- To:
- Subject: Re: [cgal-discuss] CGAL 3.5 beta installation in Widows Vista
- Date: Wed, 19 Aug 2009 20:37:05 +0200
Le mercredi 19 août 2009 18:55:30, Indika Tantrigoda a écrit :
> Hello,
> I did run cmake-gui . from the CGAL root directory. The error I get is this
> OpenGL include:
> OpenGL libraries: glu32;opengl32
> OpenGL definitions:
> Qt4 include: C:/Qt/4.5.2/include
> Qt4 libraries:
> optimized;C:/Qt/4.5.2/lib/qtmain.lib;debug;C:/Qt/4.5.2/lib/qtmaind.lib;opti
>mized;C:/Qt/4.5.2/lib/QtOpenGL4.lib;debug;C:/Qt/4.5.2/lib/QtOpenGLd4.lib;ope
>ngl32.lib glu32.lib gdi32.lib
> user32.lib;optimized;C:/Qt/4.5.2/lib/QtGui4.lib;debug;C:/Qt/4.5.2/lib/QtGui
>d4.lib;imm32;winmm;optimized;C:/Qt/4.5.2/lib/QtCore4.lib;debug;C:/Qt/4.5.2/l
>ib/QtCored4.lib;ws2_32 Qt4 definitions: -DQT_DLL
> moc executable: C:/Qt/4.5.2/bin/moc.exe
> uic executable: C:/Qt/4.5.2/bin/uic.exe
> Configuring incomplete, errors occurred!
> This doesn't seem to be the error I got initially. It was something related
> to line 689/690 in a CMAKE file. But the above error seem to be consistent
> every time I run cmake-gui . .I am using the VS 2008 compiler.
Can you post the *full* log, please? When you see "errors occurred" at the
very end of a log, then the errors are probably described... above! ;-)
That can be nice, also, if you attached the file CMakeCache.txt that lies in
the cmake binary directory (probably your current working directory).
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] CGAL 3.5 beta installation in Widows Vista, Indika Tantrigoda, 08/19/2009
- Re: [cgal-discuss] CGAL 3.5 beta installation in Widows Vista, Laurent Rineau (GeometryFactory), 08/19/2009
- Re: [cgal-discuss] CGAL 3.5 beta installation in Widows Vista, Indika Tantrigoda, 08/19/2009
- Re: [cgal-discuss] CGAL 3.5 beta installation in Widows Vista, Indika Tantrigoda, 08/20/2009
- Re: [cgal-discuss] CGAL 3.5 beta installation in Widows Vista, Laurent Rineau (GeometryFactory), 08/20/2009
