- To:
- Subject: Re: [cgal-discuss] CGAL 3.5 beta installation in Widows Vista
- Date: Thu, 20 Aug 2009 10:10:32 +0530
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Jh7+sRwQvABy7LQ/0WYUYgLznsYHvnGY363Yero3Xt6Ro8vmnNm5S+3KhBIf+i398E qXPSKZWlw0nmsC9krckcK4qi0jrluE1hR3tkYbSJ00aI0GeJtOkS+N03G3H8iUnFlM9N o527nl4kFc7Ukjqlq3+PtxGFEJv68xLZ13ZAg=
Hi,
Here is the full log and the CMakeCache.txt files.
Sorry about earlier.
Thanks
2009/8/20 Laurent Rineau (GeometryFactory) <>
Le mercredi 19 août 2009 18:55:30, Indika Tantrigoda a écrit :
> Hello,Can you post the *full* log, please? When you see "errors occurred" at the
> I did run cmake-gui . from the CGAL root directory. The error I get is this
> OpenGL include:
> OpenGL libraries: glu32;opengl32
> OpenGL definitions:
> Qt4 include: C:/Qt/4.5.2/include
> Qt4 libraries:
> optimized;C:/Qt/4.5.2/lib/qtmain.lib;debug;C:/Qt/4.5.2/lib/qtmaind.lib;opti
>mized;C:/Qt/4.5.2/lib/QtOpenGL4.lib;debug;C:/Qt/4.5.2/lib/QtOpenGLd4.lib;ope
>ngl32.lib glu32.lib gdi32.lib
> user32.lib;optimized;C:/Qt/4.5.2/lib/QtGui4.lib;debug;C:/Qt/4.5.2/lib/QtGui
>d4.lib;imm32;winmm;optimized;C:/Qt/4.5.2/lib/QtCore4.lib;debug;C:/Qt/4.5.2/l
>ib/QtCored4.lib;ws2_32 Qt4 definitions: -DQT_DLL
> moc executable: C:/Qt/4.5.2/bin/moc.exe
> uic executable: C:/Qt/4.5.2/bin/uic.exe
> Configuring incomplete, errors occurred!
> This doesn't seem to be the error I got initially. It was something related
> to line 689/690 in a CMAKE file. But the above error seem to be consistent
> every time I run cmake-gui . .I am using the VS 2008 compiler.
very end of a log, then the errors are probably described... above! ;-)
That can be nice, also, if you attached the file CMakeCache.txt that lies in
the cmake binary directory (probably your current working directory).
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
Check for working C compiler: cl
Check for working C compiler: cl -- works
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Check for working CXX compiler: cl
Check for working CXX compiler: cl -- works
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
CGAL_MAJOR_VERSION=3
CGAL_MINOR_VERSION=5
CGAL_BUILD_VERSION=
CGAL_SONAME_VERSION=4
CGAL_SOVERSION =4.0.0
CGAL_REFERENCE_CACHE_DIR=
Building static libraries
Targetting Visual Studio 9 2008
Target build enviroment supports auto-linking
Using VC90 compiler.
Generator uses intermediate configuration directory: $(OutDir)
USING CMake version: 2.6.4
System: Windows
Build type: Release
USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
-D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
-D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except-
/MD /O2 /Ob2 /D NDEBUG'
USING LDFLAGS = ' '
Found GMP: C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/include
Found MPFR: C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/include
GMP include: C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/include
GMP libraries:
GMP definitions:
USING GMP_VERSION = '4.2.4'
MPFR include: C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/include
MPFR libraries:
MPFR definitions:
USING MPFR_VERSION = '2.3.2'
CMake Error at cmake/modules/FindBoost.cmake:885 (message):
Unable to find the requested Boost libraries.
Boost version: 1.39.0
Boost include path: C:/boost/boost_1_39
The following Boost libraries could not be found:
boost_thread
No Boost libraries were found. You may need to set Boost_LIBRARYDIR to the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
Call Stack (most recent call first):
cmake/modules/CGAL_SetupBoost.cmake:12 (find_package)
cmake/modules/CGAL_SetupDependencies.cmake:17 (include)
CMakeLists.txt:220 (include)
Boost include: C:/boost/boost_1_39
Boost libraries:
Boost definitions:
USING BOOST_VERSION = '1.39.0'
Performing Test CGAL_CFG_DENORMALS_COMPILE_BUG - Success
Performing Test CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG - Success
Performing Test CGAL_CFG_IEEE_754_BUG - Success
Performing Test CGAL_CFG_ISTREAM_INT_BUG - Success
Performing Test CGAL_CFG_LONGNAME_BUG - Failed
Performing Test CGAL_CFG_MATCHING_BUG_5 - Success
Performing Test CGAL_CFG_MATCHING_BUG_6 - Failed
Performing Test CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG - Failed
Performing Test CGAL_CFG_NET2003_MATCHING_BUG - Success
Performing Test CGAL_CFG_NO_CPP0X_ARRAY - Failed
Performing Test CGAL_CFG_NO_CPP0X_DECLTYPE - Failed
Performing Test
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES - Failed
Performing Test CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS - Failed
Performing Test CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS - Failed
Performing Test CGAL_CFG_NO_CPP0X_ISFINITE - Failed
Performing Test CGAL_CFG_NO_CPP0X_LONG_LONG - Success
Performing Test CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE - Failed
Performing Test CGAL_CFG_NO_CPP0X_TUPLE - Failed
Performing Test CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES - Failed
Performing Test CGAL_CFG_NO_LIMITS - Success
Performing Test CGAL_CFG_NO_NEXTAFTER - Failed
Performing Test CGAL_CFG_NO_STATEMENT_EXPRESSIONS - Failed
Performing Test CGAL_CFG_NO_STL - Success
Performing Test CGAL_CFG_NO_TMPL_IN_TMPL_PARAM - Success
Performing Test CGAL_CFG_NO_TR1_ARRAY - Failed
Performing Test CGAL_CFG_NO_TR1_TUPLE - Failed
Performing Test CGAL_CFG_NUMERIC_LIMITS_BUG - Success
Performing Test CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG - Success
Performing Test CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG - Success
Performing Test CGAL_CFG_USING_BASE_MEMBER_BUG_2 - Success
CMAKE_INSTALL_PREFIX=C:/Program Files/CGAL
Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
OpenGL include:
NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature will
not be activated.
