cgal-discuss - [cgal-discuss] Triangulation 2D - remove_constraint
  • To:
  • Subject: [cgal-discuss] Triangulation 2D - remove_constraint
  • Date: Fri, 28 Aug 2009 10:53:52 +0200 (CEST)
Hello,
Does the function remove_constraint or the function is_constrained work ?
I search all the constrained edges and I store them in a std vector.
Then I read my vector and remove the constraints.
Problem : *sometimes* there are still constrained edges in my triangulation
and
sometimes these edges are in my vector ie I called remove_constraint on it !
*sometimes* : I move a constraint polygon interactively with the mouse.
sometimes the constraints are well removed sometimes not...
I have found a workaround : doing twice the search and remove...
Did you experiment a such problem and did you find the solution or a
workaround
I begin with CGAL but I do not see where I am wrong...
Lionel
