cgal-discuss - Re: [cgal-discuss] Re: modify weighted point
  • To:
  • Subject: Re: [cgal-discuss] Re: modify weighted point
  • Date: Wed, 19 Aug 2009 11:23:05 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=ELxtgNplY6NlBRhfp6vgtfwuGWiuJm6X/M1/JJSOKNg9WrWAP1KrZFz8Z5kmNrvefA w6w+Kw2k48SONNufK+L7Kk7pVD7QURavIqAfNskFmSfy7x2MUKUdQDT77MS8PI2v4coi Ip3ffgpEgvrPGa7B5LEUUrqsyymShPrrRMnAk=
Sebastien wrote:
     Have you consider using the remove and insert functions to simulate the move?
All my points move each time step, so I think using insert/remove functions might be slowly then rebuilding triangulation from scratch.
On Wed, Aug 19, 2009 at 8:37 AM, Sebastien Loriot <> wrote:
Vitaliy wrote:
Could anybody tell me if it is possible or not?
Otherwise I have to implement it by my self...
goal is: updating regular triangulation (instead of doing rebuilding of it from scratch each time stap)
So I get regular triangulation and then, each time step (I consider moving points) I want to update it by doing flip of edge (in 2D) which is not fit to "in circle" criteria (which is considered about weight).
So, basically what I need from CGAL after I got my regular triangulation - is flip.
But I have to change coordinates of verteces (otherwise I didn't try yet but I am not sure that flip will process correct)
thank you
Vitaliy
On Mon, Aug 17, 2009 at 7:52 PM, Vitaliy < <mailto:>> wrote:
   Hello !
   I have regular triangulation and want to modify vertices in it
   (coordinates, weight).
   I tried to make new weighted point and assign it to my vertex
   handle with use operator "=" but it seems that this way doesn't work.
   But for Delaunay triangulation it works.
   Do you know how can I do it? (in order to maintain moving points)
   Thank you,
   Vitaliy
