cgal-discuss - [cgal-discuss] Some problems on installing CGAL
  • To:
  • Subject: [cgal-discuss] Some problems on installing CGAL
  • Date: Fri, 10 Jul 2009 03:35:24 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type; b=YWrZCZicmQvYxhNIv+UknjIx9DRm75OCAXdMh0PhqLyaaWr6mjNeWqGCgun6gefged0I3u7D5mMrsb8oCqzXinP66yNuN3F/Ka58wAIedD3i1Fi5Xwmz7JmWFnt+r6aUvgWi0bdgnYhkiMUprc7CDfFH/qdkAPqAUqh/VsmRSrg=;
Hi,
I have installed CGAL on Windows with Cygwin platform. I have used CMAKE 2.6.4 for configuration and gcc 4.3.2 as the compiler. There are three issues which I would be appreciated very much to have a help on them:
 Firstly, the cmake file "findboost.cmake" does not identify the boost libraries. I have installed boost 1.33.1 from both cygwin available packages and also directly from www.boost.org. However after some modifications in the findboost.cmake file about name of searched libraries and also adding ".a" at the end of them, cmake was successful in finding them. But is it a correct way in configuring CGAL? This may be the source of the error I have described as the third case.
 Secondly, the compiler is not completely successful in passing the testfiles provided in "CGAL-3.4/config/testfiles". Al of failed cases are related to Cpp0x. Is it a serious problem?
 Thirdly, after installing CGAL,  I tried to implement the examples provided in "CGAL-3.4/examples" and have been NOT been successful in all of them. The error messages are related to the command "BOOST_STATIC_ASSERT" and all files having this command give errors in identifying it. What should I do to overcome this problem please?
 I would be very appreciated to have any help specially on the third case.
  • [cgal-discuss] Some problems on installing CGAL, a z, 07/10/2009
