- To: <>
- Subject: Re: [cgal-discuss] Installation problems
- Date: Thu, 23 Jul 2009 14:19:22 +0200
Hi,
I use XP and cygwin and I fought for days with the issue of cmake not finding boost thread.
It finally worked when I hacked the following into FindBoost.cmake, i.e. gave him the path manually.
SET(Boost_${UPPERCOMPONENT}_LIBRARY /usr/local/lib/libboost_thread-gcc34-mt-1_38.a)
message("${Boost_${UPPERCOMPONENT}_LIBRARY}\n")
message("${Boost_${UPPERCOMPONENT}_LIBRARY_RELEASE}\n")
message("${Boost_${UPPERCOMPONENT}_LIBRARY_DEBUG}\n")
_Boost_ADJUST_LIB_VARS(${UPPERCOMPONENT})
IF( Boost_USE_STATIC_LIBS )
SET(CMAKE_FIND_LIBRARY_SUFFIXES ${_boost_ORIG_CMAKE_FIND_LIBRARY_SUFFIXES})
ENDIF( Boost_USE_STATIC_LIBS )
ENDFOREACH(COMPONENT)
# End finding boost libraries
You could search the archive for "findboost" of "setupboost" to find some other threads about similar issues:
https://lists-sop.inria.fr/sympa/arc/cgal-discuss
Hope that is of any help...
Jannis Warnat
----- Original Message ----- From: <>
To:
Sent: Thursday, July 23, 2009 1:38 PM
Subject: [cgal-discuss] Installation problems
Hy everyone! I know I'm just a dreadfully annoying noob, but I can't get the
installation procedure right with cgal 3.4.
I'm running under winxp (don't stone me..). I installed boost, cmake and set
all the PATH values (BOOST_PATH, Boost_INCLUDE_DIR, Boost_LIBRARYDIR,
Boost_THREAD_LIBRARY_DEBUG & Boost_THREAD_LIBRARY_RELEASE). After all that, I
installed using the installer provided on the CGAL site, and now I'm trying to
get cmake to produce the .vcproj (I'd like to install it for visual c 2008),
but it keeps getting stuck with the error message "boost_thread not found" and
asks me to set the Boost_LIBRARYDIR variable...
The boost version is 1.39.0, cmake is 2.6.4 and cgal is 3.4. Any ideas what I'm
doing wrong?
- [cgal-discuss] Installation problems, andreisucila, 07/23/2009
- Re: [cgal-discuss] Installation problems, rlam, 07/23/2009
- Re: [cgal-discuss] Installation problems, Jannis Warnat, 07/23/2009
- Re: [cgal-discuss] Installation problems, Andrei Sucila, 07/23/2009
- Re: [cgal-discuss] Installation problems, Laurent Rineau (GeometryFactory), 07/23/2009
