- To:
- Subject: Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?
- Date: Tue, 28 Jul 2009 15:41:38 -0400
Hello Andre,
There is section of the manual on the intersection (or generally, Boolean ops) of Nef Polyhedra: http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Nef_3/Chapter_main.html
There are two papers that discuss the complexity of the operations in depth; I cannot vouch for the speed however as I have not used this feature.
Best
Amy
Andre Massing wrote:
Hi,
ATM I am studying a certain kind of finite element methods with overlapping meshes. Therefore I am adding some intersection functionality to our mesh classes (belonging to the problem solving environment http://www.fenics.org/wiki/DOLFIN). These corresponds to the functionality provided by CGAL: A boolean function "do_intersect" and an "intersection" function, which computes the actual intersection in terms of Nef Polygons.
Depending on the dimension a mesh is purely build up by segments, triangles or tetrahedrons. Everything is fine except that I am sticking with 3d case. So is there an easy (and fast?) work around for the missing do_intersect function, which takes two tetrahedrons (or even 2 Nef_3 polyhedrons)? Any hints or pointers are very much appreciated!
Kind regards,
Andre
Amy Tabb
PhD candidate
Robot Vision Laboratory
Electrical and Computer Engineering Department
465 Northwestern Avenue
West Lafayette, Indiana 47907-2035
- [cgal-discuss] do_intersect for pairs of tetrahedrons?, Andre Massing, 07/28/2009
- Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?, Amy Tabb, 07/28/2009
- Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?, Andre Massing, 07/29/2009
- Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?, Amy Tabb, 07/29/2009
- Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?, Andre Massing, 07/30/2009
