cgal-discuss - Re: [cgal-discuss] Problem of running demos!
  • To:
  • Subject: Re: [cgal-discuss] Problem of running demos!
  • Date: Mon, 29 Jun 2009 10:29:56 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type:content-transfer-encoding; b=Vf2JXoPJyp03C2WSDZc4p0jMlme4KDkf30ENbDFj9wt14tT2eloMab+4RZQGHUM8Th s14acWHp57j/g1mgd01uO4SDHTZDX/+rtnfoxVg2Iy8yA5mgoEX4i5W/Mf33DEZuA/uE TRIeWMrIlAsuZ7FPoid4iwZcuw2Pyz20tsXBY=
On Sun, Jun 28, 2009 at 12:45,
Zheng,Guang<>
wrote:
> but i cannot run any of the demos and example folders ( what i did is using
> the CMAKE to compile the *.sln file and then run it). there is a error
> message poped up in CMAKE process , the error message is as follow:
The error message you mention is not visible in the email. Forgot to add it?
~ash
