cgal-discuss - Re: [cgal-discuss] Unable to start program
  • To:
  • Subject: Re: [cgal-discuss] Unable to start program
  • Date: Sat, 27 Jun 2009 13:11:19 +0200
I done the installation with the same reference BUT i follow the
instruction of 5.Install CGAL
11.Edit the CMAKE_BUILD_TYPE to Debug
in cmake-gui for generation of the VS solution project in order to compile CGAL
I use VS9 anda my installation is working wel in 2 systems
XP, VISTA 64 bits.
Did you keep the original configuration to Release? this the defaut configuration! so maybe thats the problem why you cant run in debug mode
rlam
Citando
Hi,
I have installed cgal-3.4 on win xp 32 bit machine and I'm using Visual
Studio 8 2005 ... I did everything according to this page :
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
I compiled the simple_triangulation_3 example in debug mode and when I ran
the code this message appears :
Unable to start program :
This application has failed to start beacuse tha application configuration
is incorrect. Review the manifest file for possible errors. Reinstalling
the application may fix this problem. For more details, please see the
application event log.
Wen I compiled it in release mode it works fine. But I need the debug mode!!!
Can anyone help me?
Thanks,
Michal Jancosek
This message was sent using IMP, the Internet Messaging Program.
