- To:
- Subject: Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation
- Date: Fri, 12 Jun 2009 21:53:37 +0200
As an independent check, I would suggest converting your models to GNU GTS format (easiest via STL format) and using its check routines. You can check GTS' boolean operations too to check it they work for your model.
-- Dominik
Laure Guicherd wrote:
Hi everyone,
First i would like to thank you for all the great work.
I'm having a problem with boolean operations on Nef_polyhedron_3.
I'm using a Simple_cartesian<Gmpq> kernel and so far everything was ok, it really works fine with a lot of models :)
But I'm in trouble with a model that seems to be problematic, that passes every test with success (the Polyhedron converted from my geometry is both "valid" and "closed", and the Nef polyhedron converted from this polyhedron is "valid" and "simple".)
So I can get a valid nef, but when i try to compute boolean operations with a simple sphere (attached as sphere.off), the program crashes on :
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: itl != it->second.end()
File: /net/rnd/src/CGAL-3.4/linux-x86_64-gcc-4.1.1/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1088
Abort
I must admit I am really stuck here, as the model seems closed, valid and with no self-intersections.
The strangest thing is that it works fine with a cube, or most of the time if the sphere intersects the model differently.
I'm really sorry that the model is really big, unfortunately I was unable to reproduce the problem with a simpler one, so here is the path to the .off file (that is too big to be attached for the mailing list) : http://dl.free.fr/rXNVUQVqg
Am i missing something ? Or do you think there is a problem with the model topology ? And if there is, how can i detect it in the future to prevent crashes ?
Any help would be really appreciated, thank you !
Best regards,
Laure Guicherd
- [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation, Laure Guicherd, 06/12/2009
- Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation, Dominik Szczerba, 06/12/2009
- Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolea n operation, Peter Hachenberger, 06/13/2009
- Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation, Laure Guicherd, 06/15/2009
- Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation, Fred Dorosh, 06/15/2009
- Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolea n operation, Peter Hachenberger, 06/15/2009
- Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation, Laure Guicherd, 06/16/2009
- Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation, Andreas Fabri, 06/16/2009
- Re: [cgal-discuss] Crash on a Nef_polyhedron_3 boolean operation, Laure Guicherd, 06/25/2009
