- To:
- Subject: Re: [cgal-discuss] CGAL marching cubes is very slow?
- Date: Fri, 17 Jul 2009 11:43:40 +0200
Hi Christian,
You might further investigate the surface mesher, as comparing it with
a marching cubes algorithm is comparing apples and pears. The surface
mesher will produce quality triangles, and you can have uniform sized
triangles or triangles with the size adapted to the curvature, that
is few triangles where the surface is flat, and many triangles where
you have high curvature. So in order to have a fair comparison,
you should compare it to marching cubes followed by mesh simplification.
Obvioulsly if badly shaped triangles are not a problem for your use case,
the added value I try to point out, is not valuable for you.
Best regards,
andreas
Christian Walder wrote:
I see, thanks. Can anyone recommend a good c++ implementation of the marching cubes algorithm? I am quite surprised that this is not easier to find...
On Fri, Jul 17, 2009 at 11:09 AM, Mariette Yvinec < <mailto:>> wrote:
CGAL Surface mesher is not a marching cube.
It builds iteratively a sampling adapted to the surface geometry
so that the restricted triangulation of this sampling is
an accurate approximation of the surface and a nice
surface mesh formed with well shaped triangles.
Dear All,
I have used the CGAL library to perform marching cubes on an
implicit surface. Unfortunately it is extremely slow -
previously I have used a different implementation from an
unknown author, and it is orders of magnitude faster for roughly
the same resolution. I am wondering if I have called the
functions correctly, and whether there are any easy ways attempt
to speed it up.
Best Regards,
Christian
ps.
The key snippet of code is the following:
Tr tr; // 3D-Delaunay triangulation C2t3 c2t3 (tr); //
2D-complex in 3D-Delaunay triangulation Surface_3 surface(implicit_function,
Sphere_3(Point_3(center[0],center[1],center[2]), radius));
// defining meshing criteria CGAL::Surface_mesh_default_criteria_3<Tr> criteria(30., //
angular bound radius_bound, // radius bound distance_bound); // distance bound CGAL::make_surface_mesh(c2t3, surface, criteria,
CGAL::Non_manifold_tag());
-- Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] CGAL marching cubes is very slow?, Christian Walder, 07/16/2009
- Re: [cgal-discuss] CGAL marching cubes is very slow?, Mariette Yvinec, 07/17/2009
- Re: [cgal-discuss] CGAL marching cubes is very slow?, Christian Walder, 07/17/2009
- Re: [cgal-discuss] CGAL marching cubes is very slow?, Dominik Szczerba, 07/17/2009
- Re: [cgal-discuss] CGAL marching cubes is very slow?, Andreas Fabri, 07/17/2009
- Re: [cgal-discuss] CGAL marching cubes is very slow?, Bo Zhou, 07/17/2009
