cgal-discuss - Re: [cgal-discuss] Installation problems
  • To:
  • Cc: Andrei Sucila <>
  • Subject: Re: [cgal-discuss] Installation problems
  • Date: Thu, 23 Jul 2009 14:46:40 +0200
On Thursday 23 July 2009 14:40:36 Andrei Sucila wrote:
> Thanks alot. I tried it, and it worked. I got over cmake!
> New trouble : when I try to compile it with vc 2008, it says it cannot
> include boost/config.hpp Something is not set right. Did you run into the
> same trouble? And if so, how did you solve it?
Fill the CMake variable Boost_INCLUDE_DIR with the path to your version of
Boost, and that will solve that issue.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
