cgal-discuss - Re: [cgal-discuss] cgal-intersection-0.4
  • To:
  • Subject: Re: [cgal-discuss] cgal-intersection-0.4
  • Date: Mon, 15 Jun 2009 22:27:13 +0200
(Sorry, I send a mail twice by error. Here is the second one I should have
sent.)
Le lundi 15 juin 2009 14:41:59, Matthew Denno a écrit :
> Thank you Laurent for your reply.
> I have been experimenting with do_intersect, so I can now identify which
> triangles intersect but not the geometry of the intersection (Segment,
> Point, Polygon). Do you know if there are any plans to include Triangle_3
> - Triangle_3 intersection in future versions?
As far as I know that will not be part of next release. Nobody is working on
that. If you want to handle only the generic case, you can do:
if(do_intersect(t1, t2) {
Object obj = intersection(t1.supporting_plane(), t2.supporting_plane());
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
