cgal-discuss - Re: [cgal-discuss] Re: modify weighted point
  • To:
  • Subject: Re: [cgal-discuss] Re: modify weighted point
  • Date: Wed, 19 Aug 2009 08:37:08 +0200
Vitaliy wrote:
Could anybody tell me if it is possible or not?
Otherwise I have to implement it by my self...
goal is: updating regular triangulation (instead of doing rebuilding of it from scratch each time stap)
So I get regular triangulation and then, each time step (I consider moving points) I want to update it by doing flip of edge (in 2D) which is not fit to "in circle" criteria (which is considered about weight).
So, basically what I need from CGAL after I got my regular triangulation - is flip.
But I have to change coordinates of verteces (otherwise I didn't try yet but I am not sure that flip will process correct)
thank you
Vitaliy
Have you consider using the remove and insert functions to simulate the move?
On Mon, Aug 17, 2009 at 7:52 PM, Vitaliy < <mailto:>> wrote:
Hello !
I have regular triangulation and want to modify vertices in it
(coordinates, weight).
I tried to make new weighted point and assign it to my vertex
handle with use operator "=" but it seems that this way doesn't work.
But for Delaunay triangulation it works.
Do you know how can I do it? (in order to maintain moving points)
Thank you,
Vitaliy
