- To: "cgal-discuss" <>
- Subject: Re: [cgal-discuss] errors with Quotient.h and Object.h on windows
- Date: Fri, 7 Aug 2009 08:37:25 +0800
thanks for your reply. i check the file as you said, it's wrong, so I created it by cmake.and now it works.
regards.
------------------ Original ------------------
Date: Thu, Aug 6, 2009 10:39 PM
To: "cgal-discuss"<>;
tong wrote:
> <CGAL/config.h> is generated by the windows installer, and the same errors occur with CGAL-3.4
> *From: *"Sylvain Pion"<>;
> *Date: *2009年8月6日(星期四) 晚上10:31
> *To: *"cgal-discuss"<>;
> *Subject: *Re: [cgal-discuss] errors with Quotient.h and Object.h on windows
> wrote:
> > hi,
> > please help.
> > I installed cgal-3.5.1-beta with windows installer, when I want to
> compile the
> > example "examples/Straight_skeleton_2/Create_offset_polygons_2.cpp" in
> > vc8,some strange error occurs as following:
> It seems the <CGAL/config.h> which is found is not the correct one.
> Can you double check that you are not taking one from CGAL-3.4 ?
> (I'm not sure what the Windows installer does)
> Sylvain Pion
> INRIA Sophia-Antipolis
> Geometrica Project-Team
> CGAL, http://cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Sylvain Pion
- [cgal-discuss] errors with Quotient.h and Object.h on windows, tong-zhiqiang, 08/06/2009
- Re: [cgal-discuss] errors with Quotient.h and Object.h on windows, Sylvain Pion, 08/06/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] errors with Quotient.h and Object.h on windows, 同治强, 08/06/2009
- Re: [cgal-discuss] errors with Quotient.h and Object.h on windows, tong, 08/07/2009
