cgal-discuss - Re: [cgal-discuss] Unable to start program
  • To:
  • Subject: Re: [cgal-discuss] Unable to start program
  • Date: Mon, 29 Jun 2009 16:11:00 +0200 (CEST)
  • Importance: Normal
Hi,
thank you for your sudgestion, but I have tryed it and nothing has
changed. I have tryed almost everything. Currently I reinstall boost to
newer version and reinstal CGAL again and it crashed again but with
different message :
simple_trinagluation_3.exe - Application Eror
The application failed to initialize properly (0xc0150002). Click OK to
terminate the appliaction
And again ... it was compiled in debug mode without errors but when I ran
the appliaction it crashed :(
Michal
> I done the installation with the same reference BUT i follow the
> instruction of 5.Install CGAL
>>>>> 11.Edit the CMAKE_BUILD_TYPE to Debug
> in cmake-gui for generation of the VS solution project in order to
> compile CGAL
> I use VS9 anda my installation is working wel in 2 systems
> XP, VISTA 64 bits.
> Did you keep the original configuration to Release? this the defaut
> configuration! so maybe thats the problem why you cant run in debug mode
> rlam
> Citando
>> Hi,
>> I have installed cgal-3.4 on win xp 32 bit machine and I'm using Visual
>> Studio 8 2005 ... I did everything according to this page :
>> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
>> I compiled the simple_triangulation_3 example in debug mode and when I
>> ran
>> the code this message appears :
>> Unable to start program :
>> This application has failed to start beacuse tha application
>> configuration
>> is incorrect. Review the manifest file for possible errors. Reinstalling
>> the application may fix this problem. For more details, please see the
>> application event log.
>> Wen I compiled it in release mode it works fine. But I need the debug
>> mode!!!
>> Can anyone help me?
>> Thanks,
>> Michal Jancosek
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
> This message was sent using IMP, the Internet Messaging Program.