CGAL_Qt3 needs Qt3, cannot be configured.
Looking for Q_WS_X11
Looking for Q_WS_X11 - not found.
Looking for Q_WS_WIN
Looking for Q_WS_WIN - found
Looking for Q_WS_QWS
Looking for Q_WS_QWS - not found.
Looking for Q_WS_MAC
Looking for Q_WS_MAC - not found.
USING QT4_VERSION = '4.5.2'
OpenGL include:
OpenGL definitions:
Qt4 libraries:
optimized;C:/Qt/4.5.2/lib/qtmain.lib;debug;C:/Qt/4.5.2/lib/qtmaind.lib;optimized;C:/Qt/4.5.2/lib/QtOpenGL4.lib;debug;C:/Qt/4.5.2/lib/QtOpenGLd4.lib;opengl32.lib
glu32.lib gdi32.lib
user32.lib;optimized;C:/Qt/4.5.2/lib/QtGui4.lib;debug;C:/Qt/4.5.2/lib/QtGuid4.lib;imm32;winmm;optimized;C:/Qt/4.5.2/lib/QtCore4.lib;debug;C:/Qt/4.5.2/lib/QtCored4.lib;ws2_32
Configuring incomplete, errors occurred!# This is the CMakeCache file.
# For build in directory: c:/CGAL/CGAL-3.5-beta
# It was generated by CMake: C:/Program Files/CMake 2.6/bin/cmake.exe
# You can edit this file to change values found and used by cmake.
# If you do not want to change any of the values, simply exit the editor.
# If you do want to change a value, simply edit, save, and exit the editor.
# The syntax for the file is as follows:
# KEY:TYPE=VALUE
# KEY is the name of a variable in the cache.
# TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!.
# VALUE is the current value for the KEY.
# EXTERNAL cache entries
//Path to a file.
Boost_INCLUDE_DIR:PATH=C:/boost/boost_1_39
//Boost diagnostic define
Boost_LIB_DIAGNOSTIC_DEFINITIONS:STRING=-DBOOST_LIB_DIAGNOSTIC
//Path to a library.
Boost_THREAD_LIBRARY_DEBUG:FILEPATH=Boost_THREAD_LIBRARY_DEBUG-NOTFOUND
Boost_THREAD_LIBRARY_RELEASE:FILEPATH=Boost_THREAD_LIBRARY_RELEASE-NOTFOUND
//Value Computed by CMake
CGAL_BINARY_DIR:STATIC=C:/CGAL/CGAL-3.5-beta
//User-defined flags
CGAL_CXX_FLAGS:STRING= -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
CGAL_Core_BINARY_DIR:STATIC=C:/CGAL/CGAL-3.5-beta/src/CGALCore
//Dependencies for the target
CGAL_Core_LIB_DEPENDS:STATIC=general;psapi.lib;general;psapi.lib;
CGAL_Core_SOURCE_DIR:STATIC=C:/CGAL/CGAL-3.5-beta/src/CGALCore
//Set this to TRUE if you want to define or modify any of CMAKE_*_FLAGS.
// When this is FALSE, all the CMAKE_*_FLAGS flags are overriden
// with the values used when building the CGAL libs. For CGAL_*_flags
// (used for ADDITIONAL flags) , there is no need to set this to
// TRUE.
CGAL_DONT_OVERRIDE_CMAKE_FLAGS:BOOL=TRUE
//The folder where CGAL user-side scripts will be installed, relative
// to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_BIN_DIR:STRING=script
//The folder where CGAL CMake modules will be installed, relative
CGAL_INSTALL_CMAKE_DIR:STRING=cmake/modules
//The folder where CGAL header files will be installed, relative
CGAL_INSTALL_INC_DIR:STRING=include
//The folder where CGAL libraries will be installed, relative to
// CMAKE_INSTALL_PREFIX
CGAL_INSTALL_LIB_DIR:STRING=lib
//The folder where CGAL documentation and license files will be
// installed, relative to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_ROOT_DIR:STRING=.
CGAL_ImageIO_BINARY_DIR:STATIC=C:/CGAL/CGAL-3.5-beta/src/CGALimageIO
CGAL_ImageIO_LIB_DEPENDS:STATIC=general;psapi.lib;general;psapi.lib;general;glu32;general;opengl32;
CGAL_ImageIO_SOURCE_DIR:STATIC=C:/CGAL/CGAL-3.5-beta/src/CGALimageIO
//The CGAL library
CGAL_LIBRARY:STRING=
CGAL_LIB_DEPENDS:STATIC=general;psapi.lib;
CGAL_PDB_BINARY_DIR:STATIC=C:/CGAL/CGAL-3.5-beta/src/CGALPDB
CGAL_PDB_LIB_DEPENDS:STATIC=general;psapi.lib;general;psapi.lib;
CGAL_PDB_SOURCE_DIR:STATIC=C:/CGAL/CGAL-3.5-beta/src/CGALPDB
CGAL_Qt3_BINARY_DIR:STATIC=C:/CGAL/CGAL-3.5-beta/src/CGALQt
CGAL_Qt3_SOURCE_DIR:STATIC=C:/CGAL/CGAL-3.5-beta/src/CGALQt
CGAL_Qt4_BINARY_DIR:STATIC=C:/CGAL/CGAL-3.5-beta/src/CGALQt4
CGAL_Qt4_LIB_DEPENDS:STATIC=general;psapi.lib;general;psapi.lib;optimized;C:/Qt/4.5.2/lib/qtmain.lib;debug;C:/Qt/4.5.2/lib/qtmaind.lib;optimized;C:/Qt/4.5.2/lib/QtOpenGL4.lib;debug;C:/Qt/4.5.2/lib/QtOpenGLd4.lib;general;opengl32.lib
glu32.lib gdi32.lib
user32.lib;optimized;C:/Qt/4.5.2/lib/QtGui4.lib;debug;C:/Qt/4.5.2/lib/QtGuid4.lib;general;imm32;general;winmm;optimized;C:/Qt/4.5.2/lib/QtCore4.lib;debug;C:/Qt/4.5.2/lib/QtCored4.lib;general;ws2_32;general;glu32;general;opengl32;
CGAL_Qt4_SOURCE_DIR:STATIC=C:/CGAL/CGAL-3.5-beta/src/CGALQt4
//soname-version
CGAL_SONAME_VERSION:STRING=4
CGAL_SOURCE_DIR:STATIC=C:/CGAL/CGAL-3.5-beta
//soversion
CGAL_SOVERSION:STRING=4.0.0
//For backwards compatibility, what version of CMake commands and
// syntax should this version of CMake try to support.
