- To:
- Subject: Re: [cgal-discuss] Re: modify weighted point
- Date: Wed, 19 Aug 2009 11:27:11 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=nlaowwJcigc/JUYk31GBipRgqV00guc4uuN7y0YLZhj2dwcBGbt1GGlJRbD1jhl8mP /m5bwIuduCyEl15oPyHOLz6x2Qm0S2cc7jquPawLXw9A4f1GvHTkDY1NksDSO2kwq4ma 10Gox6X1ikjiMg8f4AforVkcZPXpERwrdZ/ko=
Benjamin wrote:
Also, I think the "kinetic data structures" module does that... thoughI never used it.
About using KDS I was confused about following sentence in manual:
"How can I use kinetic data structures to update Delaunay triangulations?
We are working on that one, but you will have to wait."
On Wed, Aug 19, 2009 at 8:47 AM, Benjamin schwarz <> wrote:
>> Otherwise I have to implement it by my self...As far as I understand it is not so easy a task.
> Have you consider using the remove and insert functions to simulate the
> move?
I never used it.
- [cgal-discuss] modify weighted point, Vitaliy, 08/17/2009
- [cgal-discuss] Re: modify weighted point, Vitaliy, 08/18/2009
- Re: [cgal-discuss] Re: modify weighted point, Sebastien Loriot, 08/19/2009
- Re: [cgal-discuss] Re: modify weighted point, Benjamin schwarz, 08/19/2009
- Re: [cgal-discuss] Re: modify weighted point, Vitaliy, 08/19/2009
