Re: [cgal-discuss] segmentation fault, 2D Delaunay triangulation, 3.4 and 3.5-beta1
- To:
- Subject: Re: [cgal-discuss] segmentation fault, 2D Delaunay triangulation, 3.4 and 3.5-beta1
- Date: Thu, 6 Aug 2009 11:16:36 +0100
- Organization: OpenCFD Ltd.
Hi Manuel,
> the move function does not seem to be documented, is it?
Possibly... I just found it in the code and gave it a go!
> Anyway, you are using the Triangulation hierarchy. Currently the move
> function is not implemented in Triangulation_hierarchy_2 but does only
> work for Delaunay_triangulation_2.
> So you either use Delaunay_triangulation_2 or you just call insert and
> remove depending on what makes more sense for your application.
Thanks, I move all the points at each step in the application, so I'll
probably do a clear and reinsertion (with the range inserter) of the whole
triangulation rather than individual remove and inserts to move each vertex.
All the best,
Graham
- Re: [cgal-discuss] segmentation fault, 2D Delaunay triangulation, 3.4 and 3.5-beta1, Manuel Caroli, 08/05/2009
- Re: [cgal-discuss] segmentation fault, 2D Delaunay triangulation, 3.4 and 3.5-beta1, Graham Macpherson, 08/05/2009
- Re: [cgal-discuss] segmentation fault, 2D Delaunay triangulation, 3.4 and 3.5-beta1, Graham Macpherson, 08/06/2009