CMAKE_BACKWARDS_COMPATIBILITY:STRING=2.4
//Build type: Release or Debug
CMAKE_BUILD_TYPE:STRING=Release
//Semicolon separated list of supported configuration types, only
// supports Debug, Release, MinSizeRel, and RelWithDebInfo, anything
// else will be ignored.
CMAKE_CONFIGURATION_TYPES:STRING=Debug;Release;MinSizeRel;RelWithDebInfo
//C++ compiler
CMAKE_CXX_COMPILER:FILEPATH=cl
CMAKE_CXX_FLAGS:STRING= /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
//Flags used by the compiler during debug builds.
CMAKE_CXX_FLAGS_DEBUG:STRING=/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1
//Flags used by the compiler during release minsize builds.
CMAKE_CXX_FLAGS_MINSIZEREL:STRING=/MD /O1 /Ob1 /D NDEBUG
//Flags used by the compiler during release builds (/MD /Ob1 /Oi
// /Ot /Oy /Gs will produce slightly less optimized but smaller
// files).
CMAKE_CXX_FLAGS_RELEASE:STRING=/MD /O2 /Ob2 /D NDEBUG
//Flags used by the compiler during Release with Debug Info builds.
CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=/MD /Zi /O2 /Ob1 /D NDEBUG
//Libraries linked by defalut with all C++ applications.
CMAKE_CXX_STANDARD_LIBRARIES:STRING='kernel32.lib user32.lib gdi32.lib
winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib
advapi32.lib '
//C compiler
CMAKE_C_COMPILER:FILEPATH=cl
//Flags used by the compiler during all build types.
CMAKE_C_FLAGS:STRING= /DWIN32 /D_WINDOWS /W3 /Zm1000
CMAKE_C_FLAGS_DEBUG:STRING=/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1
CMAKE_C_FLAGS_MINSIZEREL:STRING=/MD /O1 /Ob1 /D NDEBUG
// files).
CMAKE_C_FLAGS_RELEASE:STRING=/MD /O2 /Ob2 /D NDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=/MD /Zi /O2 /Ob1 /D NDEBUG
//Libraries linked by defalut with all C applications.
CMAKE_C_STANDARD_LIBRARIES:STRING='kernel32.lib user32.lib gdi32.lib
advapi32.lib '
//Flags used by the linker.
CMAKE_EXE_LINKER_FLAGS:STRING= /MANIFEST /STACK:10000000 /machine:I386
//Flags used by the linker during debug builds.
CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL:YES
//Flags used by the linker during release minsize builds.
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
//Flags used by the linker during release builds.
CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
//Flags used by the linker during Release with Debug Info builds.
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL:YES
//Install path prefix, prepended onto install directories.
CMAKE_INSTALL_PREFIX:PATH=C:/Program Files/CGAL
//Path to a program.
CMAKE_LINKER:FILEPATH=CMAKE_LINKER-NOTFOUND
//make program
CMAKE_MAKE_PROGRAM:FILEPATH=C:/PROGRA~1/MICROS~1.0/Common7/IDE/devenv.com
//Flags used by the linker during the creation of modules.
CMAKE_MODULE_LINKER_FLAGS:STRING= /MANIFEST /STACK:10000000 /machine:I386
CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL:YES
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL:YES
//RC compiler
CMAKE_RC_COMPILER:FILEPATH=rc
//Flags for Fortran compiler.
CMAKE_RC_FLAGS:STRING=' '
//Flags used by the linker during the creation of dll's.
CMAKE_SHARED_LINKER_FLAGS:STRING= /MANIFEST /STACK:10000000 /machine:I386
CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL:YES
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL:YES
//If set, runtime paths are not added when using shared libraries.
CMAKE_SKIP_RPATH:BOOL=NO
//If true, cmake will use relative paths in makefiles and projects.
CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
//If this value is on, makefiles will be generated without the
// .SILENT directive, and all commands will be echoed to the console
// during the make. This is useful for debugging only. With Visual
// Studio IDE projects all commands are done without /nologo.
CMAKE_VERBOSE_MAKEFILE:BOOL=FALSE
//The directory containing the GMP header files
GMP_INCLUDE_DIR:PATH=C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/include
//Directory containing the GMP library
GMP_LIBRARIES_DIR:PATH=C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/lib
//The directory containing the MPFR header files
MPFR_INCLUDE_DIR:PATH=C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/include
//Directory containing the MPFR library
MPFR_LIBRARIES_DIR:PATH=C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/lib
//OpenGL library for win32
OPENGL_gl_LIBRARY:STRING=opengl32
//GLU library for win32
OPENGL_glu_LIBRARY:STRING=glu32
//path to qt3 include directory
QT3_INCLUDE_DIR:PATH=QT3_INCLUDE_DIR-NOTFOUND
QT3_MOC_EXECUTABLE:FILEPATH=C:/Qt/4.5.2/bin/moc.exe
QT3_QASSISTANTCLIENT_LIBRARY:FILEPATH=QT3_QASSISTANTCLIENT_LIBRARY-NOTFOUND
//This Library is only needed by and included with Qt3 on MSWindows.
// It should be NOTFOUND, undefined or IGNORE otherwise.
