cgal-discuss - Re: [cgal-discuss] Why do_intersect and not an intersection?
  • To:
  • Subject: Re: [cgal-discuss] Why do_intersect and not an intersection?
  • Date: Thu, 16 Jul 2009 11:36:46 +0200
Recently I had to write some code to find the intersection of a
Triangle_3 and Segment_3. I noticed that I could do a
CGAL::do_intersect() [1] of these to find *if* there is any
intersection. But, I *cannot* do a CGAL::intersection() [2] of these
objects to obtain the intersection object. What is the reason for this
API design?
Currently, I get around this by:
(1) Getting the Plane_3 of the triangle using Triangle_3::supporting_plane()
(2) CGAL::intersection of the Plane_3 and the Segment_3 to get the
(3) Checking if the intersection CGALObject thus obtained lies on the
Triangle_3.
Is there a better way to do this?
A better way would be to use the do_intersect predicate, because it is exact and still efficient, as soon as you are using an Exact_predicate_inexact_constructions_kernel. This would mean
1) checking whether the Triangle_3 and the Segment_3 do intersect or not with CGAL::do_intersect
2) if they do intersect, using CGAL::intersection for the supporting_plane of the triangle and the segment. Then you have to deal with the various possible results (in particular with an inexact constructions kernel): if it is a point, you are done. If it is empty (this is possible if the constructions are inexact, this is not a bug), you face a robustness issue that you will have to solve in the most relevant way for your application. If it is the whole segment, you have to compute the intersection of a triangle and a segment in a 2d plane in 3-space. You can then use CGAL::intersection between Triangle_2 and Segment_2, after projection.
For (2), either you will use an exact constructions (but slow) kernel, and the code will be simple for you to write anyway, or you will use an inexact constructions (but fast) kernel, and you will have to choose how to deal with the unavoidable robustness issues.
I hope this makes clear why it is much more important to provide the do_intersect predicate than the intersection construction for these data types.
Camille
