- To:
- Subject: Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?
- Date: Wed, 29 Jul 2009 00:40:30 +0200
- Organization: Simula
Hi Amy,
thanks for the fast reply.
On Tuesday 28 July 2009 21:41:38 Amy Tabb wrote:
> Hello Andre,
> There is section of the manual on the intersection (or generally,
> Boolean ops) of Nef Polyhedra:
> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Nef_3/Chapter_main.html
Yepp, I've already scanned a bit through the documentation and was wondering,
how difficult it might be to provide (or find?) a do_intersect function for
3D
Polygons similar to those described on
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Boolean_set_operations_2_ref/Function_do_intersect.html#Cross_link_anchor_894
Actually I have no clue about what happens behind the curtain of CG
(although it is quite fascinating) since I am more affiliated to the PDE FEM
world. But I guess a (suitable) check if 2 polyhedrons intersect or not
should
be much faster then computing the actual intersection Nef poyhedron and
checking it if it is empty. That's why I want to provide a dedicated
"do_intersect" function. Since I want to deal with 2 overlapping meshes, and
at least one will move during simulation, I must assure do sort out the
overlapped cell afap.
I have been thinking about implementing it myself based on the do_intersect
function taking triangles and tetrahedrons and its implementation in
include/CGAL/Triangle_3_Tetrahedron_3_do_intersect.h
but I am not sure, whether this is the best approach, both in terms of clumsy
programming hacks and efficiency, especially since a comment in that files
indicates that already that implementation is not optimized.
Sorry for being so unfamiliar with all concepts/algorithm and maybe asking
some simple to answer question, but I' ve just entered the formerly unknown
country of CG :-)
Best wishes,
Andre
> There are two papers that discuss the complexity of the operations in
> depth; I cannot vouch for the speed however as I have not used this
> feature.
> Best
> Amy
> Andre Massing wrote:
> > Hi,
> > ATM I am studying a certain kind of finite element methods with
> > overlapping meshes. Therefore I am adding some intersection functionality
> > to our mesh classes (belonging to the problem solving environment
> > http://www.fenics.org/wiki/DOLFIN). These corresponds to the
> > functionality provided by CGAL: A boolean function "do_intersect" and an
> > "intersection" function, which computes the actual intersection in terms
> > of Nef Polygons. Depending on the dimension a mesh is purely build up by
> > segments, triangles or tetrahedrons.
> > Everything is fine except that I am sticking with 3d case. So is there an
> > easy (and fast?) work around for the missing do_intersect function, which
> > takes two tetrahedrons (or even 2 Nef_3 polyhedrons)? Any hints or
> > pointers are very much appreciated!
> > Kind regards,
> > Andre
> Amy Tabb
> PhD candidate
> Robot Vision Laboratory
> Electrical and Computer Engineering Department
> 465 Northwestern Avenue
> West Lafayette, Indiana 47907-2035
- [cgal-discuss] do_intersect for pairs of tetrahedrons?, Andre Massing, 07/28/2009
- Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?, Amy Tabb, 07/28/2009
- Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?, Andre Massing, 07/29/2009
- Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?, Amy Tabb, 07/29/2009
- Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?, Andre Massing, 07/30/2009