QT3_QTMAIN_LIBRARY:FILEPATH=C:/Qt/4.5.2/lib/qtmain.lib
QT3_QT_LIBRARY:FILEPATH=QT3_QT_LIBRARY-NOTFOUND
QT3_UIC_EXECUTABLE:FILEPATH=C:/Qt/4.5.2/bin/uic.exe
QT_DBUSCPP2XML_EXECUTABLE:FILEPATH=QT_DBUSCPP2XML_EXECUTABLE-NOTFOUND
QT_DBUSXML2CPP_EXECUTABLE:FILEPATH=QT_DBUSXML2CPP_EXECUTABLE-NOTFOUND
//The location of the Qt docs
QT_DOC_DIR:PATH=C:/Qt/4.5.2/doc
QT_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include
//Qt library dir
QT_LIBRARY_DIR:PATH=C:/Qt/4.5.2/lib
QT_LRELEASE_EXECUTABLE:FILEPATH=C:/Qt/4.5.2/bin/lrelease.exe
QT_LUPDATE_EXECUTABLE:FILEPATH=C:/Qt/4.5.2/bin/lupdate.exe
//The location of the Qt mkspecs containing qconfig.pri
QT_MKSPECS_DIR:PATH=C:/Qt/4.5.2/mkspecs
//The moc executable
QT_MOC_EXECUTABLE:FILEPATH=C:/Qt/4.5.2/bin/moc.exe
//Path to a file.
QT_PHONON_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/phonon
//The Qt PHONON library
QT_PHONON_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/phonon4.lib;debug;C:/Qt/4.5.2/lib/phonond4.lib
QT_PHONON_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/phonond4.lib
QT_PHONON_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/phonon4.lib
//The location of the Qt plugins
QT_PLUGINS_DIR:PATH=C:/Qt/4.5.2/plugins
QT_QMAKE_EXECUTABLE:FILEPATH=C:/Qt/4.5.2/bin/qmake.exe
//Path to a file.
QT_QT3SUPPORT_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/Qt3Support
//The Qt QT3SUPPORT library
QT_QT3SUPPORT_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/Qt3Support4.lib;debug;C:/Qt/4.5.2/lib/Qt3Supportd4.lib
QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/Qt3Supportd4.lib
QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/Qt3Support4.lib
//Path to a file.
QT_QTASSISTANTCLIENT_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtAssistant
//The Qt QTASSISTANTCLIENT library
QT_QTASSISTANTCLIENT_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtAssistantClient4.lib;debug;C:/Qt/4.5.2/lib/QtAssistantClientd4.lib
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtAssistantClientd4.lib
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtAssistantClient4.lib
//Path to a file.
QT_QTASSISTANT_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtAssistant
//The Qt QTASSISTANT library
QT_QTASSISTANT_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtAssistantClient4.lib;debug;C:/Qt/4.5.2/lib/QtAssistantClientd4.lib
QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtAssistantClientd4.lib
QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtAssistantClient4.lib
//The Qt QTCLUCENE library
QT_QTCLUCENE_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtCLucene4.lib;debug;C:/Qt/4.5.2/lib/QtCLucened4.lib
QT_QTCLUCENE_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtCLucened4.lib
QT_QTCLUCENE_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtCLucene4.lib
//Path to a file.
QT_QTCORE_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtCore
//The Qt QTCORE library
QT_QTCORE_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtCore4.lib;debug;C:/Qt/4.5.2/lib/QtCored4.lib
QT_QTCORE_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtCored4.lib
QT_QTCORE_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtCore4.lib
//Path to a file.
QT_QTDBUS_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtDBus
QT_QTDBUS_LIBRARY_DEBUG:FILEPATH=QT_QTDBUS_LIBRARY_DEBUG-NOTFOUND
QT_QTDBUS_LIBRARY_RELEASE:FILEPATH=QT_QTDBUS_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtDesigner
//The Qt QTDESIGNERCOMPONENTS library
QT_QTDESIGNERCOMPONENTS_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtDesignerComponents4.lib;debug;C:/Qt/4.5.2/lib/QtDesignerComponentsd4.lib
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtDesignerComponentsd4.lib
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtDesignerComponents4.lib
//Path to a file.
QT_QTDESIGNER_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtDesigner
//The Qt QTDESIGNER library
QT_QTDESIGNER_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtDesigner4.lib;debug;C:/Qt/4.5.2/lib/QtDesignerd4.lib
QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtDesignerd4.lib
QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtDesigner4.lib
//Path to a file.
QT_QTGUI_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtGui
//The Qt QTGUI library
QT_QTGUI_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtGui4.lib;debug;C:/Qt/4.5.2/lib/QtGuid4.lib
QT_QTGUI_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtGuid4.lib
QT_QTGUI_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtGui4.lib
//Path to a file.
QT_QTHELP_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtHelp
//The Qt QTHELP library
QT_QTHELP_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtHelp4.lib;debug;C:/Qt/4.5.2/lib/QtHelpd4.lib
QT_QTHELP_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtHelpd4.lib
QT_QTHELP_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtHelp4.lib
//The Qt QTMAIN library
QT_QTMAIN_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/qtmain.lib;debug;C:/Qt/4.5.2/lib/qtmaind.lib
QT_QTMAIN_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/qtmaind.lib
QT_QTMAIN_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/qtmain.lib
//Path to a file.
QT_QTNETWORK_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtNetwork
//The Qt QTNETWORK library
QT_QTNETWORK_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtNetwork4.lib;debug;C:/Qt/4.5.2/lib/QtNetworkd4.lib
QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtNetworkd4.lib
QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtNetwork4.lib
//Path to a file.
QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND
QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND
QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTOPENGL_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtOpenGL
//The Qt QTOPENGL library
QT_QTOPENGL_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtOpenGL4.lib;debug;C:/Qt/4.5.2/lib/QtOpenGLd4.lib
QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtOpenGLd4.lib
QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtOpenGL4.lib
//Path to a file.
QT_QTSCRIPT_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtScript
//The Qt QTSCRIPT library
QT_QTSCRIPT_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtScript4.lib;debug;C:/Qt/4.5.2/lib/QtScriptd4.lib
QT_QTSCRIPT_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtScriptd4.lib
QT_QTSCRIPT_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtScript4.lib
//Path to a file.
