- To:
- Subject: Re: [cgal-discuss] Mesher, bounding box.
- Date: Sat, 08 Aug 2009 09:45:16 +0200
400555 wrote:
Thank you for quick answer Manuel!Yes but as I understood you have a bounding box, right? So you can get the size and position of the bounding box and create a Sphere_3 from it which contains the bounding box entirely. Followingly it is a bounding sphere, which you can use as second argument to Implicit_surface_3.
The point is that Implicit_surface_3 has a second argument with type Sphere_3:
Manuel
Implicit_surface_3<Traits, Function> surface ( Function f, Sphere_3 <http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Kernel_23_ref/Class_Sphere_3.html#Cross_link_anchor_251> bounding_sphere, FT error_bound = FT(1e-3));
On Fri, Aug 7, 2009 at 5:09 PM, Manuel Caroli < <mailto:>> wrote:
Hi 400555,
400555 wrote:
Hello everyone !
To make surface with Implicit_surface_3 necessary to set
Bounding Sphere.
Is any way to use Bounding Box instead of it?
I don't know the surface mesher very well, but if you have a
bounding box you couldn't you use a sphere bounding the bounding box
as bounding sphere?
Also do you know last does CGAL version allow to make periodic
surfaces?
There are periodic triangulations available. However they don't
(yet) work together with the surface mesher as they have a slightly
different interface than the normal triangulations. We are working
on it.
best
Manuel
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Mesher, bounding box., 400555, 08/07/2009
- Re: [cgal-discuss] Mesher, bounding box., Manuel Caroli, 08/07/2009
- Re: [cgal-discuss] Mesher, bounding box., 400555, 08/07/2009
- Re: [cgal-discuss] Mesher, bounding box., Manuel Caroli, 08/08/2009
- Re: [cgal-discuss] Mesher, bounding box., 400555, 08/08/2009
- Re: [cgal-discuss] Mesher, bounding box., Manuel Caroli, 08/10/2009
