- To:
- Subject: Re: [cgal-discuss] Installation problems
- Date: Thu, 23 Jul 2009 14:13:38 +0200
Hello, follow the instructions on:
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
rlam
Citando
Hy everyone! I know I'm just a dreadfully annoying noob, but I can't get the
installation procedure right with cgal 3.4.
I'm running under winxp (don't stone me..). I installed boost, cmake and set
all the PATH values (BOOST_PATH, Boost_INCLUDE_DIR, Boost_LIBRARYDIR,
Boost_THREAD_LIBRARY_DEBUG & Boost_THREAD_LIBRARY_RELEASE). After all that, I
installed using the installer provided on the CGAL site, and now I'm trying to
get cmake to produce the .vcproj (I'd like to install it for visual c 2008),
but it keeps getting stuck with the error message "boost_thread not found" and
asks me to set the Boost_LIBRARYDIR variable...
The boost version is 1.39.0, cmake is 2.6.4 and cgal is 3.4. Any ideas what I'm
doing wrong?
This message was sent using IMP, the Internet Messaging Program.
- [cgal-discuss] Installation problems, andreisucila, 07/23/2009
- Re: [cgal-discuss] Installation problems, rlam, 07/23/2009
- Re: [cgal-discuss] Installation problems, Jannis Warnat, 07/23/2009
- Re: [cgal-discuss] Installation problems, Andrei Sucila, 07/23/2009
- Re: [cgal-discuss] Installation problems, Laurent Rineau (GeometryFactory), 07/23/2009
