cgal-discuss - Re: [cgal-discuss] errors with Quotient.h and Object.h on windows
  • To:
  • Subject: Re: [cgal-discuss] errors with Quotient.h and Object.h on windows
  • Date: Thu, 06 Aug 2009 16:39:28 +0200
  • Organization: INRIA
I'm sorry, I meant <CGAL/compiler_config.h>.
?????? wrote:
<CGAL/config.h> is generated by the windows installer, and the same errors
occur with CGAL-3.4
------------------ Original ------------------
Pion"<>;
*Date: *2009??8??6??(??????) ????10:31
*To:
*"cgal-discuss"<>;
*Subject: *Re: [cgal-discuss] errors with Quotient.h and Object.h on windows
wrote:
> hi,
> please help.
> I installed cgal-3.5.1-beta with windows installer, when I want to compile the
> example "examples/Straight_skeleton_2/Create_offset_polygons_2.cpp" in
> vc8,some strange error occurs as following:
It seems the <CGAL/config.h> which is found is not the correct one.
Can you double check that you are not taking one from CGAL-3.4 ?
(I'm not sure what the Windows installer does)
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
Sylvain Pion