QT_QTSQL_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtSql
//The Qt QTSQL library
QT_QTSQL_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtSql4.lib;debug;C:/Qt/4.5.2/lib/QtSqld4.lib
QT_QTSQL_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtSqld4.lib
QT_QTSQL_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtSql4.lib
//Path to a file.
QT_QTSVG_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtSvg
//The Qt QTSVG library
QT_QTSVG_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtSvg4.lib;debug;C:/Qt/4.5.2/lib/QtSvgd4.lib
QT_QTSVG_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtSvgd4.lib
QT_QTSVG_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtSvg4.lib
//Path to a file.
QT_QTTEST_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtTest
//The Qt QTTEST library
QT_QTTEST_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtTest4.lib;debug;C:/Qt/4.5.2/lib/QtTestd4.lib
QT_QTTEST_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtTestd4.lib
QT_QTTEST_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtTest4.lib
//Path to a file.
QT_QTUITOOLS_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtUiTools
//The Qt QTUITOOLS library
QT_QTUITOOLS_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtUiTools.lib;debug;C:/Qt/4.5.2/lib/QtUiToolsd.lib
QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtUiToolsd.lib
QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtUiTools.lib
//Path to a file.
QT_QTWEBKIT_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtWebKit
//The Qt QTWEBKIT library
QT_QTWEBKIT_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtWebKit4.lib;debug;C:/Qt/4.5.2/lib/QtWebKitd4.lib
QT_QTWEBKIT_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtWebKitd4.lib
QT_QTWEBKIT_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtWebKit4.lib
//Path to a file.
QT_QTXMLPATTERNS_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtXmlPatterns
//The Qt QTXMLPATTERNS library
QT_QTXMLPATTERNS_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtXmlPatterns4.lib;debug;C:/Qt/4.5.2/lib/QtXmlPatternsd4.lib
QT_QTXMLPATTERNS_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtXmlPatternsd4.lib
QT_QTXMLPATTERNS_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtXmlPatterns4.lib
//Path to a file.
QT_QTXML_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/QtXml
//The Qt QTXML library
QT_QTXML_LIBRARY:FILEPATH=optimized;C:/Qt/4.5.2/lib/QtXml4.lib;debug;C:/Qt/4.5.2/lib/QtXmld4.lib
QT_QTXML_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.5.2/lib/QtXmld4.lib
QT_QTXML_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.5.2/lib/QtXml4.lib
//Path to a file.
QT_QT_INCLUDE_DIR:PATH=C:/Qt/4.5.2/include/Qt
QT_RCC_EXECUTABLE:FILEPATH=C:/Qt/4.5.2/bin/rcc.exe
QT_UIC3_EXECUTABLE:FILEPATH=C:/Qt/4.5.2/bin/uic3.exe
//The uic executable
QT_UIC_EXECUTABLE:FILEPATH=C:/Qt/4.5.2/bin/uic.exe
//Enable CGAL component Core
WITH_CGAL_Core:BOOL=ON
//Enable CGAL component ImageIO
WITH_CGAL_ImageIO:BOOL=ON
//Enable CGAL component PDB
WITH_CGAL_PDB:BOOL=ON
//Enable CGAL component Qt3
WITH_CGAL_Qt3:BOOL=ON
//Enable CGAL component Qt4
WITH_CGAL_Qt4:BOOL=ON
//Create package generation rules
WITH_CPACK:BOOL=OFF
//Use the GMP number types if available.
WITH_GMP:BOOL=ON
//Use the LEDA number types if available.
WITH_LEDA:BOOL=OFF
//Select demos
WITH_demos:BOOL=OFF
//Select examples
WITH_examples:BOOL=OFF
//Path to a file.
ZLIB_INCLUDE_DIR:PATH=ZLIB_INCLUDE_DIR-NOTFOUND
ZLIB_LIBRARY:FILEPATH=ZLIB_LIBRARY-NOTFOUND
# INTERNAL cache entries
//Stored GUID
ALL_BUILD_GUID_CMAKE:INTERNAL=EF7DB769-6688-40E3-BD3A-D8BCDFAD75D3
//Name of all CGAL libraries.
ALL_CGAL_LIBRARIES:INTERNAL=CGAL;CGAL_Core;CGAL_ImageIO;CGAL_PDB;CGAL_Qt3;CGAL_Qt4
//Advanced flag for variable: Boost_INCLUDE_DIR
Boost_INCLUDE_DIR-ADVANCED:INTERNAL=1
//The library version string for boost libraries
Boost_LIB_VERSION:INTERNAL=1_39
//Advanced flag for variable: Boost_THREAD_LIBRARY_DEBUG
Boost_THREAD_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: Boost_THREAD_LIBRARY_RELEASE
Boost_THREAD_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//The version number for boost libraries
Boost_VERSION:INTERNAL=103900
CGAL_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_3RD_PARTY_INCLUDE_DIRS:INTERNAL=C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/include;C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/include;C:/boost/boost_1_39
CGAL_3RD_PARTY_LIBRARIES:INTERNAL=psapi.lib
CGAL_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/lib;C:/CGAL/CGAL-3.5-beta/auxiliary/gmp/lib
CGAL_CFG_DENORMALS_COMPILE_BUG:INTERNAL=0
//Result of TRY_COMPILE
CGAL_CFG_DENORMALS_COMPILE_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG:INTERNAL=0
CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_IEEE_754_BUG:INTERNAL=0
CGAL_CFG_IEEE_754_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_ISTREAM_INT_BUG:INTERNAL=0
CGAL_CFG_ISTREAM_INT_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_LONGNAME_BUG:INTERNAL=1
CGAL_CFG_LONGNAME_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_MATCHING_BUG_5:INTERNAL=0
CGAL_CFG_MATCHING_BUG_5_COMPILED:INTERNAL=TRUE
CGAL_CFG_MATCHING_BUG_6:INTERNAL=1
CGAL_CFG_MATCHING_BUG_6_COMPILED:INTERNAL=FALSE
CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG:INTERNAL=1
CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_NET2003_MATCHING_BUG:INTERNAL=0
