1
42 { 21, 245 , , , 0 } 0
43 { 21, 244 , , , 1 } 1
44 { 22, 257 , , , 0 } 0
45 { 22, 256 , , , 1 } 1
46 { 23, 269 , , , 0 } 0
47 { 23, 268 , , , 1 } 1
48 { 24, 281 , , , 0 } 0
49 { 24, 280 , , , 1 } 1
50 { 25, 293 , , , 0 } 0
51 { 25, 292 , , , 1 } 1
52 { 26, 305 , , , 0 } 0
53 { 26, 304 , , , 1 } 1
54 { 27, 317 , , , 0 } 0
55 { 27, 316 , , , 1 } 1
56 { 28, 329 , , , 0 } 0
57 { 28, 328 , , , 1 } 1
58 { 29, 341 , , , 0 } 0
59 { 29, 340 , , , 1 } 1
60 { 30, 353 , , , 0 } 0
61 { 30, 352 , , , 1 } 1
62 { 31, 365 , , , 0 } 0
63 { 31, 364 , , , 1 } 1
64 { 32, 377 , , , 0 } 0
65 { 32, 376 , , , 1 } 1
66 { 33, 389 , , , 0 } 0
67 { 33, 388 , , , 1 } 1
68 { 34, 401 , , , 0 } 0
69 { 34, 400 , , , 1 } 1
70 { 35, 413 , , , 0 } 0
71 { 35, 412 , , , 1 } 1
72 { 36, 425 , , , 0 } 0
73 { 36, 424 , , , 1 } 1
74 { 37, 437 , , , 0 } 0
75 { 37, 436 , , , 1 } 1
76 { 38, 449 , , , 0 } 0
77 { 38, 448 , , , 1 } 1
78 { 39, 461 , , , 0 } 0
79 { 39, 460 , , , 1 } 1
80 { 40, 473 , , , 0 } 0
81 { 40, 472 , , , 1 } 1
82 { 41, 485 , , , 0 } 0
83 { 41, 484 , , , 1 } 1
84 { 42, 497 , , , 0 } 0
85 { 42, 496 , , , 1 } 1
86 { 43, 509 , , , 0 } 0
87 { 43, 508 , , , 1 } 1
88 { 44, 521 , , , 0 } 0
89 { 44, 520 , , , 1 } 1
90 { 45, 533 , , , 0 } 0
91 { 45, 532 , , , 1 } 1
92 { 46, 545 , , , 0 } 0
93 { 46, 544 , , , 1 } 1
94 { 47, 557 , , , 0 } 0
95 { 47, 556 , , , 1 } 1
96 { 48, 569 , , , 0 } 0
97 { 48, 568 , , , 1 } 1
98 { 49, 581 , , , 0 } 0
99 { 49, 580 , , , 1 } 1
100 { 50, 593 , , , 0 } 0
101 { 50, 592 , , , 1 } 1
102 { 51, 603 , , , 0 } 0
103 { 51, 602 , , , 1 } 1
104 { 52, 613 , , , 0 } 0
105 { 52, 612 , , , 1 } 1
106 { 53, 623 , , , 0 } 0
107 { 53, 622 , , , 1 } 1
108 { 54, 633 , , , 0 } 0
109 { 54, 632 , , , 1 } 1
110 { 55, 643 , , , 0 } 0
111 { 55, 642 , , , 1 } 1
112 { 56, 653 , , , 0 } 0
113 { 56, 652 , , , 1 } 1
114 { 57, 663 , , , 0 } 0
115 { 57, 662 , , , 1 } 1
/* end Selective Nef complex */
[attachment "sphere.off" removed by Peter Hachenberger]
