- To:
- Subject: Re: [cgal-discuss] Problem of running demos!
- Date: Sun, 28 Jun 2009 20:21:03 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=TTYN1rUACDOTVgb9b7fp3/TRet/NRxAwHPgmRChZBy79rhTLqG47CrJbH8K7gV7pyJ f7BmlXRzG2CeDOOnFq1UJ9rjBvkzvEIy6BsXCIt72ZKgnlj/DISoS+0uDKJdabOQ5fZ4 ARDundm9vafoMIXGt4kRzPxZ2vNVNuBdQFfw0=
It seems like that I cannot send the email with a attached image, So I wil type in the error message as follow:
CMake Warning(dev) at : C:/CGAL/CGAL-3.4/cmake/modules/UseCGAL.cmake:16(include):
Policy CMP0011 is not set: Included scripts do automatic cmake_policy PUSH and POP. Run"cmake--help-policy CMP0011" for policy details. Use the cmake_policy command to set the policy and suppress this warning.
The included script
C:/CGAL/CGAL-3.4/ cmake/modules/CGAL_Command.cmake
affects policy settings. CMake is implying the NO_POLICY_SCOPE option for compatibility, so the effects are applied to the including context.
Call Stack(most recent call first):
CMakeLists.txt:19(include)
This warning is for project developer. Use-Wno-dev to suppress it.
(Press Cancel to suppress any further messages)
when i press ok till the "OK" button is available, i can get the *.sln file, and compile it successfully, when i run it, nothing happened.
Any help will be appreciated.
Guang
Guang
On 6/28/09, Ashwin Nanjappa <> wrote:
On Sun, Jun 28, 2009 at 12:45, Zheng,Guang<> wrote:
> but i cannot run any of the demos and example folders ( what i did is using
> the CMAKE to compile the *.sln file and then run it). there is a error
> message poped up in CMAKE process , the error message is as follow:
The error message you mention is not visible in the email. Forgot to add it? :-)
~ash
Guang Zheng
- [cgal-discuss] Problem of running demos!, Zheng,Guang, 06/28/2009
- Re: [cgal-discuss] Problem of running demos!, Ashwin Nanjappa, 06/29/2009
- Re: [cgal-discuss] Problem of running demos!, Zheng,Guang, 06/29/2009
