cgal-discuss - Re: [cgal-discuss] CGAL marching cubes is very slow?
  • To:
  • Subject: Re: [cgal-discuss] CGAL marching cubes is very slow?
  • Date: Fri, 17 Jul 2009 11:18:42 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Ggnx0oNsn+wv4oVG6pnt2w/OoiiixuRV2/huAmgoPz/jgHDokpwIIC/YR67oo7tk9m tVuc5qLyQbobKtrBWlpFlJ9OQYvpX+RreQS+1IzqZmfYtJ/qD2mJs7YkQTtgEQOkQcgJ 3zAXLwdso0D1ReX3JQ08SjwindRFwANKzG2bI=
I see, thanks. Can anyone recommend a good c++ implementation of the marching cubes algorithm? I am quite surprised that this is not easier to find...
On Fri, Jul 17, 2009 at 11:09 AM, Mariette Yvinec <> wrote:
CGAL Surface mesher is not a marching cube.
It builds  iteratively a sampling adapted to the surface geometry
so that the restricted triangulation  of this sampling is
an accurate approximation of the surface and a nice
surface mesh formed with well shaped triangles.
Christian Walder wrote:
Dear All,
I have used the CGAL library to perform marching cubes on an implicit surface. Unfortunately it is extremely slow - previously I have used a different implementation from an unknown author, and it is orders of magnitude faster for roughly the same resolution. I am wondering if I have called the functions correctly, and whether there are any easy ways attempt to speed it up.
Best Regards,
Christian
ps.
The key snippet of code is the following:
 Tr tr;            // 3D-Delaunay triangulation                                                            C2t3 c2t3 (tr);   // 2D-complex in 3D-Delaunay triangulation                                              Surface_3 surface(implicit_function, Sphere_3(Point_3(center[0],center[1],center[2]), radius));
 // defining meshing criteria
 CGAL::Surface_mesh_default_criteria_3<Tr> criteria(30.,  // angular bound        radius_bound,  // radius bound        distance_bound); // distance bound                    CGAL::make_surface_mesh(c2t3, surface, criteria, CGAL::Non_manifold_tag());
Mariette Yvinec
Geometrica project team
INRIA  Sophia-Antipolis