CGAL_CFG_NET2003_MATCHING_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_ARRAY:INTERNAL=1
CGAL_CFG_NO_CPP0X_ARRAY_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DECLTYPE:INTERNAL=1
CGAL_CFG_NO_CPP0X_DECLTYPE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES:INTERNAL=1
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS:INTERNAL=1
CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS:INTERNAL=1
CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_ISFINITE:INTERNAL=1
CGAL_CFG_NO_CPP0X_ISFINITE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_LONG_LONG:INTERNAL=0
CGAL_CFG_NO_CPP0X_LONG_LONG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE:INTERNAL=1
CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_TUPLE:INTERNAL=1
CGAL_CFG_NO_CPP0X_TUPLE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES:INTERNAL=1
CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_LIMITS:INTERNAL=0
CGAL_CFG_NO_LIMITS_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_NEXTAFTER:INTERNAL=1
CGAL_CFG_NO_NEXTAFTER_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_STATEMENT_EXPRESSIONS:INTERNAL=1
CGAL_CFG_NO_STATEMENT_EXPRESSIONS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_STL:INTERNAL=0
CGAL_CFG_NO_STL_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_TMPL_IN_TMPL_PARAM:INTERNAL=0
CGAL_CFG_NO_TMPL_IN_TMPL_PARAM_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_TR1_ARRAY:INTERNAL=1
CGAL_CFG_NO_TR1_ARRAY_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_TR1_TUPLE:INTERNAL=1
CGAL_CFG_NO_TR1_TUPLE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NUMERIC_LIMITS_BUG:INTERNAL=0
CGAL_CFG_NUMERIC_LIMITS_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG:INTERNAL=0
CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG:INTERNAL=0
CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_USING_BASE_MEMBER_BUG_2:INTERNAL=0
CGAL_CFG_USING_BASE_MEMBER_BUG_2_COMPILED:INTERNAL=TRUE
CGAL_Core_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Core_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Core_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Core_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Stored GUID
CGAL_Core_GUID_CMAKE:INTERNAL=78115B10-9DA1-4690-AA19-46A94EDCA464
//Variable hidden from user
CGAL_Core_LIBRARY_NAME:INTERNAL=
CGAL_EXECUTABLE_TARGETS:INTERNAL=
//Stored GUID
CGAL_GUID_CMAKE:INTERNAL=92BC9888-E9B9-48F6-AB84-664C742B1FA7
CGAL_ImageIO_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_ImageIO_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_ImageIO_3RD_PARTY_LIBRARIES:INTERNAL=glu32;opengl32
CGAL_ImageIO_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Stored GUID
CGAL_ImageIO_GUID_CMAKE:INTERNAL=CB2BC6A2-6ACD-4FE5-8DC6-E4FC71D6790A
CGAL_ImageIO_LIBRARY_NAME:INTERNAL=
CGAL_LIBRARY_NAME:INTERNAL=
CGAL_PDB_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_PDB_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_PDB_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_PDB_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Stored GUID
CGAL_PDB_GUID_CMAKE:INTERNAL=0F4F8A16-90AD-411D-9152-9FD15E5EB04E
CGAL_PDB_LIBRARY_NAME:INTERNAL=
CGAL_Qt3_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Qt3_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Qt3_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Qt3_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
CGAL_Qt3_LIBRARY_NAME:INTERNAL=
CGAL_Qt4_3RD_PARTY_DEFINITIONS:INTERNAL=-DQT_DLL
CGAL_Qt4_3RD_PARTY_INCLUDE_DIRS:INTERNAL=C:/Qt/4.5.2/include
CGAL_Qt4_3RD_PARTY_LIBRARIES:INTERNAL=optimized;C:/Qt/4.5.2/lib/qtmain.lib;debug;C:/Qt/4.5.2/lib/qtmaind.lib;optimized;C:/Qt/4.5.2/lib/QtOpenGL4.lib;debug;C:/Qt/4.5.2/lib/QtOpenGLd4.lib;opengl32.lib
glu32.lib gdi32.lib
user32.lib;optimized;C:/Qt/4.5.2/lib/QtGui4.lib;debug;C:/Qt/4.5.2/lib/QtGuid4.lib;imm32;winmm;optimized;C:/Qt/4.5.2/lib/QtCore4.lib;debug;C:/Qt/4.5.2/lib/QtCored4.lib;ws2_32;glu32;opengl32
CGAL_Qt4_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Stored GUID
CGAL_Qt4_GUID_CMAKE:INTERNAL=0386C0DB-D649-4239-828A-A6AE2EFAD76E
CGAL_Qt4_LIBRARY_NAME:INTERNAL=
//Advanced flag for variable: CGAL_SONAME_VERSION
CGAL_SONAME_VERSION-ADVANCED:INTERNAL=1
//Advanced flag for variable: CGAL_SOVERSION
CGAL_SOVERSION-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_BACKWARDS_COMPATIBILITY
CMAKE_BACKWARDS_COMPATIBILITY-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_BUILD_TOOL
CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1
//What is the target build tool cmake is generating for.
CMAKE_BUILD_TOOL:INTERNAL=C:/PROGRA~1/MICROS~1.0/Common7/IDE/devenv.com
//This is the directory where this CMakeCahe.txt was created
CMAKE_CACHEFILE_DIR:INTERNAL=c:/CGAL/CGAL-3.5-beta
//Major version of cmake used to create the current loaded cache
CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2
//Minor version of cmake used to create the current loaded cache
CMAKE_CACHE_MINOR_VERSION:INTERNAL=6
CMAKE_CACHE_RELEASE_VERSION:INTERNAL=patch 4
//Path to CMake executable.
CMAKE_COMMAND:INTERNAL=C:/Program Files/CMake 2.6/bin/cmake.exe
//Advanced flag for variable: CMAKE_CONFIGURATION_TYPES
CMAKE_CONFIGURATION_TYPES-ADVANCED:INTERNAL=1
//Path to cpack program executable.
CMAKE_CPACK_COMMAND:INTERNAL=C:/Program Files/CMake 2.6/bin/cpack.exe
//Path to ctest program executable.
