- To: cgal-discuss <>
- Subject: Re:Re: [cgal-discuss] Problems when installing taucs_full
- Date: Fri, 10 Jul 2009 16:48:42 +0800 (CST)
i got the information as following:
[root@sanlington cgal2graphite]# cc -v
Using built-in specs.
Target: i586-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --enable-plugin --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre --enable-libgcj-multifile --enable-java-maintainer-mode --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --disable-libjava-multilib --with-ppl --with-cloog --with-tune=generic --with-arch=i586 --build=i586-redhat-linux
Thread model: posix
gcc version 4.4.0 20090506 (Red Hat 4.4.0-4) (GCC)
在2009-07-10,"Laurent Saboret" <> 写道: >Hi, > >Which version of gcc do you use (cc -v)? > >-- >Laurent Saboret >INRIA Sophia-Antipolis > > >sanlington a écrit : >> hi, >> i downloaded taucs_full.tgz >> <http://gforge.inria.fr/frs/download.php/12636/taucs_full.tgz> from >> www.cgal.org, when i tried to install it,some errors occured: >> >> [root@sanlington taucs_full]# ./configure >> cc -o configurator/configurator configurator/taucs_config.c >> >> [root@sanlington taucs_full]# make >> mkdir obj >> mkdir obj/linux/ >> echo exists > obj/linux/exists.log >> cc -c -O3 -Wall -std=c99 -DMACHTYPE_ -I src/ -I build/linux/ -I >> external/src/ \ >> progs/taucs_blas_underscore_test.c \ >> -o ./obj/linux/taucs_blas_underscore_test.o >> cc \ >> -o ./obj/linux/taucs_blas_underscore_test \ >> obj/linux/taucs_blas_underscore_test.o -L external/lib/linux >> -llapack -L external/lib/linux -lf77blas -lcblas -latlas -L >> external/lib/linux -lmetis -lg2c -lm >> obj/linux/taucs_blas_underscore_test build/linux/taucs_config_tests.h >> obj/linux/taucs_blas_underscore_test: error while loading shared >> libraries: libg2c.so.0: cannot open shared object file: No such file or >> directory >> make: [build/linux/taucs_config_tests.h] Error 127 (ignored) >> cc -c -O3 -Wall -std=c99 -DMACHTYPE_ -I src/ -I build/linux/ -I >> external/src/ \ >> progs/taucs_blas_nounderscore_test.c \ >> -o ./obj/linux/taucs_blas_nounderscore_test.o >> cc \ >> -o ./obj/linux/taucs_blas_nounderscore_test \ >> obj/linux/taucs_blas_nounderscore_test.o -L external/lib/linux >> -llapack -L external/lib/linux -lf77blas -lcblas -latlas -L >> external/lib/linux -lmetis -lg2c -lm >> obj/linux/taucs_blas_nounderscore_test.o: In function `main': >> taucs_blas_nounderscore_test.c:(.text+0xa4): undefined reference to `dgemm' >> collect2: ld returned 1 exit status >> make: [build/linux/taucs_config_tests.h] Error 1 (ignored) >> obj/linux/taucs_blas_nounderscore_test build/linux/taucs_config_tests.h >> make: obj/linux/taucs_blas_nounderscore_test: Command not found >> make: [build/linux/taucs_config_tests.h] Error 127 (ignored) >> cc -c -O3 -Wall -std=c99 -DMACHTYPE_ -I src/ -I build/linux/ -I >> external/src/ \ >> progs/taucs_c99_complex_test.c \ >> -o ./obj/linux/taucs_c99_complex_test.o >> cc \ >> -o ./obj/linux/taucs_c99_complex_test \ >> obj/linux/taucs_c99_complex_test.o -L external/lib/linux -llapack >> -L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux >> -lmetis -lg2c -lm >> obj/linux/taucs_c99_complex_test build/linux/taucs_config_tests.h >> obj/linux/taucs_c99_complex_test: error while loading shared libraries: >> libg2c.so.0: cannot open shared object file: No such file or directory >> make: [build/linux/taucs_config_tests.h] Error 127 (ignored) >> cc -c -O3 -Wall -std=c99 -DMACHTYPE_ -I src/ -I