- To:
- Subject: Re: [cgal-discuss] Question about Nef Polyhedra
- Date: Sat, 27 Jun 2009 17:36:18 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=Yv4NbaCRI7Y1VV35J8/fuMrMmEce0akDHfyvUTSDH+pMp395DgY0NBOavj9l2NV0X3 VdX80hHMJ7x5+e5nOS9GuEqfxiR1lXI2H1dkMarQxBVjcyR1f+2sUXtKa/Bi+lVCMjbx tjfCS31nmO6z+rbHWl+GRbo80zaEr592AuCAw=
Hi,
Is it possible to build the Nef-polyhedra from some non-manifold dataset like a triangle-soup?
If yes, is there an example of Nef-polyhedron builder class like polyhedron builder.
Sorry for bringing up the question again. I was not sure if the question got noticed earlier.
thanks in anticipation,
-Atul
On Mon, Jun 15, 2009 at 9:07 PM, Joe C <> wrote:
I remember that the manual says the extended kernel could be used to handle non-manifold geometries. But I have no experience using that and there is no example code showing how to do that. I am also curious to know if there is a way to populate the Nef Polyhedron directly, for example, from triangle soup.
Thanks.
JoeOn Mon, Jun 15, 2009 at 4:58 PM, Atul Thakur <> wrote:
Hi all,
As far as my understanding goes about Nef Polyhedra, it is a kind of cellular model by which we can represent and operate upon the non-manifold geometries (please correct me if wrong).
Most of the CGAL examples that I have seen so far usually convert a simple Polyhedron into a Nef Polyhedron, which means that we always load manifold geometric data into a Nef Polyhedra.
If I need to operate upon a nonmanifold geometry like a sphere enclosed in a box, I am not sure how to load such data into Nef Polyhedra.
Is there a way to populate the Nef Polyhedron directly, using some kind of facet data? Can someone please point me to example code to do that?
thanks and regards,
-Atul
- [cgal-discuss] Question about Nef Polyhedra, Atul Thakur, 06/16/2009
- Re: [cgal-discuss] Question about Nef Polyhedra, Joe C, 06/16/2009
- Re: [cgal-discuss] Question about Nef Polyhedra, Atul Thakur, 06/27/2009
