- To:
- Subject: Re: [cgal-discuss] Spatial Searching with 3D triangles
- Date: Mon, 14 Sep 2009 12:33:16 -0400
Hi Markus!
I'm working finding some nearest points using range tree (3d) for mass
center on tetrahedrons and I built an example on my own, but CGAL has
bug in the 3d implementation. I posted the bug related to this earlier
but i haven't response. Anyway, in the CGAL implementation you can find
in the 3.5 CGAL version examples on 3d searchs.
Tell me if this was usefull your you.
Best regards,
Victor.
On Mon, 2009-09-07 at 16:01 +0200, Markus Eich wrote:
> Dear all,
> i have a newbie question on CGAL. I have a STL list of 3D Triangles
> (with their normals) and I want to find for each triangle the k-nearest
> spatial neighbors in 3D.
> The position of each triangle is defined, for instance, by its centre of
> gravity. While browsing the Manual I found the dD Spatial Searching chapter.
> Is there any example how I can use this structure for my application? I
> only find samples in 2d space, not in 3d. As a data strucure for my
> triangles I use a custom 3D structure but I also could use the CGAL
> Triangle_3d structure if this would be easier to handle.
> Thank you for your help.
> Markus
> Dipl. Inf. Markus Eich
> Researcher
> Bereich Logistik
> DFKI Bremen
> Robotics Innovation Center
> Robert-Hooke-Straße 5
> 28359 Bremen, Germany
> Phone: +49 (0)421 218-64100
> Fax: +49 (0)421 218-64150
> E-Mail:
> Weitere Informationen: http://www.dfki.de/robotik
> Deutsches Forschungszentrum fuer Kuenstliche Intelligenz GmbH
> Firmensitz: Trippstadter Straße 122, D-67663 Kaiserslautern
> Geschaeftsfuehrung: Prof. Dr. Dr. h.c. mult. Wolfgang Wahlster
> (Vorsitzender) Dr. Walter Olthoff
> Vorsitzender des Aufsichtsrats: Prof. Dr. h.c. Hans A. Aukes
> Amtsgericht Kaiserslautern, HRB 2313
> Sitz der Gesellschaft: Kaiserslautern (HRB 2313)
> USt-Id.Nr.: DE 148646973
> Steuernummer: 19/673/0060/3
- [cgal-discuss] Spatial Searching with 3D triangles, Markus Eich, 09/07/2009
- Re: [cgal-discuss] Spatial Searching with 3D triangles, Victor Toledo, 09/14/2009
