- To:
- Subject: Re: [cgal-discuss] Trouble with Triangle_3_Segment_3_intersection.h
- Date: Thu, 6 Aug 2009 08:33:16 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=oJchGR0wGSTAhP3fo6WT7szwmncVaGU7vlq9gPe0cEBXqW/b0T4RLTC0pxC+nOCdVE pKExtb9NrfT0ACgf16IG2U5Ng64neuCKqRNNX7zsLjCvyn6CZaJJQ7uqzGwbur45kp3w 5rTHlWR8ooxXQtioQ9ZtAXGsh8rHPippLNmkY=
Stephane,
Got it! Thanks for your help. I included CGAL/AABB_intersections.h before the kernel and removed the other Triangle_3_XXXXXXX_intersection.h files, and now it is working like I would expect.
Thanks,
Matt
On Thu, Aug 6, 2009 at 3:42 AM, Stephane Tayeb <> wrote:
Matthew Denno wrote:Hi,
Stephane,
Thank you for your reply, I really appreciate your help. I did as you
suggested and moved the include to before the CGAL Kernel, but still no
success. I actually received 312 errors when I try to compile it, they are
shown below.
I should probably take a step back and ask a simple question. Pierre Alliez
emailed me the Triangle_3_segment_3_intersection.h file along with a few
other Triangle_3_XXXXXXX_intersection.h files a few weeks back. Is it
acceptable to just copy that file into the /usr/include/CGAL directory and
use it or are some other steps needed? It appears that many of the errors
are from the intersection_3_1.h file. Would a different version of that
file be required also?
Also, I don't know if this is important, but I am using CGAL version 3.5
beta.
Thanks again for your help,
Matt
You could try to use the following includes in your main file :
#include <CGAL/intersections.h>
#include <CGAL/Triangle_3_segment_3_intersection.h>#include <CGAL/Exact_predicates_inexact_constructions_kernel.h>...
Note that the file you are using is distributed with CGAL3.5b1, located into "CGAL/AABB_intersections/Triangle_3_segment_3_intersection.h". The file
CGAL/AABB_intersections.h is including all the files of that directory if you need it (should be included before the kernel).
Best,
Stephane Tayeb
Engineer - INRIA Sophia Antipolis
Geometrica Project-Team
- [cgal-discuss] Trouble with Triangle_3_Segment_3_intersection.h, Matthew Denno, 08/05/2009
- Re: [cgal-discuss] Trouble with Triangle_3_Segment_3_intersection.h, Stephane Tayeb, 08/05/2009
- Re: [cgal-discuss] Trouble with Triangle_3_Segment_3_intersection.h, Matthew Denno, 08/06/2009
- Re: [cgal-discuss] Trouble with Triangle_3_Segment_3_intersection.h, Stephane Tayeb, 08/06/2009
