cgal-discuss - [cgal-discuss] Problem of running demos!
  • To:
  • Subject: [cgal-discuss] Problem of running demos!
  • Date: Sat, 27 Jun 2009 21:45:46 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=lf3jXC30V+gcXjYm0seCGCPrX8BSBvfcOtoNv0oQ4kDrfOxVSAZnwt7dASd6elTLaS 2PsS6AlAlYtdB2xa9hBG6YN6bF0BkA7OAk3FVqAulMGTy2R6E8RgzxAa1PaMHckkb4ky OIlR/DyCi9KLxo4xOPYxkg8UYqmuGOGboE8Ow=
Hi, All:
I have successfully installed the CGAL in my computer and run the following example whihc is in the CGAL instruction manual.
but i cannot run any of the demos and example folders ( what i did is using the CMAKE to compile the *.sln file and then run it). there is a error message poped up in CMAKE process , the error message is as follow:
Anybody know how to fix this problem? any help will be appreciated!
Thanks a lot!
Guang
