- To:
- Cc: Matthew Denno <>
- Subject: Re: [cgal-discuss] cgal-intersection-0.4
- Date: Mon, 15 Jun 2009 15:27:37 +0200
Dominik Szczerba wrote:
In CGAL-3.4, you have the intersection *test* (that only returns true/false)
for triangles.
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Kernel_23_ref/Function_do_intersect.html
So there is no way to get the intersection coordinates? I believe this would be available to the internal routine...?
You can also use the Polytope_distance_d package to obtain *some* point of intersection, if there is one, but you can't control which one you get: http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Polytope_distance_d_ref/Class_Polytope_distance_d.html#Cross_link_anchor_1520
Best,
Bernd.
- [cgal-discuss] cgal-intersection-0.4, Matthew Denno, 06/15/2009
- Message not available
- Re: [cgal-discuss] cgal-intersection-0.4, Matthew Denno, 06/15/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] cgal-intersection-0.4, Laurent Rineau (GeometryFactory), 06/15/2009
- Re: [cgal-discuss] cgal-intersection-0.4, Dominik Szczerba, 06/15/2009
- Re: [cgal-discuss] cgal-intersection-0.4, Bernd Gaertner, 06/15/2009