CMAKE_CTEST_COMMAND:INTERNAL=C:/Program Files/CMake 2.6/bin/ctest.exe
//Advanced flag for variable: CMAKE_CXX_COMPILER
CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1
CMAKE_CXX_COMPILER_WORKS:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_FLAGS_DEBUG
CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_FLAGS_MINSIZEREL
CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_FLAGS_RELEASE
CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO
CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_CXX_STANDARD_LIBRARIES
CMAKE_CXX_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_COMPILER
CMAKE_C_COMPILER-ADVANCED:INTERNAL=1
CMAKE_C_COMPILER_WORKS:INTERNAL=1
//Advanced flag for variable: CMAKE_C_FLAGS
CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_FLAGS_MINSIZEREL
CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_FLAGS_RELEASE
CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_C_STANDARD_LIBRARIES
CMAKE_C_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE
CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE
//Path to cache edit program executable.
CMAKE_EDIT_COMMAND:INTERNAL=C:/Program Files/CMake 2.6/bin/cmake-gui.exe
//Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Name of generator.
CMAKE_GENERATOR:INTERNAL=Visual Studio 9 2008
//Start directory with the top level CMakeLists.txt file for this
// project
CMAKE_HOME_DIRECTORY:INTERNAL=C:/CGAL/CGAL-3.5-beta
//Advanced flag for variable: CMAKE_LINKER
CMAKE_LINKER-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MAKE_PROGRAM
CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//number of local generators
CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=8
//Advanced flag for variable: CMAKE_RC_COMPILER
CMAKE_RC_COMPILER-ADVANCED:INTERNAL=1
CMAKE_RC_COMPILER_WORKS:INTERNAL=1
//Advanced flag for variable: CMAKE_RC_FLAGS
CMAKE_RC_FLAGS-ADVANCED:INTERNAL=1
//Path to CMake installation.
CMAKE_ROOT:INTERNAL=C:/Program Files/CMake 2.6/share/cmake-2.6
//Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_SKIP_RPATH
CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
//Suppress Warnings that are meant for the author of the CMakeLists.txt
// files.
CMAKE_SUPPRESS_DEVELOPER_WARNINGS:INTERNAL=FALSE
CMAKE_UNAME:INTERNAL=CMAKE_UNAME-NOTFOUND
//Advanced flag for variable: CMAKE_USE_RELATIVE_PATHS
CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
//Advanced flag for variable: CMAKE_VERBOSE_MAKEFILE
CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
//Stored GUID
EDIT_CACHE_GUID_CMAKE:INTERNAL=F0CEE55D-08C6-4F1A-AFDE-3FFDBD80A8D2
EXECUTABLE_OUTPUT_PATH:INTERNAL=
GMP_COMPILE_RES:INTERNAL=TRUE
GMP_IN_CGAL_AUXILIARY:INTERNAL=TRUE
//Result of TRY_RUN
GMP_RUN_RES:INTERNAL=0
//Generator uses intermediate configuration directory
HAS_CFG_INTDIR:INTERNAL=TRUE
//Stored GUID
INSTALL_GUID_CMAKE:INTERNAL=39025358-3D3E-4C2F-8CC0-5C15797BF978
LIBRARY_OUTPUT_PATH:INTERNAL=C:/CGAL/CGAL-3.5-beta/lib
MPFR_COMPILE_RES:INTERNAL=TRUE
MPFR_IN_CGAL_AUXILIARY:INTERNAL=TRUE
//Result of TRY_RUN
MPFR_RUN_RES:INTERNAL=0
//Advanced flag for variable: OPENGL_gl_LIBRARY
OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: OPENGL_glu_LIBRARY
OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1
//Stored GUID
PACKAGE_GUID_CMAKE:INTERNAL=56E9C0E2-2B23-4F60-98AB-197C1084C538
//Advanced flag for variable: QT3_INCLUDE_DIR
QT3_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_MOC_EXECUTABLE
QT3_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_QASSISTANTCLIENT_LIBRARY
QT3_QASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_QTMAIN_LIBRARY
QT3_QTMAIN_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_QT_LIBRARY
QT3_QT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT3_UIC_EXECUTABLE
QT3_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
QT4_COMPILE_RES:INTERNAL=TRUE
//Result of TRY_RUN
QT4_RUN_RES:INTERNAL=0
QT_BINARY_DIR:INTERNAL=C:/Qt/4.5.2/bin
//Advanced flag for variable: QT_DBUSCPP2XML_EXECUTABLE
QT_DBUSCPP2XML_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_DBUSXML2CPP_EXECUTABLE
QT_DBUSXML2CPP_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_DOC_DIR
QT_DOC_DIR-ADVANCED:INTERNAL=1
QT_HEADERS_DIR:INTERNAL=C:/Qt/4.5.2/include
//Advanced flag for variable: QT_INCLUDE_DIR
QT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_LIBRARY_DIR
QT_LIBRARY_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_LRELEASE_EXECUTABLE
QT_LRELEASE_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_LUPDATE_EXECUTABLE
QT_LUPDATE_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_MKSPECS_DIR
QT_MKSPECS_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_MOC_EXECUTABLE
QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_PHONON_INCLUDE_DIR
QT_PHONON_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_PHONON_LIBRARY
QT_PHONON_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_PHONON_LIBRARY_DEBUG
QT_PHONON_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_PHONON_LIBRARY_RELEASE
QT_PHONON_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_PLUGINS_DIR
QT_PLUGINS_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QT3SUPPORT_INCLUDE_DIR
QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QT3SUPPORT_LIBRARY
QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QT3SUPPORT_LIBRARY_DEBUG
QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QT3SUPPORT_LIBRARY_RELEASE
QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANTCLIENT_INCLUDE_DIR
QT_QTASSISTANTCLIENT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANTCLIENT_LIBRARY
QT_QTASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANTCLIENT_LIBRARY_DEBUG
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANTCLIENT_LIBRARY_RELEASE
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANT_INCLUDE_DIR
QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANT_LIBRARY
QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANT_LIBRARY_DEBUG
QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTASSISTANT_LIBRARY_RELEASE
QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCLUCENE_LIBRARY
QT_QTCLUCENE_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCLUCENE_LIBRARY_DEBUG
QT_QTCLUCENE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCLUCENE_LIBRARY_RELEASE
QT_QTCLUCENE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCORE_INCLUDE_DIR
QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCORE_LIBRARY
QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCORE_LIBRARY_DEBUG
QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTCORE_LIBRARY_RELEASE
QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDBUS_INCLUDE_DIR
QT_QTDBUS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDBUS_LIBRARY_DEBUG
QT_QTDBUS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDBUS_LIBRARY_RELEASE
QT_QTDBUS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY
QT_QTDESIGNERCOMPONENTS_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNER_INCLUDE_DIR
QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNER_LIBRARY
QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNER_LIBRARY_DEBUG
QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTDESIGNER_LIBRARY_RELEASE
QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTGUI_INCLUDE_DIR
QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTGUI_LIBRARY
QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTGUI_LIBRARY_DEBUG
QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTGUI_LIBRARY_RELEASE
QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTHELP_INCLUDE_DIR
QT_QTHELP_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTHELP_LIBRARY
QT_QTHELP_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTHELP_LIBRARY_DEBUG
QT_QTHELP_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTHELP_LIBRARY_RELEASE
QT_QTHELP_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTMAIN_LIBRARY
QT_QTMAIN_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTMAIN_LIBRARY_DEBUG
QT_QTMAIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTMAIN_LIBRARY_RELEASE
QT_QTMAIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNETWORK_INCLUDE_DIR
QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNETWORK_LIBRARY
QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNETWORK_LIBRARY_DEBUG
QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNETWORK_LIBRARY_RELEASE
QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNSPLUGIN_INCLUDE_DIR
QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG
QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE
QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTOPENGL_INCLUDE_DIR
QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTOPENGL_LIBRARY
QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTOPENGL_LIBRARY_DEBUG
QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTOPENGL_LIBRARY_RELEASE
QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSCRIPT_INCLUDE_DIR
QT_QTSCRIPT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSCRIPT_LIBRARY
QT_QTSCRIPT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSCRIPT_LIBRARY_DEBUG
QT_QTSCRIPT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSCRIPT_LIBRARY_RELEASE
QT_QTSCRIPT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSQL_INCLUDE_DIR
QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSQL_LIBRARY
QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSQL_LIBRARY_DEBUG
QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSQL_LIBRARY_RELEASE
QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSVG_INCLUDE_DIR
QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSVG_LIBRARY
QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSVG_LIBRARY_DEBUG
QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTSVG_LIBRARY_RELEASE
QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTTEST_INCLUDE_DIR
QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTTEST_LIBRARY
QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTTEST_LIBRARY_DEBUG
QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTTEST_LIBRARY_RELEASE
QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTUITOOLS_INCLUDE_DIR
QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTUITOOLS_LIBRARY
QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTUITOOLS_LIBRARY_DEBUG
QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTUITOOLS_LIBRARY_RELEASE
QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTWEBKIT_INCLUDE_DIR
QT_QTWEBKIT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTWEBKIT_LIBRARY
QT_QTWEBKIT_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTWEBKIT_LIBRARY_DEBUG
QT_QTWEBKIT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTWEBKIT_LIBRARY_RELEASE
QT_QTWEBKIT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXMLPATTERNS_INCLUDE_DIR
QT_QTXMLPATTERNS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXMLPATTERNS_LIBRARY
QT_QTXMLPATTERNS_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXMLPATTERNS_LIBRARY_DEBUG
QT_QTXMLPATTERNS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXMLPATTERNS_LIBRARY_RELEASE
QT_QTXMLPATTERNS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXML_INCLUDE_DIR
QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXML_LIBRARY
QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXML_LIBRARY_DEBUG
QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QTXML_LIBRARY_RELEASE
QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_QT_INCLUDE_DIR
QT_QT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_RCC_EXECUTABLE
QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_UIC3_EXECUTABLE
QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1
//Advanced flag for variable: QT_UIC_EXECUTABLE
QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
//Have symbol Q_WS_MAC
Q_WS_MAC:INTERNAL=
//Have symbol Q_WS_QWS
Q_WS_QWS:INTERNAL=
//Have symbol Q_WS_WIN
Q_WS_WIN:INTERNAL=1
//Have symbol Q_WS_X11
Q_WS_X11:INTERNAL=
//Stored GUID
REBUILD_CACHE_GUID_CMAKE:INTERNAL=9FACFF92-F70F-4D37-A99E-E98E6FBE3FA1
//Stored GUID
RUN_TESTS_GUID_CMAKE:INTERNAL=0531FB4B-A171-48E9-B82A-C7D51C1BC979
//Stored GUID
ZERO_CHECK_GUID_CMAKE:INTERNAL=F16354F9-848F-4652-863A-6B1DCF7F9144
//Advanced flag for variable: ZLIB_INCLUDE_DIR
ZLIB_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Advanced flag for variable: ZLIB_LIBRARY
ZLIB_LIBRARY-ADVANCED:INTERNAL=1
//Stored GUID
demos_GUID_CMAKE:INTERNAL=EB7CCE94-6A3C-42A9-A56E-9DEE1CBB1AEA
//Stored GUID
examples_GUID_CMAKE:INTERNAL=AFDD17E4-1183-404E-B2D2-06A5B808B0F2
//Stored GUID
install_FindCGAL_GUID_CMAKE:INTERNAL=1E3515D0-42B3-4E27-9D9C-D791C11341AA
- [cgal-discuss] CGAL 3.5 beta installation in Widows Vista, Indika Tantrigoda, 08/19/2009
- Re: [cgal-discuss] CGAL 3.5 beta installation in Widows Vista, Laurent Rineau (GeometryFactory), 08/19/2009
- Re: [cgal-discuss] CGAL 3.5 beta installation in Widows Vista, Indika Tantrigoda, 08/19/2009
- Re: [cgal-discuss] CGAL 3.5 beta installation in Widows Vista, Indika Tantrigoda, 08/20/2009
- Re: [cgal-discuss] CGAL 3.5 beta installation in Widows Vista, Laurent Rineau (GeometryFactory), 08/20/2009
