cgal-discuss - Re: [cgal-discuss] Why do_intersect and not an intersection?
  • To:
  • Subject: Re: [cgal-discuss] Why do_intersect and not an intersection?
  • Date: Mon, 27 Jul 2009 17:30:29 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type:content-transfer-encoding; b=mJRqehZs8me+mqVSmnqU+mBZaWrDnNq9uzib4bdRpNPn42dPCS5yJGkUrXOzoYrmcB 2Jd61U0U+c/+GQ75W+NHD6TbliTmCsfCNurjjzHhLI4U8Ij1cWCEl16Fx9uU4TkRob/2 HyplcRzjPbRHQksHkhlimxChP2zEmrkMU3kr8=
On Thu, Jul 16, 2009 at 17:36, Camille
Wormser<>
wrote:
> A better way would be to use the do_intersect predicate, because it is exact
> and still efficient, as soon as you are using an
> Exact_predicate_inexact_constructions_kernel. This would mean
> 1) checking whether the Triangle_3 and the Segment_3 do intersect or not
> with CGAL::do_intersect
> 2) if they do intersect, using CGAL::intersection for the supporting_plane
> of the triangle and the segment. Then you have to deal with the various
> possible results (in particular with an inexact constructions kernel):
> For (2), either you will use an exact constructions (but slow) kernel, and
> the code will be simple for you to write anyway, or you will use an inexact
> constructions (but fast) kernel, and you will have to choose how to deal
> with the unavoidable robustness issues.
> I hope this makes clear why it is much more important to provide the
> do_intersect predicate than the intersection construction for these data
> types.
Thanks Camille, for making it clear. do_intersect() requires only
exact predicates, where as intersection() requires exact constructions
too. I can understand the motive for this API design now.
IAC I use an Exact_predicates_exact_constructions_kernel and was doing
the 2 step process you have detailed above to optimize the result.
~ash
