- To:
- Subject: Re: [cgal-discuss] Trouble with Triangle_3_Segment_3_intersection.h
- Date: Thu, 06 Aug 2009 09:42:15 +0200
Matthew Denno wrote:
Stephane,Hi,
Thank you for your reply, I really appreciate your help. I did as you
suggested and moved the include to before the CGAL Kernel, but still no
success. I actually received 312 errors when I try to compile it, they are
shown below.
I should probably take a step back and ask a simple question. Pierre Alliez
emailed me the Triangle_3_segment_3_intersection.h file along with a few
other Triangle_3_XXXXXXX_intersection.h files a few weeks back. Is it
acceptable to just copy that file into the /usr/include/CGAL directory and
use it or are some other steps needed? It appears that many of the errors
are from the intersection_3_1.h file. Would a different version of that
file be required also?
Also, I don't know if this is important, but I am using CGAL version 3.5
beta.
Thanks again for your help,
Matt
You could try to use the following includes in your main file :
#include <CGAL/intersections.h>
#include <CGAL/Triangle_3_segment_3_intersection.h>
Note that the file you are using is distributed with CGAL3.5b1, located into "CGAL/AABB_intersections/Triangle_3_segment_3_intersection.h". The file
CGAL/AABB_intersections.h is including all the files of that directory if you need it (should be included before the kernel).
Best,
Stephane Tayeb
Engineer - INRIA Sophia Antipolis
Geometrica Project-Team
- [cgal-discuss] Trouble with Triangle_3_Segment_3_intersection.h, Matthew Denno, 08/05/2009
- Re: [cgal-discuss] Trouble with Triangle_3_Segment_3_intersection.h, Stephane Tayeb, 08/05/2009
- Re: [cgal-discuss] Trouble with Triangle_3_Segment_3_intersection.h, Matthew Denno, 08/06/2009
- Re: [cgal-discuss] Trouble with Triangle_3_Segment_3_intersection.h, Stephane Tayeb, 08/06/2009
