- To:
- Subject: [cgal-discuss] Spatial Searching with 3D triangles
- Date: Mon, 07 Sep 2009 16:01:06 +0200
Dear all,
i have a newbie question on CGAL. I have a STL list of 3D Triangles
(with their normals) and I want to find for each triangle the k-nearest
spatial neighbors in 3D.
The position of each triangle is defined, for instance, by its centre of
gravity. While browsing the Manual I found the dD Spatial Searching chapter.
Is there any example how I can use this structure for my application? I
only find samples in 2d space, not in 3d. As a data strucure for my
triangles I use a custom 3D structure but I also could use the CGAL
Triangle_3d structure if this would be easier to handle.
Thank you for your help.
Markus
Dipl. Inf. Markus Eich
Researcher
Bereich Logistik
DFKI Bremen
Robotics Innovation Center
Robert-Hooke-Straße 5
28359 Bremen, Germany
Phone: +49 (0)421 218-64100
Fax: +49 (0)421 218-64150
E-Mail:
Weitere Informationen: http://www.dfki.de/robotik
Deutsches Forschungszentrum fuer Kuenstliche Intelligenz GmbH
Firmensitz: Trippstadter Straße 122, D-67663 Kaiserslautern
Geschaeftsfuehrung: Prof. Dr. Dr. h.c. mult. Wolfgang Wahlster (Vorsitzender)
Dr. Walter Olthoff
Vorsitzender des Aufsichtsrats: Prof. Dr. h.c. Hans A. Aukes
Amtsgericht Kaiserslautern, HRB 2313
Sitz der Gesellschaft: Kaiserslautern (HRB 2313)
USt-Id.Nr.: DE 148646973
Steuernummer: 19/673/0060/3
- [cgal-discuss] Spatial Searching with 3D triangles, Markus Eich, 09/07/2009
- Re: [cgal-discuss] Spatial Searching with 3D triangles, Victor Toledo, 09/14/2009
