- To:
- Subject: Re: [cgal-discuss] Mesher, bounding box.
- Date: Fri, 07 Aug 2009 17:09:32 +0200
Hi 400555,
400555 wrote:
Hello everyone !I don't know the surface mesher very well, but if you have a bounding box you couldn't you use a sphere bounding the bounding box as bounding sphere?
To make surface with Implicit_surface_3 necessary to set Bounding Sphere.
Is any way to use Bounding Box instead of it?
There are periodic triangulations available. However they don't (yet) work together with the surface mesher as they have a slightly different interface than the normal triangulations. We are working on it.
Also do you know last does CGAL version allow to make periodic surfaces?
best
Manuel
- [cgal-discuss] Mesher, bounding box., 400555, 08/07/2009
- Re: [cgal-discuss] Mesher, bounding box., Manuel Caroli, 08/07/2009
- Re: [cgal-discuss] Mesher, bounding box., 400555, 08/07/2009
- Re: [cgal-discuss] Mesher, bounding box., Manuel Caroli, 08/08/2009
- Re: [cgal-discuss] Mesher, bounding box., 400555, 08/08/2009
- Re: [cgal-discuss] Mesher, bounding box., Manuel Caroli, 08/10/2009
