cgal-discuss - [cgal-discuss] Surface Mesh Generator Creates Inconsistenly-Oriented Meshes
  • To:
  • Subject: [cgal-discuss] Surface Mesh Generator Creates Inconsistenly-Oriented Meshes
  • Date: Fri, 7 Aug 2009 00:20:45 +0300
Hello,
I create a surface mesh as the zero level of an implicit function, with the
Manifold_with_boundary_tag (although the surface is a closed manifold, and the
manifold_tag works as well). However, I get meshes which triangles are
inconsistently-oriented (such as the attached output OFF file). I can work
them
out, but its a pain. also, I inted to work with non-manifold surfaces, so it
would be a problem. Is there some way to ensure consistent orientation?
I use the CGAL 3.4 surface mesher.
Amir.
Attachment: GeneratedMesh.zip
Description: Zip compressed data
