- To:
- Cc: Matthew Denno <>
- Subject: Re: [cgal-discuss] cgal-intersection-0.4
- Date: Mon, 15 Jun 2009 15:15:53 +0200
Laurent Rineau (GeometryFactory) wrote:
Le lundi 15 juin 2009 02:32:02, Matthew Denno a écrit :
> Hi All,
> Does anyone know if the cgal-intersection-0.4 extension for CGAL works
> with CGAL version 3.4 for doing Triangle_3-Triangle_3 intersection?
> According to the documentation, the last version it was tested with
> was CGAL v2.4.
> Also, am I correct to think that this Triangle_3-Triangle_3
> intersection is not available natively in the most recent version
> CGAL? It looks like it is not available according to the
> documentation for CGAL::intersect documentation:
> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Kernel_23_ref/Function_
>intersection.html#Cross_link_anchor_332
> Are there any plans to include this in future versions?
In CGAL-3.4, you have the intersection *test* (that only returns true/false)
for triangles.
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Kernel_23_ref/Function_do_intersect.html
So there is no way to get the intersection coordinates? I believe this would be available to the internal routine...?
-- Dominik
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] cgal-intersection-0.4, Matthew Denno, 06/15/2009
- Message not available
- Re: [cgal-discuss] cgal-intersection-0.4, Matthew Denno, 06/15/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] cgal-intersection-0.4, Laurent Rineau (GeometryFactory), 06/15/2009
- Re: [cgal-discuss] cgal-intersection-0.4, Dominik Szczerba, 06/15/2009
- Re: [cgal-discuss] cgal-intersection-0.4, Bernd Gaertner, 06/15/2009
