cgal-discuss - Re: [cgal-discuss] Problems when installing taucs_full
  • To:
  • Subject: Re: [cgal-discuss] Problems when installing taucs_full
  • Date: Wed, 15 Jul 2009 10:59:59 +0200
  • Organization: INRIA
Marc Glisse wrote:
On Mon, 13 Jul 2009, Laurent Saboret wrote:
Hi sanlington,
I do not have gcc version 4.4 but I was able to reproduce the bug with gcc 4.3.
The first error occurs here:
obj/linux/taucs_blas_underscore_test build/linux/taucs_config_tests.h
obj/linux/taucs_blas_underscore_test: error while loading shared
libraries: libg2c.so.0: cannot open shared object file: No such file or
directory
You need the libg2c shared library, which is part of g77 Fortran compiler = GNU 3.x Fortran compiler.
You should install g77 (not gfortran = GNU 4.x Fortran compiler).
On my OS (Fedora 7), it comes for example in the compat-gcc-34-g77 rpm.
On a modern distro, you are better off not using g77 (or g2c) at all. For taucs, replacing g77 by gfortran and removing -lg2c in the config file and removing the precompiled libs (gfortran-compiled versions of which are provided by my distro) works fine.
You are right. I use g77 to be compatible with gcc 3.x which is still
supported by CGAL 3.4.
Regards,
Laurent Saboret