build/linux/ -I >> external/src/ \ >> progs/taucs_cilk_test.c \ >> -o ./obj/linux/taucs_cilk_test.o >> progs/taucs_cilk_test.c:8:19: error: cilk.h: No such file or directory >> progs/taucs_cilk_test.c:10: warning: ignoring #pragma lang >> progs/taucs_cilk_test.c:12: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or >> ‘__attribute__’ before ‘int’ >> progs/taucs_cilk_test.c:17: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or >> ‘__attribute__’ before ‘int’ >> make: [build/linux/taucs_config_tests.h] Error 1 (ignored) >> cc \ >> -o ./obj/linux/taucs_cilk_test \ >> obj/linux/taucs_cilk_test.o -L external/lib/linux -llapack -L >> external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux >> -lmetis -lg2c -lm >> cc: obj/linux/taucs_cilk_test.o: No such file or directory >> make: [build/linux/taucs_config_tests.h] Error 1 (ignored) >> obj/linux/taucs_cilk_test build/linux/taucs_config_tests.h >> make: obj/linux/taucs_cilk_test: Command not found >> make: [build/linux/taucs_config_tests.h] Error 127 (ignored) >> mkdir bin >> mkdir: cannot create directory `bin': File exists >> make: [bin/linux/exists.log] Error 1 (ignored) >> mkdir bin/linux/ >> echo exists > bin/linux/exists.log >> mkdir lib >> mkdir: cannot create directory `lib': File exists >> make: [lib/linux/exists.log] Error 1 (ignored) >> mkdir lib/linux/ >> echo exists > lib/linux/exists.log >> cc -c -O3 -Wall -std=c99 -DMACHTYPE_ -I src/ -I build/linux/ -I >> external/src/ \ >> -DTAUCS_CORE_GENERAL \ >> src/taucs_sn_llt.c \ >> -o ./obj/linux/taucs_sn_llt.o >> In file included from src/taucs_sn_llt.c:13: >> src/taucs.h:6:32: error: taucs_config_tests.h: No such file or directory >> src/taucs.h:79:2: error: #error "taucs_blas_[no]underscore_test: linking >> with the BLAS failed both attempts" >> In file included from src/taucs_sn_llt.c:13: >> src/taucs.h:828: error: ‘taucs_blas_name’ declared as function returning >> a function >> src/taucs.h:828: warning: parameter names (without types) in function >> declaration >> src/taucs.h:829: error: ‘taucs_blas_name’ declared as function returning >> a function >> src/taucs.h:829: warning: parameter names (without types) in function >> declaration >> src/taucs.h:830: error: ‘taucs_blas_name’ declared as function returning >> a function >> src/taucs.h:830: warning: parameter names (without types) in function >> declaration >> src/taucs.h:831: error: ‘taucs_blas_name’ declared as function returning >> a function >> src/taucs.h:831: warning: parameter names (without types) in function >> declaration >> make: *** [obj/linux/taucs_sn_llt.o] Error 1 >> >> how to do next ? >> >> >> >> ------------------------------------------------------------------------ >> 200万种商品,最低价格,疯狂诱惑你 >> <http://count.mail.163.com/redirect/footer.htm?f=http://gouwu.youdao.com> > > >-- >You are currently subscribed to cgal-discuss. >To unsubscribe or access the archives, go to >https://lists-sop.inria.fr/wws/info/cgal-discuss
200万种商品,最低价格,疯狂诱惑你
- [cgal-discuss] Problems when installing taucs_full, sanlington, 07/10/2009
- Re: [cgal-discuss] Problems when installing taucs_full, Laurent Saboret, 07/10/2009
- Re:Re: [cgal-discuss] Problems when installing taucs_full, sanlington, 07/10/2009
- Re: [cgal-discuss] Problems when installing taucs_full, Laurent Saboret, 07/13/2009
- Re: [cgal-discuss] Problems when installing taucs_full, Marc Glisse, 07/14/2009
- Re: [cgal-discuss] Problems when installing taucs_full, Laurent Saboret, 07/15/2009
