- To:
- Subject: [cgal-discuss] Mesher, bounding box.
- Date: Fri, 7 Aug 2009 17:00:32 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=EbLDY94VHd86tskUUtrwaMYKWJk2W5b2hQgrUOHGJr50K7yDaLqknygl92GM1Igz2w jScvlzq9+NoXcCSR8TgEPrZ7Ke2o97pi0/zxPS+Phnmni0um4+6mpJqGszXe9I12Otb1 8ky/jbKC1t9BvAQiyt4BJXE0SFxNBnOLv3Hvo=
Hello everyone !
To make surface with Implicit_surface_3 necessary to set Bounding Sphere.
Is any way to use Bounding Box instead of it?
Also do you know last does CGAL version allow to make periodic surfaces?
Thank you.
- [cgal-discuss] Mesher, bounding box., 400555, 08/07/2009
- Re: [cgal-discuss] Mesher, bounding box., Manuel Caroli, 08/07/2009
- Re: [cgal-discuss] Mesher, bounding box., 400555, 08/07/2009
- Re: [cgal-discuss] Mesher, bounding box., Manuel Caroli, 08/08/2009
- Re: [cgal-discuss] Mesher, bounding box., 400555, 08/08/2009
- Re: [cgal-discuss] Mesher, bounding box., Manuel Caroli, 08/10/2009
